[PATCH] arm: dts: j7200: dtb sync with Linux 6.5-rc1
Sync j7200 device tree files with Linux 6.5-rc1
- k3-j7200-r5-common-proc-board.dts now inherits from k3-j7200-common-proc-board.dts instead of k3-j7200-som-p0.dtsi. This allows us to trim down the r5 file considerably by using existing properties.
- remove pimux nodes from r5 file
- remove duplicate nodes & node properties from r5/u-boot files
- mcu_timer0 now used instead of timer1
mcu_timer0 device id added to dev-data.c file in order to work
- remove cpsw node
This node is no longer required since the compatible is now fixed
- remove dummy_clock_19_2_mhz
This node wasn't being used anyhere, so it was removed.
- remove dummy_clock_200mhz
main_sdhci0 & main_sdhci1 no longer need dummy clock for eMMC/SD
- fix secure proxy node
mcu_secproxy changed to used secure_prxy_mcu which is already defined in k3-j7200-mcu-wakeup.dtsi
Signed-off-by: Reid Tonking reidt@ti.com --- based on: 976fb2ffa3 Prepare v2023.10-rc3 boot test: https://gist.github.com/Glockn/1d7a61adac8f3f56c49afffe683704b7
.../k3-j7200-common-proc-board-u-boot.dtsi | 109 ++-- arch/arm/dts/k3-j7200-common-proc-board.dts | 170 ++++-- arch/arm/dts/k3-j7200-main.dtsi | 512 +++++++++++++++++- arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 265 ++++++++- .../arm/dts/k3-j7200-r5-common-proc-board.dts | 289 +--------- arch/arm/dts/k3-j7200-som-p0.dtsi | 153 ++++-- arch/arm/dts/k3-j7200-thermal.dtsi | 47 ++ arch/arm/dts/k3-j7200.dtsi | 30 +- arch/arm/mach-k3/j7200/dev-data.c | 1 + 9 files changed, 1134 insertions(+), 442 deletions(-) create mode 100644 arch/arm/dts/k3-j7200-thermal.dtsi
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index f25c7136c9..a00e85e366 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2020-2023 Texas Instruments Incorporated - https://www.ti.com/ */
#include "k3-j7200-binman.dtsi" @@ -8,7 +8,7 @@ / { chosen { stdout-path = "serial2:115200n8"; - tick-timer = &timer1; + tick-timer = &mcu_timer0; };
aliases { @@ -28,16 +28,12 @@ bootph-pre-ram; };
-&cbass_mcu_wakeup { +&main_esm{ bootph-pre-ram; +};
- timer1: timer@40400000 { - compatible = "ti,omap5430-timer"; - reg = <0x0 0x40400000 0x0 0x80>; - ti,timer-alwon; - clock-frequency = <250000000>; - bootph-pre-ram; - }; +&cbass_mcu_wakeup { + bootph-pre-ram;
chipid@43000014 { bootph-pre-ram; @@ -45,8 +41,6 @@
mcu_navss: bus@28380000 { bootph-pre-ram; - #address-cells = <2>; - #size-cells = <2>;
ringacc@2b800000 { reg = <0x0 0x2b800000 0x0 0x400000>, @@ -78,10 +72,6 @@
&dmsc { bootph-pre-ram; - k3_sysreset: sysreset-controller { - compatible = "ti,sci-sysreset"; - bootph-pre-ram; - }; };
&k3_pds { @@ -100,6 +90,10 @@ bootph-pre-ram; };
+&wkup_pmx2 { + bootph-pre-ram; +}; + &main_pmx0 { bootph-pre-ram; }; @@ -108,6 +102,10 @@ bootph-pre-ram; };
+&main_uart2 { + bootph-pre-ram; +}; + &mcu_uart0 { bootph-pre-ram; }; @@ -122,52 +120,77 @@
&wkup_i2c0 { bootph-pre-ram; + + lp876441: lp876441@4c { + bootph-pre-ram; + + regulators: regulators { + bootph-pre-ram; + + buck1_reg: buck1 { + bootph-pre-ram; + }; + }; + }; };
&main_i2c0 { bootph-pre-ram; + + exp1: gpio@20 { + bootph-pre-ram; + }; + + exp2: gpio@22 { + bootph-pre-ram; + }; };
-&main_i2c0_pins_default { +&mcu_cpsw { bootph-pre-ram; };
-&exp2 { +&mcu_uart0 { bootph-pre-ram; };
-&mcu_cpsw { - reg = <0x0 0x46000000 0x0 0x200000>, - <0x0 0x40f00200 0x0 0x8>; - reg-names = "cpsw_nuss", "mac_efuse"; - /delete-property/ ranges; - - cpsw-phy-sel@40f04040 { - compatible = "ti,am654-cpsw-phy-sel"; - reg= <0x0 0x40f04040 0x0 0x4>; - reg-names = "gmii-sel"; - }; +&wkup_i2c0 { + bootph-pre-ram; };
-&main_usbss0_pins_default { +&wkup_uart0 { bootph-pre-ram; };
-&usbss0 { +&fss { bootph-pre-ram; - ti,usb2-only; };
-&usb0 { - dr_mode = "peripheral"; +&main_uart0_pins_default { bootph-pre-ram; };
-&mcu_fss0_hpb0_pins_default { +&main_mmc1_pins_default { bootph-pre-ram; };
-&fss { +&main_i2c0_pins_default { + bootph-pre-ram; +}; + +&wkup_i2c0_pins_default { + bootph-pre-ram; +}; + +&wkup_uart0_pins_default { + bootph-pre-ram; +}; + +&wkup_gpio_pins_default { + bootph-pre-ram; +}; + +&wkup_gpio0 { bootph-pre-ram; };
@@ -183,6 +206,20 @@ bootph-pre-ram; };
+&usbss0 { + bootph-pre-ram; + ti,usb2-only; +}; + +&usb0 { + dr_mode = "peripheral"; + bootph-pre-ram; +}; + +&ospi0 { + bootph-pre-ram; +}; + &serdes_ln_ctrl { u-boot,mux-autoprobe; }; diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index d14f3c18b6..3cf288128c 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -12,9 +12,21 @@ #include <dt-bindings/phy/phy.h>
