[GIT PULL] Please pull u-boot-imx-master-20241109
Hi Tom,
Please pull from u-boot-imx/master, thanks.
The following changes since commit a7a96a37cbd875994bc8d25adb0536bf00e4a30e:
Merge https://source.denx.de/u-boot/custodians/u-boot-riscv (2024-11-06 10:44:33 -0600)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20241105
for you to fetch changes up to 28958998f6301bc4a247a9057a623f997ee78c11:
arm: mach-imx: imx8m: re-use SNVS init routine (2024-11-09 08:55:04 -0300)
u-boot-imx-master-20241105 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/23262
- Improve imx9 boot medium autodection. - Add possibility to skip DCD on i.MX8. - Switch to using upstream DT on DH i.MX6 DHCOM. - Add support for i.MX6DL DHCOM SoM on PDK2 carrier board. - Handle FIELD_RETURN on i.MX HAB. ---------------------------------------------------------------- Benjamin Szőke (1): imx9: Improve boot mode autodetection
Heiko Schocher (1): tools: imx8image: add possibility to skip dcd
Ian Ray (2): arm: mach-imx: move snvs module arm: mach-imx: imx8m: re-use SNVS init routine
Marek Vasut (2): ARM: dts: imx6dl: Add support for i.MX6DL DHCOM SoM on PDK2 carrier board ARM: dts: imx: Switch to using upstream DT on DH i.MX6 DHCOM
Paul Geurts (2): imx: hab: rename imx_sec_config_fuse_t to imx_fuse imx: hab: Make imx_hab_is_enabled dependent on FIELD_RETURN
arch/arm/dts/Makefile | 6 +---- arch/arm/dts/imx6dl-dhcom-pdk2.dts | 15 ----------- arch/arm/dts/imx6dl-dhcom-picoitx.dts | 20 --------------- arch/arm/dts/imx6q-dhcom-pdk2.dts | 25 ------------------ arch/arm/dts/imx6s-dhcom-drc02.dts | 30 ---------------------- arch/arm/include/asm/mach-imx/hab.h | 5 ++-- arch/arm/mach-imx/Makefile | 2 ++ arch/arm/mach-imx/hab.c | 30 ++++++++++++++++++---- arch/arm/mach-imx/imx8m/soc.c | 11 +++++++- arch/arm/mach-imx/imx9/soc.c | 12 ++++++--- arch/arm/mach-imx/mx6/soc.c | 7 ++++- arch/arm/mach-imx/mx7/Makefile | 2 +- arch/arm/mach-imx/mx7/soc.c | 7 ++++- arch/arm/mach-imx/mx7ulp/soc.c | 7 ++++- arch/arm/mach-imx/{mx7 => }/snvs.c | 0 arch/arm/mach-imx/snvs.h | 6 +++++ board/freescale/imx93_evk/imx93_evk.c | 2 +- configs/dh_imx6_defconfig | 5 ++-- dts/upstream/src/arm/nxp/imx/imx6dl-dhcom-pdk2.dts | 20 +++++++++++++++ include/configs/imx93_evk.h | 8 +++++- include/imx8image.h | 1 + tools/imx8image.c | 7 ++++- 22 files changed, 113 insertions(+), 115 deletions(-) delete mode 100644 arch/arm/dts/imx6dl-dhcom-pdk2.dts delete mode 100644 arch/arm/dts/imx6dl-dhcom-picoitx.dts delete mode 100644 arch/arm/dts/imx6q-dhcom-pdk2.dts delete mode 100644 arch/arm/dts/imx6s-dhcom-drc02.dts rename arch/arm/mach-imx/{mx7 => }/snvs.c (100%) create mode 100644 arch/arm/mach-imx/snvs.h create mode 100644 dts/upstream/src/arm/nxp/imx/imx6dl-dhcom-pdk2.dts
On Sat, Nov 09, 2024 at 02:08:26PM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
