[U-Boot] [PATCH] usb: xhci: Fix bool initialization in xhci_bulk_tx
Bool initializations should use true and false.
This issue was detected with the help of Coccinelle.
Signed-off-by: Gustavo A. R. Silva gustavo@embeddedor.com Cc: Bin Meng bmeng.cn@gmail.com Cc: Marek Vasut marex@denx.de --- drivers/usb/host/xhci-ring.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/xhci-ring.c b/drivers/usb/host/xhci-ring.c index 579e670..7599c91 100644 --- a/drivers/usb/host/xhci-ring.c +++ b/drivers/usb/host/xhci-ring.c @@ -557,7 +557,7 @@ int xhci_bulk_tx(struct usb_device *udev, unsigned long pipe, { int num_trbs = 0; struct xhci_generic_trb *start_trb; - bool first_trb = 0; + bool first_trb = false; int start_cycle; u32 field = 0; u32 length_field = 0;
Applied, thanks
- bool first_trb = false; int start_cycle; u32 field = 0; u32 length_field = 0;
Quoting Marek Vasut marek.vasut@gmail.com:
Applied, thanks
Thank you, Marek. This is my very first contribution to the Das U-Boot project. :) -- Gustavo
Gustavo A. R. Silva
Gustavo A. R. Silva
