[U-Boot] [PATCH 0/3] PPC 85xx: Add support for QEMU's ppce500 PV machine
In QEMU we implement a PV machine type called "ppce500". That board is able to run any e500+ FSL cores (e500v2, e500mc, e5500, e6500).
It is heavily inspired by the MPC8544DS SoC and board combination, but implements only the bare minimum to make Linux happy enough to drive a virtual machine.
This patch set implements support for this PV machine type in U-Boot, enabling users to run their virtual machines with netboot, u-boot payload binaries or other fun things they come up with.
Alexander Graf (3): PPC 85xx: Detect e500v2 / e500mc during runtime PPC 85xx: Add ELF entry point PPC 85xx: Add qemu-ppce500 machine
arch/powerpc/cpu/mpc85xx/fixed_ivor.S | 21 ++- arch/powerpc/cpu/mpc85xx/start.S | 7 + arch/powerpc/cpu/mpc85xx/u-boot.lds | 1 + arch/powerpc/include/asm/config_mpc85xx.h | 4 + board/freescale/qemu-ppce500/Makefile | 10 ++ board/freescale/qemu-ppce500/qemu-ppce500.c | 260 +++++++++++++++++++++++++++ board/freescale/qemu-ppce500/tlb.c | 59 ++++++ boards.cfg | 1 + include/configs/qemu-ppce500.h | 235 ++++++++++++++++++++++++ 9 files changed, 593 insertions(+), 5 deletions(-) create mode 100644 board/freescale/qemu-ppce500/Makefile create mode 100644 board/freescale/qemu-ppce500/qemu-ppce500.c create mode 100644 board/freescale/qemu-ppce500/tlb.c create mode 100644 include/configs/qemu-ppce500.h
With the qemu-ppce500 machine type we can run the same board with either an e500v2 or an e500mc core plugged in.
This means that the IVOR setup can't be based on compile time decisions, so instead we have to do a runtime check which CPU generation we're running on.
Signed-off-by: Alexander Graf agraf@suse.de --- arch/powerpc/cpu/mpc85xx/fixed_ivor.S | 21 ++++++++++++++++----- 1 file changed, 16 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fixed_ivor.S b/arch/powerpc/cpu/mpc85xx/fixed_ivor.S index ebbb8c0..635a97e 100644 --- a/arch/powerpc/cpu/mpc85xx/fixed_ivor.S +++ b/arch/powerpc/cpu/mpc85xx/fixed_ivor.S @@ -36,17 +36,25 @@ SET_IVOR(14, 0x1e0) /* Instruction TLB Error */ SET_IVOR(15, 0x040) /* Debug */
-/* e500v1 & e500v2 only */ -#ifndef CONFIG_E500MC + /* Check for CPU */ + mfpvr r3 + srwi r3, r3, 16 + /* Compare with e500mc PVR major number */ + li r4, 0 + ori r4, r4, 0x8023 + cmpw r3, r4 + + /* e500v1 & e500v2 only */ + bge 1f SET_IVOR(32, 0x200) /* SPE Unavailable */ SET_IVOR(33, 0x220) /* Embedded FP Data */ SET_IVOR(34, 0x240) /* Embedded FP Round */ -#endif +1:
SET_IVOR(35, 0x260) /* Performance monitor */
-/* e500mc only */ -#ifdef CONFIG_E500MC + /* e500mc only */ + blt 2f SET_IVOR(36, 0x280) /* Processor doorbell */ SET_IVOR(37, 0x2a0) /* Processor doorbell critical */ SET_IVOR(38, 0x2c0) /* Guest Processor doorbell */ @@ -54,6 +62,8 @@ SET_IVOR(40, 0x300) /* Hypervisor system call */ SET_IVOR(41, 0x320) /* Hypervisor Priviledge */
+#ifndef CONFIG_QEMU_E500 + /* QEMU guests runs in guest mode and can't access GIVORs */ SET_GIVOR(2, 0x060) /* Guest Data Storage */ SET_GIVOR(3, 0x080) /* Guest Instruction Storage */ SET_GIVOR(4, 0x0a0) /* Guest External Input */ @@ -61,3 +71,4 @@ SET_GIVOR(13, 0x1c0) /* Guest Data TLB Error */ SET_GIVOR(14, 0x1e0) /* Guest Instruction TLB Error */ #endif +2:
Is this really the only place where you ran into this?
Also consider that you'll be adding extra size, and some of our 85xx targets are pretty close to the limit as is (though at least this code isn't used in SPLs).
I guess nobody ever bothered to set IVORs for e6500-specific exceptions.
For that matter, I don't see why we need this code at all. These aren't the addresses that U-Boot keeps its exception vectors at; it's setting them up for the OS, apparently trying to imitate some other type of book3e chip that has fixed ivors. Apparently U-Boot has done this only since 2009 (commit 26f4cdba6b51deab4ec99d60be381244068ef950), so it's not even something that an OS could depend on (and certainly Linux doesn't). So I don't see the point.
