[U-Boot] [PATCH 0/3] s3c-otg: fastboot: fixes and cleanup
These are the patches discussed in the thread [1]. This should fix fastboot on boards using s3c-otg/dwc2 gadget controller.
[1] - https://www.mail-archive.com/u-boot@lists.denx.de/msg209740.html
NOTE: I haven't tested this extensively on TI platforms other than just a fastboot download command.
-- cheers, -roger
Roger Quadros (3): fastboot: Clean up bulk-out logic usb: s3c-otg: Fix short packet for request size > ep.maxpacket usb: s3c-otg: Fix remaining bytes in debug messages
drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 6 ++-- drivers/usb/gadget/f_fastboot.c | 50 ++++++++++++++---------------- 2 files changed, 26 insertions(+), 30 deletions(-)
Just use ep->maxpacket to get the maxpacket size and simplify the bulk-out maxpacket alignment.
Signed-off-by: Roger Quadros rogerq@ti.com Tested-by: Steve Rae srae@broadcom.com --- drivers/usb/gadget/f_fastboot.c | 50 +++++++++++++++++++---------------------- 1 file changed, 23 insertions(+), 27 deletions(-)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 7961231..28b244a 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -39,6 +39,11 @@ #define TX_ENDPOINT_MAXIMUM_PACKET_SIZE (0x0040)
#define EP_BUFFER_SIZE 4096 +/* + * EP_BUFFER_SIZE must always be an integral multiple of maxpacket size + * (64 or 512 or 1024), else we break on certain controllers like DWC3 + * that expect bulk OUT requests to be divisible by maxpacket size. + */
struct f_fastboot { struct usb_function usb_function; @@ -57,7 +62,6 @@ static struct f_fastboot *fastboot_func; static unsigned int fastboot_flash_session_id; static unsigned int download_size; static unsigned int download_bytes; -static bool is_high_speed;
static struct usb_endpoint_descriptor fs_ep_in = { .bLength = USB_DT_ENDPOINT_SIZE, @@ -269,11 +273,6 @@ static int fastboot_set_alt(struct usb_function *f, debug("%s: func: %s intf: %d alt: %d\n", __func__, f->name, interface, alt);
- if (gadget->speed == USB_SPEED_HIGH) - is_high_speed = true; - else - is_high_speed = false; - d = fb_ep_desc(gadget, &fs_ep_out, &hs_ep_out); ret = usb_ep_enable(f_fb->out_ep, d); if (ret) { @@ -455,20 +454,27 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req) fastboot_tx_write_str(response); }
-static unsigned int rx_bytes_expected(unsigned int maxpacket) +static unsigned int rx_bytes_expected(struct usb_ep *ep) { int rx_remain = download_size - download_bytes; - int rem = 0; - if (rx_remain < 0) + unsigned int rem; + unsigned int maxpacket = ep->maxpacket; + + if (rx_remain <= 0) return 0; - if (rx_remain > EP_BUFFER_SIZE) + else if (rx_remain > EP_BUFFER_SIZE) return EP_BUFFER_SIZE; - if (rx_remain < maxpacket) { - rx_remain = maxpacket; - } else if (rx_remain % maxpacket != 0) { - rem = rx_remain % maxpacket; + + /* + * Some controllers e.g. DWC3 don't like OUT transfers to be + * not ending in maxpacket boundary. So just make them happy by + * always requesting for integral multiple of maxpackets. + * This shouldn't bother controllers that don't care about it. + */ + rem = rx_remain % maxpacket; + if (rem > 0) rx_remain = rx_remain + (maxpacket - rem); - } + return rx_remain; }
@@ -480,7 +486,6 @@ static void rx_handler_dl_image(struct usb_ep *ep, struct usb_request *req) const unsigned char *buffer = req->buf; unsigned int buffer_size = req->actual; unsigned int pre_dot_num, now_dot_num; - unsigned int max;
if (req->status != 0) { printf("Bad status: %d\n", req->status); @@ -518,11 +523,7 @@ static void rx_handler_dl_image(struct usb_ep *ep, struct usb_request *req)
printf("\ndownloading of %d bytes finished\n", download_bytes); } else { - max = is_high_speed ? hs_ep_out.wMaxPacketSize : - fs_ep_out.wMaxPacketSize; - req->length = rx_bytes_expected(max); - if (req->length < ep->maxpacket) - req->length = ep->maxpacket; + req->length = rx_bytes_expected(ep); }
req->actual = 0; @@ -533,7 +534,6 @@ static void cb_download(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; char response[FASTBOOT_RESPONSE_LEN]; - unsigned int max;
strsep(&cmd, ":"); download_size = simple_strtoul(cmd, NULL, 16); @@ -549,11 +549,7 @@ static void cb_download(struct usb_ep *ep, struct usb_request *req) } else { sprintf(response, "DATA%08x", download_size); req->complete = rx_handler_dl_image; - max = is_high_speed ? hs_ep_out.wMaxPacketSize : - fs_ep_out.wMaxPacketSize; - req->length = rx_bytes_expected(max); - if (req->length < ep->maxpacket) - req->length = ep->maxpacket; + req->length = rx_bytes_expected(ep); } fastboot_tx_write_str(response); }
Hi Roger,
- EP_BUFFER_SIZE must always be an integral multiple of maxpacket
size
- (64 or 512 or 1024), else we break on certain controllers like
DWC3
- that expect bulk OUT requests to be divisible by maxpacket size.
