[U-Boot] [PATCH] Revert "video: mxsfb: Configure the clock after eLCDIF reset"
Commit ec3dcea74470 ("video: mxsfb: Configure the clock after eLCDIF reset") causes boot regression on imx7d-pico/imx7d-sdb boards, so revert it until a better solution is prepared.
This reverts commit ec3dcea7447031463643c33143b3a5f027f0b54d.
Reported-by: Joris Offouga offougajoris@gmail.com Signed-off-by: Fabio Estevam festevam@gmail.com --- drivers/video/mxsfb.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index d73a8bac99..c52981053e 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -57,6 +57,9 @@ static void mxs_lcd_init(u32 fb_addr, struct ctfb_res_modes *mode, int bpp) uint32_t word_len = 0, bus_width = 0; uint8_t valid_data = 0;
+ /* Kick in the LCDIF clock */ + mxs_set_lcdclk(MXS_LCDIF_BASE, PS2KHZ(mode->pixclock)); + /* Restart the LCDIF block */ mxs_reset_block(®s->hw_lcdif_ctrl_reg);
@@ -127,9 +130,6 @@ static void mxs_lcd_init(u32 fb_addr, struct ctfb_res_modes *mode, int bpp) /* FIFO cleared */ writel(LCDIF_CTRL1_FIFO_CLEAR, ®s->hw_lcdif_ctrl1_clr);
- /* Kick in the LCDIF clock */ - mxs_set_lcdclk(MXS_LCDIF_BASE, PS2KHZ(mode->pixclock)); - /* RUN! */ writel(LCDIF_CTRL_RUN, ®s->hw_lcdif_ctrl_set); }
Hi Fabio,
Applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Fabio Estevam
