[PATCH v2 0/4] rockchip: Migrate to use DM_USB_GADGET on RK3328
USB gadget is not working fully as expected on RK3328, it uses a board_usb_init() function to initialize the DWC2 OTG port, as a result the USB2PHY driver never gets invoked. An issue is that the USB_DWC2 driver is enabled and also gets loaded for the OTG port. A side effect of that is that the board will freeze if USB gadget is started after USB host have been stopped, the USB2PHY driver puts the OTG port in suspend mode on exit.
To improve the situation this series changes to only enable one of USB_DWC2 (host) or DWC2_OTG (peripheral) depending on most likely usage of the port. It also migrates to use DM_USB_GADGET instead of board_usb_init().
First patch fixes and add Product ID for supported Rockchip SoCs.
Second patch prepare board.c for use of DM_USB_GADGET with DWC2_OTG.
Third patch add a g_dnl_bind_fixup() to configure a different Product ID when UMS is used.
Final patch updates u-boot.dtsi and defconfigs to only use USB_DWC2 for host or migrate to use DM_USB_GADGET with DWC2_OTG for peripheral. UMS and ROCKUSB is enabled for all boards with otg port in peripheral mode.
Hopefully current incompatibility between having USB_DWC2, DWC2_OTG and USB_DWC3_GADGET enabled together is something that could be improved on in a future series.
Following have been tested on a Rock64, ROC-RK3328-CC, Rock Pi E and Orange Pi R1 Plus LTS: - USB host on all host ports: usb start && usb tree && usb stop - UMS on otg port: ums 0 mmc 1 - RockUSB on otg port: rockusb 0 mmc 1
Changes in v2: - Drop use of DWC3_GENERIC and revert to use XHCI_DWC3 for USB 3.0 host for devices using another port with otg/peripheral dr_mode to work around build errors when mixing DWC3_GENERIC and DWC2_OTG. - Above change means this series can drop a rejected depends that tried to fix above build error. - Collect r-b tags
This series depends on the following series: - rockchip: rk3328: Update defconfigs, DTs and enable boot from SPI [1] - rockchip: Read cpuid and generate MAC address from efuse for RK3328 and RK3399 [2] - phy: rockchip-inno-usb2: Write to correct GRF [3]
The copy of the series and all its depends can also be found at [4].
[1] https://patchwork.ozlabs.org/cover/1900345/ [2] https://patchwork.ozlabs.org/cover/1897743/ [3] https://patchwork.ozlabs.org/cover/1903987/ [4] https://github.com/Kwiboo/u-boot-rockchip/commits/rk3328-gadget-v2
Jonas Karlman (4): rockchip: Update the default USB Product ID value rockchip: board: Prepare for use of DM_USB_GADGET with DWC2_OTG rockchip: board: Use a common USB Product ID for UMS rockchip: Migrate to use DM_USB_GADGET on RK3328
arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi | 4 ++ .../rk3328-orangepi-r1-plus-lts-u-boot.dtsi | 4 ++ .../dts/rk3328-orangepi-r1-plus-u-boot.dtsi | 4 ++ arch/arm/dts/rk3328-roc-cc-u-boot.dtsi | 4 ++ arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi | 9 ++++ arch/arm/dts/rk3328-rock64-u-boot.dtsi | 4 ++ arch/arm/dts/rk3328-u-boot.dtsi | 4 -- arch/arm/dts/rk3328.dtsi | 41 ++++++++----------- arch/arm/mach-rockchip/board.c | 19 ++++++++- configs/evb-rk3328_defconfig | 7 +++- configs/nanopi-r2c-plus-rk3328_defconfig | 7 +++- configs/nanopi-r2c-rk3328_defconfig | 7 +++- configs/nanopi-r2s-rk3328_defconfig | 7 +++- configs/orangepi-r1-plus-lts-rk3328_defconfig | 7 +++- configs/orangepi-r1-plus-rk3328_defconfig | 7 +++- configs/roc-cc-rk3328_defconfig | 7 ---- configs/rock-pi-e-rk3328_defconfig | 7 ---- configs/rock64-rk3328_defconfig | 6 --- drivers/usb/gadget/Kconfig | 15 +++++-- 19 files changed, 105 insertions(+), 65 deletions(-)
RK3036 is using the USB product id normally used by RK3066B, and RK3328 is using the product id normally used by RK3368.
