[U-Boot] Please pull u-boot-marvell/master
Hi Tom,
please pull the 2nd batch of Marvell / MVEBU patches:
---------------------------------------------------------------- - Sync DDR training with Marvell code for Armada 38x by Chris - Misc updates to Armada 38x Helios4 board by Aditya ----------------------------------------------------------------
Thanks, Stefan
The following changes since commit 3589025867274ff28f689029ab8323301771c8ec:
Merge branch '2018-12-06-master-imports' (2018-12-07 10:55:12 -0500)
git://www.denx.de/git/u-boot-marvell.git
for you to fetch changes up to 5ca84c6dd2b3060471171cce3f76d8af35060c0b:
arm: mvebu: helios4: Reset uSOM onboard phy during board init (2018-12-08 16:19:41 +0100)
---------------------------------------------------------------- Aditya Prayoga (6): arm: mvebu: helios4: mmc: move environment before 1M arm: mvebu: helios4: Enable I2C and IO Expander arm: mvebu: helios4: Enable mvebu GPIO arm: mvebu: helios4: Reduce U-Boot image size arm: mvebu: helios4: Enable SPI flash support arm: mvebu: helios4: Reset uSOM onboard phy during board init
Chris Packham (1): ARM: mvebu: a38x: sync ddr training code with mv_ddr-armada-18.09.02
arch/arm/dts/armada-388-helios4-u-boot.dtsi | 22 + board/CZ.NIC/turris_omnia/turris_omnia.c | 4 +- board/Marvell/db-88f6820-amc/db-88f6820-amc.c | 2 +- board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 2 +- board/gdsys/a38x/controlcenterdc.c | 2 +- board/kobol/helios4/helios4.c | 34 +- board/solidrun/clearfog/clearfog.c | 2 +- configs/helios4_defconfig | 13 +- drivers/ddr/marvell/a38x/ddr3_debug.c | 414 ++---------------- drivers/ddr/marvell/a38x/ddr3_init.c | 91 +--- drivers/ddr/marvell/a38x/ddr3_init.h | 43 +- drivers/ddr/marvell/a38x/ddr3_topology_def.h | 78 ---- drivers/ddr/marvell/a38x/ddr3_training.c | 484 +++++++++++---------- drivers/ddr/marvell/a38x/ddr3_training_bist.c | 1 + .../marvell/a38x/ddr3_training_centralization.c | 3 + drivers/ddr/marvell/a38x/ddr3_training_db.c | 172 +++++--- drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c | 1 + drivers/ddr/marvell/a38x/ddr3_training_ip.h | 38 -- drivers/ddr/marvell/a38x/ddr3_training_ip_def.h | 31 -- drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c | 2 + drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h | 1 + drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h | 91 +--- drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h | 10 +- drivers/ddr/marvell/a38x/ddr3_training_leveling.c | 75 ++-- drivers/ddr/marvell/a38x/ddr3_training_leveling.h | 1 - drivers/ddr/marvell/a38x/ddr3_training_pbs.c | 7 +- drivers/ddr/marvell/a38x/ddr_topology_def.h | 107 ++++- drivers/ddr/marvell/a38x/ddr_training_ip_db.h | 2 - drivers/ddr/marvell/a38x/dram_if.h | 13 + drivers/ddr/marvell/a38x/mv_ddr_build_message.c | 2 +- drivers/ddr/marvell/a38x/mv_ddr_common.h | 38 +- drivers/ddr/marvell/a38x/mv_ddr_plat.c | 181 ++++---- drivers/ddr/marvell/a38x/mv_ddr_plat.h | 12 +- drivers/ddr/marvell/a38x/mv_ddr_regs.h | 19 + drivers/ddr/marvell/a38x/mv_ddr_spd.c | 16 +- drivers/ddr/marvell/a38x/mv_ddr_topology.c | 215 +++++++-- drivers/ddr/marvell/a38x/mv_ddr_topology.h | 214 ++++++++- drivers/ddr/marvell/a38x/mv_ddr_training_db.h | 40 ++ drivers/ddr/marvell/a38x/xor.c | 8 +- include/configs/helios4.h | 48 +- 40 files changed, 1227 insertions(+), 1312 deletions(-) create mode 100644 arch/arm/dts/armada-388-helios4-u-boot.dtsi delete mode 100644 drivers/ddr/marvell/a38x/ddr3_topology_def.h create mode 100644 drivers/ddr/marvell/a38x/dram_if.h create mode 100644 drivers/ddr/marvell/a38x/mv_ddr_training_db.h
Hi Tom, Stefan,
On Sun, Dec 9, 2018 at 11:16 PM Stefan Roese sr@denx.de wrote:
Hi Tom,
Thanks, Stefan
I just noticed I managed to delete the license from 2 of the files. I've just posted a patch to correct this [1]. I'm not sure if you want Stefan to squash it into the original and re-submit or just apply it directly to u-boot master. Sorry for the hassle.
