[PATCH v4 0/6] add loongson mips ls1c300 initial support
--- Changelog for v4: - rebase to [247aa5a191159ea7e03bf1918e22fbbb784cd410] - fix rebase issues - use spl without SPL_DM - fix some more codingstyle - fix some more typo - add comments about writing sdram controler - keep .noreoder and do not use delay slot
Changelog for v3: - change cpu clock id from CLK_CPU to CLK_CPU_THROT - migrate all APB dev's clock id to CLK_APB - remove uarts' <reg-shift> property to use default value <0> - move /clocks/acc node to /soc/acc - call clk_request() before use a clk - make get_tbclk() return 1/2 clock of cpu - disable debug_uart by default - add ops for cpu_throt_factor clk - declare MSEC_PER_SEC for converting between sec and msec - return a error code when the wdt clock is out of range - minor format and codingstyle fixes - rebase to [9859465bfe838bc8264d45e1a1bed847bba74bad]
Changelog for v2: 1. dtsi: add status disabled for uart0 ~ uart11 remove bootargs from chosen make serial0 alias for uart2 oscillator remove @0 unit-address change uart2 address to kuseg
2. cleanup Kconfig and update defconfig - make these options configurable, disabled by default: CMD_DM DM_ETH DM_GPIO DM_SPI DM_SPI_FLASH DM_RESET PINCONF PINCTRL PINMUX RESET_LSMIPS - make these options configurable, enabled by default: CLK DISPLAY_CPUINFO SYSRESET ROM_EXCEPTION_VECTORS - disabled: CONFIG_ENV_IS_IN_SPI_FLASH
3. fix codingstyle drivers/watchdog/lsmips-wdt.c - priv->base + offset - add comment for default clock value
4. remove address base definition header - remove arch/mips/mach-lsmips/ls1c300/ls1c300.h - clean up files uses this header
5. spl and debug uart - add comment for spl & debug uart pinmuxing - cleanup unused registers base header
6. dtsi - add "loongson,ls1c300-uart" to all uart node
7. board dts - add memory node to board dts, start at 0x80000000, size 64MB
8. Kconfig - make ROM_EXCEPTION_VECTORS user configureable - enable ROM_EXCEPTION_VECTORS in defconfig
9. - seperate sdram_init to sdram_init.S - add macro helpers to do sdram, pll lowlevel init
10. dtsi - move clock nodes to /clocks/xxx
11. - define CONFIG_SKIP_LOWLEVEL_INIT to 1
12. - remove option PINCTRL_LS1C300 from Kconfig
13. - dram_init, use get_ram_size() to detect ram size.
14. clk driver - create custom clock ops for PLL - remove debug code
15. - rebase to 59bffec43a657598b194b9eb30dc01eec06078c7 - remove CONFIG_SYS_MONITOR_BASE from include/configs/
Du Huanpeng (6): mips: initial build infrastructure for loongson SoCs mips: ls1c300: add base support mips: add a ls1c300 based board mips: ls1c300: add clock driver mips: ls1c300: add watchdog support mips: ls1c300: add reset support based on watchdog driver
MAINTAINERS | 15 ++ Makefile | 1 + arch/mips/Kconfig | 11 ++ arch/mips/Makefile | 1 + arch/mips/dts/Makefile | 1 + arch/mips/dts/loongson32-ls1c300b.dtsi | 150 +++++++++++++++ arch/mips/dts/ls1c300-eval.dts | 30 +++ arch/mips/mach-lsmips/Kconfig | 76 ++++++++ arch/mips/mach-lsmips/Makefile | 6 + arch/mips/mach-lsmips/cpu.c | 19 ++ arch/mips/mach-lsmips/include/mach/serial.h | 16 ++ arch/mips/mach-lsmips/ls1c300/Makefile | 7 + arch/mips/mach-lsmips/ls1c300/gpio.c | 66 +++++++ arch/mips/mach-lsmips/ls1c300/init.c | 62 ++++++ arch/mips/mach-lsmips/ls1c300/lowlevel_init.S | 135 +++++++++++++ arch/mips/mach-lsmips/ls1c300/sdram.S | 96 ++++++++++ arch/mips/mach-lsmips/ls1c300/serial.c | 109 +++++++++++ arch/mips/mach-lsmips/spl.c | 47 +++++ board/loongson/ls1c300-eval/Kconfig | 12 ++ board/loongson/ls1c300-eval/MAINTAINERS | 7 + board/loongson/ls1c300-eval/Makefile | 3 + board/loongson/ls1c300-eval/board.c | 20 ++ configs/ls1c300_defconfig | 53 ++++++ drivers/clk/Makefile | 1 + drivers/clk/lsmips/Makefile | 3 + drivers/clk/lsmips/clk-ls1c300.c | 180 ++++++++++++++++++ drivers/reset/Kconfig | 7 + drivers/reset/Makefile | 1 + drivers/reset/reset-lsmips.c | 118 ++++++++++++ drivers/watchdog/Kconfig | 8 + drivers/watchdog/Makefile | 1 + drivers/watchdog/lsmips_wdt.c | 128 +++++++++++++ include/configs/ls1c300.h | 34 ++++ include/dt-bindings/clock/ls1c300-clk.h | 18 ++ include/dt-bindings/reset/ls1c300-reset.h | 36 ++++ 35 files changed, 1478 insertions(+) create mode 100644 arch/mips/dts/loongson32-ls1c300b.dtsi create mode 100644 arch/mips/dts/ls1c300-eval.dts create mode 100644 arch/mips/mach-lsmips/Kconfig create mode 100644 arch/mips/mach-lsmips/Makefile create mode 100644 arch/mips/mach-lsmips/cpu.c create mode 100644 arch/mips/mach-lsmips/include/mach/serial.h create mode 100644 arch/mips/mach-lsmips/ls1c300/Makefile create mode 100644 arch/mips/mach-lsmips/ls1c300/gpio.c create mode 100644 arch/mips/mach-lsmips/ls1c300/init.c create mode 100644 arch/mips/mach-lsmips/ls1c300/lowlevel_init.S create mode 100644 arch/mips/mach-lsmips/ls1c300/sdram.S create mode 100644 arch/mips/mach-lsmips/ls1c300/serial.c create mode 100644 arch/mips/mach-lsmips/spl.c create mode 100644 board/loongson/ls1c300-eval/Kconfig create mode 100644 board/loongson/ls1c300-eval/MAINTAINERS create mode 100644 board/loongson/ls1c300-eval/Makefile create mode 100644 board/loongson/ls1c300-eval/board.c create mode 100644 configs/ls1c300_defconfig create mode 100644 drivers/clk/lsmips/Makefile create mode 100644 drivers/clk/lsmips/clk-ls1c300.c create mode 100644 drivers/reset/reset-lsmips.c create mode 100644 drivers/watchdog/lsmips_wdt.c create mode 100644 include/configs/ls1c300.h create mode 100644 include/dt-bindings/clock/ls1c300-clk.h create mode 100644 include/dt-bindings/reset/ls1c300-reset.h
Loongson 1C is a cost-effective SOC chip for industrial control and the Internet of Things. The Loongson 1C includes a floating-point processing unit, supports multiple types of memory, and supports high-capacity MLC NAND Flash. Loongson 1C provides developers with a wealth of peripheral interfaces and on-chip modules, including Camera controller, USB OTG and USB HOST interfaces, AC97/I2S controller, LCD controller, SPI interface, UART interface, etc., providing sufficient computing power and multi-application connectivity.
