[U-Boot] [PATCH v2] cfi_flash: precision and underflow problem in tout calculation
With old configuration it could happen tout=0 if CONFIG_SYS_HZ<1000.
Signed-off-by: Alessandro Rubini rubini@gnudd.com Signed-off-by: Renato Andreola renato.andreola@imagos.it --- drivers/mtd/cfi_flash.c | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index fdba297..cd1a86e 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -537,7 +537,10 @@ static int flash_status_check (flash_info_t * info, flash_sect_t sector, ulong start;
#if CONFIG_SYS_HZ != 1000 - tout *= CONFIG_SYS_HZ/1000; + if ((ulong)CONFIG_SYS_HZ > 100000) + tout *= (ulong)CONFIG_SYS_HZ / 1000; /* for a big HZ, avoid overflow */ + else + tout = DIV_ROUND_UP(tout * (ulong)CONFIG_SYS_HZ, 1000); #endif
/* Wait for command completion */
Hi Thomas,
Sorry for nitpicking again, but you need to add your S-o-b line as well? The order should be
Signed-off-by: Renato Andreola renato.andreola@imagos.it Signed-off-by: Alessandro Rubini rubini@gnudd.com Signed-off-by: Thomas Chou thomas@wytron.com.tw
since Renato is the original author.
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
On 03/24/2010 09:46 PM, Stefan Roese wrote:
Hi Thomas,
Signed-off-by: Alessandro Rubinirubini@gnudd.com Signed-off-by: Renato Andreolarenato.andreola@imagos.it
Signed-off-by: Renato Andreolarenato.andreola@imagos.it Signed-off-by: Alessandro Rubinirubini@gnudd.com Signed-off-by: Thomas Chouthomas@wytron.com.tw
Hi Stefan,
No problem. Please review again.
Best regards, Thomas
Signed-off-by: Renato Andreola renato.andreola@imagos.it Signed-off-by: Alessandro Rubini rubini@gnudd.com Signed-off-by: Thomas Chou thomas@wytron.com.tw --- drivers/mtd/cfi_flash.c | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
Applied to u-boot-cfi-flash/master. Thanks.
Cheers, Stefan
Stefan Roese
Thomas Chou
