[U-Boot] [PATCH 1/2] sunxi: fix CONFIG_SUNXI_EMAC references
fixes CONFIG_SUNXI_EMAC references from drivers/net/Makefile and include/configs/sunxi-common.h likely forgotten in: commit abc3e4df59f5 ("sunxi: Convert SUNXI_EMAC to Kconfig")
Signed-off-by: Artturi Alm artturi.alm@gmail.com ---
drivers/net/Makefile | 2 +- include/configs/sunxi-common.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 94a4fd8..ac5443c 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -21,7 +21,7 @@ obj-$(CONFIG_DNET) += dnet.o obj-$(CONFIG_E1000) += e1000.o obj-$(CONFIG_E1000_SPI) += e1000_spi.o obj-$(CONFIG_EEPRO100) += eepro100.o -obj-$(CONFIG_SUNXI_EMAC) += sunxi_emac.o +obj-$(CONFIG_SUN4I_EMAC) += sunxi_emac.o obj-$(CONFIG_SUN8I_EMAC) += sun8i_emac.o obj-$(CONFIG_ENC28J60) += enc28j60.o obj-$(CONFIG_EP93XX) += ep93xx_eth.o diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 4207398..4391a8c 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -286,7 +286,7 @@ extern int soft_i2c_gpio_scl; #endif /* CONFIG_VIDEO_SUNXI */
/* Ethernet support */ -#ifdef CONFIG_SUNXI_EMAC +#ifdef CONFIG_SUN4I_EMAC #define CONFIG_PHY_ADDR 1 #define CONFIG_MII /* MII PHY management */ #endif
due misnaming of CONFIG_SUN4I_EMAC in include/configs/sunxi-common.h, likely missed in: commit 3146f0c017df ("Move PHYLIB to Kconfig")
drivers/net/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index c1ce54e..52555da 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -247,6 +247,7 @@ config SUN7I_GMAC config SUN4I_EMAC bool "Allwinner Sun4i Ethernet MAC support" depends on DM_ETH + select PHYLIB help This driver supports the Allwinner based SUN4I Ethernet MAC.
Reviewed-by: Jagan Teki jagan@openedev.com
thanks!
Applied to u-boot-sunxi/master
thanks!
Artturi Alm
Jagan Teki