Some highlights of this SoC are: - Single core LS232, MIPS32 instruction set compatible, main frequency 300MHZ - 16KB data cache and 16KB instruction cache - 64 bit float unit, hardware division - 8/16 bit SDRAM controller, 45 ~ 133MHz - 8/16 bit SRAM, NAND - I2S/AC97, LCD, MAC, USB, OTG, SPI, I2C, PWM, CAN, SDIO, ADC - 12 UARTs
See Techinical Reference Manual for details: https://www.loongson.cn/ https://github.com/hodcarrier/ls1c300_bsp
Signed-off-by: Du Huanpeng dhu@hodcarrier.org --- MAINTAINERS | 15 +++++ Makefile | 1 + arch/mips/Kconfig | 11 ++++ arch/mips/Makefile | 1 + arch/mips/dts/Makefile | 1 + arch/mips/mach-lsmips/Kconfig | 76 ++++++++++++++++++++++++++ arch/mips/mach-lsmips/Makefile | 6 ++ arch/mips/mach-lsmips/ls1c300/Makefile | 7 +++ configs/ls1c300_defconfig | 53 ++++++++++++++++++ 9 files changed, 171 insertions(+) create mode 100644 arch/mips/mach-lsmips/Kconfig create mode 100644 arch/mips/mach-lsmips/Makefile create mode 100644 arch/mips/mach-lsmips/ls1c300/Makefile create mode 100644 configs/ls1c300_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index 87991cccdd..91d6d714d8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1116,6 +1116,21 @@ F: drivers/net/cortina_ni.c F: drivers/net/cortina_ni.h F: drivers/net/phy/ca_phy.c
+MIPS LOONGSON LS1C300 +M: Du Huanpeng dhu@hodcarrier.org +S: Maintained +F: arch/mips/dts/loongson32-ls1c300b.dtsi +F: arch/mips/dts/ls1c300-eval.dts +F: arch/mips/mach-lsmips/ +F: board/loongson/ls1c300-eval/ +F: configs/ls1c300_defconfig +F: drivers/clk/lsmips/ +F: drivers/reset/reset-lsmips.c +F: drivers/watchdog/lsmips_wdt.c +F: include/configs/ls1c300.h +F: include/dt-bindings/clock/ls1c300-clk.h +F: include/dt-bindings/reset/ls1c300-reset.h + MIPS MEDIATEK M: Weijie Gao weijie.gao@mediatek.com R: GSS_MTK_Uboot_upstream GSS_MTK_Uboot_upstream@mediatek.com diff --git a/Makefile b/Makefile index 87f9fc786e..f7114e3597 100644 --- a/Makefile +++ b/Makefile @@ -1766,6 +1766,7 @@ ifeq ($(CONFIG_KALLSYMS),y) $(call cmd,smap) $(call cmd,u-boot__) common/system_map.o endif + -cp u-boot $(tftpboot)
ifeq ($(CONFIG_RISCV),y) @tools/prelink-riscv $@ diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 569f5f48bc..fa2d9af9ba 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -88,6 +88,16 @@ config ARCH_MTMIPS select SUPPORTS_LITTLE_ENDIAN select SUPPORT_SPL
+config ARCH_LSMIPS + bool "Support Loongson MIPS platforms" + select DM + select DM_SERIAL + select OF_CONTROL + select SUPPORTS_CPU_MIPS32_R1 + select SUPPORTS_CPU_MIPS32_R2 + select SUPPORTS_LITTLE_ENDIAN + select SUPPORT_SPL + config ARCH_JZ47XX bool "Support Ingenic JZ47xx" select SUPPORT_SPL @@ -173,6 +183,7 @@ source "arch/mips/mach-bmips/Kconfig" source "arch/mips/mach-jz47xx/Kconfig" source "arch/mips/mach-pic32/Kconfig" source "arch/mips/mach-mtmips/Kconfig" +source "arch/mips/mach-lsmips/Kconfig" source "arch/mips/mach-octeon/Kconfig"
if MIPS diff --git a/arch/mips/Makefile b/arch/mips/Makefile index a007914590..342cea6655 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -19,6 +19,7 @@ machine-$(CONFIG_ARCH_BMIPS) += bmips machine-$(CONFIG_ARCH_JZ47XX) += jz47xx machine-$(CONFIG_MACH_PIC32) += pic32 machine-$(CONFIG_ARCH_MTMIPS) += mtmips +machine-$(CONFIG_ARCH_LSMIPS) += lsmips machine-$(CONFIG_ARCH_MSCC) += mscc machine-${CONFIG_ARCH_OCTEON} += octeon
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index 1b179116c9..5cb7490a79 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -21,6 +21,7 @@ dtb-$(CONFIG_BOARD_MT7621_NAND_RFB) += mediatek,mt7621-nand-rfb.dtb dtb-$(CONFIG_BOARD_MT7628_RFB) += mediatek,mt7628-rfb.dtb dtb-$(CONFIG_BOARD_GARDENA_SMART_GATEWAY_MT7688) += gardena-smart-gateway-mt7688.dtb dtb-$(CONFIG_BOARD_LINKIT_SMART_7688) += linkit-smart-7688.dtb +dtb-$(CONFIG_BOARD_LS1C300) += ls1c300-eval.dtb dtb-$(CONFIG_TARGET_OCTEON_EBB7304) += mrvl,octeon-ebb7304.dtb dtb-$(CONFIG_TARGET_OCTEON_NIC23) += mrvl,octeon-nic23.dtb dtb-$(CONFIG_BOARD_NETGEAR_CG3100D) += netgear,cg3100d.dtb diff --git a/arch/mips/mach-lsmips/Kconfig b/arch/mips/mach-lsmips/Kconfig new file mode 100644 index 0000000000..4f9c4e36ef --- /dev/null +++ b/arch/mips/mach-lsmips/Kconfig @@ -0,0 +1,76 @@ +menu "Loongson MIPS platforms" + depends on ARCH_LSMIPS + +config SYS_MALLOC_F_LEN + default 0x1000 + +config SYS_SOC + default "ls1c300" if SOC_LS1C300 + +config SYS_DCACHE_SIZE + default 16384 + +config SYS_DCACHE_LINE_SIZE + default 32 + +config SYS_ICACHE_SIZE + default 16384 + +config SYS_ICACHE_LINE_SIZE + default 32 + +config TEXT_BASE + default 0xbfc00000 if !SPL + default 0x80200000 if SPL + +config SPL_TEXT_BASE + default 0xbfc00000 + +config SPL_PAYLOAD + default "u-boot-lzma.img" if SPL_LZMA + +config BUILD_TARGET + default "u-boot-with-spl.bin" if SPL + default "u-boot.bin" if !SPL + +choice + prompt "Loongson MIPS SoC select" + +config SOC_LS1C300 + bool "LS1C300" + select CLK_CCF + select SPL_SEPARATE_BSS if SPL + select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL + select SPL_LOADER_SUPPORT if SPL + select SPL_OF_CONTROL if SPL_DM + select SPL_SIMPLE_BUS if SPL_DM + select SPL_DM_SERIAL if SPL_DM + select SPL_CLK if SPL_DM && SPL_SERIAL + select SPL_SYSRESET if SPL_DM + select SPL_OF_LIBFDT if SPL_OF_CONTROL + help + This supports Loongson LS1C300 + +endchoice + +choice + prompt "Board select" + +config BOARD_LS1C300 + bool "Loongson LS1C300 Eval" + depends on SOC_LS1C300 + help + ls1c300-eval board has a LS1C300 SoC with 64MiB of SDRAM + and 512KiB of flash (SPI NOR) and additional NAND storage. + +endchoice + +config CONS_PIN + int "pin group used in uart" + default 0 + help + Select pin group connected to UART for your board. + +source "board/loongson/ls1c300-eval/Kconfig" + +endmenu diff --git a/arch/mips/mach-lsmips/Makefile b/arch/mips/mach-lsmips/Makefile new file mode 100644 index 0000000000..654143a5f7 --- /dev/null +++ b/arch/mips/mach-lsmips/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += cpu.o +obj-$(CONFIG_SPL_BUILD) += spl.o + +obj-$(CONFIG_SOC_LS1C300) += ls1c300/ diff --git a/arch/mips/mach-lsmips/ls1c300/Makefile b/arch/mips/mach-lsmips/ls1c300/Makefile new file mode 100644 index 0000000000..17b9d6fb9c --- /dev/null +++ b/arch/mips/mach-lsmips/ls1c300/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += lowlevel_init.o +obj-y += sdram.o +obj-y += init.o +obj-y += gpio.o +obj-$(CONFIG_SPL_BUILD) += serial.o diff --git a/configs/ls1c300_defconfig b/configs/ls1c300_defconfig new file mode 100644 index 0000000000..5634fb084a --- /dev/null +++ b/configs/ls1c300_defconfig @@ -0,0 +1,53 @@ +CONFIG_MIPS=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_MALLOC_F_LEN=0x40000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_DEFAULT_DEVICE_TREE="ls1c300-eval" +CONFIG_DM_RESET=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_SIZE_LIMIT=0x100000 +CONFIG_SPL=y +CONFIG_SYS_LOAD_ADDR=0x80010000 +CONFIG_ARCH_LSMIPS=y +CONFIG_SPL_PAYLOAD="u-boot.img" +CONFIG_ROM_EXCEPTION_VECTORS=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_LOGLEVEL=9 +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x10000 +CONFIG_SPL_PAD_TO=0 +CONFIG_SPL_BSS_START_ADDR=0x80010000 +CONFIG_SPL_BSS_MAX_SIZE=0x10000 +CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +# CONFIG_CMD_LOADS is not set +CONFIG_OF_EMBED=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +# CONFIG_NET is not set +CONFIG_CLK=y +CONFIG_SPL_CLK_CCF=y +# CONFIG_INPUT is not set +# CONFIG_POWER is not set +CONFIG_CONS_INDEX=2 +CONFIG_SPL_SYS_NS16550_SERIAL=y +CONFIG_SYS_NS16550_REG_SIZE=-1 +CONFIG_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_SYSRESET_WATCHDOG_AUTO=y +CONFIG_WATCHDOG_TIMEOUT_MSECS=3000 +CONFIG_WDT_LSMIPS=y +CONFIG_REGEX=y +# CONFIG_GZIP is not set
Signed-off-by: Du Huanpeng dhu@hodcarrier.org --- arch/mips/mach-lsmips/cpu.c | 19 +++ arch/mips/mach-lsmips/include/mach/serial.h | 16 +++ arch/mips/mach-lsmips/ls1c300/gpio.c | 66 +++++++++ arch/mips/mach-lsmips/ls1c300/init.c | 62 ++++++++ arch/mips/mach-lsmips/ls1c300/lowlevel_init.S | 135 ++++++++++++++++++ arch/mips/mach-lsmips/ls1c300/sdram.S | 96 +++++++++++++ arch/mips/mach-lsmips/ls1c300/serial.c | 109 ++++++++++++++ arch/mips/mach-lsmips/spl.c | 47 ++++++ include/configs/ls1c300.h | 34 +++++ 9 files changed, 584 insertions(+) create mode 100644 arch/mips/mach-lsmips/cpu.c create mode 100644 arch/mips/mach-lsmips/include/mach/serial.h create mode 100644 arch/mips/mach-lsmips/ls1c300/gpio.c create mode 100644 arch/mips/mach-lsmips/ls1c300/init.c create mode 100644 arch/mips/mach-lsmips/ls1c300/lowlevel_init.S create mode 100644 arch/mips/mach-lsmips/ls1c300/sdram.S create mode 100644 arch/mips/mach-lsmips/ls1c300/serial.c create mode 100644 arch/mips/mach-lsmips/spl.c create mode 100644 include/configs/ls1c300.h
diff --git a/arch/mips/mach-lsmips/cpu.c b/arch/mips/mach-lsmips/cpu.c new file mode 100644 index 0000000000..339088b435 --- /dev/null +++ b/arch/mips/mach-lsmips/cpu.c @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <init.h> +#include <malloc.h> +#include <linux/bitops.h> +#include <linux/io.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CFG_SYS_SDRAM_BASE, SZ_256M); + return 0; +} diff --git a/arch/mips/mach-lsmips/include/mach/serial.h b/arch/mips/mach-lsmips/include/mach/serial.h new file mode 100644 index 0000000000..4da1cb434c --- /dev/null +++ b/arch/mips/mach-lsmips/include/mach/serial.h @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Gao Weijie weijie.gao@mediatek.com + * + * Copyright (C) 2022 Du Huanpeng dhu@hodcarrier.org + */ + +#ifndef __LSMIPS_SERIAL_H_ +#define __LSMIPS_SERIAL_H_ + +void lsmips_spl_serial_init(void); +int gpio_set_alternate(int gpio, int func); + +#endif /* __LSMIPS_SERIAL_H_ */ diff --git a/arch/mips/mach-lsmips/ls1c300/gpio.c b/arch/mips/mach-lsmips/ls1c300/gpio.c new file mode 100644 index 0000000000..2195738b2b --- /dev/null +++ b/arch/mips/mach-lsmips/ls1c300/gpio.c @@ -0,0 +1,66 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Du Huanpeng dhu@hodcarrier.org + */ + +#include <linux/errno.h> +#include <asm/bitops.h> + +#define CBUS_FIRST0 0xbfd011c0 +#define CBUS_SECOND0 0xbfd011d0 +#define CBUS_THIRD0 0xbfd011e0 +#define CBUS_FOURTHT0 0xbfd011f0 +#define CBUS_FIFTHT0 0xbfd01200 + +#define CBUS_FIRST1 0xbfd011c4 +#define CBUS_SECOND1 0xbfd011d4 +#define CBUS_THIRD1 0xbfd011e4 +#define CBUS_FOURTHT1 0xbfd011f4 +#define CBUS_FIFTHT1 0xbfd01204 + +#define CBUS_FIRST2 0xbfd011c8 +#define CBUS_SECOND2 0xbfd011d8 +#define CBUS_THIRD2 0xbfd011e8 +#define CBUS_FOURTHT2 0xbfd011f8 +#define CBUS_FIFTHT2 0xbfd01208 + +#define CBUS_FIRST3 0xbfd011cc +#define CBUS_SECOND3 0xbfd011dc +#define CBUS_THIRD3 0xbfd011ec +#define CBUS_FOURTHT3 0xbfd011fc +#define CBUS_FIFTHT3 0xbfd0120c + +/* + * pinmux for debug uart and spl only, for others, please + * use a pinctrl driver and device-tree for pin muxing. + * + * @gpio: gpio number + * @func: alternate function 1 to 5, 0 for GPIO. + */ + +int gpio_set_alternate(int gpio, int func) +{ + volatile void __iomem *addr; + int i; + + if (gpio < 0 || gpio > 104) + return -ENODEV; + if (func < 0 || func > 5) + return -EINVAL; + + if (func) { + i = func - 1; + addr = (void *)CBUS_FIRST0 + i * 16; + set_bit(gpio, addr); + } else { + /* GPIO, clear CBUS 1 ~ 5 */ + i = 5; + } + + while (i--) { + addr = (void *)CBUS_FIRST0 + 16 * i; + clear_bit(gpio, addr); + } + + return 0; +} diff --git a/arch/mips/mach-lsmips/ls1c300/init.c b/arch/mips/mach-lsmips/ls1c300/init.c new file mode 100644 index 0000000000..0d5576fddf --- /dev/null +++ b/arch/mips/mach-lsmips/ls1c300/init.c @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Gao Weijie weijie.gao@mediatek.com + * + * based on: arch/mips/mach-mtmips/mt7628/init.c + * Copyright (C) 2020-2022 Du Huanpeng dhu@hodcarrier.org + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dm/uclass.h> +#include <dt-bindings/clock/ls1c300-clk.h> +#include <linux/io.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +int print_cpuinfo(void) +{ + struct udevice *udev; + struct clk clk; + int ret; + ulong xtal; + char buf[SZ_32]; + + printf("CPU: Loongson ls1c300b\n"); + + ret = uclass_get_device_by_driver(UCLASS_CLK, DM_DRIVER_GET(ls1c300_clk), &udev); + if (ret) { + printf("error: clock driver not found.\n"); + return 0; + } + + clk.dev = udev; + + ret = clk_request(udev, &clk); + if (ret < 0) + return ret; + + clk.id = CLK_XTAL; + xtal = clk_get_rate(&clk); + + clk.id = CLK_CPU_THROT; + gd->cpu_clk = clk_get_rate(&clk); + + clk.id = CLK_APB; + gd->mem_clk = clk_get_rate(&clk); + + printf("Clock: CPU: %sMHz, ", strmhz(buf, gd->cpu_clk)); + printf("SDRAM: %sMHz, ", strmhz(buf, gd->mem_clk)); + printf("XTAL: %sMHz\n", strmhz(buf, xtal)); + + return 0; +} + +ulong notrace get_tbclk(void) +{ + return gd->cpu_clk / 2; +} diff --git a/arch/mips/mach-lsmips/ls1c300/lowlevel_init.S b/arch/mips/mach-lsmips/ls1c300/lowlevel_init.S new file mode 100644 index 0000000000..4b453df621 --- /dev/null +++ b/arch/mips/mach-lsmips/ls1c300/lowlevel_init.S @@ -0,0 +1,135 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Gao Weijie weijie.gao@mediatek.com + * + * Copyright (C) 2020-2023 Du Huanpeng dhu@hodcarrier.org + */ + +#include <config.h> +#include <asm-offsets.h> +#include <asm/cacheops.