Multi-Soc binary support for i.MX8M Mini/Nano/Plus/? in single boot firmware binary
Greetings,
I support various iMX8M PCB's via board/gateworks/venice that are SOM based and we are starting to add SOM's that have different IMX8M variant SoC's on them which for various reasons are not binary compatible. I'm very interested in coming up with a way to make them binary compatible to reduce the number of disk images and boot firmware binaries our users work with (along with the confusion of which one they need to use).
From what I see in working thus far with the IMX8M Mini, Nano, and Plus
boot firmware differs in the following ways: - different primary image offsets - different dram config (phy training blob, phy cfg, cfg; which total about 3KiB for each config which varies based on dram type, soc variant, dram topology and bit-mapping) - different OCRAM sizes (compat binary would have to use the minimum size ie 256K) - different ATF binaries - different ATF load address - different pinmux/padconf/inputsel registers - different clk config
The primary image offsets should be able to be dealt with by placing jumps at the various offsets and I believe the rest could be dealt with via runtime code if the SPL could load soc-specific blobs including dram config, ATF, binary firmware blobs from a nice indexed image such as FIT or binman. Currently imx8m SPL's use FIT images that are loaded entirely into OCRAM which becomes an issue when you have enough dram configs that they no longer fit in the OCRAM.
Does anyone agree this is doable or is there something they see that would be a show-stopper?
I'm not all that familiar with the merits of binman fs FIT images... I think they were developed for different things. I'm not sure if either/both are suited for what I'm talking about regarding having the SPL raw load binary blobs vs having them tacked onto a FIT image.
I'm not sure if the imx8mq has enough in common to be able to do this with either, in fact I'm not even clear with SoC that is (is it what NXP calls i.MX 8M?)
Tim
Hi Tim,
On Thu, 27 May 2021 at 09:41, Tim Harvey tharvey@gateworks.com wrote:
Greetings,
From what I see in working thus far with the IMX8M Mini, Nano, and Plus boot firmware differs in the following ways:
It is possible so long as you don't mind a larger image.
Either or both. Binman lets you access the location of things without any parsing overhead in SPL but once you get to U-Boot proper, you might be better off with FIT. In any case, binman can produce the final image.
You might also consider whether you want to produce one image for each variant, but with the U-Boot binaries the same in all cases. So the same SPL binary could work on all boards, accessing things it needs via binman or FIT. Then at least you have a packaging problem, rather than a build problem.
Another option is to have multiple SPLs and a single U-Boot.
It is a shame that there are multiple TF-A binaries. The inability to take advantage of common features is one of the many things I dislike about binaries. We have this problem in spades on the Intel side.
Hi Tim,
On 27.05.21 17:41, Tim Harvey wrote:
Greetings,
This could be a very nice feature that we had before with i.MX6.
Right - we have different DDR firmware, and this should be managed in some way.
size ie 256K)
We had this also with i.MX6 - the multibinary approach should work with the minimal OCRAM, as it was with MX6(Solo).
Last twos can be solved via detection of CPus and loading different setup and/or different DTs.
Right - but the trick is to detect the right blob to be loaded. We get offset / size in the fitImage for each blob, so we could just load the relevant part in OCRAM. But I do not know how this matches with secure boot, because HAB should verify the image before loading it.
I think it is doable, not easy, and it will be a nice feature, and very important for board vendors (as gateworks). I understand that most custom projects (products) will chose just one variant, but there also cases of real products that was delivered as "lite" and "pro", with different SOCs.
I think so - I will tend to work with fitImage, and I think it suits for these needs if the issues with the size of OCRAM are solved (like a partial or selective load).
Someone from NXP should better explain this ;-)
Best regards, Stefano
Tim
On 2021/5/27 23:41, Tim Harvey wrote:
Greetings,
size ie 256K)
i.MX8MQ not have enough OCRAM for this case. SPL already use TCM here.
Regards, Peng.
Tim
Greetings,
size ie 256K)
Peng,
Could you please explain what SoC you are referring to by 'i.MX8MQ'? I don't see that on https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/...
Is this what NXP calls the 'i.MX 8M'?
Tim
Peng Fan (OSS)
Stefano Babic
Tim Harvey