-Scott
Yup. At least the only place where the difference actually matters for a VM.
Kumar, do you remember why you put this in? Was it only for prototyping purposes?
I certainly wouldn't mind removing the whole thing altogether.
Alex
Alex
I feel like we did have some support for timer & external interrupts in u-boot. Its been a while since I looked.
- k
Alex
This has nothing to do with U-Boot's own exception handlers -- this is what U-Boot is currently doing just prior to entering the OS.
-Scott
Alex
-Scott
Oh, right. Did e6500 move to fixed IVORs? If not this can probably be removed as I doubt there will be a new core from FSL that would require this. It was meant as a transition for any OS that cared (if my memory serves me).
- k
-Scott
e6500 does not have fixed IVORs. I'm not sure why it would matter even if it did. An OS should know whether it is running on a chip with fixed IVORs and behave appropriately, rather than assuming the bootloader fixes things up on older chips to look like newer chips.
-Scott
We want to be able to directly execute the ELF binary without going through the u-boot.bin one.
To know where we have to start executing this ELF binary we have to tell the linker where our entry point is.
Signed-off-by: Alexander Graf agraf@suse.de --- arch/powerpc/cpu/mpc85xx/u-boot.lds | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/powerpc/cpu/mpc85xx/u-boot.lds b/arch/powerpc/cpu/mpc85xx/u-boot.lds index 2af4c80..b34d212 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot.lds @@ -13,6 +13,7 @@ #endif
OUTPUT_ARCH(powerpc) +ENTRY(_start_e500)
PHDRS {
For KVM we have a special PV machine type called "ppce500". This machine is inspired by the MPC8544DS board, but implements a lot less features than that one.
It also provides more PCI slots and is supposed to be enumerated by device tree only.
This patch adds support for the current generation ppce500 machine as it is implemented today.
Signed-off-by: Alexander Graf agraf@suse.de --- arch/powerpc/cpu/mpc85xx/start.S | 7 + arch/powerpc/include/asm/config_mpc85xx.h | 4 + board/freescale/qemu-ppce500/Makefile | 10 ++ board/freescale/qemu-ppce500/qemu-ppce500.c | 260 +++++++++++++++++++++++++++ board/freescale/qemu-ppce500/tlb.c | 59 ++++++ boards.cfg | 1 + include/configs/qemu-ppce500.h | 235 ++++++++++++++++++++++++ 7 files changed, 576 insertions(+) create mode 100644 board/freescale/qemu-ppce500/Makefile create mode 100644 board/freescale/qemu-ppce500/qemu-ppce500.c create mode 100644 board/freescale/qemu-ppce500/tlb.c create mode 100644 include/configs/qemu-ppce500.h
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index db84d10..ccbcc03 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -80,6 +80,13 @@ _start_e500: li r1,MSR_DE mtmsr r1
+#ifdef CONFIG_QEMU_E500 + /* Save our ePAPR device tree off before we clobber it */ + lis r2, CONFIG_QEMU_DT_ADDR@h + ori r2, r2, CONFIG_QEMU_DT_ADDR@l + stw r3, 0(r2) +#endif + #ifdef CONFIG_SYS_FSL_ERRATUM_A004510 mfspr r3,SPRN_SVR rlwinm r3,r3,0,0xff diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 54ce2f0..a0ab453 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -776,6 +776,10 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_A005125
+#elif defined(CONFIG_QEMU_E500) +#define CONFIG_MAX_CPUS 1 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xe0000000 + #else #error Processor type not defined for this platform #endif diff --git a/board/freescale/qemu-ppce500/Makefile b/board/freescale/qemu-ppce500/Makefile new file mode 100644 index 0000000..193b160 --- /dev/null +++ b/board/freescale/qemu-ppce500/Makefile @@ -0,0 +1,10 @@ +# +# Copyright 2007 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += qemu-ppce500.o +obj-y += tlb.o diff --git a/board/freescale/qemu-ppce500/qemu-ppce500.c b/board/freescale/qemu-ppce500/qemu-ppce500.c new file mode 100644 index 0000000..c6c4b4a --- /dev/null +++ b/board/freescale/qemu-ppce500/qemu-ppce500.c @@ -0,0 +1,260 @@ +/* + * Copyright 2007,2009-2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_pci.