[PATCH] global_data.h: drop write-only field dm_root_f
The dm_root_f field seems to be entirely write-only and hence redundant, unless 'git grep' fails to find some access generated via preprocessor token concatenation or similar.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- common/board_r.c | 3 +-- include/asm-generic/global_data.h | 4 ---- test/dm/core.c | 1 - 3 files changed, 1 insertion(+), 7 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index da0b80f24ff..fd263f4a0a8 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -230,8 +230,7 @@ static int initr_dm(void)
oftree_reset();
- /* Save the pre-reloc driver model and start a new one */ - gd->dm_root_f = gd->dm_root; + /* Drop the pre-reloc driver model and start a new one */ gd->dm_root = NULL; #ifdef CONFIG_TIMER gd->timer = NULL; diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index fcc3c6e14ca..aa336d63e3a 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -195,10 +195,6 @@ struct global_data { * @dm_root: root instance for Driver Model */ struct udevice *dm_root; - /** - * @dm_root_f: pre-relocation root instance - */ - struct udevice *dm_root_f; /** * @uclass_root_s: * head of core tree when uclasses are not in read-only memory. diff --git a/test/dm/core.c b/test/dm/core.c index 7f3f8d183bc..34e5c163b98 100644 --- a/test/dm/core.c +++ b/test/dm/core.c @@ -1007,7 +1007,6 @@ static int dm_test_uclass_before_ready(struct unit_test_state *uts) ut_assertok(uclass_get(UCLASS_TEST, &uc));
gd->dm_root = NULL; - gd->dm_root_f = NULL; memset(&gd->uclass_root, '\0', sizeof(gd->uclass_root));
ut_asserteq_ptr(NULL, uclass_find(UCLASS_TEST));
On Mon, 27 May 2024 at 14:04, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
It is used for accessing the pre-relocation devices in case that is useful / possible. But it seems that we haven't had many use cases, so I am OK with dropping this and adding it back later if needed.
Applied to u-boot-dm, thanks!
Rasmus Villemoes