Fix this and update the default USB_GADGET_PRODUCT_NUM Kconfig option for remaining supported Rockchip SoCs to match the product id used in Maskrom mode.
Also remove a reference to an undefined ROCKCHIP_RK3229 Kconfig symbol.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v2: - Update commit message --- drivers/usb/gadget/Kconfig | 15 ++++++++++++--- 1 file changed, 12 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index c72a8047635c..4621a6fd5e64 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -70,12 +70,21 @@ config USB_GADGET_PRODUCT_NUM hex "Product ID of the USB device" default 0x701a if ARCH_TEGRA default 0x1010 if ARCH_SUNXI - default 0x310a if ROCKCHIP_RK3036 + default 0x110a if ROCKCHIP_RV1108 + default 0x110b if ROCKCHIP_RV1126 default 0x300a if ROCKCHIP_RK3066 + default 0x301a if ROCKCHIP_RK3036 + default 0x310b if ROCKCHIP_RK3188 default 0x310c if ROCKCHIP_RK3128 - default 0x320a if ROCKCHIP_RK3229 || ROCKCHIP_RK3288 - default 0x330a if ROCKCHIP_RK3328 + default 0x320a if ROCKCHIP_RK3288 + default 0x320b if ROCKCHIP_RK322X + default 0x320c if ROCKCHIP_RK3328 + default 0x330a if ROCKCHIP_RK3368 default 0x330c if ROCKCHIP_RK3399 + default 0x330d if ROCKCHIP_PX30 + default 0x330e if ROCKCHIP_RK3308 + default 0x350a if ROCKCHIP_RK3568 + default 0x350b if ROCKCHIP_RK3588 default 0x0 help Product ID of the USB device emulated, reported to the host device.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
v2:
- default 0x110a if ROCKCHIP_RV1108
- default 0x110b if ROCKCHIP_RV1126 default 0x300a if ROCKCHIP_RK3066
- default 0x301a if ROCKCHIP_RK3036
- default 0x310b if ROCKCHIP_RK3188 default 0x310c if ROCKCHIP_RK3128
- default 0x320a if ROCKCHIP_RK3288
- default 0x320b if ROCKCHIP_RK322X
- default 0x320c if ROCKCHIP_RK3328
- default 0x330a if ROCKCHIP_RK3368 default 0x330c if ROCKCHIP_RK3399
- default 0x330d if ROCKCHIP_PX30
- default 0x330e if ROCKCHIP_RK3308
- default 0x350a if ROCKCHIP_RK3568
- default 0x350b if ROCKCHIP_RK3588 default 0x0 help Product ID of the USB device emulated, reported to the host device.
The board_usb_init() and board_usb_cleanup() functions is always included when USB_GADGET and USB_GADGET_DWC2_OTG is enabled.
Prepare for a change to use DM_USB_GADGET with DWC2_OTG by adding an extra ifdef condition. The extra separate ifdef for USB_GADGET prepare for next patch that adds a g_dnl_bind_fixup() function.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - No change - Collect r-b tag --- arch/arm/mach-rockchip/board.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/board.c b/arch/arm/mach-rockchip/board.c index dea5805c4665..f84ff542aea9 100644 --- a/arch/arm/mach-rockchip/board.c +++ b/arch/arm/mach-rockchip/board.c @@ -220,7 +220,8 @@ void enable_caches(void) } #endif
-#if defined(CONFIG_USB_GADGET) && defined(CONFIG_USB_GADGET_DWC2_OTG) +#if IS_ENABLED(CONFIG_USB_GADGET) +#if IS_ENABLED(CONFIG_USB_GADGET_DWC2_OTG) && !IS_ENABLED(CONFIG_DM_USB_GADGET) #include <usb.h> #include <linux/usb/otg.h> #include <usb/dwc2_udc.h> @@ -296,6 +297,7 @@ int board_usb_cleanup(int index, enum usb_init_type init) return 0; } #endif /* CONFIG_USB_GADGET_DWC2_OTG */ +#endif /* CONFIG_USB_GADGET */
#if IS_ENABLED(CONFIG_FASTBOOT) int fastboot_set_reboot_flag(enum fastboot_reboot_reason reason)
Change to use the common Product ID 0x0010 when the ums command is used.