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <netdev.h> +#include <fdtdec.h> +#include <errno.h> +#include <malloc.h> + +int checkboard(void) +{ + return 0; +} + +static struct pci_controller pci1_hose; + +void pci_init_board(void) +{ + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + struct fsl_pci_info pci_info; + u32 devdisr, pordevsr; + u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; + int first_free_busno = 0; + + devdisr = in_be32(&gur->devdisr); + pordevsr = in_be32(&gur->pordevsr); + porpllsr = in_be32(&gur->porpllsr); + + puts("\n"); + + pci_speed = 66666000; + pci_32 = 1; + pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; + pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; + + if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { + SET_STD_PCI_INFO(pci_info, 1); + + pci_agent = fsl_setup_hose(&pci1_hose, pci_info.regs); + printf("PCI: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", + (pci_32) ? 32 : 64, + (pci_speed == 33333000) ? "33" : + (pci_speed == 66666000) ? "66" : "unknown", + pci_clk_sel ? "sync" : "async", + pci_agent ? "agent" : "host", + pci_arb ? "arbiter" : "external-arbiter", + pci_info.regs); + + first_free_busno = fsl_pci_init_port(&pci_info, + &pci1_hose, first_free_busno); + } else { + printf("PCI: disabled\n"); + } + + puts("\n"); +} + +int last_stage_init(void) +{ + int ret; + int len = 0; + const void *prop; + int chosen; + uint32_t *dt_base_ptr = (void*)CONFIG_QEMU_DT_ADDR; + uint32_t dt_base = *dt_base_ptr; + uint32_t dt_size; + void *fdt; + + dt_size = fdt_totalsize((void*)dt_base); + + /* Reserve 4k for dtb tweaks */ + dt_size += 4096; + fdt = malloc(dt_size); + + /* Open device tree */ + ret = fdt_open_into((void*)dt_base, fdt, dt_size); + if (ret) { + printf("Couldn't open fdt at %x\n", dt_base); + return -EIO; + } + + chosen = fdt_path_offset(fdt, "/chosen"); + if (chosen < 0) { + printf("Couldn't find /chosen node in fdt\n"); + return -EIO; + } + + prop = fdt_getprop(fdt, chosen, "qemu,boot-kernel", &len); + if (prop && (len >= 8)) { + /* -kernel boot */ + setenv_hex("kernel_addr", *(uint64_t*)prop); + + /* + * We already know where the initrd is inside the dtb, so no + * need to override it + */ + setenv("ramdisk_addr", "-"); + } + + /* Give the user a variable for the host fdt */ + setenv_hex("fdt_addr", (int)dt_base); + + free(fdt); + + return 0; +} + +static uint64_t get_linear_ram_size(void) +{ + const void *prop; + int memory; + int len; + uint32_t *dt_base_ptr = (void*)CONFIG_QEMU_DT_ADDR; + void *fdt = &dt_base_ptr[1]; + int ret; + uint32_t dt_base = *dt_base_ptr; + uint32_t dt_size = 1024 * 1024; + + ret = fdt_open_into((void*)dt_base, fdt, dt_size); + if (ret) + panic("Couldn't open fdt"); + + memory = fdt_path_offset(fdt, "/memory"); + prop = fdt_getprop(fdt, memory, "reg", &len); + + if (prop && len >= 16) + return *(uint64_t*)(prop+8); + + panic("Couldn't determine RAM size"); +} + +unsigned long +get_board_sys_clk(ulong dummy) +{ + /* The actual clock doesn't matter in a PV machine */ + return 33333333; +} + + +int board_phy_config(struct phy_device *phydev) +{ + return 0; +} + + +int board_eth_init(bd_t *bis) +{ + return pci_eth_init(bis); +} + +#if defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + FT_FSL_PCI_SETUP; +} +#endif + +void print_laws(void) +{ + /* We don't emulate LAWs yet */ +} + +static void fixup_tlb1(uint64_t ram_size) +{ + u32 mas0, mas1, mas2, mas3, mas7; + long tmp; + + /* Flush TLB0 - it only contains stale maps by now */ + invalidate_tlb(0); + + /* Create a temporary AS=1 map for ourselves */ + mas0 = MAS0_TLBSEL(1) | MAS0_ESEL(13); + mas1 = MAS1_VALID | MAS1_TID(0) | MAS1_TS | MAS1_TSIZE(BOOKE_PAGESZ_64M); + mas2 = FSL_BOOKE_MAS2(0, 0); + mas3 = FSL_BOOKE_MAS3(CONFIG_SYS_DDR_SDRAM_BASE, 0, + MAS3_SW|MAS3_SR|MAS3_SX); + mas7 = FSL_BOOKE_MAS7(CONFIG_SYS_DDR_SDRAM_BASE); + + write_tlb(mas0, mas1, mas2, mas3, mas7); + + /* Enter AS=1 */ + asm volatile( + "mfmsr %0 \n" + "ori %0, %0, 0x30 \n" + "mtsrr1 %0 \n" + "bl 1f \n" + "1: \n" + "mflr %0 \n" + "addi %0, %0, 16 \n" + "mtsrr0 %0 \n" + "rfi \n" + : "=r"(tmp) : : "lr"); + + /* Now we live in AS=1, so we can flush all old maps */ + clear_ddr_tlbs(ram_size >> 20); + /* and create new ones */ + setup_ddr_tlbs(ram_size >> 20); + + /* Now we can safely go back to AS=0 */ + asm volatile( + "mfmsr %0 \n" + "subi %0, %0, 0x30 \n" + "mtsrr1 %0 \n" + "bl 1f \n" + "1: \n" + "mflr %0 \n" + "addi %0, %0, 16 \n" + "mtsrr0 %0 \n" + "rfi \n" + : "=r"(tmp) : : "lr"); + + /* And remove our AS=1 map */ + disable_tlb(13); +} + +phys_size_t fixed_sdram(void) +{ + uint64_t ram_size; + + ram_size = get_linear_ram_size(); + + /* + * At this point we know that we're running in RAM, but within the + * first 64MB because we don't have a mapping for anything else. + * + * Replace that mapping with real maps for our full RAM range. + */ + fixup_tlb1(ram_size); + + return