[PATCH] efi_loader: check efi_get_variable_int return value
efi_get_variable_int() may fail, the buffer should be cleared before using it.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Addresses-Coverity-ID: 478333 ("Error handling issues") --- lib/efi_loader/efi_firmware.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/lib/efi_loader/efi_firmware.c b/lib/efi_loader/efi_firmware.c index 9fd13297a6..fb83fa8113 100644 --- a/lib/efi_loader/efi_firmware.c +++ b/lib/efi_loader/efi_firmware.c @@ -407,11 +407,11 @@ efi_status_t efi_firmware_set_fmp_state_var(struct fmp_state *state, u8 image_in /* * GetVariable may fail, EFI_NOT_FOUND is returned if FmpState * variable has not been set yet. - * Ignore the error here since the correct FmpState variable - * is set later. */ - efi_get_variable_int(varname, image_type_id, NULL, &size, var_state, - NULL); + ret = efi_get_variable_int(varname, image_type_id, NULL, &size, + var_state, NULL); + if (ret != EFI_SUCCESS) + memset(var_state, 0, num_banks * sizeof(*var_state));
/* * Only the fw_version is set here.
*/* is set later.
NULL);
- ret = efi_get_variable_int(varname, image_type_id, NULL, &size,
var_state, NULL);
- if (ret != EFI_SUCCESS)
Hello Masahisa,
We allocate var_state with calloc(). So it is cleared before we call GetVariable(). Do we have an implementation of GetVariable() that would fill it with data before returning an error code?
Best regards
Heinrich
Hi Heinrich,
* is set later. */
NULL);
var_state, NULL);
Hello Masahisa,
No, current GetVariable() implementations do not fill the buffer when GetVariable() returns an error. This is why my original implementation does not clear the buffer in case of error.
Anyway, I agree with your previous comment. I think it is better to clear the buffer in case of error for safety, because UEFI spec does not say GetVariable() will not fill the buffer in case of error.
Thanks, Masahisa Kojima
Best regards
Heinrich
On 26.01.24 12:36, Masahisa Kojima wrote:
Hi Heinrich,
* is set later. */
NULL);
var_state, NULL);
Hello Masahisa,
In this case I guess malloc() is good enough. No need to use calloc().
Best regards
Heinrich
Best regards
Heinrich
Hi Heinrich,
* is set later. */
NULL);
var_state, NULL);
Hello Masahisa,
OK, I will fix it.
Best regards
Heinrich
Best regards
Heinrich
Masahisa Kojima