This matches downstream vendor U-Boot and is a Product ID that tools such as rkdeveloptool and RKDevTool will identify as MSC mode.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - No change - Collect r-b tag --- arch/arm/mach-rockchip/board.c | 17 ++++++++++++++++- 1 file changed, 16 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/board.c b/arch/arm/mach-rockchip/board.c index f84ff542aea9..e9cfba756639 100644 --- a/arch/arm/mach-rockchip/board.c +++ b/arch/arm/mach-rockchip/board.c @@ -221,8 +221,23 @@ void enable_caches(void) #endif
#if IS_ENABLED(CONFIG_USB_GADGET) -#if IS_ENABLED(CONFIG_USB_GADGET_DWC2_OTG) && !IS_ENABLED(CONFIG_DM_USB_GADGET) #include <usb.h> + +#if IS_ENABLED(CONFIG_USB_GADGET_DOWNLOAD) +#define ROCKCHIP_G_DNL_UMS_PRODUCT_NUM 0x0010 + +int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) +{ + if (!strcmp(name, "usb_dnl_ums")) + put_unaligned(ROCKCHIP_G_DNL_UMS_PRODUCT_NUM, &dev->idProduct); + else + put_unaligned(CONFIG_USB_GADGET_PRODUCT_NUM, &dev->idProduct); + + return 0; +} +#endif /* CONFIG_USB_GADGET_DOWNLOAD */ + +#if IS_ENABLED(CONFIG_USB_GADGET_DWC2_OTG) && !IS_ENABLED(CONFIG_DM_USB_GADGET) #include <linux/usb/otg.h> #include <usb/dwc2_udc.h>
USB gadget is not working fully as expected on RK3328, it uses a board_usb_init() function to initialize the DWC2 OTG port.
The board_usb_init() function does not intgrate with the generic phy framework and as a result the USB phy is not properly configured before or after USB gadget use.
Having both USB_DWC2 and DWC2_OTG enabled for the same board is also causing some issues.
Trying to use rockusb or ums command after usb stop result in a freeze due to usb stop is putting the phy in a suspended state.
=> usb start => usb stop => ums 0 mmc 0 --> freeze due to usb phy is suspended <--
Fix this by only using one of USB_DWC2 (host) or DWC2_OTG (peripheral) depending on the most likely usage of the otg port and by migrating to use DM_USB_GADGET instead of a board_usb_init() function.
The nanopi-r2 and orangepi-r1-plus variants share OTG and power using a Type-C connector, mark these boards dr_mode as peripheral, the most likely usage is for recovery and image download.
The rock64 and roc-cc currently use dr_mode as host, remove the DWC2_OTG driver from these boards to ensure that the USB_DWC2 driver is used.
The rock-pi-e board does not enable the usb20_otg node so both USB_DWC2 and DWC2_OTG is removed from this board.
Enable RockUSB and UMS on all boards with a otg port in peripheral mode.