ram_size; +} + +phys_size_t fsl_ddr_sdram_size(void) +{ + return fixed_sdram(); +} + +void init_laws(void) +{ + /* We don't emulate LAWs yet */ +} + +int set_next_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) +{ + /* We don't emulate LAWs yet */ + return 0; +} diff --git a/board/freescale/qemu-ppce500/tlb.c b/board/freescale/qemu-ppce500/tlb.c new file mode 100644 index 0000000..cdc7013 --- /dev/null +++ b/board/freescale/qemu-ppce500/tlb.c @@ -0,0 +1,59 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024 , CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024 , CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024 , CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + /* + * TLB 0: 64M Cacheable + * 0x00000000 64M Covers RAM at 0x00000000 + */ + SET_TLB_ENTRY(1, CONFIG_SYS_BOOT_BLOCK, CONFIG_SYS_BOOT_BLOCK, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_64M, 1), + + /* + * TLB 1: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCI_VIRT, CONFIG_SYS_PCI_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 2: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCI_VIRT + 0x10000000, CONFIG_SYS_PCI_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 3: 64M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + * 0xe100_0000 255M PCI IO range + */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_64M, 1), +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index d177f82..ab50982 100644 --- a/boards.cfg +++ b/boards.cfg @@ -986,6 +986,7 @@ Active powerpc mpc85xx - freescale t2080qds Active powerpc mpc85xx - freescale t2080qds T2080QDS_SPIFLASH T2080QDS:PPC_T2080,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 Active powerpc mpc85xx - freescale t2080qds T2080QDS_NAND T2080QDS:PPC_T2080,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 Active powerpc mpc85xx - freescale t2080qds T2080QDS_SRIO_PCIE_BOOT T2080QDS:PPC_T2080,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 +Active powerpc mpc85xx - freescale qemu-ppce500 qemu-ppce500 - Alexander Graf agraf@suse.de Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD controlcenterd:36BIT,SDCARD Dirk Eibach eibach@gdsys.de Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD_DEVELOP controlcenterd:36BIT,SDCARD,DEVELOP Dirk Eibach eibach@gdsys.de Active powerpc mpc85xx - gdsys p1022 controlcenterd_TRAILBLAZER controlcenterd:TRAILBLAZER,SPIFLASH Dirk Eibach eibach@gdsys.de diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h new file mode 100644 index 0000000..981b016 --- /dev/null +++ b/include/configs/qemu-ppce500.h @@ -0,0 +1,235 @@ +/* + * Copyright 2011-2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * Corenet DS style board configuration file + */ +#ifndef __QEMU_PPCE500_H +#define __QEMU_PPCE500_H + +#define CONFIG_CMD_REGINFO + +/* High Level Configuration Options */ +#define CONFIG_BOOKE +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ +#define CONFIG_QEMU_E500 + +#undef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xf00000 /* 15 MB */ + +#undef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS (0x1000000 - 4) /* 16 MB */ + +#define CONFIG_SYS_RAMBOOT + +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCI1 1 /* PCI controller 1 */ +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ + +#define CONFIG_ENV_OVERWRITE +#define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */ + +#define CONFIG_ENABLE_36BIT_PHYS + +#define CONFIG_ADDR_MAP +#define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ + +#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x00400000 +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +#define CONFIG_SYS_CCSRBAR 0xe0000000 +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR + +#define CONFIG_FW_CFG_ADDR 0xFF7FFFFC +#define CONFIG_QEMU_DT_ADDR ((2 * 1024 * 1024) - 4) /* below 2MB */ + +/* + * DDR Setup + */ +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +/* CONFIG_NUM_DDR_CONTROLLERS is defined in include/asm/config_mpc85xx.h */ +#define CONFIG_DIMM_SLOTS_PER_CTLR 0 +#define CONFIG_CHIP_SELECTS_PER_CTRL 0 + +/* Get RAM size from device tree */ +#define CONFIG_DDR_SPD + +#define CONFIG_SYS_CLK_FREQ 33000000 + + +/* + * IFC Definitions + */ + +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_SYS_BOOT_BLOCK 0x00000000 /* boot TLB */ +#define CONFIG_SYS_FLASH_BASE 0xff800000 /* start of FLASH 8M */ +#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ + +#define CONFIG_SYS_MONITOR_BASE (CONFIG_RESET_VECTOR_ADDRESS - 0x100000 + 4) +#define CONFIG_SYS_SDRAM_SIZE 64 + +#define CONFIG_ENV_IS_NOWHERE + +#define CONFIG_HWCONFIG + +#define CONFIG_SYS_INIT_RAM_ADDR 0x00100000 +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0x0 +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0x00100000 +/* The assembler doesn't like typecast */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ + ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ + CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) + +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)) + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ + +#define CONFIG_SYS_PCI_VIRT 0xc0000000 /* 512M PCI TLB */ +#define CONFIG_SYS_PCI_PHYS 0xc0000000 /* 512M PCI TLB */ + +#define CONFIG_SYS_PCI1_MEM_VIRT 0xc0000000 +#define CONFIG_SYS_PCI1_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCI1_MEM_PHYS 0xc0000000 +#define CONFIG_SYS_PCI1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCI1_IO_VIRT 0xe1000000 +#define CONFIG_SYS_PCI1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCI1_IO_PHYS 0xe1000000 +#define CONFIG_SYS_PCI1_IO_SIZE 0x00010000 /* 64k */ + +#ifdef CONFIG_PCI +#define CONFIG_PCI_INDIRECT_BRIDGE +#define CONFIG_NET_MULTI +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_E1000 + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_DOS_PARTITION +#endif /* CONFIG_PCI */ + +#define CONFIG_LBA48 +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 + +/* + * Environment + */ +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) */ + +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +#define CONFIG_LAST_STAGE_INIT + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_ERRATA +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_PING +#define CONFIG_CMD_SETEXPR + +#ifdef CONFIG_PCI +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server*/ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_BOOTDELAY 1 +#define CONFIG_BOOTCOMMAND \ + "test -n "$kernel_addr" && bootm $kernel_addr $ramdisk_addr $fdt_addr\0" + +#endif /* __QEMU_PPCE500_H */
- /* Save our ePAPR device tree off before we clobber it */
- lis r2, CONFIG_QEMU_DT_ADDR@h
- ori r2, r2, CONFIG_QEMU_DT_ADDR@l
- stw r3, 0(r2)
r2 has a special purpose -- please don't use it for other things, even if it's too early to be a problem and other code is similarly bad.
Instead of saving the DT pointer in some random hardcoded address, how about sticking it in a callee-saved register until you're able to store it in the global data struct?
This is supposed to come from the device tree. We will want to change that address eventually to support larger guest memory.
- Copyright 2007,2009-2014 Freescale Semiconductor, Inc.
Do you really need all these headers? miiphy?
- volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
- struct fsl_pci_info pci_info;
- u32 devdisr, pordevsr;
- u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel;
- int first_free_busno = 0;
- devdisr = in_be32(&gur->devdisr);
- pordevsr = in_be32(&gur->pordevsr);
- porpllsr = in_be32(&gur->porpllsr);
Why are you reading registers that don't exist in QEMU?
- int ret;
- int len = 0;
- const void *prop;
- int chosen;
Whitespace
- uint32_t dt_base = *dt_base_ptr;
- uint32_t dt_size;
- void *fdt;
- dt_size = fdt_totalsize((void*)dt_base);
Please put a space before the * in casts.
- /* Reserve 4k for dtb tweaks */
- dt_size += 4096;
- fdt = malloc(dt_size);
- /* Open device tree */
- ret = fdt_open_into((void*)dt_base, fdt, dt_size);
- if (ret) {
return -EIO;
- chosen = fdt_path_offset(fdt, "/chosen");
- if (chosen < 0) {
return -EIO;
- prop = fdt_getprop(fdt, chosen, "qemu,boot-kernel", &len);
- if (prop && (len >= 8)) {
/* -kernel boot */
Don't cast away the const. This looks like the only place you use prop; why not make it uint64_t to begin with?
Indentation.
What if the user wants to specify the initrd from within U-Boot? This should be handled via the default environment, not by overriding the user's choice.
- /* Give the user a variable for the host fdt */
- setenv_hex("fdt_addr", (int)dt_base);
Unnecessary cast.
- free(fdt);
Why is the device tree handling here different from anything else we already have? In particular, why do you create a temporary fdt (with space for tweaks that never happen) just to read from it?
- const void *prop;
- int memory;
- int len;
Whitespace.
int ret;
if (ret)
Again, there's no need to create a temporary fdt copy every time you want to read from it.
