[U-Boot] [GIT PULL] Xilinx fixes for v2018.01-rc2 v2
Hi Tom, +Stephen
This is second pull request. I have removed that AES command enabling which was causing compilation warning on arm64.
Thanks, Michal
The following changes since commit 659208da4703de50826a469cbb38bf6afb938978:
README: update the kernel coding style reference (2017-12-12 21:34:10 -0500)
git://www.denx.de/git/u-boot-microblaze.git tags/xilinx-for-v2018.01-rc2-v2
for you to fetch changes up to 3e229a83bd4190f99731992d3a56983f29313899:
test/py: Setup variables based on HUSH selection (2017-12-18 09:32:07 +0100)
---------------------------------------------------------------- Xilinx changes for v2018.01-rc2-v2
fpga: - Enable loading bitstream via fit image for !xilinx platforms
zynq: - Fix SPL SD boot mode
zynqmp: - Not not reset in panic - Do not use simple allocator because of fat changes - Various dt chagnes - modeboot variable setup - Fix fpga loading on automotive devices - Fix coverity issues
test: - Fix env test for !hush case - Stephen's patch
---------------------------------------------------------------- Goldschmidt Simon (1): fpga: allow programming fpga from FIT image for all FPGA drivers
Javier Martinez Canillas (1): arm64: zynqmp: Add generic compatible string for I2C EEPROM
Michal Simek (18): arm: zynq: Fix SPL SD boot mode arm64: zynqmp: Do not perform reset in case of panic arm64: zynqmp: Do not use SPL_SYS_MALLOC_SIMPLE allocator arm64: zynqmp: Add reference to pmu firmware node arm64: zynqmp: Add support for generic QSPI boot arm64: zynqmp: Enable SPL_CLK when SPL is enabled arm64: zynqmp: Setup modeboot variable based on bootmode arm64: zynqmp: Enable phys for zcu102 arm64: zynqmp: Enable clock command for all boards arm64: zynqmp: Remove undocumented dma properties arm64: zynqmp: Use only earlycon bootargs instead of full one arm64: zynqmp: Add missing zynq_board_read_rom_ethaddr() prototype arm64: zynqmp: Add support for zynqmp automotive silicons arm64: zynqmp: Enable misc devices arm64: zynqmp: Enable SPL ram support arm64: zynqmp: Enable fpga bitstream loading arm64: zynqmp: Enable spi flashes tools: zynqmpimage: Check return values from file functions
Siva Durga Prasad Paladugu (3): arm64: zynqmp: Read boot mode register using zynqmp_mmio_read arm64: zynqmp: Dont use 4K sector erase by default for spi-flashes arm64: zynqmp: Access timestamp_ref_ctrl register only if running in el3
Stephen Warren (1): test/py: Setup variables based on HUSH selection
arch/arm/Kconfig | 2 +- arch/arm/dts/zynqmp-ep108.dts | 4 ++-- arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 9 --------- arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 9 --------- arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 9 --------- arch/arm/dts/zynqmp-zc1751-xm019-dc5.dts | 11 +---------- arch/arm/dts/zynqmp-zcu102-revA.dts | 20 +++++++++++--------- arch/arm/dts/zynqmp.dtsi | 3 ++- arch/arm/include/asm/arch-zynqmp/sys_proto.h | 1 + board/xilinx/zynqmp/zynqmp.c | 23 +++++++++++++++++++---- common/bootm.c | 2 +- common/image.c | 6 ++---- configs/syzygy_hub_defconfig | 2 ++ configs/topic_miami_defconfig | 2 ++ configs/topic_miamilite_defconfig | 2 ++ configs/topic_miamiplus_defconfig | 2 ++ configs/xilinx_zynqmp_ep_defconfig | 7 ++++++- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 9 ++++++++- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 7 ++++++- configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 14 +++++++++++++- configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 7 ++++++- configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 9 ++++++++- configs/xilinx_zynqmp_zcu102_revA_defconfig | 9 ++++++++- configs/xilinx_zynqmp_zcu102_revB_defconfig | 9 ++++++++- configs/zynq_cc108_defconfig | 2 ++ configs/zynq_cse_qspi_defconfig | 2 ++ configs/zynq_microzed_defconfig | 2 ++ configs/zynq_picozed_defconfig | 2 ++ configs/zynq_z_turn_defconfig | 2 ++ configs/zynq_zc702_defconfig | 2 ++ configs/zynq_zc706_defconfig | 2 ++ configs/zynq_zc770_xm010_defconfig | 2 ++ configs/zynq_zc770_xm011_defconfig | 2 ++ configs/zynq_zc770_xm012_defconfig | 2 ++ configs/zynq_zc770_xm013_defconfig | 2 ++ configs/zynq_zed_defconfig | 2 ++ configs/zynq_zybo_defconfig | 2 ++ drivers/fpga/fpga.c | 9 +++++++++ drivers/fpga/xilinx.c | 13 +++++++++++++ include/configs/xilinx_zynqmp.h | 16 +++++++++++++--- include/configs/zynq-common.h | 7 ++----- include/fpga.h | 1 + test/py/tests/test_env.py | 11 ++++++++++- tools/zynqmpimage.c | 32 +++++++++++++++++++++++++++----- 44 files changed, 212 insertions(+), 81 deletions(-)
On Mon, Dec 18, 2017 at 01:34:03PM +0100, Michal Simek wrote:
Hi Tom, +Stephen
Thanks, Michal
Michal Simek
