[U-Boot] [PATCH] mmc: cat u8 to u64 to avoid unexpected error
Suspicious implicit sign extension exist. ext_csd[] is defined as "u8", capacity is defined as u64, so u8 is promoted to signed int first int the "|" expersion, then the sign extended to u64. if the tmp sign value is largeer than 0x7fffffff, after the sign extension, the upper bits of the result will all be 1. Thanks to coverity http://www.coverity.com
e.g. u8 data_8; u64 data_64;
data_8 = 0x80; data_64 = data_8 << 24; //0xffffffff80000000 data_64 = ((u64)data_8) << 24; //0x80000000
Signed-off-by: Haibo Chen haibo.chen@nxp.com --- drivers/mmc/mmc.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 43ea0bb..c1d1dc6 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1176,10 +1176,10 @@ static int mmc_startup(struct mmc *mmc) * ext_csd's capacity is valid if the value is more * than 2GB */ - capacity = ext_csd[EXT_CSD_SEC_CNT] << 0 - | ext_csd[EXT_CSD_SEC_CNT + 1] << 8 - | ext_csd[EXT_CSD_SEC_CNT + 2] << 16 - | ext_csd[EXT_CSD_SEC_CNT + 3] << 24; + capacity = ((u64)ext_csd[EXT_CSD_SEC_CNT]) << 0 + | ((u64)ext_csd[EXT_CSD_SEC_CNT + 1]) << 8 + | ((u64)ext_csd[EXT_CSD_SEC_CNT + 2]) << 16 + | ((u64)ext_csd[EXT_CSD_SEC_CNT + 3]) << 24; capacity *= MMC_MAX_BLOCK_LEN; if ((capacity >> 20) > 2 * 1024) mmc->capacity_user = capacity;
Please add a 'Reported-by: Coverity' and you can include the CID if you like.
Can't we just move capacity down to a u8 instead? Thanks!
I think cid doesn't need to change type.
Maybe not to move down to a u8..because it's displayed the real capacity for storage.
And i wonder that coverity didn't report about the line 1294?
Best Regards, Jaehoon Chung
I mean the coverity CID :) In the public coverity project it's 149300
We could update those lines too? It's just that one case right there, yes?
It does, along with 1256.
Thanks!
Ah! I misunderstood CID as cid register. :)
If it's possible to calculate the correct capacity?
Thanks!
... I think? I hadn't had my coffee yet when I did a quick compile test this morning but it looks like all of the uses of capacity would fit into a u8. Someone should check and make a formal patch :)
Haibo Chen
Jaehoon Chung