Also with the migration to DM_USB_GADGET completed the U-Boot specific change to reorder usb nodes in the soc device tree can be reverted.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Drop use of DWC3_GENERIC and revert to use XHCI_DWC3 for USB 3.0 host for devices using another port with otg/peripheral dr_mode to work around build errors when mixing DWC3_GENERIC and DWC2_OTG. - Collect r-b tag --- arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi | 4 ++ .../rk3328-orangepi-r1-plus-lts-u-boot.dtsi | 4 ++ .../dts/rk3328-orangepi-r1-plus-u-boot.dtsi | 4 ++ arch/arm/dts/rk3328-roc-cc-u-boot.dtsi | 4 ++ arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi | 9 ++++ arch/arm/dts/rk3328-rock64-u-boot.dtsi | 4 ++ arch/arm/dts/rk3328-u-boot.dtsi | 4 -- arch/arm/dts/rk3328.dtsi | 41 ++++++++----------- configs/evb-rk3328_defconfig | 7 +++- configs/nanopi-r2c-plus-rk3328_defconfig | 7 +++- configs/nanopi-r2c-rk3328_defconfig | 7 +++- configs/nanopi-r2s-rk3328_defconfig | 7 +++- configs/orangepi-r1-plus-lts-rk3328_defconfig | 7 +++- configs/orangepi-r1-plus-rk3328_defconfig | 7 +++- configs/roc-cc-rk3328_defconfig | 7 ---- configs/rock-pi-e-rk3328_defconfig | 7 ---- configs/rock64-rk3328_defconfig | 6 --- 17 files changed, 75 insertions(+), 61 deletions(-)
diff --git a/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi index cca4f06145cf..4fa170eeaf8d 100644 --- a/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi +++ b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi @@ -15,6 +15,10 @@ bootph-all; };
+&usb20_otg { + dr_mode = "peripheral"; +}; + &vcc_io_sdio { bootph-pre-ram; }; diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi b/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi index 0dbe5a01f986..0a9423cd9c7e 100644 --- a/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi +++ b/arch/arm/dts/rk3328-orangepi-r1-plus-lts-u-boot.dtsi @@ -33,6 +33,10 @@ bootph-pre-ram; };
+&usb20_otg { + dr_mode = "peripheral"; +}; + &vcc_sd { bootph-pre-ram; }; diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi b/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi index 1af75ada1a62..1096821fc5d3 100644 --- a/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi +++ b/arch/arm/dts/rk3328-orangepi-r1-plus-u-boot.dtsi @@ -33,6 +33,10 @@ bootph-pre-ram; };
+&usb20_otg { + dr_mode = "peripheral"; +}; + &vcc_sd { bootph-pre-ram; }; diff --git a/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi b/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi index 47d74964fd0c..582d6ba49b4e 100644 --- a/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi +++ b/arch/arm/dts/rk3328-roc-cc-u-boot.dtsi @@ -29,6 +29,10 @@ }; };
+&usb20_otg { + hnp-srp-disable; +}; + &vcc_sd { bootph-pre-ram; }; diff --git a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi b/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi index 9ed0aef1ecc9..d314bfad6fc0 100644 --- a/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock-pi-e-u-boot.dtsi @@ -29,6 +29,15 @@ }; };
+&u2phy_host { + phy-supply = <&vcc_host_5v>; +}; + +&vcc_host_5v { + /delete-property/ regulator-always-on; + /delete-property/ regulator-boot-on; +}; + &vcc_sd { bootph-pre-ram; }; diff --git a/arch/arm/dts/rk3328-rock64-u-boot.dtsi b/arch/arm/dts/rk3328-rock64-u-boot.dtsi index 85426495c3d8..551cff6f24f6 100644 --- a/arch/arm/dts/rk3328-rock64-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock64-u-boot.dtsi @@ -55,6 +55,10 @@ bootph-pre-ram; };
+&usb20_otg { + hnp-srp-disable; +}; + &vcc_sd { bootph-pre-ram; }; diff --git a/arch/arm/dts/rk3328-u-boot.dtsi b/arch/arm/dts/rk3328-u-boot.dtsi index 4d43fe2fb51a..e0c6aee58aba 100644 --- a/arch/arm/dts/rk3328-u-boot.dtsi +++ b/arch/arm/dts/rk3328-u-boot.dtsi @@ -130,10 +130,6 @@ bootph-all; };
-&usb20_otg { - hnp-srp-disable; -}; - #ifdef CONFIG_ROCKCHIP_SPI_IMAGE &binman { simple-bin-spi { diff --git a/arch/arm/dts/rk3328.dtsi b/arch/arm/dts/rk3328.dtsi index fe81b97bbe78..fb5dcf6e9327 100644 --- a/arch/arm/dts/rk3328.dtsi +++ b/arch/arm/dts/rk3328.dtsi @@ -965,6 +965,22 @@ }; };