What if memory doesn't start at zero (e.g. for e500v2 VFIO)?
- /* The actual clock doesn't matter in a PV machine */
- return 33333333;
s/doesn't matter/doesn't exist/
Where is this used from? Can it be skipped for this target? Is the CPU timebase handled properly?
Why?
mpc8544ds is the only board in boards/freescale that has this, so it's clearly optional, and you clearly don't need it...
Just because QEMU started with mpc8544ds doesn't mean this needs to be a copy-and-paste of the U-Boot mpc8544ds code. In fact it's better if it isn't to reduce the likelihood of accidentally depending on hardcoded addresses and such.
- return pci_eth_init(bis);
- FT_FSL_PCI_SETUP;
+} +#endif
- /* We don't emulate LAWs yet */
- u32 mas0, mas1, mas2, mas3, mas7;
- long tmp;
- /* Flush TLB0 - it only contains stale maps by now */
- invalidate_tlb(0);
- /* Create a temporary AS=1 map for ourselves */
Whitespace. Please run scripts/checkpatch.pl.
- /* Enter AS=1 */
- asm volatile(
"mfmsr %0 \n"
"mtsrr1 %0 \n"
"bl 1f \n"
"1: \n"
"mflr %0 \n"
"mtsrr0 %0 \n"
"rfi \n"
- : "=r"(tmp) : : "lr");
- /* Now we live in AS=1, so we can flush all old maps */
- clear_ddr_tlbs(ram_size >> 20);
- /* and create new ones */
- setup_ddr_tlbs(ram_size >> 20);
- /* Now we can safely go back to AS=0 */
- asm volatile(
"mfmsr %0 \n"
"mtsrr1 %0 \n"
"bl 1f \n"
"1: \n"
"mflr %0 \n"
"mtsrr0 %0 \n"
"rfi \n"
- /* And remove our AS=1 map */
- disable_tlb(13);
Why aren't we already in AS1? What code are you replacing with this?
- uint64_t ram_size;
- ram_size = get_linear_ram_size();
- fixup_tlb1(ram_size);
- return ram_size;
- return fixed_sdram();
What is calling set_next_law()?
- Copyright 2008 Freescale Semiconductor, Inc.
- (C) Copyright 2000
- Wolfgang Denk, DENX Software Engineering, wd@denx.de.
- /* TLB 0 - for temp stack in cache */
- SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR,
- SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024 , CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024,
- SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024 , CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024,
- SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024 , CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024,
Isn't this just normal RAM? Thus, aren't you creating overlapping TLB entries here?
- SET_TLB_ENTRY(1, CONFIG_SYS_BOOT_BLOCK, CONFIG_SYS_BOOT_BLOCK,
- SET_TLB_ENTRY(1, CONFIG_SYS_PCI_VIRT, CONFIG_SYS_PCI_PHYS,
- SET_TLB_ENTRY(1, CONFIG_SYS_PCI_VIRT + 0x10000000, CONFIG_SYS_PCI_PHYS + 0x10000000,
- SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS,
These should not be executable.
- Copyright 2011-2014 Freescale Semiconductor, Inc.
- Corenet DS style board configuration file
Does QEMU begin execution here, or at the ELF entry point?
SRIO and DDR interrupts?
Why do we need CONFIG_INTERRUPTS at all?
Again, shouldn't be hardcoded (and must equal the default since QEMU doesn't currently support relocating CCSR)
Where did this come from? If this is a new paravirt device please advertise it through the device tree rather than a hardcoded address. And if it must be a hardcoded address, please put it well above 4G.
This is U-Boot-internal and not something hardcoded in QEMU, right?
Why are we including code that cares about this?
Likewise. BTW, this made up sysclock frequency doesn't match the one you made up elsewhere.
- IFC Definitions
There is no IFC.
NO_FLASH, but flash starts at 0xff800000?
Why hardcoded to 64 MiB?
- General PCI
- Memory space is mapped 1-1, but I/O space must start from 0.
I assume U-Boot will reprogram PCI based on this, but does QEMU support that for I/O (for memory IIRC it completely ignores the ATMU)? Don't rely on the QEMU address not changing.
- Environment
Even though ENV_IS_NOWHERE. :-)
Baud rate?
Errata?
KGDB?
This is copy-and-paste cruft even on the non-QEMU targets.
-Scott
- stw r3, 0(r2)
Heh, ok. I'll use r4 instead.
I did that at first but that didn't survive relocation. However, I just remembered that I had my global variable in bss, so maybe relocation doesn't work properly there. Instead I put it in .data now and that seems to work.
It's certainly the nicer solution, I agree.
That's a lot easier said than done. There is a lot of code in u-boot that puts the CCSRBAR or addresses derived from CCSRBAR into arrays which fails miserably when you make it a variable.
It's certainly a reasonably big task.
Ah, I missed that one during my header cleaning :). Reved that and immap_85xx.h.
