[U-Boot] [PATCH 1/1] ppc4xx: fix UIC hang if critical or non-critical interrupt is set at the same time as a normal interrupt is set on UIC0
Signed-off-by: Victor Gallardo vgallardo@amcc.com --- cpu/ppc4xx/uic.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpu/ppc4xx/uic.c b/cpu/ppc4xx/uic.c index 7944c6c..a95d1cb 100644 --- a/cpu/ppc4xx/uic.c +++ b/cpu/ppc4xx/uic.c @@ -129,11 +129,11 @@ void external_interrupt(struct pt_regs *regs) uic_interrupt(UIC3_DCR_BASE, 96); #endif
+ mtdcr(uic0sr, (uic_msr & UICB0_ALL)); + if (uic_msr & ~(UICB0_ALL)) uic_interrupt(UIC0_DCR_BASE, 0);
- mtdcr(uic0sr, uic_msr); - return; }
Dear vgallardo@amcc.com,
Can you please provide a real name with your mail address when submitting patches?
In message 1219956791-5783-1-git-send-email-vgallardo@amcc.com you wrote:
Subject: [U-Boot] [PATCH 1/1] ppc4xx: fix UIC hang if critical or non-critical interrupt is set at the same time as a normal interrupt is set on UIC0
This is an awfully long subject line.
As you are probably aware, the Subject line will be used as part of the git commit message, and it will be shown as "title" of your patch by tools like "git log" or "gitk" etc.
However, these tools will truncate the line after 70 characters. That means, your commit message will read:
commit ... Author: vgallardo@amcc.com Date: ...
This is not exactly useful, is it?
So please use SHORT subject lines and provide the explanation in the message body.
Thanks.
Dear Feng Kan,
In message 48B72323.4050608@amcc.com you wrote:
I send the patch out for Victor. In the original email the From
field did indicate his name. Am I missing something?
I don't know what you did, but there were actually two semi-identical postings:
------ Subject: [U-Boot] [PATCH 1/1] ppc4xx: fix UIC hang if critical or non-critical interrupt is set at the same time as a normal interrupt is set on UIC0 From: vgallardo@amcc.com Date: Thu, 28 Aug 2008 13:53:11 -0700 (22:53 MEST) To: u-boot@lists.denx.de Cc: sr@denx.de ------ Subject: [U-Boot] [PATCH 1/1] ppc4xx: fix UIC hang if critical or non-critical interrupt is set at the same time as a normal interrupt is set on UIC0 From: fkan@amcc.com Date: Thu, 28 Aug 2008 13:55:14 -0700 (22:55 MEST) To: u-boot@lists.denx.de Cc: sr@denx.de ------
As you can see, both were sent about two minutes apart, and none of them had a realname in the From: field.
See also http://lists.denx.de/pipermail/u-boot/2008-August/039566.html and http://lists.denx.de/pipermail/u-boot/2008-August/039567.html
Feng Kan
vgallardo@amcc.com
