[PATCH 1/4] powerpc: Remove unused MPC8540/60ADS code
Remove some code, primarily CPM2 related, that is now unused since the removal of MPC8540/60ADS.
Fixes 3913191c8a6b ("powerpc: mpc8540ads: mpc8560ads: Drop support for MPC8540/60ADS") Signed-off-by: Tom Rini trini@konsulko.com --- arch/powerpc/cpu/mpc85xx/Makefile | 2 - arch/powerpc/cpu/mpc85xx/commproc.c | 188 ------ arch/powerpc/cpu/mpc85xx/cpu.c | 4 - arch/powerpc/cpu/mpc85xx/cpu_init.c | 72 --- arch/powerpc/cpu/mpc85xx/fdt.c | 8 - arch/powerpc/cpu/mpc85xx/serial_scc.c | 262 -------- arch/powerpc/cpu/mpc85xx/speed.c | 16 - arch/powerpc/include/asm/cpm_85xx.h | 824 ------------------------- arch/powerpc/include/asm/global_data.h | 11 - arch/powerpc/include/asm/immap_85xx.h | 327 ---------- arch/powerpc/lib/bdinfo.c | 13 - arch/powerpc/lib/bootm.c | 6 - drivers/pci/pci_mpc85xx.c | 1 - include/asm-generic/u-boot.h | 6 - include/configs/MPC8540ADS.h | 303 --------- include/configs/MPC8560ADS.h | 292 --------- 16 files changed, 2335 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc85xx/commproc.c delete mode 100644 arch/powerpc/cpu/mpc85xx/serial_scc.c delete mode 100644 arch/powerpc/include/asm/cpm_85xx.h delete mode 100644 include/configs/MPC8540ADS.h delete mode 100644 include/configs/MPC8560ADS.h
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 6f4ad1f9b762..c32cde04e16a 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -27,7 +27,6 @@ obj-$(CONFIG_MP) += release.o ifndef CONFIG_SPL_BUILD obj-$(CONFIG_CMD_ERRATA) += cmd_errata.o endif -obj-$(CONFIG_CPM2) += commproc.o
obj-$(CONFIG_OF_LIBFDT) += fdt.o obj-$(CONFIG_FSL_CORENET) += liodn.o @@ -49,7 +48,6 @@ obj-$(CONFIG_ARCH_T2080) += t2080_ids.o
obj-$(CONFIG_QE) += qe_io.o -obj-$(CONFIG_CPM2) += serial_scc.o obj-$(CONFIG_SYS_FSL_QORIQ_CHASSIS1) += fsl_corenet_serdes.o obj-$(CONFIG_SYS_FSL_QORIQ_CHASSIS2) += fsl_corenet2_serdes.o
diff --git a/arch/powerpc/cpu/mpc85xx/commproc.c b/arch/powerpc/cpu/mpc85xx/commproc.c deleted file mode 100644 index 8e8427a08bbe..000000000000 --- a/arch/powerpc/cpu/mpc85xx/commproc.c +++ /dev/null @@ -1,188 +0,0 @@ -/* - * Adapted for Motorola MPC8560 chips - * Xianghua Xiao x.xiao@motorola.com - * - * This file is based on "arch/powerpc/8260_io/commproc.c" - here is it's - * copyright notice: - * - * General Purpose functions for the global management of the - * 8220 Communication Processor Module. - * Copyright (c) 1999 Dan Malek (dmalek@jlc.net) - * Copyright (c) 2000 MontaVista Software, Inc (source@mvista.com) - * 2.3.99 Updates - * Copyright (c) 2003 Motorola,Inc. - * - * In addition to the individual control of the communication - * channels, there are a few functions that globally affect the - * communication processor. - * - * Buffer descriptors must be allocated from the dual ported memory - * space. The allocator for that is here. When the communication - * process is reset, we reclaim the memory available. There is - * currently no deallocator for this memory. - */ -#include <common.h> -#include <asm-offsets.h> -#include <asm/cpm_85xx.h> -#include <asm/global_data.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* - * because we have stack and init data in dual port ram - * we must reduce the size - */ -#undef CPM_DATAONLY_SIZE -#define CPM_DATAONLY_SIZE ((uint)(8 * 1024) - CPM_DATAONLY_BASE) - -void -m8560_cpm_reset(void) -{ - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - volatile ulong count; - - gd = (gd_t *) (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET); - - /* Reclaim the DP memory for our use. - */ - gd->arch.dp_alloc_base = CPM_DATAONLY_BASE; - gd->arch.dp_alloc_top = gd->arch.dp_alloc_base + CPM_DATAONLY_SIZE; - - /* - * Reset CPM - */ - cpm->im_cpm_cp.cpcr = CPM_CR_RST; - count = 0; - do { /* Spin until command processed */ - __asm__ __volatile__ ("eieio"); - } while ((cpm->im_cpm_cp.cpcr & CPM_CR_FLG) && ++count < 1000000); -} - -/* Allocate some memory from the dual ported ram. - * To help protocols with object alignment restrictions, we do that - * if they ask. - */ -uint -m8560_cpm_dpalloc(uint size, uint align) -{ - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - uint retloc; - uint align_mask, off; - uint savebase; - - align_mask = align - 1; - savebase = gd->arch.dp_alloc_base; - - off = gd->arch.dp_alloc_base & align_mask; - if (off != 0) - gd->arch.dp_alloc_base += (align - off); - - if ((off = size & align_mask) != 0) - size += align - off; - - if ((gd->arch.dp_alloc_base + size) >= gd->arch.dp_alloc_top) { - gd->arch.dp_alloc_base = savebase; - panic("m8560_cpm_dpalloc: ran out of dual port ram!"); - } - - retloc = gd->arch.dp_alloc_base; - gd->arch.dp_alloc_base += size; - - memset((void *)&(cpm->im_dprambase[retloc]), 0, size); - - return(retloc); -} - -/* We also own one page of host buffer space for the allocation of - * UART "fifos" and the like. - */ -uint -m8560_cpm_hostalloc(uint size, uint align) -{ - /* the host might not even have RAM yet - just use dual port RAM */ - return (m8560_cpm_dpalloc(size, align)); -} - -/* Set a baud rate generator. This needs lots of work. There are - * eight BRGs, which can be connected to the CPM channels or output - * as clocks. The BRGs are in two different block of internal - * memory mapped space. - * The baud rate clock is the system clock divided by something. - * It was set up long ago during the initial boot phase and is - * is given to us. - * Baud rate clocks are zero-based in the driver code (as that maps - * to port numbers). Documentation uses 1-based numbering. - */ -#define BRG_INT_CLK gd->arch.brg_clk -#define BRG_UART_CLK ((BRG_INT_CLK + 15) / 16) - -/* This function is used by UARTS, or anything else that uses a 16x - * oversampled clock. - */ -void -m8560_cpm_setbrg(uint brg, uint rate) -{ - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - volatile uint *bp; - - /* This is good enough to get SMCs running..... - */ - if (brg < 4) { - bp = (uint *)&(cpm->im_cpm_brg1.brgc1); - } - else { - bp = (uint *)&(cpm->im_cpm_brg2.brgc5); - brg -= 4; - } - bp += brg; - *bp = (((((BRG_UART_CLK+rate-1)/rate)-1)&0xfff)<<1)|CPM_BRG_EN; -} - -/* This function is used to set high speed synchronous baud rate - * clocks. - */ -void -m8560_cpm_fastbrg(uint brg, uint rate, int div16) -{ - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - volatile uint *bp; - - /* This is good enough to get SMCs running..... - */ - if (brg < 4) { - bp = (uint *)&(cpm->im_cpm_brg1.brgc1); - } - else { - bp = (uint *)&(cpm->im_cpm_brg2.brgc5); - brg -= 4; - } - bp += brg; - *bp = (((((BRG_INT_CLK+rate-1)/rate)-1)&0xfff)<<1)|CPM_BRG_EN; - if (div16) - *bp |= CPM_BRG_DIV16; -} - -/* This function is used to set baud rate generators using an external - * clock source and 16x oversampling. - */ - -void -m8560_cpm_extcbrg(uint brg, uint rate, uint extclk, int pinsel) -{ - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - volatile uint *bp; - - if (brg < 4) { - bp = (uint *)&(cpm->im_cpm_brg1.brgc1); - } - else { - bp = (uint *)&(cpm->im_cpm_brg2.brgc5); - brg -= 4; - } - bp += brg; - *bp = ((((((extclk/16)+rate-1)/rate)-1)&0xfff)<<1)|CPM_BRG_EN; - if (pinsel == 0) - *bp |= CPM_BRG_EXTC_CLK3_9; - else - *bp |= CPM_BRG_EXTC_CLK5_15; -} diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index cd32290410f6..cc1d02df8115 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -241,10 +241,6 @@ int checkcpu (void) printf("IFC:%-4s MHz\n", strmhz(buf1, sysinfo.freq_localbus)); #endif
-#ifdef CONFIG_CPM2 - printf("CPM: %s MHz\n", strmhz(buf1, sysinfo.freq_systembus)); -#endif - #ifdef CONFIG_QE printf(" QE:%-4s MHz\n", strmhz(buf1, sysinfo.freq_qe)); #endif diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index e920e01b254f..e9e133baf070 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -152,70 +152,6 @@ static void config_qe_ioports(void) } #endif
-#ifdef CONFIG_CPM2 -void config_8560_ioports (volatile ccsr_cpm_t * cpm) -{ - int portnum; - - for (portnum = 0; portnum < 4; portnum++) { - uint pmsk = 0, - ppar = 0, - psor = 0, - pdir = 0, - podr = 0, - pdat = 0; - iop_conf_t *iopc = (iop_conf_t *) & iop_conf_tab[portnum][0]; - iop_conf_t *eiopc = iopc + 32; - uint msk = 1; - - /* - * NOTE: - * index 0 refers to pin 31, - * index 31 refers to pin 0 - */ - while (iopc < eiopc) { - if (iopc->conf) { - pmsk |= msk; - if (iopc->ppar) - ppar |= msk; - if (iopc->psor) - psor |= msk; - if (iopc->pdir) - pdir |= msk; - if (iopc->podr) - podr |= msk; - if (iopc->pdat) - pdat |= msk; - } - - msk <<= 1; - iopc++; - } - - if (pmsk != 0) { - volatile ioport_t *iop = ioport_addr (cpm, portnum); - uint tpmsk = ~pmsk; - - /* - * the (somewhat confused) paragraph at the - * bottom of page 35-5 warns that there might - * be "unknown behaviour" when programming - * PSORx and PDIRx, if PPARx = 1, so I - * decided this meant I had to disable the - * dedicated function first, and enable it - * last. - */ - iop->ppar &= tpmsk; - iop->psor = (iop->psor & tpmsk) | psor; - iop->podr = (iop->podr & tpmsk) | podr; - iop->pdat = (iop->pdat & tpmsk) | pdat; - iop->pdir = (iop->pdir & tpmsk) | pdir; - iop->ppar |= ppar; - } - } -} -#endif - #ifdef CONFIG_SYS_FSL_CPC #if defined(CONFIG_RAMBOOT_PBL) || defined(CONFIG_SYS_CPC_REINIT_F) void disable_cpc_sram(void) @@ -474,16 +410,8 @@ ulong cpu_init_f(void) #endif #endif
-#ifdef CONFIG_CPM2 - config_8560_ioports((ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR); -#endif - init_early_memctl_regs();
-#if defined(CONFIG_CPM2) - m8560_cpm_reset(); -#endif - #if defined(CONFIG_QE) && !defined(CONFIG_U_QE) /* Config QE ioports */ config_qe_ioports(); diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index d4b828e3824c..c8ad6a1b01ce 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -652,14 +652,6 @@ void ft_cpu_setup(void *blob, struct bd_info *bd) "clock-frequency", CONFIG_SYS_NS16550_CLK, 1); #endif
-#ifdef CONFIG_CPM2 - do_fixup_by_compat_u32(blob, "fsl,cpm2-scc-uart", - "current-speed", gd->baudrate, 1); - - do_fixup_by_compat_u32(blob, "fsl,cpm2-brg", - "clock-frequency", bd->bi_brgfreq, 1); -#endif - #ifdef CONFIG_FSL_CORENET do_fixup_by_compat_u32(blob, "fsl,qoriq-clockgen-1.0", "clock-frequency", get_board_sys_clk(), 1); diff --git a/arch/powerpc/cpu/mpc85xx/serial_scc.c b/arch/powerpc/cpu/mpc85xx/serial_scc.c deleted file mode 100644 index a2505d1ffc1d..000000000000 --- a/arch/powerpc/cpu/mpc85xx/serial_scc.c +++ /dev/null @@ -1,262 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2003 Motorola Inc. - * Xianghua Xiao (X.Xiao@motorola.com) - * Modified based on 8260 for 8560. - * - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Hacked for MPC8260 by Murray.Jensen@cmst.csiro.au, 19-Oct-00. - */ - -/* - * Minimal serial functions needed to use one of the SCC ports - * as serial console interface. - */ - -#include <common.h> -#include <asm/cpm_85xx.h> -#include <serial.h> -#include <asm/global_data.h> -#include <linux/compiler.