Dropped
- int ret;
- int len = 0;
- const void *prop;
- int chosen;
Whitespace
- uint32_t dt_size;
- void *fdt;
- dt_size += 4096;
- if (ret) {
return -EIO;
- if (chosen < 0) {
return -EIO;
/* -kernel boot */
Good idea. Fixed.
Indentation.
I'm not sure I see the difference. We have the following default boot script:
#define CONFIG_BOOTCOMMAND \ "test -n "$kernel_addr" && bootm $kernel_addr $ramdisk_addr $fdt_addr\0"
which is the only place where we actually use $ramdisk_addr. If a user wants to specify the initrd within U-Boot he can do that easily because he would specify his own boot command anyway, right?
Maybe I should rename kernel_addr to qemu_kernel_addr and drop ramdisk_addr completely in favor for a - in the bootm command? Yeah, I'll do that :).
Unnecessary cast.
- free(fdt);
Because I had no idea :). Changed to directly use the in-memory fdt.
- const void *prop;
- int memory;
- int len;
Whitespace.
int ret;
if (ret)
In that case we're pretty broken regardless of determining the correct memory size. Can u-boot handle that case at all? How would this work?
- return 33333333;
Turns out it's not required at all. Must have been a dependency of something I threw away in between.
Why?
Yup. I just had to start from somewhere :). Removed.
- FT_FSL_PCI_SETUP;
+} +#endif
- long tmp;
I shouldn't copy&paste I suppose :).
- /* Enter AS=1 */
- asm volatile(
"mfmsr %0 \n"
"mtsrr1 %0 \n"
"bl 1f \n"
"1: \n"
"mflr %0 \n"
"mtsrr0 %0 \n"
"rfi \n"
- asm volatile(
"mfmsr %0 \n"
"mtsrr1 %0 \n"
"bl 1f \n"
"1: \n"
"mflr %0 \n"
"mtsrr0 %0 \n"
"rfi \n"
- disable_tlb(13);
I honestly don't know how it's supposed to work at all usually.
- return ram_size;
Nothing anymore apparently. Removed.
Indeed. Removed.
Aww :). Fixed.
At the ELF entry point. But I need to define this to something.
We don't. Removed.
Yes.
It's a leftover from a time when I used fw_cfg to fetch the dt pointer. Removed.
Yes, and it's gone now :).
In file included from cpu.c:25:0: /root/u-boot/include/fsl_ddr_sdram.h:183:7: error: 'CONFIG_CHIP_SELECTS_PER_CTRL' undeclared here (not in a function)
So we don't include code, but we include a header that cares.
speed.c: In function 'get_sys_info': speed.c:347:42: error: 'CONFIG_SYS_CLK_FREQ' undeclared (first use in this function)
- IFC Definitions
There is no IFC.
Removed.
Yeah, I was experimenting with putting up a flash there. Removed.
The define wasn't needed anymore. Removed.
- General PCI
It populated its PCI accessor struct based on this. This ideally should be dt based. But for now we have something that works at all :).
- Environment
Removed :)
Baud rate?
Removed.
Errata?
Eh - removed :)
KGDB?
*shrug* I just copied this from somewhere.
Ok, I'll remove it.
Alex
- stw r3, 0(r2)
I don't mean a global variable, but a field in the global data struct (gd_t). BSS should not be accessed, and global variables should not be written, before relocation (although you may get away with the latter pre-relocation in ramboot cases, you still shouldn't).
Indentation.
Oh. I was confusing it with the existing $ramdiskaddr. So I'm changing my objection to the fact that it's confusing. :-)
Likewise $fdt_addr versus $fdtaddr.
OK.
- if (ret)
- memory = fdt_path_offset(fdt, "/memory");
- prop = fdt_getprop(fdt, memory, "reg", &len);
- if (prop && len >= 16)
- panic("Couldn't determine RAM size");
U-Boot can handle this on other architectures. Not sure about the PPC code.
- return 33333333;
OK. I'm still curious about how the timebase frequency is handled.
- /* Enter AS=1 */
- asm volatile(
"mfmsr %0 \n"
"mtsrr1 %0 \n"
"bl 1f \n"
"1: \n"
"mflr %0 \n"
"mtsrr0 %0 \n"
"rfi \n"
- asm volatile(
"mfmsr %0 \n"
"mtsrr1 %0 \n"
"bl 1f \n"
"1: \n"
"mflr %0 \n"
"mtsrr0 %0 \n"
"rfi \n"
- disable_tlb(13);
Usually we enter AS1 from start.S during early boot (see switch_as), and return to AS0 later in start.S (see _start_cont) after calling cpu_init_early_f().
Set CONFIG_SYS_MPC85XX_NO_RESETVEC.
I see. Would be nice to clean that up at some point, but OK for now.
What do we need from speed.c?