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <asm/asm.h> +#include <linux/sizes.h> + +/* PLL control register */ +#define NAND_BASE 0xbfe70000 +#define START_FREQ 0x8030 +#define CLK_DIV_PARAM 0x8034 +#define CPU_THROT 0xc010 + +/* START_FREQ */ +#define PLL_VALID 31 +#define Reserved_24 24 +#define FRAC_N 16 +#define M_PLL 8 +#define Reserved_4 4 +#define RST_TIME 2 +#define SDRAM_DIV 0 + #define SDRAM_DIV2 0 + #define SDRAM_DIV4 1 + #define SDRAM_DIV3 2 + +/* CLK_DIV_PARAM */ +#define PIX_DIV 24 +#define CAM_DIV 16 +#define CPU_DIV 8 +#define PIX_DIV_VALID 5 +#define PIX_SEL 4 +#define CAM_DIV_VALID 3 +#define CAM_SEL 2 +#define CPU_DIV_VALID 1 +#define CPU_SEL 0 + +/* Document: + * Freq_PLL = XIN *(M_PLL + FRAC_N)/4 + */ +#define XIN 24000000 +#define PLL_VALID_1 (1<<PLL_VALID) +#define PREP_M_PLL(Freq_PLL) (((Freq_PLL * 4) / XIN) << M_PLL) +#define PREP_SDRAM_DIV(div) (div<<SDRAM_DIV) +#define PREP_CPU_DIV(div1) ((0x80|div1)<<CPU_DIV | (div1&&div1)<<CPU_DIV_VALID) +#define PREP_PIX_DIV(div2) (div2<<PIX_DIV) +#define PREP_CAM_DIV(div3) (div3<<CAM_DIV) + +/* PLL @264MHz, CPU @132MHz, SDRAM @66MHz */ +#define CFG_START_FREQ (PLL_VALID_1 | PREP_M_PLL(264000000) | SDRAM_DIV2) +#define CFG_CLK_DIV_PARAM (PREP_CPU_DIV(2) | PREP_PIX_DIV(0x24) | PREP_CAM_DIV(0x24)) +#define CFG_CPU_THROT 15 + +/* SPI0 control register */ +#define SPI0_BASE 0xbfe80000 +#define SPCR 0 +#define SPSR 1 +#define TxFIFO 2 +#define RxFIFO 2 +#define SPER 3 +#define SFC_PARAM 4 + #define CLK_DIV 4 + #define DUAL_IO 3 + #define FAST_READ 2 + #define BURST_EN 1 + #define MEMORY_EN 0 +#define SFC_SOFTCS 5 +#define SFC_TIMING 6 + #define T_FAST 2 + #define T_CSH 0 + + .set noreorder +LEAF(ls1c300_pll_init) +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) + li t0, NAND_BASE + li t1, CFG_START_FREQ + li t2, CFG_CLK_DIV_PARAM + li t3, CFG_CPU_THROT + + sw t3, CPU_THROT (t0) + sw t2, CLK_DIV_PARAM (t0) + sw t1, START_FREQ (t0) + + ori t2, 1<<CPU_SEL + sw t2, CLK_DIV_PARAM (t0) +#endif + li v0, 264000000 + jr ra + nop +END(ls1c300_pll_init) + +LEAF(ls1c300_spi_init) +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) + li t0, SPI0_BASE + li t1, (1<<MEMORY_EN) | (1<<BURST_EN) | (1<<FAST_READ) | (1<<DUAL_IO) + sb t1, SFC_PARAM (t0) + li t2, (1<<T_FAST) | (1<<T_CSH) + sb t2, SFC_TIMING (t0) +#endif + jr ra + nop +END(ls1c300_spi_init) + +NESTED(lowlevel_init, 0, ra) + /* Save ra and do real lowlevel initialization */ + move s0, ra + /* Setup PLL @264MHz */ + PTR_LA t9, ls1c300_pll_init + jalr t9 + nop + + /* Setup SPI Dual IO@33MHz */ + PTR_LA t9, ls1c300_spi_init + jalr t9 + nop + + /* Setup external SDRAM @66MHz */ + PTR_LA t9, ls1c300_sdram_init + jalr t9 + nop + + move ra, s0 + jr ra + nop +END(lowlevel_init) diff --git a/arch/mips/mach-lsmips/ls1c300/sdram.S b/arch/mips/mach-lsmips/ls1c300/sdram.S new file mode 100644 index 0000000000..4797b1d8a2 --- /dev/null +++ b/arch/mips/mach-lsmips/ls1c300/sdram.S @@ -0,0 +1,96 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020-2022 Du Huanpeng dhu@hodcarrier.org + */ + +#include <config.h> +#include <asm-offsets.h> +#include <asm/cacheops.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <asm/asm.h> +#include <linux/sizes.h> + +/* sdram control 64 bit register */ +#define SD_CONFIG 0xbfd00000 +#define SD_CONFIGHI 0x414 +#define SD_CONFIGLO 0x410 + +#define CONFIG_VALID 41 +#define HANG_UP 40 +#define DEF_SEL 39 +#define TWR 37 +#define TREF 25 +#define TRAS 21 +#define TRFC 17 +#define TRP 14 +#define TCL 11 +#define TRCD 8 + +#define SD_BIT 6 + #define SD_8BIT (0<<SD_BIT) + #define SD_16BIT (1<<SD_BIT) + #define SD_32BIT (2<<SD_BIT) +#define SD_CSIZE 3 + #define SD_CSIZE_512 (0<<SD_CSIZE) + #define SD_CSIZE_1K (1<<SD_CSIZE) + #define SD_CSIZE_2K (2<<SD_CSIZE) + #define SD_CSIZE_4K (3<<SD_CSIZE) + #define SD_CSIZE_256 (7<<SD_CSIZE) +#define SD_RSIZE 0 + #define SD_RSIZE_2K (0<<SD_RSIZE) + #define SD_RSIZE_4K (1<<SD_RSIZE) + #define SD_RSIZE_8K (2<<SD_RSIZE) + #define SD_RSIZE_16K (3<<SD_RSIZE) + +#define SD_CFG_1(tWR, tREF, tRAS, tRFC, tRP, tCL, tRCD) \ + ((tWR<<TWR)|(tREF<<TREF)|(tRAS<<TRAS)|(tRFC<<TRFC)|(tRP<<TRP)|(tCL<<TCL)|(tRCD<<TRCD)) +#define CFG_SD_0(b, c, r) \ + ((b<<SD_BIT)|(c<<SD_CSIZE)|(r<<SD_RSIZE)) +/* + * recommended values by ls1c300 user manual, + * tweak to fit your board. + */ +#define SD_CONFIG_133MHz SD_CFG_1(2, 0x818, 6, 8, 3, 3, 3) +#define SD_CONFIG_100MHz SD_CFG_1(2, 0x620, 5, 6, 2, 3, 2) +#define SD_CONFIG_75MHz SD_CFG_1(1, 0x494, 4, 5, 2, 2, 2) +#define SD_CONFIG_33MHz SD_CFG_1(1, 0x204, 2, 2, 1, 2, 1) + +#define SD_CONFIG_66MHz SD_CFG_1(1, 0x401, 4, 4, 2, 2, 2) + +#define SD_CONFIG64 (SD_CONFIG_66MHz | SD_16BIT | SD_CSIZE_1K | SD_RSIZE_8K) +#define CFG_SDCONFIGHI (SD_CONFIG64 /(1<<32)) +#define CFG_SDCONFIGLO (SD_CONFIG64 %(1<<32)) + + .set noreorder +/* + * Loongson ls1c300 SoC do not have onchip sram for initial stack, + * initialize the external sdram on reset as early as possiable. + */ +LEAF(ls1c300_sdram_init) +#if !CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) + li t0, SD_CONFIG + li t1, CFG_SDCONFIGLO + li t2, CFG_SDCONFIGHI + +/* store twice as the hardware manual required. */ + sw t1, SD_CONFIGLO (t0) + sw t2, SD_CONFIGHI (t0) + sync + + sw t1, SD_CONFIGLO (t0) + sw t2, SD_CONFIGHI (t0) + sync + + ori t2, 1<<(CONFIG_VALID-32) + sw t1, SD_CONFIGLO (t0) + sw t2, SD_CONFIGHI (t0) + sync +#endif + li v0, SZ_64M + jr ra + nop +END(ls1c300_sdram_init) + + diff --git a/arch/mips/mach-lsmips/ls1c300/serial.c b/arch/mips/mach-lsmips/ls1c300/serial.c new file mode 100644 index 0000000000..93fd653385 --- /dev/null +++ b/arch/mips/mach-lsmips/ls1c300/serial.c @@ -0,0 +1,109 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Gao Weijie weijie.gao@mediatek.com + * + * Copyright (C) 2020-2022 Du Huanpeng dhu@hodcarrier.org + */ + +#include <mach/serial.h> +#include <linux/kernel.h> + +struct uart_pin_config { + char port; + char af; + char rx; + char tx; +}; + +struct uart_pin_config con[] = { +#if CONFIG_CONS_INDEX == 0 + { 0, 2, 74, 75 }, + { 0, 3, 23, 24 }, + { 0, 3, 99, 100 }, + +#elif CONFIG_CONS_INDEX == 1 + { 1, 1, 17, 18 }, + { 1, 1, 101, 102 }, + { 1, 2, 40, 41 }, + { 1, 4, 2, 3 }, + +#elif CONFIG_CONS_INDEX == 2 + { 2, 2, 36, 37 }, + { 2, 2, 42, 43 }, + { 2, 3, 27, 28 }, + { 2, 3, 103, 104 }, + { 2, 4, 4, 5 }, + +#elif CONFIG_CONS_INDEX == 3 + { 3, 2, 17, 18 }, + { 3, 2, 33, 34 }, + { 3, 2, 44, 45 }, + { 3, 4, 0, 1 }, + +#elif CONFIG_CONS_INDEX == 4 + { 4, 5, 23, 24 }, + { 4, 5, 58, 59 }, + { 4, 5, 80, 79 }, + +#elif CONFIG_CONS_INDEX == 5 + { 5, 5, 25, 26 }, + { 5, 5, 60, 61 }, + { 5, 5, 81, 78 }, + +#elif CONFIG_CONS_INDEX == 6 + { 6, 5, 27, 46 }, + { 6, 5, 62, 63 }, + +#elif