[PATCH] arm: dts: socfpga: agilex: Add freeze controller node
The freeze controller is required for FPGA partial reconfig. This node is disable on default. Enable this node via u-boot fdt command when needed.
Signed-off-by: Yau Wai Gan yau.wai.gan@intel.com Signed-off-by: Dinesh Maniyam dinesh.maniyam@intel.com --- arch/arm/dts/socfpga_agilex_socdk-u-boot.dtsi | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/socfpga_agilex_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_agilex_socdk-u-boot.dtsi index 6cac36a1fc..2400fad18a 100644 --- a/arch/arm/dts/socfpga_agilex_socdk-u-boot.dtsi +++ b/arch/arm/dts/socfpga_agilex_socdk-u-boot.dtsi @@ -2,7 +2,7 @@ /* * U-Boot additions * - * Copyright (C) 2019 Intel Corporation <www.intel.com> + * Copyright (C) 2019-2022 Intel Corporation <www.intel.com> */
#include "socfpga_agilex-u-boot.dtsi" @@ -11,6 +11,15 @@ aliases { spi0 = &qspi; i2c0 = &i2c1; + freeze_br0 = &freeze_controller; + }; + + soc { + freeze_controller: freeze_controller@f9000450 { + compatible = "altr,freeze-bridge-controller"; + reg = <0xf9000450 0x00000010>; + status = "disabled"; + }; };
memory {
-----Original Message----- From: Maniyam, Dinesh dinesh.maniyam@intel.com Sent: Tuesday, 31 May, 2022 4:06 PM To: u-boot@lists.denx.de Cc: Chee, Tien Fong tien.fong.chee@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Gan, Yau Wai yau.wai.gan@intel.com; Kho, Sin Hui sin.hui.kho@intel.com; Lokanathan, Raaj raaj.lokanathan@intel.com; Maniyam, Dinesh dinesh.maniyam@intel.com Subject: [PATCH] arm: dts: socfpga: agilex: Add freeze controller node
- U-Boot additions
- Copyright (C) 2019 Intel Corporation <www.intel.com>
- Copyright (C) 2019-2022 Intel Corporation <www.intel.com>
soc {
memory {
-- 2.26.2
Reviewed-by: Tien Fong Chee tien.fong.chee@intel.com
Regards Tien Fong
Chee, Tien Fong
