[U-Boot] [PATCH v3] fastboot: add support for reboot-bootloader command
The "fastboot reboot-bootloader" command is defined to re-enter into fastboot mode after rebooting into bootloader. This command is usually used after updating bootloader via fastboot.
This commit implements only a generic side of the command - setting of the reset flag and then resetting. Setting of the reset flag is implemented using __weak fb_set_reboot_flag() function. The actual setting and checking of the reset flag should be implemented by a boot script and/or board/SoC specific code.
Signed-off-by: Alexey Firago alexey_firago@mentor.com ---
Changes in v3: - return -ENOSYS from default fb_set_reboot_flag()
Changes in v2: - return error in default fb_set_reboot_flag()
drivers/usb/gadget/f_fastboot.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 310175a..a000c25 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -122,6 +122,7 @@ static struct usb_gadget_strings *fastboot_strings[] = { };
static void rx_handler_command(struct usb_ep *ep, struct usb_request *req); +static int strcmp_l1(const char *s1, const char *s2);
static void fastboot_complete(struct usb_ep *ep, struct usb_request *req) { @@ -317,8 +318,20 @@ static void compl_do_reset(struct usb_ep *ep, struct usb_request *req) do_reset(NULL, 0, 0, NULL); }
+int __weak fb_set_reboot_flag(void) +{ + return -ENOSYS; +} + static void cb_reboot(struct usb_ep *ep, struct usb_request *req) { + char *cmd = req->buf; + if (!strcmp_l1("reboot-bootloader", cmd)) { + if (fb_set_reboot_flag()) { + fastboot_tx_write_str("FAILCannot set reboot flag"); + return; + } + } fastboot_func->in_req->complete = compl_do_reset; fastboot_tx_write_str("OKAY"); }
Hi Alexey,
Changes in v3:
Changes in v2:
- return -ENOSYS;
- char *cmd = req->buf;
- if (!strcmp_l1("reboot-bootloader", cmd)) {
flag");
return;
- } fastboot_func->in_req->complete = compl_do_reset; fastboot_tx_write_str("OKAY");
Applied to u-boot-dfu.
Thanks for patch!
Hi Lukasz,
Hmm, I don't see it applied to u-boot-dfu now. Do I need to add something ?
Thanks, Alexey
On 26.02.2015 13:22, Lukasz Majewski wrote:
Hi Alexey,
Changes in v3:
Changes in v2:
- return -ENOSYS;
- static void cb_reboot(struct usb_ep *ep, struct usb_request *req) {
flag");
return;
- } fastboot_func->in_req->complete = compl_do_reset; fastboot_tx_write_str("OKAY"); }
Thanks for patch!
Hi Alexey,
Hi Lukasz,
If possible, please look into the current status of fastboot support in u-boot mainline (since we are at -rc3).
Since I'm not (yet) a fastboot user, please support me with testing.
Best regards, Lukasz
Thanks, Alexey
Hi Alexey,
Changes in v3:
Changes in v2:
static void rx_handler_command(struct usb_ep *ep, struct usb_request *req); +static int strcmp_l1(const char *s1, const char *s2); static void fastboot_complete(struct usb_ep *ep, struct usb_request *req) { @@ -317,8 +318,20 @@ static void compl_do_reset(struct usb_ep *ep, struct usb_request *req) do_reset(NULL, 0, 0, NULL); }
- return -ENOSYS;
reboot flag");
return;
Thanks for patch!
Lukasz,
Here is how I've tested "v3 fastboot: add support for reboot-bootloader command" patch:
* Applied it to master ( 7ae8350f67eea861280a4cbd2d067777a0e87153) * Board to test - Nitrogen6q * Applied attached "0001-test-nitrogen6x-fastboot-add-reboot-bootloader-suppo.patch" with the board specific flags handling functions and envs * On "fastboot reboot-bootloader" command, nitrogen6x specific fb_set_reboot_flag() is called, setting bit in the SNVS_LPGPR register (as in Freescale's releases) * On reboot board checks this bit in board's misc_init_r() and sets "fastboot_flag" env accordingly * bootscript handles "fastboot_flag"
Let me know if I've missed something.
Regards, Alexey
On 05.03.2015 13:04, Lukasz Majewski wrote:
Hi Alexey,
Hi Lukasz,
Thanks, Alexey
Hi Alexey,
Changes in v3:
Changes in v2:
- return -ENOSYS;
reboot flag");
return;
Thanks for patch!
Changes in v3:
Changes in v2:
- return -ENOSYS;
return;
Tested-by: Steve Rae srae@broadcom.com
(on bcm28155_ap board) Thanks!
Hi Steve,
Changes in v3:
Changes in v2:
- return -ENOSYS;
reboot flag");
return;
Applied to u-boot-dfu tree. Thanks!
Alexey Firago
Lukasz Majewski
Steve Rae
