[PATCH v2] power: zynqmp: Add power domain driver for ZynqMP
Driver should be enabled by CONFIG_POWER_DOMAIN=y and CONFIG_ZYNQMP_POWER_DOMAIN=y. Power domain driver doesn't have own DT node but it uses zynqmp firmware DT node that's why there is a need to bind driver when firmware node is found.
Driver itself is simple. It is sending pmufw config object overlay for enabling access to device which is done in ...domain_request(). In ...domain_on() capabilities are passed and node is requested. This should be bare minimum of required to get power domain driver working.
Changes in v2: - s/binded/bound/ - Reported by gvb
MAINTAINERS | 1 + drivers/firmware/firmware-zynqmp.c | 18 +++++ drivers/power/domain/Kconfig | 9 +++ drivers/power/domain/Makefile | 1 + drivers/power/domain/zynqmp-power-domain.c | 91 ++++++++++++++++++++++ include/zynqmp_firmware.h | 31 ++++++++ 6 files changed, 151 insertions(+) create mode 100644 drivers/power/domain/zynqmp-power-domain.c
diff --git a/MAINTAINERS b/MAINTAINERS index 64648c29219f..fca5227d0b93 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -628,6 +628,7 @@ F: drivers/mtd/nand/raw/zynq_nand.c F: drivers/net/phy/xilinx_phy.c F: drivers/net/zynq_gem.c F: drivers/phy/phy-zynqmp.c +F: drivers/power/domain/zynqmp-power-domain.c F: drivers/serial/serial_zynq.c F: drivers/reset/reset-zynqmp.c F: drivers/rtc/zynqmp_rtc.c diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index 839203ec82a1..5a618e490725 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -8,6 +8,7 @@ #include <common.h> #include <cpu_func.h> #include <dm.h> +#include <dm/lists.h> #include <log.h> #include <zynqmp_firmware.h> #include <asm/cache.h> @@ -226,8 +227,25 @@ static const struct udevice_id zynqmp_firmware_ids[] = { { } };
+static int zynqmp_firmware_bind(struct udevice *dev) +{ + int ret; + struct udevice *child; + + if (IS_ENABLED(CONFIG_ZYNQMP_POWER_DOMAIN)) { + ret = device_bind_driver_to_node(dev, "zynqmp_power_domain", + "zynqmp_power_domain", + dev_ofnode(dev), &child); + if (ret) + printf("zynqmp power domain driver is not bound\n"); + } + + return dm_scan_fdt_dev(dev); +} + U_BOOT_DRIVER(zynqmp_firmware) = { .id = UCLASS_FIRMWARE, .name = "zynqmp_firmware", .of_match = zynqmp_firmware_ids, + .bind = zynqmp_firmware_bind, }; diff --git a/drivers/power/domain/Kconfig b/drivers/power/domain/Kconfig index 9aea5fcdf082..93d2599d83c2 100644 --- a/drivers/power/domain/Kconfig +++ b/drivers/power/domain/Kconfig @@ -88,4 +88,13 @@ config TI_POWER_DOMAIN help Generic power domain implementation for TI K3 devices.
