[U-Boot] [PATCH] ARM: tegra: Build warning fixes for 64-bit
Signed-off-by: Thierry Reding treding@nvidia.com Signed-off-by: Tom Warren twarren@nvidia.com [swarren, stripped out changes not strictly related to warnings] Signed-off-by: Stephen Warren swarren@nvidia.com --- Tom, if you look at https://github.com/swarren/u-boot/tree/t210-testing you'll see commit "ARM: tegra: parts of 64-bit port". Those changes were originally included in Thierry's version of this patch, but aren't strictly related to build warnings. I separated them out to keep warning fixes and 64-bit support separate. I think you should squash "ARM: tegra: parts of 64-bit port" into your T210 support series. Does that seem reasonable?
arch/arm/mach-tegra/ap.c | 4 ++-- arch/arm/mach-tegra/pinmux-common.c | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-tegra/ap.c b/arch/arm/mach-tegra/ap.c index 0b94e8aaf9c3..7b89c0107196 100644 --- a/arch/arm/mach-tegra/ap.c +++ b/arch/arm/mach-tegra/ap.c @@ -131,8 +131,8 @@ static u32 get_odmdata(void) * on BCTs for currently supported SoCs, which are locked down. * If this changes in new chips, we can revisit this algorithm. */ - - u32 bct_start, odmdata; + unsigned long bct_start; + u32 odmdata;
bct_start = readl(NV_PA_BASE_SRAM + NVBOOTINFOTABLE_BCTPTR); odmdata = readl(bct_start + BCT_ODMDATA_OFFSET); diff --git a/arch/arm/mach-tegra/pinmux-common.c b/arch/arm/mach-tegra/pinmux-common.c index b4a1432afcb1..5862c4ac3dc6 100644 --- a/arch/arm/mach-tegra/pinmux-common.c +++ b/arch/arm/mach-tegra/pinmux-common.c @@ -78,7 +78,7 @@ (((hsm) >= PMUX_HSM_DISABLE) && ((hsm) <= PMUX_HSM_ENABLE)) #endif
-#define _R(offset) (u32 *)(NV_PA_APB_MISC_BASE + (offset)) +#define _R(offset) (u32 *)((unsigned long)NV_PA_APB_MISC_BASE + (offset))
#if defined(CONFIG_TEGRA20)
Stephen Warren
