[U-Boot] [PATCH] arm: omap4: Fix SDRAM AUTO DETECTION
Commit "8602114 omap: emif: configure emif only when required" breaks SDRAM_AUTO_DETECTION. The issue is dmm_init() depends on emif_sizes[](SDRAM Auto detection) done in do_sdram_init(). The above commit moves dmm_init() above do_sdram_init() because of which dmm_init() uses uninitialized emif_sizes[]. So instead of using global emif_sizes[], get sdram details locally and calculate emif sizes.
Reported-by: Michael Cashwell mboards@prograde.net Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/cpu/armv7/omap-common/emif-common.c | 29 ++++++++++++++------------ arch/arm/cpu/armv7/omap4/emif.c | 1 - arch/arm/cpu/armv7/omap5/emif.c | 1 - arch/arm/include/asm/arch-omap4/omap.h | 1 - arch/arm/include/asm/arch-omap5/omap.h | 1 - arch/arm/include/asm/emif.h | 1 - 6 files changed, 16 insertions(+), 18 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index 9eb1279..cdb4439 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -655,20 +655,27 @@ static u32 get_ddr_phy_ctrl_1(u32 freq, u8 RL) return phy; }
-static u32 get_emif_mem_size(struct emif_device_details *devices) +static u32 get_emif_mem_size(u32 base) { u32 size_mbytes = 0, temp; + struct emif_device_details dev_details; + struct lpddr2_device_details cs0_dev_details, cs1_dev_details; + u32 emif_nr = emif_num(base);
- if (!devices) - return 0; + emif_reset_phy(base); + dev_details.cs0_device_details = emif_get_device_details(emif_nr, CS0, + &cs0_dev_details); + dev_details.cs1_device_details = emif_get_device_details(emif_nr, CS1, + &cs1_dev_details); + emif_reset_phy(base);
- if (devices->cs0_device_details) { - temp = devices->cs0_device_details->density; + if (dev_details.cs0_device_details) { + temp = dev_details.cs0_device_details->density; size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; }
- if (devices->cs1_device_details) { - temp = devices->cs1_device_details->density; + if (dev_details.cs1_device_details) { + temp = dev_details.cs1_device_details->density; size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; } /* convert to bytes */ @@ -1040,13 +1047,9 @@ static void do_sdram_init(u32 base) /* Return if no devices on this EMIF */ if (!dev_details.cs0_device_details && !dev_details.cs1_device_details) { - emif_sizes[emif_nr - 1] = 0; return; }
- if (!in_sdram) - emif_sizes[emif_nr - 1] = get_emif_mem_size(&dev_details); - /* * Get device timings: * - Default timings specified by JESD209-2 if @@ -1108,8 +1111,8 @@ void dmm_init(u32 base) mapped_size = 0; section_cnt = 3; sys_addr = CONFIG_SYS_SDRAM_BASE; - emif1_size = emif_sizes[0]; - emif2_size = emif_sizes[1]; + emif1_size = get_emif_mem_size(EMIF1_BASE); + emif2_size = get_emif_mem_size(EMIF2_BASE); debug("emif1_size 0x%x emif2_size 0x%x\n", emif1_size, emif2_size);
if (!emif1_size && !emif2_size) diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index ca4823d..53f6063 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -33,7 +33,6 @@ #ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS u32 *const T_num = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_NUM; u32 *const T_den = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_DEN; -u32 *const emif_sizes = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_SIZE; #endif
#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS diff --git a/arch/arm/cpu/armv7/omap5/emif.c b/arch/arm/cpu/armv7/omap5/emif.c index 90d362c..9f53c90 100644 --- a/arch/arm/cpu/armv7/omap5/emif.c +++ b/arch/arm/cpu/armv7/omap5/emif.c @@ -34,7 +34,6 @@ #define print_timing_reg(reg) debug(#reg" - 0x%08x\n", (reg)) u32 *const T_num = (u32 *)OMAP5_SRAM_SCRATCH_EMIF_T_NUM; u32 *const T_den = (u32 *)OMAP5_SRAM_SCRATCH_EMIF_T_DEN; -u32 *const emif_sizes = (u32 *)OMAP5_SRAM_SCRATCH_EMIF_SIZE; #endif
#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS diff --git a/arch/arm/include/asm/arch-omap4/omap.h b/arch/arm/include/asm/arch-omap4/omap.h index 5f321fe..ad984da 100644 --- a/arch/arm/include/asm/arch-omap4/omap.h +++ b/arch/arm/include/asm/arch-omap4/omap.h @@ -147,7 +147,6 @@ struct s32ktimer { #define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START /* SRAM scratch space entries */ #define OMAP4_SRAM_SCRATCH_OMAP4_REV SRAM_SCRATCH_SPACE_ADDR -#define OMAP4_SRAM_SCRATCH_EMIF_SIZE (SRAM_SCRATCH_SPACE_ADDR + 0x4) #define OMAP4_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) #define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) #define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index b632635..887fcaa 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -196,7 +196,6 @@ struct s32ktimer { * SRAM scratch space entries */ #define OMAP5_SRAM_SCRATCH_OMAP5_REV SRAM_SCRATCH_SPACE_ADDR -#define OMAP5_SRAM_SCRATCH_EMIF_SIZE (SRAM_SCRATCH_SPACE_ADDR + 0x4) #define OMAP5_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) #define OMAP5_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) #define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index c5d1e6c..5f11d7b 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -1165,7 +1165,6 @@ void get_lpddr2_mr_regs(const struct lpddr2_mr_regs **regs); #ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS extern u32 *const T_num; extern u32 *const T_den; -extern u32 *const emif_sizes; #endif
void config_data_eye_leveling_samples(u32 emif_base);
+ Michael
- struct emif_device_details dev_details;
- struct lpddr2_device_details cs0_dev_details, cs1_dev_details;
- u32 emif_nr = emif_num(base);
- if (!devices)
- emif_reset_phy(base);
- dev_details.cs0_device_details = emif_get_device_details(emif_nr, CS0,
&cs0_dev_details);
- dev_details.cs1_device_details = emif_get_device_details(emif_nr, CS1,
&cs1_dev_details);
- if (dev_details.cs0_device_details) {
size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; }temp = dev_details.cs0_device_details->density;
- if (dev_details.cs1_device_details) {
size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; } /* convert to bytes */temp = dev_details.cs1_device_details->density;
return; }
if (!in_sdram)
- Get device timings:
- SRAM scratch space entries
Applied to u-boot-ti/master, thanks!
Lokesh Vutla