[1] - http://patchwork.ozlabs.org/patch/1010175/
arch/arm/dts/armada-388-helios4-u-boot.dtsi | 22 + board/CZ.NIC/turris_omnia/turris_omnia.c | 4 +- board/Marvell/db-88f6820-amc/db-88f6820-amc.c | 2 +- board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 2 +- board/gdsys/a38x/controlcenterdc.c | 2 +- board/kobol/helios4/helios4.c | 34 +- board/solidrun/clearfog/clearfog.c | 2 +- configs/helios4_defconfig | 13 +- drivers/ddr/marvell/a38x/ddr3_debug.c | 414 ++---------------- drivers/ddr/marvell/a38x/ddr3_init.c | 91 +--- drivers/ddr/marvell/a38x/ddr3_init.h | 43 +- drivers/ddr/marvell/a38x/ddr3_topology_def.h | 78 ---- drivers/ddr/marvell/a38x/ddr3_training.c | 484 +++++++++++---------- drivers/ddr/marvell/a38x/ddr3_training_bist.c | 1 + .../marvell/a38x/ddr3_training_centralization.c | 3 + drivers/ddr/marvell/a38x/ddr3_training_db.c | 172 +++++--- drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c | 1 + drivers/ddr/marvell/a38x/ddr3_training_ip.h | 38 -- drivers/ddr/marvell/a38x/ddr3_training_ip_def.h | 31 -- drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c | 2 + drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h | 1 + drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h | 91 +--- drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h | 10 +- drivers/ddr/marvell/a38x/ddr3_training_leveling.c | 75 ++-- drivers/ddr/marvell/a38x/ddr3_training_leveling.h | 1 - drivers/ddr/marvell/a38x/ddr3_training_pbs.c | 7 +- drivers/ddr/marvell/a38x/ddr_topology_def.h | 107 ++++- drivers/ddr/marvell/a38x/ddr_training_ip_db.h | 2 - drivers/ddr/marvell/a38x/dram_if.h | 13 + drivers/ddr/marvell/a38x/mv_ddr_build_message.c | 2 +- drivers/ddr/marvell/a38x/mv_ddr_common.h | 38 +- drivers/ddr/marvell/a38x/mv_ddr_plat.c | 181 ++++---- drivers/ddr/marvell/a38x/mv_ddr_plat.h | 12 +- drivers/ddr/marvell/a38x/mv_ddr_regs.h | 19 + drivers/ddr/marvell/a38x/mv_ddr_spd.c | 16 +- drivers/ddr/marvell/a38x/mv_ddr_topology.c | 215 +++++++-- drivers/ddr/marvell/a38x/mv_ddr_topology.h | 214 ++++++++- drivers/ddr/marvell/a38x/mv_ddr_training_db.h | 40 ++ drivers/ddr/marvell/a38x/xor.c | 8 +- include/configs/helios4.h | 48 +- 40 files changed, 1227 insertions(+), 1312 deletions(-) create mode 100644 arch/arm/dts/armada-388-helios4-u-boot.dtsi delete mode 100644 drivers/ddr/marvell/a38x/ddr3_topology_def.h create mode 100644 drivers/ddr/marvell/a38x/dram_if.h create mode 100644 drivers/ddr/marvell/a38x/mv_ddr_training_db.h _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Chris Packham
Stefan Roese