+config ZYNQMP_POWER_DOMAIN + bool "Enable the Xilinx ZynqMP Power domain driver" + depends on POWER_DOMAIN && ZYNQMP_FIRMWARE + help + Generic power domain implementation for Xilinx ZynqMP devices. + The driver should be enabled when system starts in very minimal + configuration and it is extended at run time. Then enabling + the driver will ensure that PMUFW enable access to requested IP. + endmenu diff --git a/drivers/power/domain/Makefile b/drivers/power/domain/Makefile index 530ae35671a2..7c8af67dbd64 100644 --- a/drivers/power/domain/Makefile +++ b/drivers/power/domain/Makefile @@ -16,3 +16,4 @@ obj-$(CONFIG_SANDBOX_POWER_DOMAIN) += sandbox-power-domain-test.o obj-$(CONFIG_TEGRA186_POWER_DOMAIN) += tegra186-power-domain.o obj-$(CONFIG_TI_SCI_POWER_DOMAIN) += ti-sci-power-domain.o obj-$(CONFIG_TI_POWER_DOMAIN) += ti-power-domain.o +obj-$(CONFIG_ZYNQMP_POWER_DOMAIN) += zynqmp-power-domain.o diff --git a/drivers/power/domain/zynqmp-power-domain.c b/drivers/power/domain/zynqmp-power-domain.c new file mode 100644 index 000000000000..0a6cb67a8acc --- /dev/null +++ b/drivers/power/domain/zynqmp-power-domain.c @@ -0,0 +1,91 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2021, Xilinx. Inc. + */ + +#include <common.h> +#include <dm.h> +#include <log.h> +#include <malloc.h> +#include <misc.h> +#include <power-domain-uclass.h> +#include <linux/bitops.h> + +#include <zynqmp_firmware.h> + +#define NODE_ID_LOCATION 5 + +static unsigned int xpm_configobject[] = { + /**********************************************************************/ + /* HEADER */ + 2, /* Number of remaining words in the header */ + 1, /* Number of sections included in config object */ + PM_CONFIG_OBJECT_TYPE_OVERLAY, /* Type of Config object as overlay*/ + /**********************************************************************/ + /* SLAVE SECTION */ + + PM_CONFIG_SLAVE_SECTION_ID, /* Section ID */ + 1, /* Number of slaves */ + + 0, /* Node ID which will be changed below */ + PM_SLAVE_FLAG_IS_SHAREABLE, + PM_CONFIG_IPI_PSU_CORTEXA53_0_MASK | + PM_CONFIG_IPI_PSU_CORTEXR5_0_MASK | + PM_CONFIG_IPI_PSU_CORTEXR5_1_MASK, /* IPI Mask */ +}; + +static int zynqmp_pm_request_node(const u32 node, const u32 capabilities, + const u32 qos, const enum zynqmp_pm_request_ack ack) +{ + return xilinx_pm_request(PM_REQUEST_NODE, node, capabilities, + qos, ack, NULL); +} + +static int zynqmp_power_domain_request(struct power_domain *power_domain) +{ + /* Record power domain id */ + xpm_configobject[NODE_ID_LOCATION] = power_domain->id; + + zynqmp_pmufw_load_config_object(xpm_configobject, sizeof(xpm_configobject)); + + return 0; +} + +static int zynqmp_power_domain_free(struct power_domain *power_domain) +{ + /* nop now */ + return 0; +} + +static int zynqmp_power_domain_on(struct power_domain *power_domain) +{ + return zynqmp_pm_request_node(power_domain->id, + ZYNQMP_PM_CAPABILITY_ACCESS, + ZYNQMP_PM_MAX_QOS, + ZYNQMP_PM_REQUEST_ACK_BLOCKING); +} + +static int zynqmp_power_domain_off(struct power_domain *power_domain) +{ + /* nop now */ + return 0; +} + +struct power_domain_ops zynqmp_power_domain_ops = { + .request = zynqmp_power_domain_request, + .rfree = zynqmp_power_domain_free, + .on = zynqmp_power_domain_on, + .off = zynqmp_power_domain_off, +}; + +static int zynqmp_power_domain_probe(struct udevice *dev) +{ + return 0; +} + +U_BOOT_DRIVER(zynqmp_power_domain) = { + .name = "zynqmp_power_domain", + .id = UCLASS_POWER_DOMAIN, + .probe = zynqmp_power_domain_probe, + .ops = &zynqmp_power_domain_ops, +}; diff --git a/include/zynqmp_firmware.h b/include/zynqmp_firmware.h index cfd92d3fe567..19c004e91993 100644 --- a/include/zynqmp_firmware.h +++ b/include/zynqmp_firmware.h @@ -371,4 +371,35 @@ void zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size); int xilinx_pm_request(u32 api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, u32 *ret_payload);
