[PATCH v2 1/1] arm: apple: Switch to fully dynamic mem layout
Support for Apple M1 Pro and Max will allow using a single binary for all M1 SoCs. The M1 Pro/Max have a different memory layout. The RAM start address is 0x100_0000_0000 instead of 0x8_0000_0000. Replace the hardcoded memory layout with dynamic initialized environment variables in board_late_init().
Tested on Mac Mini (2020) and Macbook Pro 14-inch (2021).
Signed-off-by: Janne Grunau j@jannau.net Reviewed-by: Mark Kettenis kettenis@openbsd.org ---
Changed in v2: - ensure adresses are aligned - added space between addresses at the top and stack - added loadaddr and set the default to 0 - pick up Mark's Reviewed-by - whitespace fixes
arch/arm/mach-apple/board.c | 31 +++++++++++++++++++++++++++++++ configs/apple_m1_defconfig | 3 ++- include/configs/apple.h | 5 ----- 3 files changed, 33 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-apple/board.c b/arch/arm/mach-apple/board.c index b7e8d212f1..46877569af 100644 --- a/arch/arm/mach-apple/board.c +++ b/arch/arm/mach-apple/board.c @@ -136,3 +136,34 @@ ulong board_get_usable_ram_top(ulong total_size) */ return 0x980000000; } + +int board_late_init(void) +{ + unsigned long base; + unsigned long top; + u32 status = 0; + + /* Reserve 4M each for scriptaddr and pxefile_addr_r at the top of RAM + * at least 1M below the stack. + */ + top = gd->start_addr_sp - CONFIG_STACK_SIZE - SZ_8M - SZ_1M; + top = ALIGN_DOWN(top, SZ_8M); + + status |= env_set_hex("scriptaddr", top + SZ_4M); + status |= env_set_hex("pxefile_addr_r", top); + + /* somewhat based on the Linux Kernel boot requirements: + * align by 2M and maximal FDT size 2M + */ + base = ALIGN(gd->ram_base, SZ_2M); + + status |= env_set_hex("fdt_addr_r", base); + status |= env_set_hex("kernel_addr_r", base + SZ_2M); + status |= env_set_hex("ramdisk_addr_r", base + SZ_128M); + status |= env_set_hex("loadaddr", base + SZ_2G); + + if (status) + log_warning("late_init: Failed to set run time variables\n"); + + return 0; +} diff --git a/configs/apple_m1_defconfig b/configs/apple_m1_defconfig index cb235e4e7d..b96d31db2c 100644 --- a/configs/apple_m1_defconfig +++ b/configs/apple_m1_defconfig @@ -4,10 +4,11 @@ CONFIG_DEFAULT_DEVICE_TREE="t8103-j274" CONFIG_DEBUG_UART_BASE=0x235200000 CONFIG_DEBUG_UART_CLOCK=240000 CONFIG_DEBUG_UART=y -CONFIG_SYS_LOAD_ADDR=0x880000000 +CONFIG_SYS_LOAD_ADDR=0x0 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_LATE_INIT=y # CONFIG_NET is not set # CONFIG_MMC is not set CONFIG_DEBUG_UART_ANNOUNCE=y diff --git a/include/configs/apple.h b/include/configs/apple.h index 3e5fb495f1..f73f4f047b 100644 --- a/include/configs/apple.h +++ b/include/configs/apple.h @@ -9,10 +9,6 @@ "stdout=serial,vidconsole\0" \ "stderr=serial,vidconsole\0"
-#define ENV_MEM_LAYOUT_SETTINGS \ - "fdt_addr_r=0x960100000\0" \ - "kernel_addr_r=0x960200000\0" - #if CONFIG_IS_ENABLED(CMD_USB) #define BOOT_TARGET_USB(func) func(USB, usb, 0) #else @@ -26,7 +22,6 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ ENV_DEVICE_SETTINGS \ - ENV_MEM_LAYOUT_SETTINGS \ BOOTENV
#endif
Janne Grunau