-Scott
- stw r3, 0(r2)
But the global data gets cleared in cpu_init_early_f(). So I'd have to shove it to some non-volatile, make sure no other code uses that particular register and then move it into gd. And how do I get offsets into the gd structure from asm in the first place?
Or are you suggesting I move r3 into r2x, leave it there until after cpu_init_early_f(), copy it back to r3 and then call a C helper that puts it into gd? Sounds quite excessive for something that works quite well with a global variable in .data :).
Indentation.
Mind to explain what the difference is between $fdtaddr, $fdt_addr (pxe boot?) and $fdt_addr_r? Which one should I set?
OK.
- if (ret)
It's handled through preprocessor configuration magic again. I'll leave that for later though.
- return 33333333;
Incorrectly. The question is whether it matters.
- /* Enter AS=1 */
- asm volatile(
"mfmsr %0 \n"
"mtsrr1 %0 \n"
"bl 1f \n"
"1: \n"
"mflr %0 \n"
"mtsrr0 %0 \n"
"rfi \n"
- asm volatile(
"mfmsr %0 \n"
"mtsrr1 %0 \n"
"bl 1f \n"
"1: \n"
"mflr %0 \n"
"mtsrr0 %0 \n"
"rfi \n"
- disable_tlb(13);
Right, but the only function that gets called in AS=1 is cpu_init_early_f() which is CPU, not board specific. I really don't want to mess with common code too much unless I'm 100% sure I don't break it and it doesn't break me next time.
So I need to run this from AS=0 context, which means we need to quickly go out of AS=0, modify the AS=0 map and go back into AS=0.
Sounds easy, but doesn't boot anymore now. I guess I'll need to figure out where in that fragile TLB setup mess it fails this time.
Nothing really, but it gets included unconditionally in arch/powerpc/cpu/mpc85xx/Makefile so I can't override it with my own stubs.
Alex
- stw r3, 0(r2)
Right.
See lib/asm-offsets.c
It only works because you are booting directly from RAM, and the variable you're writing to isn't subject to relocation, and isn't in the BSS (unlike most uninitialized/zero-initialized data). It's not good practice. What if you later want to simulate NOR flash and boot from that?
I don't know what the "_r" is supposed to mean, but the underscore seems to just be something that varies from board to board. Our boards use $fdtaddr and until now I didn't realize other boards do it differently.
- return 33333333;
Incorrectly for U-Boot's own use? Incorrectly for passing to Linux?
The latter case definitely matters. The former case would affect the boot delay, so it needs to be at least reasonably close.
What sort of messing would you need to do to cpu_init_early_f()? What part of the normal workflow breaks under QEMU?
You could stick an ifndef CONFIG_QEMU_E500 in there I guess, or define it to be zero and make sure you don't call any of those functions that depend on it.
-Scott
- stw r3, 0(r2)
Right.
Ok, I'll change it :)
Saving it from asm only doesn't work though because we end up accessing the fdt pointer inside of cpu_early_init_f() which clears the gd. I've made the fdt pointer a function argument now.
Bah - I'll just set all of them.
- return 33333333;
We don't modify the DT when passing it to Linux. That would mess up quite a number of things (SMP among others).
As for internal use, it's definitely close enough on everything I tested it on.
#ifndef CONFIG_FSL_CORENET #if (defined(CONFIG_SYS_RAMBOOT) || defined(CONFIG_SPL)) && \ !defined(CONFIG_SYS_INIT_L2_ADDR) phys_size_t initdram(int board_type) { #if defined(CONFIG_SPD_EEPROM) || defined(CONFIG_DDR_SPD) return fsl_ddr_sdram_size(); #else return (phys_size_t)CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; #endif } #else /* CONFIG_SYS_RAMBOOT */ phys_size_t initdram(int board_type) { [...] dram_size = setup_ddr_tlbs(dram_size / 0x100000); [...]
So because we set CONFIG_SYS_RAMBOOT we never call setup_ddr_tlbs() but instead have to do it ourselves in fsl_ddr_sdram_size(). I'll move the TLB fixup there.
Hrm, let me try that.
Alex
Ugh, no.
It looks like these are documented in README (and our use of fdtaddr is nonstandard, though the README does state that they're just suggestions). fdt_addr is supposed to be the address in flash, and fdt_addr_r is supposed to be the address in RAM.
That looks like a bug in RAMBOOT handling, not specific to the QEMU target.
You shouldn't be calling fsl_ddr_sdram_size() at all -- there's no emulated SPD EEPROM.
For that matter, I don't see much in cpu.c that we really want to use for the QEMU target.
-Scott
Looks you got plenty feedback from Scott. I am going to mark this set as "change requested" so they will drop off from my to-do list. Please submit a v2 when they are ready (all three patches together) with change log.
York
Alexander Graf
Kumar Gala
Scott Wood
York Sun