CONFIG_CONS_INDEX == 7 + { 7, 5, 57, 56 }, + { 7, 5, 64, 65 }, + { 7, 5, 87, 88 }, + +#elif CONFIG_CONS_INDEX == 8 + { 8, 5, 55, 54 }, + { 8, 5, 66, 67 }, + { 8, 5, 89, 90 }, + +#elif CONFIG_CONS_INDEX == 9 + { 9, 5, 53, 52 }, + { 9, 5, 68, 69 }, + { 9, 5, 85, 86 }, + +#elif CONFIG_CONS_INDEX == 10 + { 10, 5, 51, 50 }, + { 10, 5, 70, 71 }, + { 10, 5, 84, 82 }, + +#elif CONFIG_CONS_INDEX == 11 + { 11, 5, 49, 48 }, + { 11, 5, 72, 73 }, +#endif /* CONFIG_CONS_INDEX */ +}; + +#define UART2_RX 36 +#define UART2_TX 37 +#define AFUNC 2 + +void lsmips_spl_serial_init(void) +{ +#if defined(CONFIG_SPL_SERIAL) + int pin_rx, pin_tx; + int afunc; + + if (CONFIG_CONS_PIN < ARRAY_SIZE(con)) { + pin_rx = con[CONFIG_CONS_PIN].rx; + pin_tx = con[CONFIG_CONS_PIN].tx; + afunc = con[CONFIG_CONS_PIN].af; + } else { + pin_rx = UART2_RX; + pin_tx = UART2_TX; + afunc = AFUNC; + } + + gpio_set_alternate(pin_rx, afunc); + gpio_set_alternate(pin_tx, afunc); +#endif /* CONFIG_SPL_SERIAL */ + return; +} diff --git a/arch/mips/mach-lsmips/spl.c b/arch/mips/mach-lsmips/spl.c new file mode 100644 index 0000000000..c7c28989f2 --- /dev/null +++ b/arch/mips/mach-lsmips/spl.c @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Gao Weijie weijie.gao@mediatek.com + * + * Copyright (C) 2022 Du Huanpeng dhu@hodcarrier.org + */ + +#include <common.h> +#include <init.h> +#include <spl.h> +#include <asm/sections.h> +#include <linux/libfdt.h> +#include <linux/sizes.h> +#include <mach/serial.h> + +void __noreturn board_init_f(ulong dummy) +{ + spl_init(); + +#ifdef CONFIG_SPL_SERIAL + /* + * lsmips_spl_serial_init() is useful if debug uart is enabled, + * or DM based serial is not enabled. + */ + lsmips_spl_serial_init(); + preloader_console_init(); +#endif + + board_init_r(NULL, 0); +} + +void board_boot_order(u32 *spl_boot_list) +{ + spl_boot_list[0] = BOOT_DEVICE_NOR; +} + +unsigned long spl_nor_get_uboot_base(void) +{ + void *uboot_base = __image_copy_end; + + if (fdt_magic(uboot_base) == FDT_MAGIC) + return (unsigned long)uboot_base + fdt_totalsize(uboot_base); + + return (unsigned long)uboot_base; +} diff --git a/include/configs/ls1c300.h b/include/configs/ls1c300.h new file mode 100644 index 0000000000..4d07b07759 --- /dev/null +++ b/include/configs/ls1c300.h @@ -0,0 +1,34 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Gao Weijie weijie.gao@mediatek.com + * based on: include/configs/mt7628.h + * Copyright (C) 2022-2023 Du Huanpeng dhu@hodcarrier.org + */ + +#ifndef __CONFIG_LS1C300_H__ +#define __CONFIG_LS1C300_H__ + +#define CFG_SYS_SDRAM_BASE 0x80000000 +#define CFG_SYS_INIT_SP_OFFSET 0x2000 + +/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL) +#define CFG_SYS_NS16550_CLK 66000000 +#define CFG_SYS_NS16550_COM1 0xbfe44000 +#define CFG_SYS_NS16550_COM2 0xbfe48000 +#define CFG_SYS_NS16550_COM3 0xbfe4c000 +#define CFG_SYS_NS16550_COM4 0xbfe4c400 +#define CFG_SYS_NS16550_COM5 0xbfe4c500 +#define CFG_SYS_NS16550_COM6 0xbfe4c600 +#endif + +/* Serial common */ +#define CFG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400, 460800, 921600 } + +/* SPL */ +#define CFG_MALLOC_F_ADDR 0x80100000 /* FIXME: find a proper place */ +#define CFG_SYS_UBOOT_BASE 0xbd000000 + +#endif /* __CONFIG_LS1C300_H__ */
Signed-off-by: Du Huanpeng dhu@hodcarrier.org --- arch/mips/dts/loongson32-ls1c300b.dtsi | 150 ++++++++++++++++++++++++ arch/mips/dts/ls1c300-eval.dts | 30 +++++ board/loongson/ls1c300-eval/Kconfig | 12 ++ board/loongson/ls1c300-eval/MAINTAINERS | 7 ++ board/loongson/ls1c300-eval/Makefile | 3 + board/loongson/ls1c300-eval/board.c | 20 ++++ 6 files changed, 222 insertions(+) create mode 100644 arch/mips/dts/loongson32-ls1c300b.dtsi create mode 100644 arch/mips/dts/ls1c300-eval.dts create mode 100644 board/loongson/ls1c300-eval/Kconfig create mode 100644 board/loongson/ls1c300-eval/MAINTAINERS create mode 100644 board/loongson/ls1c300-eval/Makefile create mode 100644 board/loongson/ls1c300-eval/board.c
diff --git a/arch/mips/dts/loongson32-ls1c300b.dtsi b/arch/mips/dts/loongson32-ls1c300b.dtsi new file mode 100644 index 0000000000..b2a89d0ae7 --- /dev/null +++ b/arch/mips/dts/loongson32-ls1c300b.dtsi @@ -0,0 +1,150 @@ +// SPDX-License-Identifier: GPL-2.0 +#include <dt-bindings/clock/ls1c300-clk.h> +#include <dt-bindings/reset/ls1c300-reset.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "loongson,ls1c300-soc"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu@0 { + device_type = "cpu"; + reg = <0>; + compatible = "loongson,gs232", "mips,mips4Kc"; + clocks = <&acc CLK_CPU_THROT>; + }; + }; + + clocks { + #address-cells = <1>; + #size-cells = <1>; + u-boot,dm-pre-reloc; + + xtal: oscillator { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + #clock-cells = <0>; + }; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + ranges; + + acc: clock-controller@1fe78030 { + compatible = "loongson,ls1c300-clk"; + clocks = <&xtal>; + #clock-cells = <1>; + reg = <0x1fe78030 0x8>, <0x1fe7c010 0x4>; + u-boot,dm-pre-reloc; + }; + + uart0: serial@1fe40000 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe40000 0x100>; + status = "disabled"; + }; + + uart1: serial@1fe44000 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe44000 0x100>; + status = "disabled"; + }; + + uart2: serial@1fe48000 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe48000 0x100>; + resets = <&shut_ctrl UART2_SHUT>; + reset-names = "uart2"; + status = "disabled"; + }; + + uart3: serial@1fe4c000 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe4c000 0x100>; + status = "disabled"; + }; + + uart4: serial@1fe4c400 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe4c400 0x100>; + status = "disabled"; + }; + + uart5: serial@1fe4c500 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe4c500 0x100>; + status = "disabled"; + }; + + uart6: serial@1fe4c600 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe4c600 0x100>; + status = "disabled"; + }; + + uart7: serial@1fe4c700 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe4c700 0x100>; + status = "disabled"; + }; + + uart8: serial@1fe4c800 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe4c800 0x100>; + status = "disabled"; + }; + + uart9: serial@1fe4c900 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe4c900 0x100>; + status = "disabled"; + }; + + uart10: serial@1fe4ca00 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe4ca00 0x100>; + status = "disabled"; + }; + + uart11: serial@1fe4cb00 { + compatible = "loongson,ls1c300-uart", "ns16550a"; + clocks = <&acc CLK_APB>; + reg = <0x1fe4cb00 0x100>; + status = "disabled"; + }; + + wdt: watchdog@1fe5c060 { + compatible = "loongson,ls1c300-wdt"; + clocks = <&acc CLK_APB>; + reg = <0x1fe5c060 0x10>; + }; + + reset-controller { + compatible = "wdt-reboot"; + wdt = <&wdt>; + }; + + shut_ctrl: reset-controller@1fd00420 { + compatible = "loongson,shut_ctrl"; + reg = <0x1fd00420 0x4>; + #reset-cells = <1>; + }; + }; +}; diff --git a/arch/mips/dts/ls1c300-eval.dts b/arch/mips/dts/ls1c300-eval.dts new file mode 100644 index 0000000000..422e7a858c --- /dev/null +++ b/arch/mips/dts/ls1c300-eval.dts @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Du Huanpeng dhu@hodcarrier.org + */ + +/dts-v1/; + +#include "loongson32-ls1c300b.dtsi" + +/ { + compatible = "lsmips,ls1c300-soc"; + model = "ls1c300-eval"; + + aliases { + serial0 = &uart2; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x4000000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&uart2 { + status = "okay"; +}; diff --git a/board/loongson/ls1c300-eval/Kconfig b/board/loongson/ls1c300-eval/Kconfig new file mode 100644 index 0000000000..e427570a83 --- /dev/null +++ b/board/loongson/ls1c300-eval/Kconfig @@ -0,0 +1,12 @@ +if BOARD_LS1C300 + +config SYS_BOARD + default "ls1c300-eval" + +config SYS_VENDOR + default "loongson" + +config SYS_CONFIG_NAME + default "ls1c300" + +endif diff --git a/board/loongson/ls1c300-eval/MAINTAINERS b/board/loongson/ls1c300-eval/MAINTAINERS new file mode 100644 index 0000000000..5420198dab --- /dev/null +++ b/board/loongson/ls1c300-eval/MAINTAINERS @@ -0,0 +1,7 @@ +LS1C300_EVAL BOARD +M: Du Huanpengdhu@hodcarrier.org +S: Maintained +F: board/loongson/ls1c300-eval +F: include/configs/ls1c300.h +F: configs/ls1c300_defconfig +F: arch/mips/dts/ls1c300-eval.dts diff --git a/board/loongson/ls1c300-eval/Makefile b/board/loongson/ls1c300-eval/Makefile new file mode 100644 index 0000000000..db129c5aba --- /dev/null +++ b/board/loongson/ls1c300-eval/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += board.o diff --git a/board/loongson/ls1c300-eval/board.c b/board/loongson/ls1c300-eval/board.c new file mode 100644 index 0000000000..6809d66515 --- /dev/null +++ b/board/loongson/ls1c300-eval/board.c @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020-2022 Du Huanpeng dhu@hodcarrier.org + */ + +#include <common.h> +#include <mach/serial.h> + +#if defined(CONFIG_DEBUG_UART_BOARD_INIT) + +#define UART2_RX 36 +#define UART2_TX 37 +#define AFUNC 2 + +void board_debug_uart_init(void) +{ + gpio_set_alternate(UART2_TX, AFUNC); + gpio_set_alternate(UART2_RX, AFUNC); +} +#endif
Signed-off-by: Du Huanpeng dhu@hodcarrier.org --- drivers/clk/Makefile | 1 + drivers/clk/lsmips/Makefile | 3 + drivers/clk/lsmips/clk-ls1c300.c | 180 ++++++++++++++++++++++++ include/dt-bindings/clock/ls1c300-clk.h | 18 +++ 4 files changed, 202 insertions(+) create mode 100644 drivers/clk/lsmips/Makefile create mode 100644 drivers/clk/lsmips/clk-ls1c300.c create mode 100644 include/dt-bindings/clock/ls1c300-clk.h
diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index e22c8cf291..32cf35ac5d 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -18,6 +18,7 @@ obj-y += tegra/ obj-y += ti/ obj-$(CONFIG_$(SPL_TPL_)CLK_INTEL) += intel/ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ +obj-$(CONFIG_ARCH_LSMIPS) += lsmips/ obj-$(CONFIG_ARCH_MEDIATEK) += mediatek/ obj-$(CONFIG_ARCH_MESON) += meson/ obj-$(CONFIG_ARCH_MTMIPS) += mtmips/ diff --git a/drivers/clk/lsmips/Makefile b/drivers/clk/lsmips/Makefile new file mode 100644 index 0000000000..0a47269cd3 --- /dev/null +++ b/drivers/clk/lsmips/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-$(CONFIG_SOC_LS1C300) += clk-ls1c300.o diff --git a/drivers/clk/lsmips/clk-ls1c300.c b/drivers/clk/lsmips/clk-ls1c300.c new file mode 100644 index 0000000000..46a94e9748 --- /dev/null +++ b/drivers/clk/lsmips/clk-ls1c300.c @@ -0,0 +1,180 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * reference: + * drivers/clk/microchip/mpfs_clk.c + * drivers/clk/clk_octeon.c + * + * Copyright (C) 2020-2022 Du Huanpeng dhu@hodcarrier.org + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dt-bindings/clock/ls1c300-clk.h> +#include <linux/bitops.h> +#include <linux/bitfield.h> +#include <linux/io.h> +#include <linux/clk-provider.h> + +/* PLL/SDRAM Frequency Configuration Register */ +#define START_FREQ 0 +#define CLK_DIV_PARAM 4 + +/* START_FREQ */ +#define PLL_VALID BIT(31) +#define RESERVED0 GENMASK(30, 24) +#define FRAC_N GENMASK(23, 16) +#define M_PLL GENMASK(15, 8) +#define RESERVED1 GENMASK(7, 4) +#define RST_TIME GENMASK(3, 2) +#define SDRAM_DIV GENMASK(1, 0) +/* CLK_DIV_PARAM */ +#define PIX_DIV GENMASK(31, 24) +#define CAM_DIV GENMASK(23, 16) +#define CPU_DIV GENMASK(15, 8) +#define RESERVED2 GENMASK(7, 6) +#define PIX_DIV_VALID BIT(5) +#define PIX_SEL BIT(4) +#define CAM_DIV_VALID BIT(3) +#define CAM_SEL BIT(2) +#define CPU_DIV_VALID BIT(1) +#define CPU_SEL BIT(0) +/* CPU_THROT */ +#define CPU_THROT GENMASK(3, 0) + +static const struct clk_div_table sdram_div_table[] = { + {.val = 0, .div = 2}, + {.val = 1, .div = 4}, + {.val = 2, .div = 3}, + {.val = 3, .div = 3}, +}; + +ulong ls1c300_pll_get_rate(struct clk *clk) +{ + unsigned int mult; + long long parent_rate; + void *base; + unsigned int val; + + parent_rate = clk_get_parent_rate(clk); + base = (void *)clk->data; + + val = readl(base + START_FREQ); + mult = FIELD_GET(FRAC_N, val) + FIELD_GET(M_PLL, val); + return (mult * parent_rate) / 4; +} + +static ulong ls1c300_clk_get_rate(struct clk *clk) +{ + struct clk *cl; + ulong rate; + int err; + + err = clk_get_by_id(clk->id, &cl); + if (err) + return err; + + rate = clk_get_rate(cl); + return rate; +} + +static int ls1c300_clk_probe(struct udevice *dev) +{ + void __iomem *base; + void __iomem *cpu_throt; + void __iomem *addr; + + struct clk *cl, clk; + const char *parent_name; + int flags; + int ret; + + base = (void *)dev_remap_addr_index(dev, 0); + cpu_throt = (void *)dev_remap_addr_index(dev, 1); + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return ret; + + ret = clk_get_rate(&clk); + + parent_name = clk.dev->name; + + cl = kzalloc(sizeof(*cl), GFP_KERNEL); + cl->data = (unsigned long)base; + ret = clk_register(cl, "clk_ls1c300_pll", "pll", parent_name); + clk_dm(CLK_PLL, cl); + + addr = base + CLK_DIV_PARAM; + flags = CLK_DIVIDER_ONE_BASED | CLK_DIVIDER_ALLOW_ZERO; + cl = clk_register_divider(NULL, "cpu_div", "pll", 0, addr, 8, 7, flags); + clk_dm(CLK_CPU, cl); + cl = clk_register_divider(NULL, "cam_div", "pll", 0, addr, 16, 7, flags); + clk_dm(CLK_CAMERA, cl); + cl = clk_register_divider(NULL, "pix_div", "pll", 0, addr, 24, 7, flags); + clk_dm(CLK_PIX, cl); + + cl = kzalloc(sizeof(*cl), GFP_KERNEL); + cl->data = (unsigned long)cpu_throt; + ret = clk_register(cl, "clk_cpu_throt", "cpu_throt_factor", "cpu_div"); + clk_dm(CLK_CPU_THROT, cl); + + addr = base + START_FREQ; + cl = clk_register_divider(NULL, "sdram_div", "cpu_div", 0, addr, 0, 2, 0); + to_clk_divider(cl)->table = sdram_div_table; + clk_dm(CLK_APB, cl); + + return 0; +} + +static ulong cpu_throt_get_rate(struct clk *clk) +{ + void __iomem *cpu_throt; + long long parent_rate; + ulong ret; + + parent_rate = clk_get_parent_rate(clk); + cpu_throt = (void *)clk->data; + + ret = readl(cpu_throt) + 1; + ret = parent_rate * ret / 16; + return ret; +} + +static const struct udevice_id ls1c300_clk_ids[] = { + { .compatible = "loongson,ls1c300-clk" }, + { } +}; + +static const struct clk_ops clk_cpu_throt_ops = { + .get_rate = cpu_throt_get_rate, +}; + +static const struct clk_ops clk_ls1c300_pll_ops = { + .get_rate = ls1c300_pll_get_rate, +}; + +static const struct clk_ops ls1c300_clk_ops = { + .get_rate = ls1c300_clk_get_rate, +}; + +U_BOOT_DRIVER(clk_ls1c300_cpu_throt) = { + .name = "clk_cpu_throt", + .id = UCLASS_CLK, + .ops = &clk_cpu_throt_ops, +}; + +U_BOOT_DRIVER(clk_ls1c300_pll) = { + .name = "clk_ls1c300_pll", + .id = UCLASS_CLK, + .ops = &clk_ls1c300_pll_ops, +}; + +U_BOOT_DRIVER(ls1c300_clk) = { + .name = "clk_ls1c300", + .id = UCLASS_CLK, + .of_match = ls1c300_clk_ids, + .probe = ls1c300_clk_probe, + .priv_auto = sizeof(struct clk), + .ops = &ls1c300_clk_ops, +}; diff --git a/include/dt-bindings/clock/ls1c300-clk.h b/include/dt-bindings/clock/ls1c300-clk.h new file mode 100644 index 0000000000..5aae46e89e --- /dev/null +++ b/include/dt-bindings/clock/ls1c300-clk.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 Du Huanpeng dhu@hodcarrier.org + */ + +#ifndef __DT_BINDINGS_LS1C300_CLK_H__ +#define __DT_BINDINGS_LS1C300_CLK_H__ + +#define CLK_XTAL 0 +#define CLK_PLL 1 +#define CLK_CPU 2 +#define CLK_APB 3 +#define CLK_CAMERA 4 +#define CLK_PIX 5 +#define CLK_AXIMUX 6 +#define CLK_CPU_THROT 7 + +#endif /* __DT_BINDINGS_LS1C300_CLK_H__ */
Signed-off-by: Du Huanpeng dhu@hodcarrier.org --- drivers/watchdog/Kconfig | 8 +++ drivers/watchdog/Makefile | 1 + drivers/watchdog/lsmips_wdt.c | 128 ++++++++++++++++++++++++++++++++++ 3 files changed, 137 insertions(+) create mode 100644 drivers/watchdog/lsmips_wdt.c
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 646663528a..f60011e5b3 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -171,6 +171,14 @@ config WDT_GPIO doc/device-tree-bindings/watchdog/gpio-wdt.txt for information on how to describe the watchdog in device tree.
+config WDT_LSMIPS + bool "Loongson MIPS watchdog timer support" + depends on WDT + help + Select this to enable watchdog timer for Loongson SoCs. + The watchdog timer is stopped when initialized. + It performs full SoC reset. + config WDT_MAX6370 bool "MAX6370 watchdog timer support" depends on WDT diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index fd5d9c7376..8afd61a4fc 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -30,6 +30,7 @@ obj-$(CONFIG_WDT_ORION) += orion_wdt.o obj-$(CONFIG_WDT_CDNS) += cdns_wdt.o obj-$(CONFIG_WDT_FTWDT010) += ftwdt010_wdt.o obj-$(CONFIG_WDT_GPIO) += gpio_wdt.o +obj-$(CONFIG_WDT_LSMIPS) += lsmips_wdt.o obj-$(CONFIG_WDT_MAX6370) += max6370_wdt.o obj-$(CONFIG_WDT_MESON_GXBB) += meson_gxbb_wdt.o obj-$(CONFIG_WDT_MPC8xxx) += mpc8xxx_wdt.o diff --git a/drivers/watchdog/lsmips_wdt.c b/drivers/watchdog/lsmips_wdt.c new file mode 100644 index 0000000000..69006d332d --- /dev/null +++ b/drivers/watchdog/lsmips_wdt.c @@ -0,0 +1,128 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Watchdog driver for MediaTek SoCs + * + * Copyright (C) 2018 MediaTek Inc. + * Author: Ryder Lee ryder.lee@mediatek.com + * + * based on: drivers/watchdog/mtk_wdt.c + * Copyright (C) 2020-2023 Du Huanpeng dhu@hodcarrier.org + */ + +#include <common.h> +#include <dm.h> +#include <hang.h> +#include <wdt.h> +#include <asm/io.h> +#include <clk.h> + + +struct lsmips_wdt_priv { + void __iomem *base; +#define WDT_EN 0 +#define WDT_TIMER 4 +#define WDT_SET 8 + ulong clock; + unsigned long timeout; +}; + +static int lsmips_wdt_reset(struct udevice *dev) +{ + struct lsmips_wdt_priv *priv = dev_get_priv(dev); + + writel(priv->timeout, priv->base + WDT_TIMER); + writel(1, priv->base + WDT_SET); + + return 0; +} + +static int lsmips_wdt_stop(struct udevice *dev) +{ + struct lsmips_wdt_priv *priv = dev_get_priv(dev); + + writel(0, priv->base + WDT_EN); + return 0; +} + +static int lsmips_wdt_expire_now(struct udevice *dev, ulong flags) +{ + struct lsmips_wdt_priv *priv = dev_get_priv(dev); + + writel(1, priv->base + WDT_EN); + writel(1, priv->base + WDT_TIMER); + writel(1, priv->base + WDT_SET); + + hang(); + return 0; +} + +static int lsmips_wdt_start(struct udevice *dev, u64 timeout_ms, ulong flags) +{ + struct lsmips_wdt_priv *priv = dev_get_priv(dev); + unsigned int timeout; + const unsigned int MSEC_PER_SEC = 1000; + + timeout = U32_MAX / (priv->clock / MSEC_PER_SEC); + + if (timeout < timeout_ms) + timeout = U32_MAX; + else + timeout = timeout_ms * (priv->clock / MSEC_PER_SEC); + + debug("WDT: reload = %08x\n", timeout); + + writel(1, priv->base + WDT_EN); + writel(timeout, priv->base + WDT_TIMER); + writel(1, priv->base + WDT_SET); + + priv->timeout = timeout; + + return 0; +} + +static int lsmips_wdt_probe(struct udevice *dev) +{ + struct lsmips_wdt_priv *priv = dev_get_priv(dev); + struct clk cl; + ulong clock; + + priv->base = dev_remap_addr(dev); + if (!priv->base) + return -ENOENT; + + if (clk_get_by_index(dev, 0, &cl) == 0) + clock = clk_get_rate(&cl); + + debug("WDT: clock = %ld\n", clock); + + if (IS_ERR_VALUE(clock)) { + dev_err(dev, "failed to get rate\n"); + return clock; + } + + priv->clock = clock; + writel(0, priv->base + WDT_EN); + return 0; +} + +static const struct wdt_ops lsmips_wdt_ops = { + .start = lsmips_wdt_start, + .reset = lsmips_wdt_reset, + .stop = lsmips_wdt_stop, + .expire_now = lsmips_wdt_expire_now, +}; + +static const struct udevice_id lsmips_wdt_ids[] = { + { .compatible = "loongson,ls1c300-wdt"}, + {} +}; + +U_BOOT_DRIVER(lsmips_wdt) = { + .name = "lsmips_wdt", + .id = UCLASS_WDT, + .of_match = lsmips_wdt_ids, + .priv_auto = sizeof(struct lsmips_wdt_priv), + .probe = lsmips_wdt_probe, + .ops = &lsmips_wdt_ops, + .flags = DM_FLAG_PRE_RELOC, +};
A small description is always helpful (mandatory) in the commit text. Please add at least one or two sentences here.
+config WDT_LSMIPS
- bool "Loongson MIPS watchdog timer support"
- depends on WDT
- help
- config WDT_MAX6370 bool "MAX6370 watchdog timer support" depends on WDT
- Watchdog driver for MediaTek SoCs
- Copyright (C) 2018 MediaTek Inc.
