[PATCH] net: phy: mscc: add support for VSC8502 in dual RGMII mode
The VSC8502 is a Microchip (formerly Microsemi, formerly Vitesse) dual port, gigabit Ethernet copper PHY which supports the MII, GMII and RGMII MAC-side interfaces.
Of these, I could only test RGMII, and my board needed RGMII delays to be applied by software, so I am able to confirm that this patch handles that properly.
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com --- drivers/net/phy/mscc.c | 56 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 56 insertions(+)
diff --git a/drivers/net/phy/mscc.c b/drivers/net/phy/mscc.c index d1a643cf5a0c..f9482b21a010 100644 --- a/drivers/net/phy/mscc.c +++ b/drivers/net/phy/mscc.c @@ -19,6 +19,7 @@ /* Microsemi PHY ID's */ #define PHY_ID_VSC8530 0x00070560 #define PHY_ID_VSC8531 0x00070570 +#define PHY_ID_VSC8502 0x00070630 #define PHY_ID_VSC8540 0x00070760 #define PHY_ID_VSC8541 0x00070770 #define PHY_ID_VSC8574 0x000704a0 @@ -1513,6 +1514,50 @@ static int vsc8584_config(struct phy_device *phydev) return vsc8584_config_init(phydev); }
+static int vsc8502_config(struct phy_device *phydev) +{ + bool rgmii_rx_delay = false, rgmii_tx_delay = false; + u16 reg = 0; + int ret; + + /* Assume nothing needs to be done for the default GMII/MII mode */ + if (!phy_interface_is_rgmii(phydev)) + return 0; + + /* Set Extended PHY Control 1 register to RGMII */ + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_PHY_EXT_PHY_CNTL_1_REG, + BIT(13) | BIT(12)); + + /* Soft reset required after changing PHY mode from the default + * of GMII/MII + */ + ret = mscc_phy_soft_reset(phydev); + if (ret) + return ret; + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + rgmii_rx_delay = true; + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + rgmii_tx_delay = true; + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_EXT2); + + if (rgmii_rx_delay) + reg |= VSC_PHY_RGMII_DELAY_2000_PS << RGMII_RX_CLK_DELAY_POS; + if (rgmii_tx_delay) + reg |= VSC_PHY_RGMII_DELAY_2000_PS << RGMII_TX_CLK_DELAY_POS; + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_PHY_RGMII_CNTL_REG, reg); + + phy_write(phydev, MDIO_DEVAD_NONE, MSCC_EXT_PAGE_ACCESS, + MSCC_PHY_PAGE_STD); + + return 0; +} + static struct phy_driver VSC8530_driver = { .name = "Microsemi VSC8530", .uid = PHY_ID_VSC8530, @@ -1533,6 +1578,16 @@ static struct phy_driver VSC8531_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver VSC8502_driver = { + .name = "Microsemi VSC8502", + .uid = PHY_ID_VSC8502, + .mask = 0x000ffff0, + .features = PHY_GBIT_FEATURES, + .config = &vsc8502_config, + .startup = &mscc_startup, + .shutdown = &genphy_shutdown, +}; + static struct phy_driver VSC8540_driver = { .name = "Microsemi VSC8540", .uid = PHY_ID_VSC8540, @@ -1577,6 +1632,7 @@ int phy_mscc_init(void) { phy_register(&VSC8530_driver); phy_register(&VSC8531_driver); + phy_register(&VSC8502_driver); phy_register(&VSC8540_driver); phy_register(&VSC8541_driver); phy_register(&VSC8574_driver);
On Tue, Sep 28, 2021 at 2:13 AM Vladimir Oltean vladimir.oltean@nxp.com wrote:
u16 reg = 0;
int ret;
BIT(13) | BIT(12));
* of GMII/MII
if (ret)
return ret;
if (rgmii_rx_delay)
if (rgmii_tx_delay)
MSCC_PHY_PAGE_STD);
.mask = 0x000ffff0,
-- 2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
u16 reg = 0;
int ret;
BIT(13) | BIT(12));
* of GMII/MII
if (ret)
return ret;
if (rgmii_rx_delay)
if (rgmii_tx_delay)
MSCC_PHY_PAGE_STD);
.mask = 0x000ffff0,
-- 2.25.1
Applied to u-boot-net/next Thanks, Ramon.
Ramon Fried
Vladimir Oltean