- else
- int rem = 0;
- unsigned int rem;
- unsigned int maxpacket = ep->maxpacket;
- if (rx_remain <= 0) return 0;
- else if (rx_remain > EP_BUFFER_SIZE) return EP_BUFFER_SIZE;
by
it.
- if (rem > 0) rx_remain = rx_remain + (maxpacket - rem);
- return rx_remain;
unsigned int max;
@@ -518,11 +523,7 @@ static void rx_handler_dl_image(struct usb_ep *ep, struct usb_request *req) printf("\ndownloading of %d bytes finished\n", download_bytes); } else {
req->actual = 0;
unsigned int max;
} fastboot_tx_write_str(response);req->length = rx_bytes_expected(ep);
Reviewed-by: Lukasz Majewski l.majewski@samsung.com
Hi Roger,
size
DWC3
- else
- int rem = 0;
- unsigned int rem;
by
it.
- return rx_remain;
unsigned int max;
req->actual = 0;
unsigned int max;
I cannot apply this patch on temporary u-boot-usb/master branch (SHA1: e6c0bc0643e5a4387fecbcf83080d0b796eb067c).
Could you apply your changes (from this patch) on top of newest u-boot-usb repo?
On Thu, Apr 21, 2016 at 3:03 AM, Lukasz Majewski l.majewski@samsung.com wrote:
Hi Roger,
size
DWC3
else
int rem = 0;
if (rx_remain < 0)
unsigned int rem;
by
it.
return rx_remain;
unsigned int max; if (req->status != 0) { printf("Bad status: %d\n", req->status);
req->length = rx_bytes_expected(ep); } req->actual = 0;
unsigned int max; strsep(&cmd, ":"); download_size = simple_strtoul(cmd, NULL, 16);
Lukasz, (in case Roger doesn't reply soon....)
-- this needs to be applied on top of his earlier patches: (1) http://patchwork.ozlabs.org/patch/609417/ [U-Boot,1/2] fastboot: Fix wMaxPacketSize for High-Speed IN endpoint (2) http://patchwork.ozlabs.org/patch/609896/ [U-Boot,v2,2/2] fastboot: Enable the respective speed endpoints at runtime
... then this one will apply (http://patchwork.ozlabs.org/patch/612006/)
Thanks, Steve
Lukasz Majewski
Samsung R&D Institute Poland (SRPOL) | Linux Platform Group
Hi Roger,
maxpacket size
DWC3
size.
else
int rem = 0;
if (rx_remain < 0)
unsigned int rem;
by
it.
return rx_remain;
Steve, thanks for tip. I was missing this information :-)
Best regards, Łukasz
Thanks, Steve
Lukasz Majewski
Request size can be greater than ep.packet and still end in a short packet. We need to tackle this case as end of transfer (if short_not_ok is not set) as indicated in USB 2.0 Specification [1], else we get stuck up on certain protocols like fastboot.