- Author: Ryder Lee ryder.lee@mediatek.com
- based on: drivers/watchdog/mtk_wdt.c
- Copyright (C) 2020-2023 Du Huanpeng dhu@hodcarrier.org
- void __iomem *base;
- ulong clock;
- unsigned long timeout;
- struct lsmips_wdt_priv *priv = dev_get_priv(dev);
- writel(priv->timeout, priv->base + WDT_TIMER);
- writel(1, priv->base + WDT_SET);
- writel(0, priv->base + WDT_EN);
- writel(1, priv->base + WDT_EN);
- writel(1, priv->base + WDT_TIMER);
- hang();
- unsigned int timeout;
- const unsigned int MSEC_PER_SEC = 1000;
Upper case variable names are very unusual. Why not use a macro / define instead?
Nitpicking:
Reverse X-mas tree ordering of the variable declarations is preferred.
- timeout = U32_MAX / (priv->clock / MSEC_PER_SEC);
- if (timeout < timeout_ms)
timeout = U32_MAX;
- else
- debug("WDT: reload = %08x\n", timeout);
- writel(timeout, priv->base + WDT_TIMER);
- priv->timeout = timeout;
- struct clk cl;
- ulong clock;
- priv->base = dev_remap_addr(dev);
- if (!priv->base)
return -ENOENT;
- if (clk_get_by_index(dev, 0, &cl) == 0)
- debug("WDT: clock = %ld\n", clock);
- if (IS_ERR_VALUE(clock)) {
return clock;
- priv->clock = clock;
- .start = lsmips_wdt_start,
- .reset = lsmips_wdt_reset,
- .stop = lsmips_wdt_stop,
- .expire_now = lsmips_wdt_expire_now,
- { .compatible = "loongson,ls1c300-wdt"},
I was not able to find this compatible property in the Linux source tree. Is this WDT not supported there?
Thanks, Stefan
Signed-off-by: Du Huanpeng dhu@hodcarrier.org --- drivers/reset/Kconfig | 7 ++ drivers/reset/Makefile | 1 + drivers/reset/reset-lsmips.c | 118 ++++++++++++++++++++++ include/dt-bindings/reset/ls1c300-reset.h | 36 +++++++ 4 files changed, 162 insertions(+) create mode 100644 drivers/reset/reset-lsmips.c create mode 100644 include/dt-bindings/reset/ls1c300-reset.h
diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 73bbd30692..b65e2aa097 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -121,6 +121,13 @@ config RESET_SOCFPGA help Support for reset controller on SoCFPGA platform.
+config RESET_LSMIPS + bool "Reset controller driver for Loongson MIPS platform" + depends on DM_RESET && ARCH_LSMIPS + default y + help + Support for reset controller on Loongson MIPS platform. + config RESET_MEDIATEK bool "Reset controller driver for MediaTek SoCs" depends on DM_RESET && ARCH_MEDIATEK && CLK diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index e2239a250a..5a94d9f58d 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -19,6 +19,7 @@ obj-$(CONFIG_RESET_AST2600) += reset-ast2600.o obj-$(CONFIG_RESET_ROCKCHIP) += reset-rockchip.o rst-rk3588.o obj-$(CONFIG_RESET_MESON) += reset-meson.o obj-$(CONFIG_RESET_SOCFPGA) += reset-socfpga.o +obj-$(CONFIG_RESET_LSMIPS) += reset-lsmips.o obj-$(CONFIG_RESET_MEDIATEK) += reset-mediatek.o obj-$(CONFIG_RESET_MTMIPS) += reset-mtmips.o obj-$(CONFIG_RESET_SUNXI) += reset-sunxi.o diff --git a/drivers/reset/reset-lsmips.c b/drivers/reset/reset-lsmips.c new file mode 100644 index 0000000000..937aac1f4c --- /dev/null +++ b/drivers/reset/reset-lsmips.c @@ -0,0 +1,118 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 MediaTek Inc. + * + * Author: Ryder Lee ryder.lee@mediatek.com + * Weijie Gao weijie.gao@mediatek.com + * Copyright (C) 2022 Du Huanpeng dhu@hodcarrier.org + */ + +#include <common.h> +#include <dm.h> +#include <log.h> +#include <malloc.h> +#include <dm/lists.h> +#include <regmap.h> +#include <reset-uclass.h> +#include <syscon.h> +#include <dm/device-internal.h> +#include <linux/bitops.h> +#include <linux/err.h> + +struct mediatek_reset_priv { + struct regmap *regmap; + u32 regofs; + u32 nr_resets; +}; + +int regmap_update_bits(struct regmap *map, uint offset, uint mask, uint val) +{ + return 0; +} + +struct regmap *syscon_node_to_regmap(ofnode node) +{ + return NULL; +} + +static int mediatek_reset_request(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static int mediatek_reset_free(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static int mediatek_reset_assert(struct reset_ctl *reset_ctl) +{ + struct mediatek_reset_priv *priv = dev_get_priv(reset_ctl->dev); + int id = reset_ctl->id; + + if (id >= priv->nr_resets) + return -EINVAL; + + return regmap_update_bits(priv->regmap, + priv->regofs + ((id / 32) << 2), BIT(id % 32), BIT(id % 32)); +} + +static int mediatek_reset_deassert(struct reset_ctl *reset_ctl) +{ + struct mediatek_reset_priv *priv = dev_get_priv(reset_ctl->dev); + int id = reset_ctl->id; + + if (id >= priv->nr_resets) + return -EINVAL; + + return regmap_update_bits(priv->regmap, + priv->regofs + ((id / 32) << 2), BIT(id % 32), 0); +} + +struct reset_ops mediatek_reset_ops = { + .request = mediatek_reset_request, + .rfree = mediatek_reset_free, + .rst_assert = mediatek_reset_assert, + .rst_deassert = mediatek_reset_deassert, +}; + +static int mediatek_reset_probe(struct udevice *dev) +{ + struct mediatek_reset_priv *priv = dev_get_priv(dev); + + if (!priv->regofs && !priv->nr_resets) + return -EINVAL; + + priv->regmap = syscon_node_to_regmap(dev_ofnode(dev)); + if (IS_ERR(priv->regmap)) + return PTR_ERR(priv->regmap); + + return 0; +} + +int mediatek_reset_bind(struct udevice *pdev, u32 regofs, u32 num_regs) +{ + struct udevice *rst_dev; + struct mediatek_reset_priv *priv; + int ret; + + ret = device_bind_driver_to_node(pdev, "mediatek_reset", "reset", + dev_ofnode(pdev), &rst_dev); + if (ret) + return ret; + + priv = malloc(sizeof(struct mediatek_reset_priv)); + priv->regofs = regofs; + priv->nr_resets = num_regs * 32; + dev_set_priv(rst_dev, priv); + + return 0; +} + +U_BOOT_DRIVER(mediatek_reset) = { + .name = "loongson,shut_ctrl", + .id = UCLASS_RESET, + .probe = mediatek_reset_probe, + .ops = &mediatek_reset_ops, + .priv_auto = sizeof(struct mediatek_reset_priv), +}; diff --git a/include/dt-bindings/reset/ls1c300-reset.h b/include/dt-bindings/reset/ls1c300-reset.h new file mode 100644 index 0000000000..761a6f97e0 --- /dev/null +++ b/include/dt-bindings/reset/ls1c300-reset.h @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2022 Du Huanpeng dhu@hodcarrier.org + */ + +#ifndef _DT_BINDINGS_LS1C300_RESET_H_ +#define _DT_BINDINGS_LS1C300_RESET_H_ + +#define ADC_SHUT 25 +#define SDIO_SHUT 24 +#define DMA2_SHUT 23 +#define DMA1_SHUT 22 +#define DMA0_SHUT 21 +#define SPI1_SHUT 20 +#define SPI0_SHUT 19 +#define I2C2_SHUT 18 +#define I2C1_SHUT 17 +#define I2C0_SHUT 16 +#define AC97_SHUT 15 +#define I2S_SHUT 14 +#define UART3_SHUT 13 +#define UART2_SHUT 12 +#define UART1_SHUT 11 +#define UART0_SHUT 10 +#define CAN1_SHUT 9 +#define CAN0_SHUT 8 +#define ECC_SHUT 7 +#define MAC_SHUT 6 +#define USBHOST_SHUT 5 +#define USBOTG_SHUT 4 +#define SDRAM_SHUT 3 +#define SRAM_SHUT 2 +#define CAM_SHUT 1 +#define LCD_SHUT 0 + +#endif /* _DT_BINDINGS_LS1C300_RESET_H_*/
Du Huanpeng
Stefan Roese