+ usb20_otg: usb@ff580000 { + compatible = "rockchip,rk3328-usb", "rockchip,rk3066-usb", + "snps,dwc2"; + reg = <0x0 0xff580000 0x0 0x40000>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_OTG>; + clock-names = "otg"; + dr_mode = "otg"; + g-np-tx-fifo-size = <16>; + g-rx-fifo-size = <280>; + g-tx-fifo-size = <256 128 128 64 32 16>; + phys = <&u2phy_otg>; + phy-names = "usb2-phy"; + status = "disabled"; + }; + usb_host0_ehci: usb@ff5c0000 { compatible = "generic-ehci"; reg = <0x0 0xff5c0000 0x0 0x10000>; @@ -1004,31 +1020,6 @@ status = "disabled"; };
- /* - * U-Boot Specific Change - * - * The OTG controller must come after the USB host pair for it - * to work. This is likely due to lack of support for the USB - * PHYs. This must be manually changed after each device tree - * sync. There is no clean way to handle this in -u-boot.dtsi - * files. - */ - usb20_otg: usb@ff580000 { - compatible = "rockchip,rk3328-usb", "rockchip,rk3066-usb", - "snps,dwc2"; - reg = <0x0 0xff580000 0x0 0x40000>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_OTG>; - clock-names = "otg"; - dr_mode = "otg"; - g-np-tx-fifo-size = <16>; - g-rx-fifo-size = <280>; - g-tx-fifo-size = <256 128 128 64 32 16>; - phys = <&u2phy_otg>; - phy-names = "usb2-phy"; - status = "disabled"; - }; - gic: interrupt-controller@ff811000 { compatible = "arm,gic-400"; #interrupt-cells = <3>; diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 4fa8a7d365a4..75a0e0f286bd 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_CMD_REGULATOR=y @@ -83,17 +85,18 @@ CONFIG_SYSINFO=y CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set -CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_FUNCTION_ROCKUSB=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/nanopi-r2c-plus-rk3328_defconfig b/configs/nanopi-r2c-plus-rk3328_defconfig index 5302fd91a0f5..beef682a582e 100644 --- a/configs/nanopi-r2c-plus-rk3328_defconfig +++ b/configs/nanopi-r2c-plus-rk3328_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_CMD_REGULATOR=y @@ -90,17 +92,18 @@ CONFIG_SYSINFO=y CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set -CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_FUNCTION_ROCKUSB=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/nanopi-r2c-rk3328_defconfig b/configs/nanopi-r2c-rk3328_defconfig index 5a722c182631..8960c1afaba5 100644 --- a/configs/nanopi-r2c-rk3328_defconfig +++ b/configs/nanopi-r2c-rk3328_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_CMD_REGULATOR=y @@ -90,17 +92,18 @@ CONFIG_SYSINFO=y CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set -CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_FUNCTION_ROCKUSB=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig index 985d02475ece..96e67e248d32 100644 --- a/configs/nanopi-r2s-rk3328_defconfig +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_CMD_REGULATOR=y @@ -90,17 +92,18 @@ CONFIG_SYSINFO=y CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set -CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_FUNCTION_ROCKUSB=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/orangepi-r1-plus-lts-rk3328_defconfig b/configs/orangepi-r1-plus-lts-rk3328_defconfig index e9f7a1306923..5fbbd5fc6558 100644 --- a/configs/orangepi-r1-plus-lts-rk3328_defconfig +++ b/configs/orangepi-r1-plus-lts-rk3328_defconfig @@ -38,6 +38,8 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_CMD_REGULATOR=y @@ -100,17 +102,18 @@ CONFIG_SYSINFO=y CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set -CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_FUNCTION_ROCKUSB=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/orangepi-r1-plus-rk3328_defconfig b/configs/orangepi-r1-plus-rk3328_defconfig index 6019f33ae3f5..c5afe5ea6e5c 100644 --- a/configs/orangepi-r1-plus-rk3328_defconfig +++ b/configs/orangepi-r1-plus-rk3328_defconfig @@ -38,6 +38,8 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_CMD_REGULATOR=y @@ -100,17 +102,18 @@ CONFIG_SYSINFO=y CONFIG_SYSRESET=y # CONFIG_TPL_SYSRESET is not set CONFIG_USB=y +CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y # CONFIG_USB_DWC3_GADGET is not set -CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_FUNCTION_ROCKUSB=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig index 191dbff928bb..6526d2606e72 100644 --- a/configs/roc-cc-rk3328_defconfig +++ b/configs/roc-cc-rk3328_defconfig @@ -13,7 +13,6 @@ CONFIG_DEBUG_UART_BASE=0xFF130000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y -# CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_SIGNATURE=y @@ -34,7 +33,6 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_POWEROFF=y CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_CMD_REGULATOR=y @@ -55,8 +53,6 @@ CONFIG_SPL_SYSCON=y CONFIG_TPL_SYSCON=y CONFIG_CLK=y CONFIG_SPL_CLK=y -CONFIG_FASTBOOT_BUF_ADDR=0x800800 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y @@ -97,10 +93,7 @@ CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y -# CONFIG_USB_DWC3_GADGET is not set CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index e4f2123e0b17..23029255bca2 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -13,7 +13,6 @@ CONFIG_DEBUG_UART_BASE=0xFF130000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y -# CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_SIGNATURE=y @@ -52,8 +51,6 @@ CONFIG_SPL_SYSCON=y CONFIG_TPL_SYSCON=y CONFIG_CLK=y CONFIG_SPL_CLK=y -CONFIG_FASTBOOT_BUF_ADDR=0x800800 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y @@ -92,12 +89,8 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y -CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y -# CONFIG_USB_DWC3_GADGET is not set CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index f38431891bf8..b0be1d1d7633 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -16,7 +16,6 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y -# CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_SIGNATURE=y @@ -59,8 +58,6 @@ CONFIG_SPL_SYSCON=y CONFIG_TPL_SYSCON=y CONFIG_CLK=y CONFIG_SPL_CLK=y -CONFIG_FASTBOOT_BUF_ADDR=0x800800 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y @@ -106,10 +103,7 @@ CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_DWC3=y -# CONFIG_USB_DWC3_GADGET is not set CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y
Hi Jonas,
Again, not able to apply changes for rk3328 defconfig.
Thanks,
- Kever
v2:
- Collect r-b tag
+&usb20_otg {
- dr_mode = "peripheral";
- &vcc_io_sdio { bootph-pre-ram; };
+&usb20_otg {
- &vcc_sd { bootph-pre-ram; };
+&usb20_otg {
+&usb20_otg {
- hnp-srp-disable;
+&u2phy_host {
- phy-supply = <&vcc_host_5v>;
+&vcc_host_5v {
- /delete-property/ regulator-always-on;
- /delete-property/ regulator-boot-on;
+&usb20_otg {
- hnp-srp-disable;
-&usb20_otg {
- hnp-srp-disable;
"snps,dwc2";
dr_mode = "otg";
- usb_host0_ehci: usb@ff5c0000 { compatible = "generic-ehci"; reg = <0x0 0xff5c0000 0x0 0x10000>;
* files.
"snps,dwc2";
dr_mode = "otg";
Hi Kever,
On 2024-03-13 11:45, Kever Yang wrote:
Hi Jonas,
As mentioned in the cover letter, this series depends on the "rockchip: rk3328: Update defconfigs, DTs and enable boot from SPI" [1] series for a clean apply.
That series should also fix the following build error [2] seen in your for-next branch:
aarch64-linux-ld.bfd: drivers/misc/rockchip-efuse.o: in function `rockchip_efuse_of_to_plat': drivers/misc/rockchip-efuse.c:273:(.text.rockchip_efuse_of_to_plat+0x1c): undefined reference to `dev_read_addr_ptr' drivers/misc/rockchip-efuse.c:273:(.text.rockchip_efuse_of_to_plat+0x1c): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `dev_read_addr_ptr'
[1] https://patchwork.ozlabs.org/cover/1900345/ [2] https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/jobs/797813
Regards, Jonas
Thanks,
- Kever
v2:
- Collect r-b tag
+&usb20_otg {
+&usb20_otg {
+&usb20_otg {
+&usb20_otg {
- hnp-srp-disable;
+&u2phy_host {
+&vcc_host_5v {
+&usb20_otg {
- hnp-srp-disable;
-&usb20_otg {
- hnp-srp-disable;
"snps,dwc2";
dr_mode = "otg";
* files.
"snps,dwc2";
dr_mode = "otg";
Jonas Karlman
Kever Yang