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_CONS_ON_SCC) - -#if CONFIG_CONS_INDEX == 1 /* Console on SCC1 */ - -#define SCC_INDEX 0 -#define PROFF_SCC PROFF_SCC1 -#define CMXSCR_MASK (CMXSCR_GR1|CMXSCR_SC1|\ - CMXSCR_RS1CS_MSK|CMXSCR_TS1CS_MSK) -#define CMXSCR_VALUE (CMXSCR_RS1CS_BRG1|CMXSCR_TS1CS_BRG1) -#define CPM_CR_SCC_PAGE CPM_CR_SCC1_PAGE -#define CPM_CR_SCC_SBLOCK CPM_CR_SCC1_SBLOCK - -#elif CONFIG_CONS_INDEX == 2 /* Console on SCC2 */ - -#define SCC_INDEX 1 -#define PROFF_SCC PROFF_SCC2 -#define CMXSCR_MASK (CMXSCR_GR2|CMXSCR_SC2|\ - CMXSCR_RS2CS_MSK|CMXSCR_TS2CS_MSK) -#define CMXSCR_VALUE (CMXSCR_RS2CS_BRG2|CMXSCR_TS2CS_BRG2) -#define CPM_CR_SCC_PAGE CPM_CR_SCC2_PAGE -#define CPM_CR_SCC_SBLOCK CPM_CR_SCC2_SBLOCK - -#elif CONFIG_CONS_INDEX == 3 /* Console on SCC3 */ - -#define SCC_INDEX 2 -#define PROFF_SCC PROFF_SCC3 -#define CMXSCR_MASK (CMXSCR_GR3|CMXSCR_SC3|\ - CMXSCR_RS3CS_MSK|CMXSCR_TS3CS_MSK) -#define CMXSCR_VALUE (CMXSCR_RS3CS_BRG3|CMXSCR_TS3CS_BRG3) -#define CPM_CR_SCC_PAGE CPM_CR_SCC3_PAGE -#define CPM_CR_SCC_SBLOCK CPM_CR_SCC3_SBLOCK - -#elif CONFIG_CONS_INDEX == 4 /* Console on SCC4 */ - -#define SCC_INDEX 3 -#define PROFF_SCC PROFF_SCC4 -#define CMXSCR_MASK (CMXSCR_GR4|CMXSCR_SC4|\ - CMXSCR_RS4CS_MSK|CMXSCR_TS4CS_MSK) -#define CMXSCR_VALUE (CMXSCR_RS4CS_BRG4|CMXSCR_TS4CS_BRG4) -#define CPM_CR_SCC_PAGE CPM_CR_SCC4_PAGE -#define CPM_CR_SCC_SBLOCK CPM_CR_SCC4_SBLOCK - -#else - -#error "console not correctly defined" - -#endif - -static int mpc85xx_serial_init(void) -{ - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - volatile ccsr_cpm_scc_t *sp; - volatile scc_uart_t *up; - volatile cbd_t *tbdf, *rbdf; - volatile ccsr_cpm_cp_t *cp = &(cpm->im_cpm_cp); - uint dpaddr; - - /* initialize pointers to SCC */ - - sp = (ccsr_cpm_scc_t *) &(cpm->im_cpm_scc[SCC_INDEX]); - up = (scc_uart_t *)&(cpm->im_dprambase[PROFF_SCC]); - - /* Disable transmitter/receiver. - */ - sp->gsmrl &= ~(SCC_GSMRL_ENR | SCC_GSMRL_ENT); - - /* put the SCC channel into NMSI (non multiplexd serial interface) - * mode and wire the selected SCC Tx and Rx clocks to BRGx (15-15). - */ - cpm->im_cpm_mux.cmxscr = \ - (cpm->im_cpm_mux.cmxscr&~CMXSCR_MASK)|CMXSCR_VALUE; - - /* Set up the baud rate generator. - */ - serial_setbrg (); - - /* Allocate space for two buffer descriptors in the DP ram. - * damm: allocating space after the two buffers for rx/tx data - */ - - dpaddr = m8560_cpm_dpalloc((2 * sizeof (cbd_t)) + 2, 16); - - /* Set the physical address of the host memory buffers in - * the buffer descriptors. - */ - rbdf = (cbd_t *)&(cpm->im_dprambase[dpaddr]); - rbdf->cbd_bufaddr = (uint) (rbdf+2); - rbdf->cbd_sc = BD_SC_EMPTY | BD_SC_WRAP; - tbdf = rbdf + 1; - tbdf->cbd_bufaddr = ((uint) (rbdf+2)) + 1; - tbdf->cbd_sc = BD_SC_WRAP; - - /* Set up the uart parameters in the parameter ram. - */ - up->scc_genscc.scc_rbase = dpaddr; - up->scc_genscc.scc_tbase = dpaddr+sizeof(cbd_t); - up->scc_genscc.scc_rfcr = CPMFCR_EB; - up->scc_genscc.scc_tfcr = CPMFCR_EB; - up->scc_genscc.scc_mrblr = 1; - up->scc_maxidl = 0; - up->scc_brkcr = 1; - up->scc_parec = 0; - up->scc_frmec = 0; - up->scc_nosec = 0; - up->scc_brkec = 0; - up->scc_uaddr1 = 0; - up->scc_uaddr2 = 0; - up->scc_toseq = 0; - up->scc_char1 = up->scc_char2 = up->scc_char3 = up->scc_char4 = 0x8000; - up->scc_char5 = up->scc_char6 = up->scc_char7 = up->scc_char8 = 0x8000; - up->scc_rccm = 0xc0ff; - - /* Mask all interrupts and remove anything pending. - */ - sp->sccm = 0; - sp->scce = 0xffff; - - /* Set 8 bit FIFO, 16 bit oversampling and UART mode. - */ - sp->gsmrh = SCC_GSMRH_RFW; /* 8 bit FIFO */ - sp->gsmrl = \ - SCC_GSMRL_TDCR_16 | SCC_GSMRL_RDCR_16 | SCC_GSMRL_MODE_UART; - - /* Set CTS no flow control, 1 stop bit, 8 bit character length, - * normal async UART mode, no parity - */ - sp->psmr = SCU_PSMR_CL; - - /* execute the "Init Rx and Tx params" CP command. - */ - - while (cp->cpcr & CPM_CR_FLG) /* wait if cp is busy */ - ; - - cp->cpcr = mk_cr_cmd(CPM_CR_SCC_PAGE, CPM_CR_SCC_SBLOCK, - 0, CPM_CR_INIT_TRX) | CPM_CR_FLG; - - while (cp->cpcr & CPM_CR_FLG) /* wait if cp is busy */ - ; - - /* Enable transmitter/receiver. - */ - sp->gsmrl |= SCC_GSMRL_ENR | SCC_GSMRL_ENT; - - return (0); -} - -static void mpc85xx_serial_setbrg(void) -{ -#if defined(CONFIG_CONS_USE_EXTC) - m8560_cpm_extcbrg(SCC_INDEX, gd->baudrate, - CONFIG_CONS_EXTC_RATE, CONFIG_CONS_EXTC_PINSEL); -#else - m8560_cpm_setbrg(SCC_INDEX, gd->baudrate); -#endif -} - -static void mpc85xx_serial_putc(const char c) -{ - volatile scc_uart_t *up; - volatile cbd_t *tbdf; - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - - if (c == '\n') - serial_putc ('\r'); - - up = (scc_uart_t *)&(cpm->im_dprambase[PROFF_SCC]); - tbdf = (cbd_t *)&(cpm->im_dprambase[up->scc_genscc.scc_tbase]); - - /* Wait for last character to go. - */ - while (tbdf->cbd_sc & BD_SC_READY) - ; - - /* Load the character into the transmit buffer. - */ - *(volatile char *)tbdf->cbd_bufaddr = c; - tbdf->cbd_datlen = 1; - tbdf->cbd_sc |= BD_SC_READY; -} - -static int mpc85xx_serial_getc(void) -{ - volatile cbd_t *rbdf; - volatile scc_uart_t *up; - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - unsigned char c; - - up = (scc_uart_t *)&(cpm->im_dprambase[PROFF_SCC]); - rbdf = (cbd_t *)&(cpm->im_dprambase[up->scc_genscc.scc_rbase]); - - /* Wait for character to show up. - */ - while (rbdf->cbd_sc & BD_SC_EMPTY) - ; - - /* Grab the char and clear the buffer again. - */ - c = *(volatile unsigned char *)rbdf->cbd_bufaddr; - rbdf->cbd_sc |= BD_SC_EMPTY; - - return (c); -} - -static int mpc85xx_serial_tstc(void) -{ - volatile cbd_t *rbdf; - volatile scc_uart_t *up; - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - - up = (scc_uart_t *)&(cpm->im_dprambase[PROFF_SCC]); - rbdf = (cbd_t *)&(cpm->im_dprambase[up->scc_genscc.scc_rbase]); - - return ((rbdf->cbd_sc & BD_SC_EMPTY) == 0); -} - -static struct serial_device mpc85xx_serial_drv = { - .name = "mpc85xx_serial", - .start = mpc85xx_serial_init, - .stop = NULL, - .setbrg = mpc85xx_serial_setbrg, - .putc = mpc85xx_serial_putc, - .puts = default_serial_puts, - .getc = mpc85xx_serial_getc, - .tstc = mpc85xx_serial_tstc, -}; - -void mpc85xx_serial_initialize(void) -{ - serial_register(&mpc85xx_serial_drv); -} - -__weak struct serial_device *default_serial_console(void) -{ - return &mpc85xx_serial_drv; -} -#endif /* CONFIG_CONS_ON_SCC */ diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index 5a9cd281617b..4b6f3d28baa6 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -580,15 +580,6 @@ int get_clocks(void) sys_info_t sys_info; #ifdef CONFIG_ARCH_MPC8544 volatile ccsr_gur_t *gur = (void *) CONFIG_SYS_MPC85xx_GUTS_ADDR; -#endif -#if defined(CONFIG_CPM2) - volatile ccsr_cpm_t *cpm = (ccsr_cpm_t *)CONFIG_SYS_MPC85xx_CPM_ADDR; - uint sccr, dfbrg; - - /* set VCO = 4 * BRG */ - cpm->im_cpm_intctl.sccr &= 0xfffffffc; - sccr = cpm->im_cpm_intctl.sccr; - dfbrg = (sccr & SCCR_DFBRG_MSK) >> SCCR_DFBRG_SHIFT; #endif get_sys_info (&sys_info); gd->cpu_clk = sys_info.freq_processor[0]; @@ -635,13 +626,6 @@ int get_clocks(void) #endif #endif /* defined(CONFIG_FSL_ESDHC) */
-#if defined(CONFIG_CPM2) - gd->arch.vco_out = 2*sys_info.freq_systembus; - gd->arch.cpm_clk = gd->arch.vco_out / 2; - gd->arch.scc_clk = gd->arch.vco_out / 4; - gd->arch.brg_clk = gd->arch.vco_out / (1 << (2 * (dfbrg + 1))); -#endif - if(gd->cpu_clk != 0) return (0); else return (1); } diff --git a/arch/powerpc/include/asm/cpm_85xx.h b/arch/powerpc/include/asm/cpm_85xx.h deleted file mode 100644 index d42469c6e056..000000000000 --- a/arch/powerpc/include/asm/cpm_85xx.h +++ /dev/null @@ -1,824 +0,0 @@ -/* - * MPC85xx Communication Processor Module - * Copyright (c) 2003,Motorola Inc. - * Xianghua Xiao (X.Xiao@motorola.com) - * - * MPC8260 Communication Processor Module. - * Copyright (c) 1999 Dan Malek (dmalek@jlc.net) - * - * This file contains structures and information for the communication - * processor channels found in the dual port RAM or parameter RAM. - * All CPM control and status is available through the MPC8260 internal - * memory map. See immap.h for details. - */ -#ifndef __CPM_85XX__ -#define __CPM_85XX__ - -#include <asm/immap_85xx.h> - -/* CPM Command register. -*/ -#define CPM_CR_RST ((uint)0x80000000) -#define CPM_CR_PAGE ((uint)0x7c000000) -#define CPM_CR_SBLOCK ((uint)0x03e00000) -#define CPM_CR_FLG ((uint)0x00010000) -#define CPM_CR_MCN ((uint)0x00003fc0) -#define CPM_CR_OPCODE ((uint)0x0000000f) - -/* Device sub-block and page codes. -*/ -#define CPM_CR_SCC1_SBLOCK (0x04) -#define CPM_CR_SCC2_SBLOCK (0x05) -#define CPM_CR_SCC3_SBLOCK (0x06) -#define CPM_CR_SCC4_SBLOCK (0x07) -#define CPM_CR_SMC1_SBLOCK (0x08) -#define CPM_CR_SMC2_SBLOCK (0x09) -#define CPM_CR_SPI_SBLOCK (0x0a) -#define CPM_CR_I2C_SBLOCK (0x0b) -#define CPM_CR_TIMER_SBLOCK (0x0f) -#define CPM_CR_RAND_SBLOCK (0x0e) -#define CPM_CR_FCC1_SBLOCK (0x10) -#define CPM_CR_FCC2_SBLOCK (0x11) -#define CPM_CR_FCC3_SBLOCK (0x12) -#define CPM_CR_MCC1_SBLOCK (0x1c) - -#define CPM_CR_SCC1_PAGE (0x00) -#define CPM_CR_SCC2_PAGE (0x01) -#define CPM_CR_SCC3_PAGE (0x02) -#define CPM_CR_SCC4_PAGE (0x03) -#define CPM_CR_SPI_PAGE (0x09) -#define CPM_CR_I2C_PAGE (0x0a) -#define CPM_CR_TIMER_PAGE (0x0a) -#define CPM_CR_RAND_PAGE (0x0a) -#define CPM_CR_FCC1_PAGE (0x04) -#define CPM_CR_FCC2_PAGE (0x05) -#define CPM_CR_FCC3_PAGE (0x06) -#define CPM_CR_MCC1_PAGE (0x07) -#define CPM_CR_MCC2_PAGE (0x08) - -/* Some opcodes (there are more...later) -*/ -#define CPM_CR_INIT_TRX ((ushort)0x0000) -#define CPM_CR_INIT_RX ((ushort)0x0001) -#define CPM_CR_INIT_TX ((ushort)0x0002) -#define CPM_CR_HUNT_MODE ((ushort)0x0003) -#define CPM_CR_STOP_TX ((ushort)0x0004) -#define CPM_CR_RESTART_TX ((ushort)0x0006) -#define CPM_CR_SET_GADDR ((ushort)0x0008) - -#define mk_cr_cmd(PG, SBC, MCN, OP) \ - ((PG << 26) | (SBC << 21) | (MCN << 6) | OP) - -/* Dual Port RAM addresses. The first 16K is available for almost - * any CPM use, so we put the BDs there. The first 128 bytes are - * used for SMC1 and SMC2 parameter RAM, so we start allocating - * BDs above that. All of this must change when we start - * downloading RAM microcode. - */ -#define CPM_DATAONLY_BASE ((uint)128) -#define CPM_DP_NOSPACE ((uint)0x7FFFFFFF) -#define CPM_FCC_SPECIAL_BASE ((uint)0x0000B000) -#define CPM_DATAONLY_SIZE ((uint)(16 * 1024) - CPM_DATAONLY_BASE) - -/* The number of pages of host memory we allocate for CPM. This is - * done early in kernel initialization to get physically contiguous - * pages. - */ -#define NUM_CPM_HOST_PAGES 2 - -/* Export the base address of the communication processor registers - * and dual port ram. - */ -/*extern cpm8560_t *cpmp; Pointer to comm processor */ -uint m8560_cpm_dpalloc(uint size, uint align); -uint m8560_cpm_hostalloc(uint size, uint align); -void m8560_cpm_setbrg(uint brg, uint rate); -void m8560_cpm_fastbrg(uint brg, uint rate, int div16); -void m8560_cpm_extcbrg(uint brg, uint rate, uint extclk, int pinsel); - -/* Buffer descriptors used by many of the CPM protocols. -*/ -typedef struct cpm_buf_desc { - ushort cbd_sc; /* Status and Control */ - ushort cbd_datlen; /* Data length in buffer */ - uint cbd_bufaddr; /* Buffer address in host memory */ -} cbd_t; - -#define BD_SC_EMPTY ((ushort)0x8000) /* Receive is empty */ -#define BD_SC_READY ((ushort)0x8000) /* Transmit is ready */ -#define BD_SC_WRAP ((ushort)0x2000) /* Last buffer descriptor */ -#define BD_SC_INTRPT ((ushort)0x1000) /* Interrupt on change */ -#define BD_SC_LAST ((ushort)0x0800) /* Last buffer in frame */ -#define BD_SC_CM ((ushort)0x0200) /* Continous mode */ -#define BD_SC_ID ((ushort)0x0100) /* Rec'd too many idles */ -#define BD_SC_P ((ushort)0x0100) /* xmt preamble */ -#define BD_SC_BR ((ushort)0x0020) /* Break received */ -#define BD_SC_FR ((ushort)0x0010) /* Framing error */ -#define BD_SC_PR ((ushort)0x0008) /* Parity error */ -#define BD_SC_OV ((ushort)0x0002) /* Overrun */ -#define BD_SC_CD ((ushort)0x0001) /* ?? */ - -/* Function code bits, usually generic to devices. -*/ -#define CPMFCR_GBL ((u_char)0x20) /* Set memory snooping */ -#define CPMFCR_EB ((u_char)0x10) /* Set big endian byte order */ -#define CPMFCR_TC2 ((u_char)0x04) /* Transfer code 2 value */ -#define CPMFCR_DTB ((u_char)0x02) /* Use local bus for data when set */ -#define CPMFCR_BDB ((u_char)0x01) /* Use local bus for BD when set */ - -/* Parameter RAM offsets from the base. -*/ -#define CPM_POST_WORD_ADDR 0x80FC /* steal a long at the end of SCC1 */ -#define PROFF_SCC1 ((uint)0x8000) -#define PROFF_SCC2 ((uint)0x8100) -#define PROFF_SCC3 ((uint)0x8200) -#define PROFF_SCC4 ((uint)0x8300) -#define PROFF_FCC1 ((uint)0x8400) -#define PROFF_FCC2 ((uint)0x8500) -#define PROFF_FCC3 ((uint)0x8600) -#define PROFF_MCC1 ((uint)0x8700) -#define PROFF_MCC2 ((uint)0x8800) -#define PROFF_SPI_BASE ((uint)0x89fc) -#define PROFF_TIMERS ((uint)0x8ae0) -#define PROFF_REVNUM ((uint)0x8af0) -#define PROFF_RAND ((uint)0x8af8) -#define PROFF_I2C_BASE ((uint)0x8afc) - -/* Baud rate generators. -*/ -#define CPM_BRG_RST ((uint)0x00020000) -#define CPM_BRG_EN ((uint)0x00010000) -#define CPM_BRG_EXTC_INT ((uint)0x00000000) -#define CPM_BRG_EXTC_CLK3_9 ((uint)0x00004000) -#define CPM_BRG_EXTC_CLK5_15 ((uint)0x00008000) -#define CPM_BRG_ATB ((uint)0x00002000) -#define CPM_BRG_CD_MASK ((uint)0x00001ffe) -#define CPM_BRG_DIV16 ((uint)0x00000001) - -/* SCCs. -*/ -#define SCC_GSMRH_IRP ((uint)0x00040000) -#define SCC_GSMRH_GDE ((uint)0x00010000) -#define SCC_GSMRH_TCRC_CCITT ((uint)0x00008000) -#define SCC_GSMRH_TCRC_BISYNC ((uint)0x00004000) -#define SCC_GSMRH_TCRC_HDLC ((uint)0x00000000) -#define SCC_GSMRH_REVD ((uint)0x00002000) -#define SCC_GSMRH_TRX ((uint)0x00001000) -#define SCC_GSMRH_TTX ((uint)0x00000800) -#define SCC_GSMRH_CDP ((uint)0x00000400) -#define SCC_GSMRH_CTSP ((uint)0x00000200) -#define SCC_GSMRH_CDS ((uint)0x00000100) -#define SCC_GSMRH_CTSS ((uint)0x00000080) -#define SCC_GSMRH_TFL ((uint)0x00000040) -#define SCC_GSMRH_RFW ((uint)0x00000020) -#define SCC_GSMRH_TXSY ((uint)0x00000010) -#define SCC_GSMRH_SYNL16 ((uint)0x0000000c) -#define SCC_GSMRH_SYNL8 ((uint)0x00000008) -#define SCC_GSMRH_SYNL4 ((uint)0x00000004) -#define SCC_GSMRH_RTSM ((uint)0x00000002) -#define SCC_GSMRH_RSYN ((uint)0x00000001) - -#define SCC_GSMRL_SIR ((uint)0x80000000) /* SCC2 only */ -#define SCC_GSMRL_EDGE_NONE ((uint)0x60000000) -#define SCC_GSMRL_EDGE_NEG ((uint)0x40000000) -#define SCC_GSMRL_EDGE_POS ((uint)0x20000000) -#define SCC_GSMRL_EDGE_BOTH ((uint)0x00000000) -#define SCC_GSMRL_TCI ((uint)0x10000000) -#define SCC_GSMRL_TSNC_3 ((uint)0x0c000000) -#define SCC_GSMRL_TSNC_4 ((uint)0x08000000) -#define SCC_GSMRL_TSNC_14 ((uint)0x04000000) -#define SCC_GSMRL_TSNC_INF ((uint)0x00000000) -#define SCC_GSMRL_RINV ((uint)0x02000000) -#define SCC_GSMRL_TINV ((uint)0x01000000) -#define SCC_GSMRL_TPL_128 ((uint)0x00c00000) -#define SCC_GSMRL_TPL_64 ((uint)0x00a00000) -#define SCC_GSMRL_TPL_48 ((uint)0x00800000) -#define SCC_GSMRL_TPL_32 ((uint)0x00600000) -#define SCC_GSMRL_TPL_16 ((uint)0x00400000) -#define SCC_GSMRL_TPL_8 ((uint)0x00200000) -#define SCC_GSMRL_TPL_NONE ((uint)0x00000000) -#define SCC_GSMRL_TPP_ALL1 ((uint)0x00180000) -#define SCC_GSMRL_TPP_01 ((uint)0x00100000) -#define SCC_GSMRL_TPP_10 ((uint)0x00080000) -#define SCC_GSMRL_TPP_ZEROS ((uint)0x00000000) -#define SCC_GSMRL_TEND ((uint)0x00040000) -#define SCC_GSMRL_TDCR_32 ((uint)0x00030000) -#define SCC_GSMRL_TDCR_16 ((uint)0x00020000) -#define SCC_GSMRL_TDCR_8 ((uint)0x00010000) -#define SCC_GSMRL_TDCR_1 ((uint)0x00000000) -#define SCC_GSMRL_RDCR_32 ((uint)0x0000c000) -#define SCC_GSMRL_RDCR_16 ((uint)0x00008000) -#define SCC_GSMRL_RDCR_8 ((uint)0x00004000) -#define SCC_GSMRL_RDCR_1 ((uint)0x00000000) -#define SCC_GSMRL_RENC_DFMAN ((uint)0x00003000) -#define SCC_GSMRL_RENC_MANCH ((uint)0x00002000) -#define SCC_GSMRL_RENC_FM0 ((uint)0x00001000) -#define SCC_GSMRL_RENC_NRZI ((uint)0x00000800) -#define SCC_GSMRL_RENC_NRZ ((uint)0x00000000) -#define SCC_GSMRL_TENC_DFMAN ((uint)0x00000600) -#define SCC_GSMRL_TENC_MANCH ((uint)0x00000400) -#define SCC_GSMRL_TENC_FM0 ((uint)0x00000200) -#define SCC_GSMRL_TENC_NRZI ((uint)0x00000100) -#define SCC_GSMRL_TENC_NRZ ((uint)0x00000000) -#define SCC_GSMRL_DIAG_LE ((uint)0x000000c0) /* Loop and echo */ -#define SCC_GSMRL_DIAG_ECHO ((uint)0x00000080) -#define SCC_GSMRL_DIAG_LOOP ((uint)0x00000040) -#define SCC_GSMRL_DIAG_NORM ((uint)0x00000000) -#define SCC_GSMRL_ENR ((uint)0x00000020) -#define SCC_GSMRL_ENT ((uint)0x00000010) -#define SCC_GSMRL_MODE_ENET ((uint)0x0000000c) -#define SCC_GSMRL_MODE_DDCMP ((uint)0x00000009) -#define SCC_GSMRL_MODE_BISYNC ((uint)0x00000008) -#define SCC_GSMRL_MODE_V14 ((uint)0x00000007) -#define SCC_GSMRL_MODE_AHDLC ((uint)0x00000006) -#define SCC_GSMRL_MODE_PROFIBUS ((uint)0x00000005) -#define SCC_GSMRL_MODE_UART ((uint)0x00000004) -#define SCC_GSMRL_MODE_SS7 ((uint)0x00000003) -#define SCC_GSMRL_MODE_ATALK ((uint)0x00000002) -#define SCC_GSMRL_MODE_HDLC ((uint)0x00000000) - -#define SCC_TODR_TOD ((ushort)0x8000) - -/* SCC Event and Mask register. -*/ -#define SCCM_TXE ((unsigned char)0x10) -#define SCCM_BSY ((unsigned char)0x04) -#define SCCM_TX ((unsigned char)0x02) -#define SCCM_RX ((unsigned char)0x01) - -typedef struct scc_param { - ushort scc_rbase; /* Rx Buffer descriptor base address */ - ushort scc_tbase; /* Tx Buffer descriptor base address */ - u_char scc_rfcr; /* Rx function code */ - u_char scc_tfcr; /* Tx function code */ - ushort scc_mrblr; /* Max receive buffer length */ - uint scc_rstate; /* Internal */ - uint scc_idp; /* Internal */ - ushort scc_rbptr; /* Internal */ - ushort scc_ibc; /* Internal */ - uint scc_rxtmp; /* Internal */ - uint scc_tstate; /* Internal */ - uint scc_tdp; /* Internal */ - ushort scc_tbptr; /* Internal */ - ushort scc_tbc; /* Internal */ - uint scc_txtmp; /* Internal */ - uint scc_rcrc; /* Internal */ - uint scc_tcrc; /* Internal */ -} sccp_t; - -/* CPM Ethernet through SCC1. - */ -typedef struct scc_enet { - sccp_t sen_genscc; - uint sen_cpres; /* Preset CRC */ - uint sen_cmask; /* Constant mask for CRC */ - uint sen_crcec; /* CRC Error counter */ - uint sen_alec; /* alignment error counter */ - uint sen_disfc; /* discard frame counter */ - ushort sen_pads; /* Tx short frame pad character */ - ushort sen_retlim; /* Retry limit threshold */ - ushort sen_retcnt; /* Retry limit counter */ - ushort sen_maxflr; /* maximum frame length register */ - ushort sen_minflr; /* minimum frame length register */ - ushort sen_maxd1; /* maximum DMA1 length */ - ushort sen_maxd2; /* maximum DMA2 length */ - ushort sen_maxd; /* Rx max DMA */ - ushort sen_dmacnt; /* Rx DMA counter */ - ushort sen_maxb; /* Max BD byte count */ - ushort sen_gaddr1; /* Group address filter */ - ushort sen_gaddr2; - ushort sen_gaddr3; - ushort sen_gaddr4; - uint sen_tbuf0data0; /* Save area 0 - current frame */ - uint sen_tbuf0data1; /* Save area 1 - current frame */ - uint sen_tbuf0rba; /* Internal */ - uint sen_tbuf0crc; /* Internal */ - ushort sen_tbuf0bcnt; /* Internal */ - ushort sen_paddrh; /* physical address (MSB) */ - ushort sen_paddrm; - ushort sen_paddrl; /* physical address (LSB) */ - ushort sen_pper; /* persistence */ - ushort sen_rfbdptr; /* Rx first BD pointer */ - ushort sen_tfbdptr; /* Tx first BD pointer */ - ushort sen_tlbdptr; /* Tx last BD pointer */ - uint sen_tbuf1data0; /* Save area 0 - current frame */ - uint sen_tbuf1data1; /* Save area 1 - current frame */ - uint sen_tbuf1rba; /* Internal */ - uint sen_tbuf1crc; /* Internal */ - ushort sen_tbuf1bcnt; /* Internal */ - ushort sen_txlen; /* Tx Frame length counter */ - ushort sen_iaddr1; /* Individual address filter */ - ushort sen_iaddr2; - ushort sen_iaddr3; - ushort sen_iaddr4; - ushort sen_boffcnt; /* Backoff counter */ - - /* NOTE: Some versions of the manual have the following items - * incorrectly documented. Below is the proper order. - */ - ushort sen_taddrh; /* temp address (MSB) */ - ushort sen_taddrm; - ushort sen_taddrl; /* temp address (LSB) */ -} scc_enet_t; - - -/* SCC Event register as used by Ethernet. -*/ -#define SCCE_ENET_GRA ((ushort)0x0080) /* Graceful stop complete */ -#define SCCE_ENET_TXE ((ushort)0x0010) /* Transmit Error */ -#define SCCE_ENET_RXF ((ushort)0x0008) /* Full frame received */ -#define SCCE_ENET_BSY ((ushort)0x0004) /* All incoming buffers full */ -#define SCCE_ENET_TXB ((ushort)0x0002) /* A buffer was transmitted */ -#define SCCE_ENET_RXB ((ushort)0x0001) /* A buffer was received */ - -/* SCC Mode Register (PSMR) as used by Ethernet. -*/ -#define SCC_PSMR_HBC ((ushort)0x8000) /* Enable heartbeat */ -#define SCC_PSMR_FC ((ushort)0x4000) /* Force collision */ -#define SCC_PSMR_RSH ((ushort)0x2000) /* Receive short frames */ -#define SCC_PSMR_IAM ((ushort)0x1000) /* Check individual hash */ -#define SCC_PSMR_ENCRC ((ushort)0x0800) /* Ethernet CRC mode */ -#define SCC_PSMR_PRO ((ushort)0x0200) /* Promiscuous mode */ -#define SCC_PSMR_BRO ((ushort)0x0100) /* Catch broadcast pkts */ -#define SCC_PSMR_SBT ((ushort)0x0080) /* Special backoff timer */ -#define SCC_PSMR_LPB ((ushort)0x0040) /* Set Loopback mode */ -#define SCC_PSMR_SIP ((ushort)0x0020) /* Sample Input Pins */ -#define SCC_PSMR_LCW ((ushort)0x0010) /* Late collision window */ -#define SCC_PSMR_NIB22 ((ushort)0x000a) /* Start frame search */ -#define SCC_PSMR_FDE ((ushort)0x0001) /* Full duplex enable */ - -/* Buffer descriptor control/status used by Ethernet receive. - * Common to SCC and FCC. - */ -#define BD_ENET_RX_EMPTY ((ushort)0x8000) -#define BD_ENET_RX_WRAP ((ushort)0x2000) -#define BD_ENET_RX_INTR ((ushort)0x1000) -#define BD_ENET_RX_LAST ((ushort)0x0800) -#define BD_ENET_RX_FIRST ((ushort)0x0400) -#define BD_ENET_RX_MISS ((ushort)0x0100) -#define BD_ENET_RX_BC ((ushort)0x0080) /* FCC Only */ -#define BD_ENET_RX_MC ((ushort)0x0040) /* FCC Only */ -#define BD_ENET_RX_LG ((ushort)0x0020) -#define BD_ENET_RX_NO ((ushort)0x0010) -#define BD_ENET_RX_SH ((ushort)0x0008) -#define BD_ENET_RX_CR ((ushort)0x0004) -#define BD_ENET_RX_OV ((ushort)0x0002) -#define BD_ENET_RX_CL ((ushort)0x0001) -#define BD_ENET_RX_STATS ((ushort)0x01ff) /* All status bits */ - -/* Buffer descriptor control/status used by Ethernet transmit. - * Common to SCC and FCC. - */ -#define BD_ENET_TX_READY ((ushort)0x8000) -#define BD_ENET_TX_PAD ((ushort)0x4000) -#define BD_ENET_TX_WRAP ((ushort)0x2000) -#define BD_ENET_TX_INTR ((ushort)0x1000) -#define BD_ENET_TX_LAST ((ushort)0x0800) -#define BD_ENET_TX_TC ((ushort)0x0400) -#define BD_ENET_TX_DEF ((ushort)0x0200) -#define BD_ENET_TX_HB ((ushort)0x0100) -#define BD_ENET_TX_LC ((ushort)0x0080) -#define BD_ENET_TX_RL ((ushort)0x0040) -#define BD_ENET_TX_RCMASK ((ushort)0x003c) -#define BD_ENET_TX_UN ((ushort)0x0002) -#define BD_ENET_TX_CSL ((ushort)0x0001) -#define BD_ENET_TX_STATS ((ushort)0x03ff) /* All status bits */ - -/* SCC as UART -*/ -typedef struct scc_uart { - sccp_t scc_genscc; - uint scc_res1; /* Reserved */ - uint scc_res2; /* Reserved */ - ushort scc_maxidl; /* Maximum idle chars */ - ushort scc_idlc; /* temp idle counter */ - ushort scc_brkcr; /* Break count register */ - ushort scc_parec; /* receive parity error counter */ - ushort scc_frmec; /* receive framing error counter */ - ushort scc_nosec; /* receive noise counter */ - ushort scc_brkec; /* receive break condition counter */ - ushort scc_brkln; /* last received break length */ - ushort scc_uaddr1; /* UART address character 1 */ - ushort scc_uaddr2; /* UART address character 2 */ - ushort scc_rtemp; /* Temp storage */ - ushort scc_toseq; /* Transmit out of sequence char */ - ushort scc_char1; /* control character 1 */ - ushort scc_char2; /* control character 2 */ - ushort scc_char3; /* control character 3 */ - ushort scc_char4; /* control character 4 */ - ushort scc_char5; /* control character 5 */ - ushort scc_char6; /* control character 6 */ - ushort scc_char7; /* control character 7 */ - ushort scc_char8; /* control character 8 */ - ushort scc_rccm; /* receive control character mask */ - ushort scc_rccr; /* receive control character register */ - ushort scc_rlbc; /* receive last break character */ -} scc_uart_t; - -/* SCC Event and Mask registers when it is used as a UART. -*/ -#define UART_SCCM_GLR ((ushort)0x1000) -#define UART_SCCM_GLT ((ushort)0x0800) -#define UART_SCCM_AB ((ushort)0x0200) -#define UART_SCCM_IDL ((ushort)0x0100) -#define UART_SCCM_GRA ((ushort)0x0080) -#define UART_SCCM_BRKE ((ushort)0x0040) -#define UART_SCCM_BRKS ((ushort)0x0020) -#define UART_SCCM_CCR ((ushort)0x0008) -#define UART_SCCM_BSY ((ushort)0x0004) -#define UART_SCCM_TX ((ushort)0x0002) -#define UART_SCCM_RX ((ushort)0x0001) - -/* The SCC PSMR when used as a UART. -*/ -#define SCU_PSMR_FLC ((ushort)0x8000) -#define SCU_PSMR_SL ((ushort)0x4000) -#define SCU_PSMR_CL ((ushort)0x3000) -#define SCU_PSMR_UM ((ushort)0x0c00) -#define SCU_PSMR_FRZ ((ushort)0x0200) -#define SCU_PSMR_RZS ((ushort)0x0100) -#define SCU_PSMR_SYN ((ushort)0x0080) -#define SCU_PSMR_DRT ((ushort)0x0040) -#define SCU_PSMR_PEN ((ushort)0x0010) -#define SCU_PSMR_RPM ((ushort)0x000c) -#define SCU_PSMR_REVP ((ushort)0x0008) -#define SCU_PSMR_TPM ((ushort)0x0003) -#define SCU_PSMR_TEVP ((ushort)0x0003) - -/* CPM Transparent mode SCC. - */ -typedef struct scc_trans { - sccp_t st_genscc; - uint st_cpres; /* Preset CRC */ - uint st_cmask; /* Constant mask for CRC */ -} scc_trans_t; - -#define BD_SCC_TX_LAST ((ushort)0x0800) - -/* How about some FCCs..... -*/ -#define FCC_GFMR_DIAG_NORM ((uint)0x00000000) -#define FCC_GFMR_DIAG_LE ((uint)0x40000000) -#define FCC_GFMR_DIAG_AE ((uint)0x80000000) -#define FCC_GFMR_DIAG_ALE ((uint)0xc0000000) -#define FCC_GFMR_TCI ((uint)0x20000000) -#define FCC_GFMR_TRX ((uint)0x10000000) -#define FCC_GFMR_TTX ((uint)0x08000000) -#define FCC_GFMR_TTX ((uint)0x08000000) -#define FCC_GFMR_CDP ((uint)0x04000000) -#define FCC_GFMR_CTSP ((uint)0x02000000) -#define FCC_GFMR_CDS ((uint)0x01000000) -#define FCC_GFMR_CTSS ((uint)0x00800000) -#define FCC_GFMR_SYNL_NONE ((uint)0x00000000) -#define FCC_GFMR_SYNL_AUTO ((uint)0x00004000) -#define FCC_GFMR_SYNL_8 ((uint)0x00008000) -#define FCC_GFMR_SYNL_16 ((uint)0x0000c000) -#define FCC_GFMR_RTSM ((uint)0x00002000) -#define FCC_GFMR_RENC_NRZ ((uint)0x00000000) -#define FCC_GFMR_RENC_NRZI ((uint)0x00000800) -#define FCC_GFMR_REVD ((uint)0x00000400) -#define FCC_GFMR_TENC_NRZ ((uint)0x00000000) -#define FCC_GFMR_TENC_NRZI ((uint)0x00000100) -#define FCC_GFMR_TCRC_16 ((uint)0x00000000) -#define FCC_GFMR_TCRC_32 ((uint)0x00000080) -#define FCC_GFMR_ENR ((uint)0x00000020) -#define FCC_GFMR_ENT ((uint)0x00000010) -#define FCC_GFMR_MODE_ENET ((uint)0x0000000c) -#define FCC_GFMR_MODE_ATM ((uint)0x0000000a) -#define FCC_GFMR_MODE_HDLC ((uint)0x00000000) - -/* Generic FCC parameter ram. -*/ -typedef struct fcc_param { - ushort fcc_riptr; /* Rx Internal temp pointer */ - ushort fcc_tiptr; /* Tx Internal temp pointer */ - ushort fcc_res1; - ushort fcc_mrblr; /* Max receive buffer length, mod 32 bytes */ - uint fcc_rstate; /* Upper byte is Func code, must be set */ - uint fcc_rbase; /* Receive BD base */ - ushort fcc_rbdstat; /* RxBD status */ - ushort fcc_rbdlen; /* RxBD down counter */ - uint fcc_rdptr; /* RxBD internal data pointer */ - uint fcc_tstate; /* Upper byte is Func code, must be set */ - uint fcc_tbase; /* Transmit BD base */ - ushort fcc_tbdstat; /* TxBD status */ - ushort fcc_tbdlen; /* TxBD down counter */ - uint fcc_tdptr; /* TxBD internal data pointer */ - uint fcc_rbptr; /* Rx BD Internal buf pointer */ - uint fcc_tbptr; /* Tx BD Internal buf pointer */ - uint fcc_rcrc; /* Rx temp CRC */ - uint fcc_res2; - uint fcc_tcrc; /* Tx temp CRC */ -} fccp_t; - - -/* Ethernet controller through FCC. -*/ -typedef struct fcc_enet { - fccp_t fen_genfcc; - uint fen_statbuf; /* Internal status buffer */ - uint fen_camptr; /* CAM address */ - uint fen_cmask; /* Constant mask for CRC */ - uint fen_cpres; /* Preset CRC */ - uint fen_crcec; /* CRC Error counter */ - uint fen_alec; /* alignment error counter */ - uint fen_disfc; /* discard frame counter */ - ushort fen_retlim; /* Retry limit */ - ushort fen_retcnt; /* Retry counter */ - ushort fen_pper; /* Persistence */ - ushort fen_boffcnt; /* backoff counter */ - uint fen_gaddrh; /* Group address filter, high 32-bits */ - uint fen_gaddrl; /* Group address filter, low 32-bits */ - ushort fen_tfcstat; /* out of sequence TxBD */ - ushort fen_tfclen; - uint fen_tfcptr; - ushort fen_mflr; /* Maximum frame length (1518) */ - ushort fen_paddrh; /* MAC address */ - ushort fen_paddrm; - ushort fen_paddrl; - ushort fen_ibdcount; /* Internal BD counter */ - ushort fen_ibdstart; /* Internal BD start pointer */ - ushort fen_ibdend; /* Internal BD end pointer */ - ushort fen_txlen; /* Internal Tx frame length counter */ - uint fen_ibdbase[8]; /* Internal use */ - uint fen_iaddrh; /* Individual address filter */ - uint fen_iaddrl; - ushort fen_minflr; /* Minimum frame length (64) */ - ushort fen_taddrh; /* Filter transfer MAC address */ - ushort fen_taddrm; - ushort fen_taddrl; - ushort fen_padptr; /* Pointer to pad byte buffer */ - ushort fen_cftype; /* control frame type */ - ushort fen_cfrange; /* control frame range */ - ushort fen_maxb; /* maximum BD count */ - ushort fen_maxd1; /* Max DMA1 length (1520) */ - ushort fen_maxd2; /* Max DMA2 length (1520) */ - ushort fen_maxd; /* internal max DMA count */ - ushort fen_dmacnt; /* internal DMA counter */ - uint fen_octc; /* Total octect counter */ - uint fen_colc; /* Total collision counter */ - uint fen_broc; /* Total broadcast packet counter */ - uint fen_mulc; /* Total multicast packet count */ - uint fen_uspc; /* Total packets < 64 bytes */ - uint fen_frgc; /* Total packets < 64 bytes with errors */ - uint fen_ospc; /* Total packets > 1518 */ - uint fen_jbrc; /* Total packets > 1518 with errors */ - uint fen_p64c; /* Total packets == 64 bytes */ - uint fen_p65c; /* Total packets 64 < bytes <= 127 */ - uint fen_p128c; /* Total packets 127 < bytes <= 255 */ - uint fen_p256c; /* Total packets 256 < bytes <= 511 */ - uint fen_p512c; /* Total packets 512 < bytes <= 1023 */ - uint fen_p1024c; /* Total packets 1024 < bytes <= 1518 */ - uint fen_cambuf; /* Internal CAM buffer poiner */ - ushort fen_rfthr; /* Received frames threshold */ - ushort fen_rfcnt; /* Received frames count */ -} fcc_enet_t; - -/* FCC Event/Mask register as used by Ethernet. -*/ -#define FCC_ENET_GRA ((ushort)0x0080) /* Graceful stop complete */ -#define FCC_ENET_RXC ((ushort)0x0040) /* Control Frame Received */ -#define FCC_ENET_TXC ((ushort)0x0020) /* Out of seq. Tx sent */ -#define FCC_ENET_TXE ((ushort)0x0010) /* Transmit Error */ -#define FCC_ENET_RXF ((ushort)0x0008) /* Full frame received */ -#define FCC_ENET_BSY ((ushort)0x0004) /* Busy. Rx Frame dropped */ -#define FCC_ENET_TXB ((ushort)0x0002) /* A buffer was transmitted */ -#define FCC_ENET_RXB ((ushort)0x0001) /* A buffer was received */ - -/* FCC Mode Register (FPSMR) as used by Ethernet. -*/ -#define FCC_PSMR_HBC ((uint)0x80000000) /* Enable heartbeat */ -#define FCC_PSMR_FC ((uint)0x40000000) /* Force Collision */ -#define FCC_PSMR_SBT ((uint)0x20000000) /* Stop backoff timer */ -#define FCC_PSMR_LPB ((uint)0x10000000) /* Local protect. 1 = FDX */ -#define FCC_PSMR_LCW ((uint)0x08000000) /* Late collision select */ -#define FCC_PSMR_FDE ((uint)0x04000000) /* Full Duplex Enable */ -#define FCC_PSMR_MON ((uint)0x02000000) /* RMON Enable */ -#define FCC_PSMR_PRO ((uint)0x00400000) /* Promiscuous Enable */ -#define FCC_PSMR_FCE ((uint)0x00200000) /* Flow Control Enable */ -#define FCC_PSMR_RSH ((uint)0x00100000) /* Receive Short Frames */ -#define FCC_PSMR_CAM ((uint)0x00000400) /* CAM enable */ -#define FCC_PSMR_BRO ((uint)0x00000200) /* Broadcast pkt discard */ -#define FCC_PSMR_ENCRC ((uint)0x00000080) /* Use 32-bit CRC */ - -/* IIC parameter RAM. -*/ -typedef struct iic { - ushort iic_rbase; /* Rx Buffer descriptor base address */ - ushort iic_tbase; /* Tx Buffer descriptor base address */ - u_char iic_rfcr; /* Rx function code */ - u_char iic_tfcr; /* Tx function code */ - ushort iic_mrblr; /* Max receive buffer length */ - uint iic_rstate; /* Internal */ - uint iic_rdp; /* Internal */ - ushort iic_rbptr; /* Internal */ - ushort iic_rbc; /* Internal */ - uint iic_rxtmp; /* Internal */ - uint iic_tstate; /* Internal */ - uint iic_tdp; /* Internal */ - ushort iic_tbptr; /* Internal */ - ushort iic_tbc; /* Internal */ - uint iic_txtmp; /* Internal */ -} iic_t; - -/* SPI parameter RAM. -*/ -typedef struct spi { - ushort spi_rbase; /* Rx Buffer descriptor base address */ - ushort spi_tbase; /* Tx Buffer descriptor base address */ - u_char spi_rfcr; /* Rx function code */ - u_char spi_tfcr; /* Tx function code */ - ushort spi_mrblr; /* Max receive buffer length */ - uint spi_rstate; /* Internal */ - uint spi_rdp; /* Internal */ - ushort spi_rbptr; /* Internal */ - ushort spi_rbc; /* Internal */ - uint spi_rxtmp; /* Internal */ - uint spi_tstate; /* Internal */ - uint spi_tdp; /* Internal */ - ushort spi_tbptr; /* Internal */ - ushort spi_tbc; /* Internal */ - uint spi_txtmp; /* Internal */ - uint spi_res; /* Tx temp. */ - uint spi_res1[4]; /* SDMA temp. */ -} spi_t; - -/* SPI Mode register. -*/ -#define SPMODE_LOOP ((ushort)0x4000) /* Loopback */ -#define SPMODE_CI ((ushort)0x2000) /* Clock Invert */ -#define SPMODE_CP ((ushort)0x1000) /* Clock Phase */ -#define SPMODE_DIV16 ((ushort)0x0800) /* BRG/16 mode */ -#define SPMODE_REV ((ushort)0x0400) /* Reversed Data */ -#define SPMODE_MSTR ((ushort)0x0200) /* SPI Master */ -#define SPMODE_EN ((ushort)0x0100) /* Enable */ -#define SPMODE_LENMSK ((ushort)0x00f0) /* character length */ -#define SPMODE_PMMSK ((ushort)0x000f) /* prescale modulus */ - -#define SPMODE_LEN(x) ((((x)-1)&0xF)<<4) -#define SPMODE_PM(x) ((x) &0xF) - -#define SPI_EB ((u_char)0x10) /* big endian byte order */ - -#define BD_IIC_START ((ushort)0x0400) - -/*----------------------------------------------------------------------- - * CMXFCR - CMX FCC Clock Route Register 15-12 - */ -#define CMXFCR_FC1 0x40000000 /* FCC1 connection */ -#define CMXFCR_RF1CS_MSK 0x38000000 /* Receive FCC1 Clock Source Mask */ -#define CMXFCR_TF1CS_MSK 0x07000000 /* Transmit FCC1 Clock Source Mask */ -#define CMXFCR_FC2 0x00400000 /* FCC2 connection */ -#define CMXFCR_RF2CS_MSK 0x00380000 /* Receive FCC2 Clock Source Mask */ -#define CMXFCR_TF2CS_MSK 0x00070000 /* Transmit FCC2 Clock Source Mask */ -#define CMXFCR_FC3 0x00004000 /* FCC3 connection */ -#define CMXFCR_RF3CS_MSK 0x00003800 /* Receive FCC3 Clock Source Mask */ -#define CMXFCR_TF3CS_MSK 0x00000700 /* Transmit FCC3 Clock Source Mask */ - -#define CMXFCR_RF1CS_BRG5 0x00000000 /* Receive FCC1 Clock Source is BRG5 */ -#define CMXFCR_RF1CS_BRG6 0x08000000 /* Receive FCC1 Clock Source is BRG6 */ -#define CMXFCR_RF1CS_BRG7 0x10000000 /* Receive FCC1 Clock Source is BRG7 */ -#define CMXFCR_RF1CS_BRG8 0x18000000 /* Receive FCC1 Clock Source is BRG8 */ -#define CMXFCR_RF1CS_CLK9 0x20000000 /* Receive FCC1 Clock Source is CLK9 */ -#define CMXFCR_RF1CS_CLK10 0x28000000 /* Receive FCC1 Clock Source is CLK10 */ -#define CMXFCR_RF1CS_CLK11 0x30000000 /* Receive FCC1 Clock Source is CLK11 */ -#define CMXFCR_RF1CS_CLK12 0x38000000 /* Receive FCC1 Clock Source is CLK12 */ - -#define CMXFCR_TF1CS_BRG5 0x00000000 /* Transmit FCC1 Clock Source is BRG5 */ -#define CMXFCR_TF1CS_BRG6 0x01000000 /* Transmit FCC1 Clock Source is BRG6 */ -#define CMXFCR_TF1CS_BRG7 0x02000000 /* Transmit FCC1 Clock Source is BRG7 */ -#define CMXFCR_TF1CS_BRG8 0x03000000 /* Transmit FCC1 Clock Source is BRG8 */ -#define CMXFCR_TF1CS_CLK9 0x04000000 /* Transmit FCC1 Clock Source is CLK9 */ -#define CMXFCR_TF1CS_CLK10 0x05000000 /* Transmit FCC1 Clock Source is CLK10 */ -#define CMXFCR_TF1CS_CLK11 0x06000000 /* Transmit FCC1 Clock Source is CLK11 */ -#define CMXFCR_TF1CS_CLK12 0x07000000 /* Transmit FCC1 Clock Source is CLK12 */ - -#define CMXFCR_RF2CS_BRG5 0x00000000 /* Receive FCC2 Clock Source is BRG5 */ -#define CMXFCR_RF2CS_BRG6 0x00080000 /* Receive FCC2 Clock Source is BRG6 */ -#define CMXFCR_RF2CS_BRG7 0x00100000 /* Receive FCC2 Clock Source is BRG7 */ -#define CMXFCR_RF2CS_BRG8 0x00180000 /* Receive FCC2 Clock Source is BRG8 */ -#define CMXFCR_RF2CS_CLK13 0x00200000 /* Receive FCC2 Clock Source is CLK13 */ -#define CMXFCR_RF2CS_CLK14 0x00280000 /* Receive FCC2 Clock Source is CLK14 */ -#define CMXFCR_RF2CS_CLK15 0x00300000 /* Receive FCC2 Clock Source is CLK15 */ -#define CMXFCR_RF2CS_CLK16 0x00380000 /* Receive FCC2 Clock Source is CLK16 */ - -#define CMXFCR_TF2CS_BRG5 0x00000000 /* Transmit FCC2 Clock Source is BRG5 */ -#define CMXFCR_TF2CS_BRG6 0x00010000 /* Transmit FCC2 Clock Source is BRG6 */ -#define CMXFCR_TF2CS_BRG7 0x00020000 /* Transmit FCC2 Clock Source is BRG7 */ -#define CMXFCR_TF2CS_BRG8 0x00030000 /* Transmit FCC2 Clock Source is BRG8 */ -#define CMXFCR_TF2CS_CLK13 0x00040000 /* Transmit FCC2 Clock Source is CLK13 */ -#define CMXFCR_TF2CS_CLK14 0x00050000 /* Transmit FCC2 Clock Source is CLK14 */ -#define CMXFCR_TF2CS_CLK15 0x00060000 /* Transmit FCC2 Clock Source is CLK15 */ -#define CMXFCR_TF2CS_CLK16 0x00070000 /* Transmit FCC2 Clock Source is CLK16 */ - -#define CMXFCR_RF3CS_BRG5 0x00000000 /* Receive FCC3 Clock Source is BRG5 */ -#define CMXFCR_RF3CS_BRG6 0x00000800 /* Receive FCC3 Clock Source is BRG6 */ -#define CMXFCR_RF3CS_BRG7 0x00001000 /* Receive FCC3 Clock Source is BRG7 */ -#define CMXFCR_RF3CS_BRG8 0x00001800 /* Receive FCC3 Clock Source is BRG8 */ -#define CMXFCR_RF3CS_CLK13 0x00002000 /* Receive FCC3 Clock Source is CLK13 */ -#define CMXFCR_RF3CS_CLK14 0x00002800 /* Receive FCC3 Clock Source is CLK14 */ -#define CMXFCR_RF3CS_CLK15 0x00003000 /* Receive FCC3 Clock Source is CLK15 */ -#define CMXFCR_RF3CS_CLK16 0x00003800 /* Receive FCC3 Clock Source is CLK16 */ - -#define CMXFCR_TF3CS_BRG5 0x00000000 /* Transmit FCC3 Clock Source is BRG5 */ -#define CMXFCR_TF3CS_BRG6 0x00000100 /* Transmit FCC3 Clock Source is BRG6 */ -#define CMXFCR_TF3CS_BRG7 0x00000200 /* Transmit FCC3 Clock Source is BRG7 */ -#define CMXFCR_TF3CS_BRG8 0x00000300 /* Transmit FCC3 Clock Source is BRG8 */ -#define CMXFCR_TF3CS_CLK13 0x00000400 /* Transmit FCC3 Clock Source is CLK13 */ -#define CMXFCR_TF3CS_CLK14 0x00000500 /* Transmit FCC3 Clock Source is CLK14 */ -#define CMXFCR_TF3CS_CLK15 0x00000600 /* Transmit FCC3 Clock Source is CLK15 */ -#define CMXFCR_TF3CS_CLK16 0x00000700 /* Transmit FCC3 Clock Source is CLK16 */ - -/*----------------------------------------------------------------------- - * CMXSCR - CMX SCC Clock Route Register 15-14 - */ -#define CMXSCR_GR1 0x80000000 /* Grant Support of SCC1 */ -#define CMXSCR_SC1 0x40000000 /* SCC1 connection */ -#define CMXSCR_RS1CS_MSK 0x38000000 /* Receive SCC1 Clock Source Mask */ -#define CMXSCR_TS1CS_MSK 0x07000000 /* Transmit SCC1 Clock Source Mask */ -#define CMXSCR_GR2 0x00800000 /* Grant Support of SCC2 */ -#define CMXSCR_SC2 0x00400000 /* SCC2 connection */ -#define CMXSCR_RS2CS_MSK 0x00380000 /* Receive SCC2 Clock Source Mask */ -#define CMXSCR_TS2CS_MSK 0x00070000 /* Transmit SCC2 Clock Source Mask */ -#define CMXSCR_GR3 0x00008000 /* Grant Support of SCC3 */ -#define CMXSCR_SC3 0x00004000 /* SCC3 connection */ -#define CMXSCR_RS3CS_MSK 0x00003800 /* Receive SCC3 Clock Source Mask */ -#define CMXSCR_TS3CS_MSK 0x00000700 /* Transmit SCC3 Clock Source Mask */ -#define CMXSCR_GR4 0x00000080 /* Grant Support of SCC4 */ -#define CMXSCR_SC4 0x00000040 /* SCC4 connection */ -#define CMXSCR_RS4CS_MSK 0x00000038 /* Receive SCC4 Clock Source Mask */ -#define CMXSCR_TS4CS_MSK 0x00000007 /* Transmit SCC4 Clock Source Mask */ - -#define CMXSCR_RS1CS_BRG1 0x00000000 /* SCC1 Rx Clock Source is BRG1 */ -#define CMXSCR_RS1CS_BRG2 0x08000000 /* SCC1 Rx Clock Source is BRG2 */ -#define CMXSCR_RS1CS_BRG3 0x10000000 /* SCC1 Rx Clock Source is BRG3 */ -#define CMXSCR_RS1CS_BRG4 0x18000000 /* SCC1 Rx Clock Source is BRG4 */ -#define CMXSCR_RS1CS_CLK11 0x20000000 /* SCC1 Rx Clock Source is CLK11 */ -#define CMXSCR_RS1CS_CLK12 0x28000000 /* SCC1 Rx Clock Source is CLK12 */ -#define CMXSCR_RS1CS_CLK3 0x30000000 /* SCC1 Rx Clock Source is CLK3 */ -#define CMXSCR_RS1CS_CLK4 0x38000000 /* SCC1 Rx Clock Source is CLK4 */ - -#define CMXSCR_TS1CS_BRG1 0x00000000 /* SCC1 Tx Clock Source is BRG1 */ -#define CMXSCR_TS1CS_BRG2 0x01000000 /* SCC1 Tx Clock Source is BRG2 */ -#define CMXSCR_TS1CS_BRG3 0x02000000 /* SCC1 Tx Clock Source is BRG3 */ -#define CMXSCR_TS1CS_BRG4 0x03000000 /* SCC1 Tx Clock Source is BRG4 */ -#define CMXSCR_TS1CS_CLK11 0x04000000 /* SCC1 Tx Clock Source is CLK11 */ -#define CMXSCR_TS1CS_CLK12 0x05000000 /* SCC1 Tx Clock Source is CLK12 */ -#define CMXSCR_TS1CS_CLK3 0x06000000 /* SCC1 Tx Clock Source is CLK3 */ -#define CMXSCR_TS1CS_CLK4 0x07000000 /* SCC1 Tx Clock Source is CLK4 */ - -#define CMXSCR_RS2CS_BRG1 0x00000000 /* SCC2 Rx Clock Source is BRG1 */ -#define CMXSCR_RS2CS_BRG2 0x00080000 /* SCC2 Rx Clock Source is BRG2 */ -#define CMXSCR_RS2CS_BRG3 0x00100000 /* SCC2 Rx Clock Source is BRG3 */ -#define CMXSCR_RS2CS_BRG4 0x00180000 /* SCC2 Rx Clock Source is BRG4 */ -#define CMXSCR_RS2CS_CLK11 0x00200000 /* SCC2 Rx Clock Source is CLK11 */ -#define CMXSCR_RS2CS_CLK12 0x00280000 /* SCC2 Rx Clock Source is CLK12 */ -#define CMXSCR_RS2CS_CLK3 0x00300000 /* SCC2 Rx Clock Source is CLK3 */ -#define CMXSCR_RS2CS_CLK4 0x00380000 /* SCC2 Rx Clock Source is CLK4 */ - -#define CMXSCR_TS2CS_BRG1 0x00000000 /* SCC2 Tx Clock Source is BRG1 */ -#define CMXSCR_TS2CS_BRG2 0x00010000 /* SCC2 Tx Clock Source is BRG2 */ -#define CMXSCR_TS2CS_BRG3 0x00020000 /* SCC2 Tx Clock Source is BRG3 */ -#define CMXSCR_TS2CS_BRG4 0x00030000 /* SCC2 Tx Clock Source is BRG4 */ -#define CMXSCR_TS2CS_CLK11 0x00040000 /* SCC2 Tx Clock Source is CLK11 */ -#define CMXSCR_TS2CS_CLK12 0x00050000 /* SCC2 Tx Clock Source is CLK12 */ -#define CMXSCR_TS2CS_CLK3 0x00060000 /* SCC2 Tx Clock Source is CLK3 */ -#define CMXSCR_TS2CS_CLK4 0x00070000 /* SCC2 Tx Clock Source is CLK4 */ - -#define CMXSCR_RS3CS_BRG1 0x00000000 /* SCC3 Rx Clock Source is BRG1 */ -#define CMXSCR_RS3CS_BRG2 0x00000800 /* SCC3 Rx Clock Source is BRG2 */ -#define CMXSCR_RS3CS_BRG3 0x00001000 /* SCC3 Rx Clock Source is BRG3 */ -#define CMXSCR_RS3CS_BRG4 0x00001800 /* SCC3 Rx Clock Source is BRG4 */ -#define CMXSCR_RS3CS_CLK5 0x00002000 /* SCC3 Rx Clock Source is CLK5 */ -#define CMXSCR_RS3CS_CLK6 0x00002800 /* SCC3 Rx Clock Source is CLK6 */ -#define CMXSCR_RS3CS_CLK7 0x00003000 /* SCC3 Rx Clock Source is CLK7 */ -#define CMXSCR_RS3CS_CLK8 0x00003800 /* SCC3 Rx Clock Source is CLK8 */ - -#define CMXSCR_TS3CS_BRG1 0x00000000 /* SCC3 Tx Clock Source is BRG1 */ -#define CMXSCR_TS3CS_BRG2 0x00000100 /* SCC3 Tx Clock Source is BRG2 */ -#define CMXSCR_TS3CS_BRG3 0x00000200 /* SCC3 Tx Clock Source is BRG3 */ -#define CMXSCR_TS3CS_BRG4 0x00000300 /* SCC3 Tx Clock Source is BRG4 */ -#define CMXSCR_TS3CS_CLK5 0x00000400 /* SCC3 Tx Clock Source is CLK5 */ -#define CMXSCR_TS3CS_CLK6 0x00000500 /* SCC3 Tx Clock Source is CLK6 */ -#define CMXSCR_TS3CS_CLK7 0x00000600 /* SCC3 Tx Clock Source is CLK7 */ -#define CMXSCR_TS3CS_CLK8 0x00000700 /* SCC3 Tx Clock Source is CLK8 */ - -#define CMXSCR_RS4CS_BRG1 0x00000000 /* SCC4 Rx Clock Source is BRG1 */ -#define CMXSCR_RS4CS_BRG2 0x00000008 /* SCC4 Rx Clock Source is BRG2 */ -#define CMXSCR_RS4CS_BRG3 0x00000010 /* SCC4 Rx Clock Source is BRG3 */ -#define CMXSCR_RS4CS_BRG4 0x00000018 /* SCC4 Rx Clock Source is BRG4 */ -#define CMXSCR_RS4CS_CLK5 0x00000020 /* SCC4 Rx Clock Source is CLK5 */ -#define CMXSCR_RS4CS_CLK6 0x00000028 /* SCC4 Rx Clock Source is CLK6 */ -#define CMXSCR_RS4CS_CLK7 0x00000030 /* SCC4 Rx Clock Source is CLK7 */ -#define CMXSCR_RS4CS_CLK8 0x00000038 /* SCC4 Rx Clock Source is CLK8 */ - -#define CMXSCR_TS4CS_BRG1 0x00000000 /* SCC4 Tx Clock Source is BRG1 */ -#define CMXSCR_TS4CS_BRG2 0x00000001 /* SCC4 Tx Clock Source is BRG2 */ -#define CMXSCR_TS4CS_BRG3 0x00000002 /* SCC4 Tx Clock Source is BRG3 */ -#define CMXSCR_TS4CS_BRG4 0x00000003 /* SCC4 Tx Clock Source is BRG4 */ -#define CMXSCR_TS4CS_CLK5 0x00000004 /* SCC4 Tx Clock Source is CLK5 */ -#define CMXSCR_TS4CS_CLK6 0x00000005 /* SCC4 Tx Clock Source is CLK6 */ -#define CMXSCR_TS4CS_CLK7 0x00000006 /* SCC4 Tx Clock Source is CLK7 */ -#define CMXSCR_TS4CS_CLK8 0x00000007 /* SCC4 Tx Clock Source is CLK8 */ - -#endif /* __CPM_85XX__ */ diff --git a/arch/powerpc/include/asm/global_data.h b/arch/powerpc/include/asm/global_data.h index 2975255bfe23..770adcd30f29 100644 --- a/arch/powerpc/include/asm/global_data.h +++ b/arch/powerpc/include/asm/global_data.h @@ -19,13 +19,6 @@ struct arch_global_data { #endif #if defined(CONFIG_MPC8xx) unsigned long brg_clk; -#endif -#if defined(CONFIG_CPM2) - /* There are many clocks on the MPC8260 - see page 9-5 */ - unsigned long vco_out; - unsigned long cpm_clk; - unsigned long scc_clk; - unsigned long brg_clk; #endif /* TODO: sjg@chromium.org: Should these be unslgned long? */ #if defined(CONFIG_MPC83xx) @@ -88,10 +81,6 @@ struct arch_global_data { unsigned long arbiter_event_attributes; unsigned long arbiter_event_address; #endif -#if defined(CONFIG_CPM2) - unsigned int dp_alloc_base; - unsigned int dp_alloc_top; -#endif #ifdef CONFIG_SYS_FPGA_COUNT unsigned fpga_state[CONFIG_SYS_FPGA_COUNT]; #endif diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 770705a8794b..b8bc58448217 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -921,330 +921,6 @@ typedef struct ccsr_pic { u8 res150[130892]; } ccsr_pic_t;
-/* CPM Block */ -#ifndef CONFIG_CPM2 -typedef struct ccsr_cpm { - u8 res[262144]; -} ccsr_cpm_t; -#else -/* - * DPARM - * General SIU - */ -typedef struct ccsr_cpm_siu { - u8 res1[80]; - u32 smaer; - u32 smser; - u32 smevr; - u8 res2[4]; - u32 lmaer; - u32 lmser; - u32 lmevr; - u8 res3[2964]; -} ccsr_cpm_siu_t; - -/* IRQ Controller */ -typedef struct ccsr_cpm_intctl { - u16 sicr; - u8 res1[2]; - u32 sivec; - u32 sipnrh; - u32 sipnrl; - u32 siprr; - u32 scprrh; - u32 scprrl; - u32 simrh; - u32 simrl; - u32 siexr; - u8 res2[88]; - u32 sccr; - u8 res3[124]; -} ccsr_cpm_intctl_t; - -/* input/output port */ -typedef struct ccsr_cpm_iop { - u32 pdira; - u32 ppara; - u32 psora; - u32 podra; - u32 pdata; - u8 res1[12]; - u32 pdirb; - u32 pparb; - u32 psorb; - u32 podrb; - u32 pdatb; - u8 res2[12]; - u32 pdirc; - u32 pparc; - u32 psorc; - u32 podrc; - u32 pdatc; - u8 res3[12]; - u32 pdird; - u32 ppard; - u32 psord; - u32 podrd; - u32 pdatd; - u8 res4[12]; -} ccsr_cpm_iop_t; - -/* CPM timers */ -typedef struct ccsr_cpm_timer { - u8 tgcr1; - u8 res1[3]; - u8 tgcr2; - u8 res2[11]; - u16 tmr1; - u16 tmr2; - u16 trr1; - u16 trr2; - u16 tcr1; - u16 tcr2; - u16 tcn1; - u16 tcn2; - u16 tmr3; - u16 tmr4; - u16 trr3; - u16 trr4; - u16 tcr3; - u16 tcr4; - u16 tcn3; - u16 tcn4; - u16 ter1; - u16 ter2; - u16 ter3; - u16 ter4; - u8 res3[608]; -} ccsr_cpm_timer_t; - -/* SDMA */ -typedef struct ccsr_cpm_sdma { - u8 sdsr; - u8 res1[3]; - u8 sdmr; - u8 res2[739]; -} ccsr_cpm_sdma_t; - -/* FCC1 */ -typedef struct ccsr_cpm_fcc1 { - u32 gfmr; - u32 fpsmr; - u16 ftodr; - u8 res1[2]; - u16 fdsr; - u8 res2[2]; - u16 fcce; - u8 res3[2]; - u16 fccm; - u8 res4[2]; - u8 fccs; - u8 res5[3]; - u8 ftirr_phy[4]; -} ccsr_cpm_fcc1_t; - -/* FCC2 */ -typedef struct ccsr_cpm_fcc2 { - u32 gfmr; - u32 fpsmr; - u16 ftodr; - u8 res1[2]; - u16 fdsr; - u8 res2[2]; - u16 fcce; - u8 res3[2]; - u16 fccm; - u8 res4[2]; - u8 fccs; - u8 res5[3]; - u8 ftirr_phy[4]; -} ccsr_cpm_fcc2_t; - -/* FCC3 */ -typedef struct ccsr_cpm_fcc3 { - u32 gfmr; - u32 fpsmr; - u16 ftodr; - u8 res1[2]; - u16 fdsr; - u8 res2[2]; - u16 fcce; - u8 res3[2]; - u16 fccm; - u8 res4[2]; - u8 fccs; - u8 res5[3]; - u8 res[36]; -} ccsr_cpm_fcc3_t; - -/* FCC1 extended */ -typedef struct ccsr_cpm_fcc1_ext { - u32 firper; - u32 firer; - u32 firsr_h; - u32 firsr_l; - u8 gfemr; - u8 res[15]; - -} ccsr_cpm_fcc1_ext_t; - -/* FCC2 extended */ -typedef struct ccsr_cpm_fcc2_ext { - u32 firper; - u32 firer; - u32 firsr_h; - u32 firsr_l; - u8 gfemr; - u8 res[31]; -} ccsr_cpm_fcc2_ext_t; - -/* FCC3 extended */ -typedef struct ccsr_cpm_fcc3_ext { - u8 gfemr; - u8 res[47]; -} ccsr_cpm_fcc3_ext_t; - -/* TC layers */ -typedef struct ccsr_cpm_tmp1 { - u8 res[496]; -} ccsr_cpm_tmp1_t; - -/* BRGs:5,6,7,8 */ -typedef struct ccsr_cpm_brg2 { - u32 brgc5; - u32 brgc6; - u32 brgc7; - u32 brgc8; - u8 res[608]; -} ccsr_cpm_brg2_t; - -/* I2C */ -typedef struct ccsr_cpm_i2c { - u8 i2mod; - u8 res1[3]; - u8 i2add; - u8 res2[3]; - u8 i2brg; - u8 res3[3]; - u8 i2com; - u8 res4[3]; - u8 i2cer; - u8 res5[3]; - u8 i2cmr; - u8 res6[331]; -} ccsr_cpm_i2c_t; - -/* CPM core */ -typedef struct ccsr_cpm_cp { - u32 cpcr; - u32 rccr; - u8 res1[14]; - u16 rter; - u8 res2[2]; - u16 rtmr; - u16 rtscr; - u8 res3[2]; - u32 rtsr; - u8 res4[12]; -} ccsr_cpm_cp_t; - -/* BRGs:1,2,3,4 */ -typedef struct ccsr_cpm_brg1 { - u32 brgc1; - u32 brgc2; - u32 brgc3; - u32 brgc4; -} ccsr_cpm_brg1_t; - -/* SCC1-SCC4 */ -typedef struct ccsr_cpm_scc { - u32 gsmrl; - u32 gsmrh; - u16 psmr; - u8 res1[2]; - u16 todr; - u16 dsr; - u16 scce; - u8 res2[2]; - u16 sccm; - u8 res3; - u8 sccs; - u8 res4[8]; -} ccsr_cpm_scc_t; - -typedef struct ccsr_cpm_tmp2 { - u8 res[32]; -} ccsr_cpm_tmp2_t; - -/* SPI */ -typedef struct ccsr_cpm_spi { - u16 spmode; - u8 res1[4]; - u8 spie; - u8 res2[3]; - u8 spim; - u8 res3[2]; - u8 spcom; - u8 res4[82]; -} ccsr_cpm_spi_t; - -/* CPM MUX */ -typedef struct ccsr_cpm_mux { - u8 cmxsi1cr; - u8 res1; - u8 cmxsi2cr; - u8 res2; - u32 cmxfcr; - u32 cmxscr; - u8 res3[2]; - u16 cmxuar; - u8 res4[16]; -} ccsr_cpm_mux_t; - -/* SI,MCC,etc */ -typedef struct ccsr_cpm_tmp3 { - u8 res[58592]; -} ccsr_cpm_tmp3_t; - -typedef struct ccsr_cpm_iram { - u32 iram[8192]; - u8 res[98304]; -} ccsr_cpm_iram_t; - -typedef struct ccsr_cpm { - /* Some references are into the unique & known dpram spaces, - * others are from the generic base. - */ -#define im_dprambase im_dpram1 - u8 im_dpram1[16*1024]; - u8 res1[16*1024]; - u8 im_dpram2[16*1024]; - u8 res2[16*1024]; - ccsr_cpm_siu_t im_cpm_siu; /* SIU Configuration */ - ccsr_cpm_intctl_t im_cpm_intctl; /* IRQ Controller */ - ccsr_cpm_iop_t im_cpm_iop; /* IO Port control/status */ - ccsr_cpm_timer_t im_cpm_timer; /* CPM timers */ - ccsr_cpm_sdma_t im_cpm_sdma; /* SDMA control/status */ - ccsr_cpm_fcc1_t im_cpm_fcc1; - ccsr_cpm_fcc2_t im_cpm_fcc2; - ccsr_cpm_fcc3_t im_cpm_fcc3; - ccsr_cpm_fcc1_ext_t im_cpm_fcc1_ext; - ccsr_cpm_fcc2_ext_t im_cpm_fcc2_ext; - ccsr_cpm_fcc3_ext_t im_cpm_fcc3_ext; - ccsr_cpm_tmp1_t im_cpm_tmp1; - ccsr_cpm_brg2_t im_cpm_brg2; - ccsr_cpm_i2c_t im_cpm_i2c; - ccsr_cpm_cp_t im_cpm_cp; - ccsr_cpm_brg1_t im_cpm_brg1; - ccsr_cpm_scc_t im_cpm_scc[4]; - ccsr_cpm_tmp2_t im_cpm_tmp2; - ccsr_cpm_spi_t im_cpm_spi; - ccsr_cpm_mux_t im_cpm_mux; - ccsr_cpm_tmp3_t im_cpm_tmp3; - ccsr_cpm_iram_t im_cpm_iram; -} ccsr_cpm_t; -#endif - #ifdef CONFIG_SYS_SRIO /* Architectural regsiters */ struct rio_arch { @@ -2888,7 +2564,6 @@ struct ccsr_pman { #define CONFIG_SYS_MPC85xx_SERDES1_OFFSET 0xE3000 #define CONFIG_SYS_SEC_MON_OFFSET 0xE6000 #define CONFIG_SYS_SFP_OFFSET 0xE7000 -#define CONFIG_SYS_MPC85xx_CPM_OFFSET 0x80000 #define CONFIG_SYS_FSL_QMAN_OFFSET 0x88000 #define CONFIG_SYS_FSL_BMAN_OFFSET 0x8a000 #define CONFIG_SYS_FSL_FM1_OFFSET 0x100000 @@ -2965,8 +2640,6 @@ struct ccsr_pman { (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_ESDHC_OFFSET) #define CONFIG_SYS_MPC8xxx_PIC_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_PIC_OFFSET) -#define CONFIG_SYS_MPC85xx_CPM_ADDR \ - (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_CPM_OFFSET) #define CONFIG_SYS_MPC85xx_SERDES1_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_MPC85xx_SERDES1_OFFSET) #define CONFIG_SYS_MPC85xx_SERDES2_ADDR \ diff --git a/arch/powerpc/lib/bdinfo.c b/arch/powerpc/lib/bdinfo.c index d2e5e6057b34..55dcad5df8e9 100644 --- a/arch/powerpc/lib/bdinfo.c +++ b/arch/powerpc/lib/bdinfo.c @@ -27,13 +27,6 @@ int arch_setup_bdinfo(void) bd->bi_intfreq = gd->cpu_clk; /* Internal Freq, in Hz */ bd->bi_busfreq = gd->bus_clk; /* Bus Freq, in Hz */
