[U-Boot] [PATCH] kirkwood_egiga: bugfix: add DMA sequence points
Insert isb() sequence points to ensure DMA descriptors are filled in and set up before actual DMA occurs.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- drivers/net/kirkwood_egiga.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/net/kirkwood_egiga.c b/drivers/net/kirkwood_egiga.c index 932792e..9eca2f3 100644 --- a/drivers/net/kirkwood_egiga.c +++ b/drivers/net/kirkwood_egiga.c @@ -447,6 +447,8 @@ static int kwgbe_init(struct eth_device *dev)
/* Assignment of Rx CRDB of given RXUQ */ KWGBEREG_WR(regs->rxcdp[RXUQ], (u32) dkwgbe->p_rxdesc_curr); + /* ensure previous write is done before enabling Rx DMA */ + isb(); /* Enable port Rx. */ KWGBEREG_WR(regs->rqc, (1 << RXUQ));
@@ -536,6 +538,9 @@ static int kwgbe_send(struct eth_device *dev, volatile void *dataptr, p_txdesc->buf_ptr = (u8 *) p; p_txdesc->byte_cnt = datasize;
+ /* ensure tx desc writes above are performed before we start Tx DMA */ + isb(); + /* Apply send command using zeroth TXUQ */ KWGBEREG_WR(regs->tcqdp[TXUQ], (u32) p_txdesc); KWGBEREG_WR(regs->tqc, (1 << TXUQ));
Please disregard. I have misplaced the second isb().
- /* ensure tx desc writes above are performed before we start Tx DMA */
- isb();
- /* Apply send command using zeroth TXUQ */ KWGBEREG_WR(regs->tcqdp[TXUQ], (u32) p_txdesc); KWGBEREG_WR(regs->tqc, (1<< TXUQ));
It should actually apprear right before the write to tqc.
Resending correct patch.
Amicalement,
Albert ARIBAUD
Albert Aribaud