+/* Type of Config Object */ +#define PM_CONFIG_OBJECT_TYPE_BASE 0x1U +#define PM_CONFIG_OBJECT_TYPE_OVERLAY 0x2U + +/* Section Id */ +#define PM_CONFIG_SLAVE_SECTION_ID 0x102U +#define PM_CONFIG_SET_CONFIG_SECTION_ID 0x107U + +/* Flag Option */ +#define PM_SLAVE_FLAG_IS_SHAREABLE 0x1U +#define PM_MASTER_USING_SLAVE_MASK 0x2U + +/* IPI Mask for Master */ +#define PM_CONFIG_IPI_PSU_CORTEXA53_0_MASK 0x00000001 +#define PM_CONFIG_IPI_PSU_CORTEXR5_0_MASK 0x00000100 +#define PM_CONFIG_IPI_PSU_CORTEXR5_1_MASK 0x00000200 + +enum zynqmp_pm_request_ack { + ZYNQMP_PM_REQUEST_ACK_NO = 1, + ZYNQMP_PM_REQUEST_ACK_BLOCKING = 2, + ZYNQMP_PM_REQUEST_ACK_NON_BLOCKING = 3, +}; + +/* Node capabilities */ +#define ZYNQMP_PM_CAPABILITY_ACCESS 0x1U +#define ZYNQMP_PM_CAPABILITY_CONTEXT 0x2U +#define ZYNQMP_PM_CAPABILITY_WAKEUP 0x4U +#define ZYNQMP_PM_CAPABILITY_UNUSABLE 0x8U + +#define ZYNQMP_PM_MAX_QOS 100U + #endif /* _ZYNQMP_FIRMWARE_H_ */
Changes in v2:
- int ret;
- struct udevice *child;
- if (IS_ENABLED(CONFIG_ZYNQMP_POWER_DOMAIN)) {
if (ret)
Doesn't need to handle error case? And how about displaying an error value(ret)?
- return dm_scan_fdt_dev(dev);
- .bind = zynqmp_firmware_bind,
- bool "Enable the Xilinx ZynqMP Power domain driver"
- depends on POWER_DOMAIN && ZYNQMP_FIRMWARE
- help
- Copyright (c) 2021, Xilinx. Inc.
Remove "/***....***/". It doesn't need to add.
- /* HEADER */
- 2, /* Number of remaining words in the header */
- 1, /* Number of sections included in config object */
- PM_CONFIG_OBJECT_TYPE_OVERLAY, /* Type of Config object as overlay*/
Ditto.
Best Regards, Jaehoon Chung
- /* SLAVE SECTION */
- PM_CONFIG_SLAVE_SECTION_ID, /* Section ID */
- 1, /* Number of slaves */
- 0, /* Node ID which will be changed below */
- PM_SLAVE_FLAG_IS_SHAREABLE,
- PM_CONFIG_IPI_PSU_CORTEXA53_0_MASK |
- PM_CONFIG_IPI_PSU_CORTEXR5_0_MASK |
- PM_CONFIG_IPI_PSU_CORTEXR5_1_MASK, /* IPI Mask */
- return xilinx_pm_request(PM_REQUEST_NODE, node, capabilities,
qos, ack, NULL);
- /* Record power domain id */
- xpm_configobject[NODE_ID_LOCATION] = power_domain->id;
- zynqmp_pmufw_load_config_object(xpm_configobject, sizeof(xpm_configobject));
- /* nop now */
- return zynqmp_pm_request_node(power_domain->id,
ZYNQMP_PM_MAX_QOS,
- /* nop now */
- .request = zynqmp_power_domain_request,
- .rfree = zynqmp_power_domain_free,
- .on = zynqmp_power_domain_on,
- .off = zynqmp_power_domain_off,
- .name = "zynqmp_power_domain",
- .id = UCLASS_POWER_DOMAIN,
- .probe = zynqmp_power_domain_probe,
- .ops = &zynqmp_power_domain_ops,
- ZYNQMP_PM_REQUEST_ACK_NO = 1,
- ZYNQMP_PM_REQUEST_ACK_BLOCKING = 2,
- ZYNQMP_PM_REQUEST_ACK_NON_BLOCKING = 3,
Changes in v2:
- int ret;
if (ret)
I have added it there in v3
- U_BOOT_DRIVER(zynqmp_firmware) = { .id = UCLASS_FIRMWARE, .name = "zynqmp_firmware", .of_match = zynqmp_firmware_ids,
- .bind = zynqmp_firmware_bind, };
- help
- endmenu
- /* HEADER */
Ditto.
Both fixed.
Thanks, Michal
Jaehoon Chung
Michal Simek