-#if defined(CONFIG_CPM2) - bd->bi_cpmfreq = gd->arch.cpm_clk; - bd->bi_brgfreq = gd->arch.brg_clk; - bd->bi_sccfreq = gd->arch.scc_clk; - bd->bi_vco = gd->arch.vco_out; -#endif /* CONFIG_CPM2 */ - return 0; }
@@ -59,10 +52,4 @@ void arch_print_bdinfo(void) puts("addressing = 32-bit\n"); #endif board_detail(); -#if defined(CONFIG_CPM2) - bdinfo_print_mhz("cpmfreq", bd->bi_cpmfreq); - bdinfo_print_mhz("vco", bd->bi_vco); - bdinfo_print_mhz("sccfreq", bd->bi_sccfreq); - bdinfo_print_mhz("brgfreq", bd->bi_brgfreq); -#endif } diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index 8d65047aa4d4..3b43066bb4f2 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -266,12 +266,6 @@ static void set_clocks_in_mhz (struct bd_info *kbd) /* convert all clock information to MHz */ kbd->bi_intfreq /= 1000000L; kbd->bi_busfreq /= 1000000L; -#if defined(CONFIG_CPM2) - kbd->bi_cpmfreq /= 1000000L; - kbd->bi_brgfreq /= 1000000L; - kbd->bi_sccfreq /= 1000000L; - kbd->bi_vco /= 1000000L; -#endif } }
diff --git a/drivers/pci/pci_mpc85xx.c b/drivers/pci/pci_mpc85xx.c index 1e180ee289b0..8a81a74067e9 100644 --- a/drivers/pci/pci_mpc85xx.c +++ b/drivers/pci/pci_mpc85xx.c @@ -6,7 +6,6 @@ */ #include <common.h> #include <asm/bitops.h> -#include <asm/cpm_85xx.h> #include <pci.h> #include <dm.h> #include <asm/fsl_law.h> diff --git a/include/asm-generic/u-boot.h b/include/asm-generic/u-boot.h index 637de0c4558a..1becc669aee9 100644 --- a/include/asm-generic/u-boot.h +++ b/include/asm-generic/u-boot.h @@ -52,12 +52,6 @@ struct bd_info { unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ unsigned long bi_busfreq; /* Bus Freq, in MHz */ -#if defined(CONFIG_CPM2) - unsigned long bi_cpmfreq; /* CPM_CLK Freq, in MHz */ - unsigned long bi_brgfreq; /* BRG_CLK Freq, in MHz */ - unsigned long bi_sccfreq; /* SCC_CLK Freq, in MHz */ - unsigned long bi_vco; /* VCO Out from PLL, in MHz */ -#endif #if defined(CONFIG_M68K) unsigned long bi_pcifreq; /* PCI Bus Freq, in MHz */ #endif diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h deleted file mode 100644 index 57097b17eb16..000000000000 --- a/include/configs/MPC8540ADS.h +++ /dev/null @@ -1,303 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2004, 2011 Freescale Semiconductor. - * (C) Copyright 2002,2003 Motorola,Inc. - * Xianghua Xiao X.Xiao@motorola.com - */ - -/* - * mpc8540ads board configuration file - * - * Please refer to doc/README.mpc85xx for more info. - * - * Make sure you change the MAC address and other network params first, - * search for CONFIG_SERVERIP, etc in this file. - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * default CCARBAR is at 0xff700000 - * assume U-Boot is less than 0.5MB - */ - -#ifndef CONFIG_HAS_FEC -#define CONFIG_HAS_FEC 1 /* 8540 has FEC */ -#endif - -/* - * sysclk for MPC85xx - * - * Two valid values are: - * 33000000 - * 66000000 - * - * Most PCI cards are still 33Mhz, so in the presence of PCI, 33MHz - * is likely the desired value here, so that is now the default. - * The board, however, can run at 66MHz. In any event, this value - * must match the settings of some switches. Details can be found - * in the README.mpc85xxads. - * - * XXX -- Can't we run at 66 MHz, anyway? PCI should drop to - * 33MHz to accommodate, based on a PCI pin. - * Note that PCI-X won't work at 33MHz. - */ - -/* - * These can be toggled for performance analysis, otherwise use default. - */ -#define CONFIG_L2_CACHE /* toggle L2 cache */ -#define CONFIG_BTB /* toggle branch predition */ - -#define CONFIG_SYS_CCSRBAR 0xe0000000 -#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR - -/* DDR Setup */ -#define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup*/ - -#define CONFIG_MEM_INIT_VALUE 0xDeadBeef - -#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE - -#define CONFIG_DIMM_SLOTS_PER_CTLR 1 -#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) - -/* I2C addresses of SPD EEPROMs */ -#define SPD_EEPROM_ADDRESS 0x51 /* CTLR 0 DIMM 0 */ - -/* These are used when DDR doesn't use SPD. */ -#define CONFIG_SYS_SDRAM_SIZE 128 /* DDR is 128MB */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 /* 0-128MB */ -#define CONFIG_SYS_DDR_CS0_CONFIG 0x80000002 -#define CONFIG_SYS_DDR_TIMING_1 0x37344321 -#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ -#define CONFIG_SYS_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ -#define CONFIG_SYS_DDR_MODE 0x00000062 /* DLL,normal,seq,4/2.5 */ -#define CONFIG_SYS_DDR_INTERVAL 0x05200100 /* autocharge,no open page */ - -/* - * SDRAM on the Local Bus - */ -#define CONFIG_SYS_LBC_SDRAM_BASE 0xf0000000 /* Localbus SDRAM */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -#define CONFIG_SYS_FLASH_BASE 0xff000000 /* start of FLASH 16M */ - -#define CONFIG_SYS_MAX_FLASH_SECT 64 /* sectors per device */ -#undef CONFIG_SYS_FLASH_CHECKSUM -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -#define CONFIG_SYS_RAMBOOT -#else -#undef CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_FLASH_EMPTY_INFO - -/* - * Local Bus Definitions - */ - -/* - * Base Register 2 and Option Register 2 configure SDRAM. - * The SDRAM base address, CONFIG_SYS_LBC_SDRAM_BASE, is 0xf0000000. - * - * For BR2, need: - * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 - * port-size = 32-bits = BR2[19:20] = 11 - * no parity checking = BR2[21:22] = 00 - * SDRAM for MSEL = BR2[24:26] = 011 - * Valid = BR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 - * - * FIXME: CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * FIXME: the top 17 bits of BR2. - */ - -/* - * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. - * - * For OR2, need: - * 64MB mask for AM, OR2[0:7] = 1111 1100 - * XAM, OR2[17:18] = 11 - * 9 columns OR2[19-21] = 010 - * 13 rows OR2[23-25] = 100 - * EAD set for extra time OR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 - */ - -#define CONFIG_SYS_LBC_LCRR 0x00030004 /* LB clock ratio reg */ -#define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ -#define CONFIG_SYS_LBC_LSRT 0x20000000 /* LB sdram refresh timer */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal*/ - -#define CONFIG_SYS_LBC_LSDMR_COMMON ( LSDMR_BSMA1516 \ - | LSDMR_RFCR5 \ - | LSDMR_PRETOACT3 \ - | LSDMR_ACTTORW3 \ - | LSDMR_BL8 \ - | LSDMR_WRC2 \ - | LSDMR_CL3 \ - | LSDMR_RFEN \ - ) - -/* - * SDRAM Controller configuration sequence. - */ -#define CONFIG_SYS_LBC_LSDMR_1 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_PCHALL) -#define CONFIG_SYS_LBC_LSDMR_2 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_3 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_4 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_MRW) -#define CONFIG_SYS_LBC_LSDMR_5 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_NORMAL) - -/* - * 32KB, 8-bit wide for ADS config reg - */ -#define CONFIG_SYS_BCSR (CONFIG_SYS_BR4_PRELIM & 0xffff8000) - -#define CONFIG_SYS_INIT_RAM_LOCK 1 -#define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */ - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ - -/* Serial Port */ -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) - -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} - -#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) - -/* - * I2C - */ -#define CONFIG_SYS_I2C_NOPROBES { {0, 0x69} } - -/* RapidIO MMU */ -#define CONFIG_SYS_RIO_MEM_VIRT 0xc0000000 /* base address */ -#define CONFIG_SYS_RIO_MEM_BUS 0xc0000000 /* base address */ -#define CONFIG_SYS_RIO_MEM_PHYS 0xc0000000 -#define CONFIG_SYS_RIO_MEM_SIZE 0x20000000 /* 128M */ - -/* - * General PCI - * Memory space is mapped 1-1, but I/O space must start from 0. - */ -#define CONFIG_SYS_PCI1_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCI1_MEM_BUS 0x80000000 -#define CONFIG_SYS_PCI1_MEM_PHYS 0x80000000 -#define CONFIG_SYS_PCI1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCI1_IO_VIRT 0xe2000000 -#define CONFIG_SYS_PCI1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCI1_IO_PHYS 0xe2000000 -#define CONFIG_SYS_PCI1_IO_SIZE 0x100000 /* 1M */ - -#if defined(CONFIG_PCI) - -#if !defined(CONFIG_PCI_PNP) - #define PCI_ENET0_IOADDR 0xe0000000 - #define PCI_ENET0_MEMADDR 0xe0000000 - #define PCI_IDSEL_NUMBER 0x0c /* slot0->3(IDSEL)=12->15 */ -#endif - -#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ - -#endif /* CONFIG_PCI */ - -#if defined(CONFIG_TSEC_ENET) - -#define CONFIG_TSEC1 1 -#define CONFIG_TSEC1_NAME "TSEC0" -#define CONFIG_TSEC2 1 -#define CONFIG_TSEC2_NAME "TSEC1" -#define TSEC1_PHY_ADDR 0 -#define TSEC2_PHY_ADDR 1 -#define TSEC1_PHYIDX 0 -#define TSEC2_PHYIDX 0 -#define TSEC1_FLAGS TSEC_GIGABIT -#define TSEC2_FLAGS TSEC_GIGABIT - -#if CONFIG_HAS_FEC -#define CONFIG_MPC85XX_FEC 1 -#define CONFIG_MPC85XX_FEC_NAME "FEC" -#define FEC_PHY_ADDR 3 -#define FEC_PHYIDX 0 -#define FEC_FLAGS 0 -#endif - -/* Options are: TSEC[0-1], FEC */ -#define CONFIG_ETHPRIME "TSEC0" - -#endif /* CONFIG_TSEC_ENET */ - -/* - * Environment - */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE - -/* - * Miscellaneous configurable options - */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 64 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial Memory map for Linux*/ -#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ - -/* - * Environment Configuration - */ - -/* The mac addresses for all ethernet interface */ -#if defined(CONFIG_TSEC_ENET) -#define CONFIG_HAS_ETH0 -#define CONFIG_HAS_ETH1 -#define CONFIG_HAS_ETH2 -#endif - -#define CONFIG_IPADDR 192.168.1.253 - -#define CONFIG_HOSTNAME "unknown" -#define CONFIG_ROOTPATH "/nfsroot" -#define CONFIG_BOOTFILE "your.uImage" - -#define CONFIG_SERVERIP 192.168.1.1 -#define CONFIG_GATEWAYIP 192.168.1.1 -#define CONFIG_NETMASK 255.255.255.0 - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=1000000\0" \ - "ramdiskfile=your.ramdisk.u-boot\0" \ - "fdtaddr=400000\0" \ - "fdtfile=your.fdt.dtb\0" - -#endif /* __CONFIG_H */ diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h deleted file mode 100644 index d23cf0e41aa1..000000000000 --- a/include/configs/MPC8560ADS.h +++ /dev/null @@ -1,292 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2004, 2011 Freescale Semiconductor. - * (C) Copyright 2002,2003 Motorola,Inc. - * Xianghua Xiao X.Xiao@motorola.com - */ - -/* - * mpc8560ads board configuration file - * - * Please refer to doc/README.mpc85xx for more info. - * - * Make sure you change the MAC address and other network params first, - * search for CONFIG_SERVERIP, etc. in this file. - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#include <linux/delay.h> - -/* High Level Configuration Options */ -#define CONFIG_CPM2 1 /* has CPM2 */ - -/* - * default CCARBAR is at 0xff700000 - * assume U-Boot is less than 0.5MB - */ - -#define CONFIG_RESET_PHY_R 1 /* Call reset_phy() */ - -/* - * sysclk for MPC85xx - * - * Two valid values are: - * 33000000 - * 66000000 - * - * Most PCI cards are still 33Mhz, so in the presence of PCI, 