[1] - USB2.0 Specification, Section 5.3.2 Pipes
Reported-by: Steve Rae steve.rae@broadcom.com Signed-off-by: Roger Quadros rogerq@ti.com Tested-by: Steve Rae steve.rae@broadcom.com --- drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c index bce9c30..a31d875 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c @@ -229,7 +229,7 @@ static void complete_rx(struct dwc2_udc *dev, u8 ep_num) ROUND(xfer_size, CONFIG_SYS_CACHELINE_SIZE));
req->req.actual += min(xfer_size, req->req.length - req->req.actual); - is_short = (xfer_size < ep->ep.maxpacket); + is_short = xfer_size % ep->ep.maxpacket;
debug_cond(DEBUG_OUT_EP != 0, "%s: RX DMA done : ep = %d, rx bytes = %d/%d, "
Hi Roger,
- is_short = xfer_size % ep->ep.maxpacket;
is_short is a flag - so maybe it would be better to write something like:
is_short = !!(xfer_size % ep->ep.maxpacket)) ?
I'm going to test those patches on my boards. I will share the results ASAP.
Hi Lukasz,
On 19/04/16 12:02, Lukasz Majewski wrote:
Hi Roger,
but it is defined as u32 so I thought it might as well print the short packet length instead of just 1/0.
-- cheers, -roger
Hi Roger,
Hi Lukasz,
Hi Roger,
I mean that it looks strange for me in debug message when one see:
"is_short: 8" (as it was shown at Steve's output).
-- cheers, -roger
On 19/04/16 14:25, Lukasz Majewski wrote:
Hi Roger,
Hi Lukasz,
Hi Roger,
Agreed. I'll convert it to boolean then.
-- cheers, -roger
diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c index bce9c30..9aa0f33 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c @@ -229,7 +229,7 @@ static void complete_rx(struct dwc2_udc *dev, u8 ep_num) ROUND(xfer_size, CONFIG_SYS_CACHELINE_SIZE));
req->req.actual += min(xfer_size, req->req.length - req->req.actual); - is_short = (xfer_size < ep->ep.maxpacket); + is_short = !!(xfer_size % ep->ep.maxpacket);
Hi Roger,
Tested-by: Lukasz Majewski l.majewski@samsung.com
Test HW: Odroid U3 (Exynos 4412)
Test: ./test/py DFU & UMS
Remaining bytes means bytes that are not yet transferred and not the bytes that were transferred in the last transfer.
Reported-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Roger Quadros rogerq@ti.com --- drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c index a31d875..0594c3d 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c @@ -235,7 +235,7 @@ static void complete_rx(struct dwc2_udc *dev, u8 ep_num) "%s: RX DMA done : ep = %d, rx bytes = %d/%d, " "is_short = %d, DOEPTSIZ = 0x%x, remained bytes = %d\n", __func__, ep_num, req->req.actual, req->req.length, - is_short, ep_tsr, xfer_size); + is_short, ep_tsr, req->req.length - req->req.actual);
if (is_short || req->req.actual == req->req.length) { if (ep_num == EP0_CON && dev->ep0state == DATA_STATE_RECV) { @@ -292,7 +292,7 @@ static void complete_tx(struct dwc2_udc *dev, u8 ep_num) "%s: TX DMA done : ep = %d, tx bytes = %d/%d, " "is_short = %d, DIEPTSIZ = 0x%x, remained bytes = %d\n", __func__, ep_num, req->req.actual, req->req.length, - is_short, ep_tsr, xfer_size); + is_short, ep_tsr, req->req.length - req->req.actual);
if (ep_num == 0) { if (dev->ep0state == DATA_STATE_XMIT) {
Hi Roger,
req->req.actual); if (is_short || req->req.actual == req->req.length) { if (ep_num == EP0_CON && dev->ep0state == DATA_STATE_RECV) { @@ -292,7 +292,7 @@ static void complete_tx(struct dwc2_udc *dev, u8 ep_num) "%s: TX DMA done : ep = %d, tx bytes = %d/%d, " "is_short = %d, DIEPTSIZ = 0x%x, remained bytes = %d\n", __func__, ep_num, req->req.actual, req->req.length,
Acked-by: Lukasz Majewski l.majewski@samsung.com
On Thu, Apr 21, 2016 at 3:05 AM, Lukasz Majewski l.majewski@samsung.com wrote:
Hi Roger,
is_short, ep_tsr, req->req.length - req->req.actual); if (ep_num == 0) { if (dev->ep0state == DATA_STATE_XMIT) {
[Test HW: bcm28155_ap board]
Thanks, Steve
-- Best regards,
Lukasz Majewski
Hi Roger,
Thanks, Steve
retry because patchworks missed this....
Tested-by: Steve Rae srae@broadcom.com [Test HW: bcm28155_ap board]
-- Best regards,
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
Roger Quadros
Steve Rae