33MHz - * is likely the desired value here, so that is now the default. - * The board, however, can run at 66MHz. In any event, this value - * must match the settings of some switches. Details can be found - * in the README.mpc85xxads. - */ - -/* - * These can be toggled for performance analysis, otherwise use default. - */ -#define CONFIG_L2_CACHE /* toggle L2 cache */ -#define CONFIG_BTB /* toggle branch predition */ - -#define CONFIG_SYS_INIT_DBCR DBCR_IDM /* Enable Debug Exceptions */ - -#define CONFIG_SYS_CCSRBAR 0xe0000000 -#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR - -/* DDR Setup */ -#define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup*/ - -#define CONFIG_MEM_INIT_VALUE 0xDeadBeef - -#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE - -#define CONFIG_DIMM_SLOTS_PER_CTLR 1 -#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) - -/* I2C addresses of SPD EEPROMs */ -#define SPD_EEPROM_ADDRESS 0x51 /* CTLR 0 DIMM 0 */ - -/* These are used when DDR doesn't use SPD. */ -#define CONFIG_SYS_SDRAM_SIZE 128 /* DDR is 128MB */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 /* 0-128MB */ -#define CONFIG_SYS_DDR_CS0_CONFIG 0x80000002 -#define CONFIG_SYS_DDR_TIMING_1 0x37344321 -#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ -#define CONFIG_SYS_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ -#define CONFIG_SYS_DDR_MODE 0x00000062 /* DLL,normal,seq,4/2.5 */ -#define CONFIG_SYS_DDR_INTERVAL 0x05200100 /* autocharge,no open page */ - -/* - * SDRAM on the Local Bus - */ -#define CONFIG_SYS_LBC_SDRAM_BASE 0xf0000000 /* Localbus SDRAM */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -#define CONFIG_SYS_FLASH_BASE 0xff000000 /* start of FLASH 16M */ - -#define CONFIG_SYS_MAX_FLASH_SECT 64 /* sectors per device */ -#undef CONFIG_SYS_FLASH_CHECKSUM -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ - -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -#define CONFIG_SYS_RAMBOOT -#else -#undef CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_FLASH_EMPTY_INFO - -/* - * Local Bus Definitions - */ - -/* - * Base Register 2 and Option Register 2 configure SDRAM. - * The SDRAM base address, CONFIG_SYS_LBC_SDRAM_BASE, is 0xf0000000. - * - * For BR2, need: - * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 - * port-size = 32-bits = BR2[19:20] = 11 - * no parity checking = BR2[21:22] = 00 - * SDRAM for MSEL = BR2[24:26] = 011 - * Valid = BR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 - * - * FIXME: CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * FIXME: the top 17 bits of BR2. - */ - -/* - * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. - * - * For OR2, need: - * 64MB mask for AM, OR2[0:7] = 1111 1100 - * XAM, OR2[17:18] = 11 - * 9 columns OR2[19-21] = 010 - * 13 rows OR2[23-25] = 100 - * EAD set for extra time OR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 - */ - -#define CONFIG_SYS_LBC_LCRR 0x00030004 /* LB clock ratio reg */ -#define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ -#define CONFIG_SYS_LBC_LSRT 0x20000000 /* LB sdram refresh timer */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal*/ - -#define CONFIG_SYS_LBC_LSDMR_COMMON ( LSDMR_BSMA1516 \ - | LSDMR_RFCR5 \ - | LSDMR_PRETOACT3 \ - | LSDMR_ACTTORW3 \ - | LSDMR_BL8 \ - | LSDMR_WRC2 \ - | LSDMR_CL3 \ - | LSDMR_RFEN \ - ) - -/* - * SDRAM Controller configuration sequence. - */ -#define CONFIG_SYS_LBC_LSDMR_1 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_PCHALL) -#define CONFIG_SYS_LBC_LSDMR_2 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_3 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_4 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_MRW) -#define CONFIG_SYS_LBC_LSDMR_5 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_NORMAL) - -/* - * 32KB, 8-bit wide for ADS config reg - */ -#define CONFIG_SYS_BCSR (CONFIG_SYS_BR4_PRELIM & 0xffff8000) - -#define CONFIG_SYS_INIT_RAM_LOCK 1 -#define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */ - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ - -/* Serial Port */ -#define CONFIG_CONS_ON_SCC /* define if console on SCC */ - -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} - -/* - * I2C - */ -#define CONFIG_SYS_I2C_NOPROBES { {0, 0x69} } - -/* RapidIO MMU */ -#define CONFIG_SYS_RIO_MEM_VIRT 0xc0000000 /* base address */ -#define CONFIG_SYS_RIO_MEM_BUS 0xc0000000 /* base address */ -#define CONFIG_SYS_RIO_MEM_PHYS 0xc0000000 -#define CONFIG_SYS_RIO_MEM_SIZE 0x20000000 /* 128M */ - -/* - * General PCI - * Memory space is mapped 1-1, but I/O space must start from 0. - */ -#define CONFIG_SYS_PCI1_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCI1_MEM_BUS 0x80000000 -#define CONFIG_SYS_PCI1_MEM_PHYS 0x80000000 -#define CONFIG_SYS_PCI1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCI1_IO_VIRT 0xe2000000 -#define CONFIG_SYS_PCI1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCI1_IO_PHYS 0xe2000000 -#define CONFIG_SYS_PCI1_IO_SIZE 0x100000 /* 1M */ - -#if defined(CONFIG_PCI) - -#if !defined(CONFIG_PCI_PNP) - #define PCI_ENET0_IOADDR 0xe0000000 - #define PCI_ENET0_MEMADDR 0xe0000000 - #define PCI_IDSEL_NUMBER 0x0c /* slot0->3(IDSEL)=12->15 */ -#endif - -#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ - -#endif /* CONFIG_PCI */ - -#ifdef CONFIG_TSEC_ENET - -#define CONFIG_TSEC1 1 -#define CONFIG_TSEC1_NAME "TSEC0" -#define CONFIG_TSEC2 1 -#define CONFIG_TSEC2_NAME "TSEC1" -#define TSEC1_PHY_ADDR 0 -#define TSEC2_PHY_ADDR 1 -#define TSEC1_PHYIDX 0 -#define TSEC2_PHYIDX 0 -#define TSEC1_FLAGS TSEC_GIGABIT -#define TSEC2_FLAGS TSEC_GIGABIT - -/* Options are: TSEC[0-1] */ -#define CONFIG_ETHPRIME "TSEC0" - -#endif /* CONFIG_TSEC_ENET */ - -/* - * Environment - */ - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE - -/* - * Miscellaneous configurable options - */ - -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 64 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial Memory map for Linux*/ -#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ - -/* - * Environment Configuration - */ -#if defined(CONFIG_TSEC_ENET) -#define CONFIG_HAS_ETH0 -#define CONFIG_HAS_ETH1 -#define CONFIG_HAS_ETH2 -#define CONFIG_HAS_ETH3 -#endif - -#define CONFIG_IPADDR 192.168.1.253 - -#define CONFIG_HOSTNAME "unknown" -#define CONFIG_ROOTPATH "/nfsroot" -#define CONFIG_BOOTFILE "your.uImage" - -#define CONFIG_SERVERIP 192.168.1.1 -#define CONFIG_GATEWAYIP 192.168.1.1 -#define CONFIG_NETMASK 255.255.255.0 - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "consoledev=ttyCPM\0" \ - "ramdiskaddr=1000000\0" \ - "ramdiskfile=your.ramdisk.u-boot\0" \ - "fdtaddr=400000\0" \ - "fdtfile=mpc8560ads.dtb\0" - -#endif /* __CONFIG_H */
This converts the following to Kconfig: CONFIG_BTB
Signed-off-by: Tom Rini trini@konsulko.com --- arch/powerpc/cpu/mpc85xx/Kconfig | 10 ++++++++++ include/configs/MPC8548CDS.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/kmcent2.h | 1 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/socrates.h | 1 - 13 files changed, 10 insertions(+), 12 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index c308447d493a..a978eea1617a 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -317,6 +317,7 @@ config ARCH_MPC8540
config ARCH_MPC8544 bool + select BTB select FSL_LAW select SYS_CACHE_SHIFT_5 select SYS_FSL_ERRATUM_A005125 @@ -330,6 +331,7 @@ config ARCH_MPC8544
config ARCH_MPC8548 bool + select BTB select FSL_LAW select SYS_FSL_ERRATUM_A005125 select SYS_FSL_ERRATUM_NMG_DDR120 @@ -352,6 +354,7 @@ config ARCH_MPC8560
config ARCH_P1010 bool + select BTB select FSL_LAW select SYS_CACHE_SHIFT_5 select SYS_HAS_SERDES @@ -400,6 +403,7 @@ config ARCH_P1011
config ARCH_P1020 bool + select BTB select FSL_LAW select SYS_CACHE_SHIFT_5 select SYS_FSL_ERRATUM_A004508 @@ -496,6 +500,7 @@ config ARCH_P1025
config ARCH_P2020 bool + select BTB select FSL_LAW select SYS_CACHE_SHIFT_5 select SYS_FSL_ERRATUM_A004477 @@ -772,6 +777,9 @@ config MPC85XX_HAVE_RESET_VECTOR bool "Indicate reset vector at CONFIG_RESET_VECTOR_ADDRESS - 0xffc" depends on MPC85xx
+config BTB + bool "toggle branch predition" + config BOOKE bool default y @@ -784,12 +792,14 @@ config E500
config E500MC bool + select BTB imply CMD_PCI help Enble PowerPC E500MC core
config E6500 bool + select BTB help Enable PowerPC E6500 core
diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index e16d870a5e66..b5430c950d03 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -30,7 +30,6 @@ * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_L2_CACHE /* toggle L2 cache */ -#define CONFIG_BTB /* toggle branch predition */
/* * Only possible on E500 Version 2 or newer cores. diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 106d1e6a4b7e..827edf484b76 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -151,7 +151,6 @@ * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_L2_CACHE /* toggle L2 cache */ -#define CONFIG_BTB /* toggle branch predition */
#define CONFIG_ENABLE_36BIT_PHYS diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index e6d5321070bf..027f1479319d 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -58,7 +58,6 @@ #define CONFIG_SYS_CACHE_STASHING #define CONFIG_BACKSIDE_L2_CACHE #define CONFIG_SYS_INIT_L2CSR0 L2CSR0_L2E -#define CONFIG_BTB /* toggle branch predition */
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index d24cfce8b3b9..2fe53bf6be9f 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -121,7 +121,6 @@ #define CONFIG_SYS_CACHE_STASHING #define CONFIG_BACKSIDE_L2_CACHE #define CONFIG_SYS_INIT_L2CSR0 L2CSR0_L2E -#define CONFIG_BTB /* toggle branch predition */ #ifdef CONFIG_DDR_ECC #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 9433f14227bb..2c4ede960ec1 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -98,7 +98,6 @@ #define CONFIG_SYS_CACHE_STASHING #define CONFIG_BACKSIDE_L2_CACHE #define CONFIG_SYS_INIT_L2CSR0 L2CSR0_L2E -#define CONFIG_BTB /* toggle branch predition */ #ifdef CONFIG_DDR_ECC #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index a41f9f0d9b83..3fcab6a0213c 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -88,7 +88,6 @@ * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_SYS_CACHE_STASHING -#define CONFIG_BTB /* toggle branch predition */ #ifdef CONFIG_DDR_ECC #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 7165ba082833..8a725cd1f78f 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -83,7 +83,6 @@ * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_SYS_CACHE_STASHING -#define CONFIG_BTB /* toggle branch predition */ #ifdef CONFIG_DDR_ECC #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index daccd816c104..441ff18441a6 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -65,7 +65,6 @@ * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_SYS_CACHE_STASHING -#define CONFIG_BTB /* toggle branch predition */ #ifdef CONFIG_DDR_ECC #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index bd264122da76..79c90a7addb8 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -59,7 +59,6 @@ #define CONFIG_SYS_CACHE_STASHING #define CONFIG_BACKSIDE_L2_CACHE #define CONFIG_SYS_INIT_L2CSR0 L2CSR0_L2E -#define CONFIG_BTB /* toggle branch predition */ #ifdef CONFIG_DDR_ECC #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif diff --git a/include/configs/kmcent2.h b/include/configs/kmcent2.h index ca0cb31c2964..52a5ff9382ed 100644 --- a/include/configs/kmcent2.h +++ b/include/configs/kmcent2.h @@ -152,7 +152,6 @@ #define CONFIG_SYS_CACHE_STASHING #define CONFIG_BACKSIDE_L2_CACHE #define CONFIG_SYS_INIT_L2CSR0 L2CSR0_L2E -#define CONFIG_BTB /* toggle branch predition */
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 92008cd38e49..549adf04b62d 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -145,7 +145,6 @@ * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_L2_CACHE -#define CONFIG_BTB
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index a51a162ee044..4eb19b0e3e3f 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -42,7 +42,6 @@ * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_L2_CACHE /* toggle L2 cache */ -#define CONFIG_BTB /* toggle branch predition */
These particular values are not configurable and today we always set CONFIG_SECURE_BL1_ONLY. Move these to where they're used in the code, and drop from the CONFIG namespace.
Cc: Minkyu Kang mk7.kang@samsung.com Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-exynos/spl_boot.c | 30 ++++++++++++++++++++++++++++++ include/configs/exynos5-common.h | 24 ------------------------ include/configs/origen.h | 5 ----- include/configs/smdkv310.h | 5 ----- 4 files changed, 30 insertions(+), 34 deletions(-)
diff --git a/arch/arm/mach-exynos/spl_boot.c b/arch/arm/mach-exynos/spl_boot.c index 722449881af2..93fea9c749a6 100644 --- a/arch/arm/mach-exynos/spl_boot.c +++ b/arch/arm/mach-exynos/spl_boot.c @@ -22,6 +22,36 @@ #include "common_setup.h" #include "clock_init.h"
+#ifdef CONFIG_ARCH_EXYNOS5 +#define SECURE_BL1_ONLY + +/* Secure FW size configuration */ +#ifdef SECURE_BL1_ONLY +#define SEC_FW_SIZE (8 << 10) /* 8KB */ +#else +#define SEC_FW_SIZE 0 +#endif + +/* Configuration of BL1, BL2, ENV Blocks on mmc */ +#define RES_BLOCK_SIZE (512) +#define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ +#define BL2_SIZE (512UL << 10UL) /* 512 KB */ + +#define BL1_OFFSET (RES_BLOCK_SIZE + SEC_FW_SIZE) +#define BL2_OFFSET (BL1_OFFSET + BL1_SIZE) + +/* U-Boot copy size from boot Media to DRAM.*/ +#define BL2_START_OFFSET (BL2_OFFSET/512) +#define BL2_SIZE_BLOC_COUNT (BL2_SIZE/512) + +#define EXYNOS_COPY_SPI_FNPTR_ADDR 0x02020058 +#define SPI_FLASH_UBOOT_POS (SEC_FW_SIZE + BL1_SIZE) +#elif defined(CONFIG_ARCH_EXYNOS4) +#define COPY_BL2_SIZE 0x80000 +#define BL2_START_OFFSET ((CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)/512) +#define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512) +#endif + DECLARE_GLOBAL_DATA_PTR;
/* Index into irom ptr table */ diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 90d095d535b0..410243bb2c91 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -58,30 +58,6 @@
#define CONFIG_SYS_MONITOR_BASE 0x00000000
-#define CONFIG_SECURE_BL1_ONLY - -/* Secure FW size configuration */ -#ifdef CONFIG_SECURE_BL1_ONLY -#define CONFIG_SEC_FW_SIZE (8 << 10) /* 8KB */ -#else -#define CONFIG_SEC_FW_SIZE 0 -#endif - -/* Configuration of BL1, BL2, ENV Blocks on mmc */ -#define CONFIG_RES_BLOCK_SIZE (512) -#define CONFIG_BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ -#define CONFIG_BL2_SIZE (512UL << 10UL) /* 512 KB */ - -#define CONFIG_BL1_OFFSET (CONFIG_RES_BLOCK_SIZE + CONFIG_SEC_FW_SIZE) -#define CONFIG_BL2_OFFSET (CONFIG_BL1_OFFSET + CONFIG_BL1_SIZE) - -/* U-Boot copy size from boot Media to DRAM.*/ -#define BL2_START_OFFSET (CONFIG_BL2_OFFSET/512) -#define BL2_SIZE_BLOC_COUNT (CONFIG_BL2_SIZE/512) - -#define EXYNOS_COPY_SPI_FNPTR_ADDR 0x02020058 -#define SPI_FLASH_UBOOT_POS (CONFIG_SEC_FW_SIZE + CONFIG_BL1_SIZE) - /* SPI */
/* Ethernet Controllor Driver */ diff --git a/include/configs/origen.h b/include/configs/origen.h index 1caeed6ba5cd..22325180ce0e 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -58,9 +58,4 @@
#define CONFIG_SYS_INIT_SP_ADDR 0x02040000
-/* U-Boot copy size from boot Media to DRAM.*/ -#define COPY_BL2_SIZE 0x80000 -#define BL2_START_OFFSET ((CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)/512) -#define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512) - #endif /* __CONFIG_H */ diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index f113fa44045e..32196a5aef94 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -51,11 +51,6 @@
-/* U-Boot copy size from boot Media to DRAM.*/ -#define COPY_BL2_SIZE 0x80000 -#define BL2_START_OFFSET ((CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)/512) -#define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512) - /* Ethernet Controllor Driver */ #ifdef CONFIG_CMD_NET #define CONFIG_ENV_SROM_BANK 1
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
/* SPI */
Dear Tom,
2022년 2월 24일 (목) 09:03, Jaehoon Chung jh80.chung@samsung.com님이 작성:
Reviewed-by: Minkyu Kang mk7.kang@samsung.com
Thanks.
Cc: Minkyu Kang mk7.kang@samsung.com Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Minkyu Kang mk7.kang@samsung.com
This converts the following to Kconfig: CONFIG_BOARD_COMMON
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-exynos/Kconfig | 4 ++++ include/configs/espresso7420.h | 2 -- include/configs/exynos4-common.h | 2 -- include/configs/exynos5-dt-common.h | 2 -- include/configs/exynos78x0-common.h | 2 -- include/configs/odroid_xu3.h | 2 -- include/configs/smdk5250.h | 2 -- include/configs/smdk5420.h | 2 -- include/configs/smdkv310.h | 1 - include/configs/snow.h | 2 -- include/configs/spring.h | 2 -- scripts/config_whitelist.txt | 1 - 12 files changed, 4 insertions(+), 20 deletions(-)
diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index 6087d93c71a4..f73dbbb507d1 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -1,5 +1,9 @@ if ARCH_EXYNOS
+config BOARD_COMMON + def_bool y + depends on !TARGET_SMDKV310 && !TARGET_ARNDALE + choice prompt "EXYNOS architecture type select" optional diff --git a/include/configs/espresso7420.h b/include/configs/espresso7420.h index 2495db93f8d4..d936b7f09fcd 100644 --- a/include/configs/espresso7420.h +++ b/include/configs/espresso7420.h @@ -10,8 +10,6 @@
#include <configs/exynos7420-common.h>
-#define CONFIG_BOARD_COMMON - #define CONFIG_ESPRESSO7420
#define CONFIG_SYS_SDRAM_BASE 0x40000000 diff --git a/include/configs/exynos4-common.h b/include/configs/exynos4-common.h index 52dcf7a3bc42..4202c6261262 100644 --- a/include/configs/exynos4-common.h +++ b/include/configs/exynos4-common.h @@ -12,8 +12,6 @@
#include "exynos-common.h"
-#define CONFIG_BOARD_COMMON - /* SD/MMC configuration */ #define CONFIG_MMC_DEFAULT_DEV 0
diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index 00b67787d9e6..bcbdfa7ae35a 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -21,8 +21,6 @@ #define FLASH_SIZE (4 << 20) #define CONFIG_SPI_BOOTING
-#define CONFIG_BOARD_COMMON - /* Display */ #ifdef CONFIG_LCD #define CONFIG_EXYNOS_FB diff --git a/include/configs/exynos78x0-common.h b/include/configs/exynos78x0-common.h index 8d3449f028c3..6b1df63dc32f 100644 --- a/include/configs/exynos78x0-common.h +++ b/include/configs/exynos78x0-common.h @@ -36,8 +36,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE \ {9600, 19200, 38400, 57600, 115200, 230400, 460800, 921600}
-#define CONFIG_BOARD_COMMON - #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_2M - GENERATED_GBL_DATA_SIZE) /* DRAM Memory Banks */ diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index a4825982a898..616f25eafd3e 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -10,8 +10,6 @@ #include <configs/exynos5420-common.h> #include <configs/exynos5-common.h>
#define TZPC_BASE_OFFSET 0x10000 diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index d7e86f2f7644..1ea3b650cd26 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -15,6 +15,4 @@ #undef CONFIG_EXYNOS_FB #undef CONFIG_EXYNOS_DP
-#define CONFIG_BOARD_COMMON - #endif /* __CONFIG_SMDK_H */ diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h index 38691b63dafe..f26995d5c1c9 100644 --- a/include/configs/smdk5420.h +++ b/include/configs/smdk5420.h @@ -15,8 +15,6 @@ #undef CONFIG_EXYNOS_FB #undef CONFIG_EXYNOS_DP
-#define CONFIG_BOARD_COMMON - #define CONFIG_SMDK5420 /* which is in a SMDK5420 */
#define CONFIG_SYS_SDRAM_BASE 0x20000000 diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 32196a5aef94..84b8537e54df 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -10,7 +10,6 @@
#include "exynos4-common.h"
-#undef CONFIG_BOARD_COMMON #undef CONFIG_USB_GADGET_DWC2_OTG_PHY
/* High Level Configuration Options */ diff --git a/include/configs/snow.h b/include/configs/snow.h index c082b2d82d86..00d9b4d41673 100644 --- a/include/configs/snow.h +++ b/include/configs/snow.h @@ -15,6 +15,4 @@ #include <configs/exynos5-dt-common.h> #include <configs/exynos5-common.h>
-#define CONFIG_BOARD_COMMON - #endif /* __CONFIG_SNOW_H */ diff --git a/include/configs/spring.h b/include/configs/spring.h index 0b052453a51c..2f0a5807be0d 100644 --- a/include/configs/spring.h +++ b/include/configs/spring.h @@ -10,6 +10,4 @@ #include <configs/exynos5-dt-common.h> #include <configs/exynos5-common.h>
-#define CONFIG_BOARD_COMMON - #endif /* __CONFIG_SPRING_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index a6bc234f51ed..1e78d266aed4 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -37,7 +37,6 @@ CONFIG_BL2_OFFSET CONFIG_BL2_SIZE CONFIG_BOARDDIR CONFIG_BOARDNAME -CONFIG_BOARD_COMMON CONFIG_BOARD_ECC_SUPPORT CONFIG_BOARD_NAME CONFIG_BOARD_POSTCLK_INIT
On Wed, 23 Feb 2022 at 10:29, Tom Rini trini@konsulko.com wrote:
Remove some code, primarily CPM2 related, that is now unused since the removal of MPC8540/60ADS.
Fixes 3913191c8a6b ("powerpc: mpc8540ads: mpc8560ads: Drop support for MPC8540/60ADS") Signed-off-by: Tom Rini trini@konsulko.com
arch/powerpc/cpu/mpc85xx/Makefile | 2 - arch/powerpc/cpu/mpc85xx/commproc.c | 188 ------ arch/powerpc/cpu/mpc85xx/cpu.c | 4 - arch/powerpc/cpu/mpc85xx/cpu_init.c | 72 --- arch/powerpc/cpu/mpc85xx/fdt.c | 8 - arch/powerpc/cpu/mpc85xx/serial_scc.c | 262 -------- arch/powerpc/cpu/mpc85xx/speed.c | 16 - arch/powerpc/include/asm/cpm_85xx.h | 824 ------------------------- arch/powerpc/include/asm/global_data.h | 11 - arch/powerpc/include/asm/immap_85xx.h | 327 ---------- arch/powerpc/lib/bdinfo.c | 13 - arch/powerpc/lib/bootm.c | 6 - drivers/pci/pci_mpc85xx.c | 1 - include/asm-generic/u-boot.h | 6 - include/configs/MPC8540ADS.h | 303 --------- include/configs/MPC8560ADS.h | 292 --------- 16 files changed, 2335 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc85xx/commproc.c delete mode 100644 arch/powerpc/cpu/mpc85xx/serial_scc.c delete mode 100644 arch/powerpc/include/asm/cpm_85xx.h delete mode 100644 include/configs/MPC8540ADS.h delete mode 100644 include/configs/MPC8560ADS.h
Fixes 3913191c8a6b ("powerpc: mpc8540ads: mpc8560ads: Drop support for MPC8540/60ADS") Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org
Jaehoon Chung
Minkyu Kang