/ { + compatible = "ti,j7200-evm", "ti,j7200"; + model = "Texas Instruments J7200 EVM"; + + aliases { + serial0 = &wkup_uart0; + serial1 = &mcu_uart0; + serial2 = &main_uart0; + serial3 = &main_uart1; + serial5 = &main_uart3; + mmc0 = &main_sdhci0; + mmc1 = &main_sdhci1; + }; + chosen { stdout-path = "serial2:115200n8"; - bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; };
evm_12v0: fixedregulator-evm12v0 { @@ -78,47 +90,87 @@ };
&wkup_pmx0 { - mcu_cpsw_pins_default: mcu-cpsw-pins-default { + mcu_uart0_pins_default: mcu-uart0-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xf4, PIN_INPUT, 0) /* (D20) MCU_UART0_RXD */ + J721E_WKUP_IOPAD(0xf0, PIN_OUTPUT, 0) /* (D19) MCU_UART0_TXD */ + J721E_WKUP_IOPAD(0xf8, PIN_INPUT, 0) /* (E20) MCU_UART0_CTSn */ + J721E_WKUP_IOPAD(0xfc, PIN_OUTPUT, 0) /* (E21) MCU_UART0_RTSn */ + >; + }; + + wkup_uart0_pins_default: wkup-uart0-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 0) /* (B14) WKUP_UART0_RXD */ + J721E_WKUP_IOPAD(0xb4, PIN_OUTPUT, 0) /* (A14) WKUP_UART0_TXD */ + >; + }; +}; + +&wkup_pmx2 { + mcu_cpsw_pins_default: mcu-cpsw-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x0000, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */ + J721E_WKUP_IOPAD(0x0004, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */ + J721E_WKUP_IOPAD(0x0008, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */ + J721E_WKUP_IOPAD(0x000c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */ + J721E_WKUP_IOPAD(0x0010, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */ + J721E_WKUP_IOPAD(0x0014, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */ + J721E_WKUP_IOPAD(0x0020, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */ + J721E_WKUP_IOPAD(0x0024, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */ + J721E_WKUP_IOPAD(0x0028, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */ + J721E_WKUP_IOPAD(0x002c, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */ + J721E_WKUP_IOPAD(0x0018, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */ + J721E_WKUP_IOPAD(0x001c, PIN_INPUT, 0) /* MCU_RGMII1_RXC */ + >; + }; + + wkup_gpio_pins_default: wkup-gpio-default-pins { pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */ - J721E_WKUP_IOPAD(0x006c, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */ - J721E_WKUP_IOPAD(0x0070, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */ - J721E_WKUP_IOPAD(0x0074, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */ - J721E_WKUP_IOPAD(0x0078, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */ - J721E_WKUP_IOPAD(0x007c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */ - J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */ - J721E_WKUP_IOPAD(0x008c, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */ - J721E_WKUP_IOPAD(0x0090, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */ - J721E_WKUP_IOPAD(0x0094, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */ - J721E_WKUP_IOPAD(0x0080, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */ - J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* MCU_RGMII1_RXC */ + J721E_WKUP_IOPAD(0x70, PIN_INPUT, 7) /* (C14) WKUP_GPIO0_6 */ >; };
- mcu_mdio_pins_default: mcu-mdio1-pins-default { + mcu_mdio_pins_default: mcu-mdio1-default-pins { pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x009c, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */ - J721E_WKUP_IOPAD(0x0098, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */ + J721E_WKUP_IOPAD(0x0034, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */ + J721E_WKUP_IOPAD(0x0030, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */ >; }; };
&main_pmx0 { - main_i2c0_pins_default: main-i2c0-pins-default { + main_uart0_pins_default: main-uart0-default-pins { pinctrl-single,pins = < - J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ - J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ + J721E_IOPAD(0xb0, PIN_INPUT, 0) /* (T16) UART0_RXD */ + J721E_IOPAD(0xb4, PIN_OUTPUT, 0) /* (T17) UART0_TXD */ + J721E_IOPAD(0xc0, PIN_INPUT, 2) /* (W3) SPI0_CS0.UART0_CTSn */ + J721E_IOPAD(0xc4, PIN_OUTPUT, 2) /* (U5) SPI0_CS1.UART0_RTSn */ >; };
- main_i2c1_pins_default: main-i2c1-pins-default { + main_uart1_pins_default: main-uart1-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0xb8, PIN_INPUT, 0) /* (T18) UART1_RXD */ + J721E_IOPAD(0xbc, PIN_INPUT, 0) /* (T20) UART1_TXD */ + >; + }; + + main_uart3_pins_default: main-uart3-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x60, PIN_INPUT, 11) /* (T15) MCAN8_TX.UART3_CTSn */ + J721E_IOPAD(0x30, PIN_INPUT, 11) /* (Y18) MCAN2_TX.UART3_RXD */ + >; + }; + + main_i2c1_pins_default: main-i2c1-default-pins { pinctrl-single,pins = < J721E_IOPAD(0xdc, PIN_INPUT_PULLUP, 3) /* (U3) ECAP0_IN_APWM_OUT.I2C1_SCL */ J721E_IOPAD(0xe0, PIN_INPUT_PULLUP, 3) /* (T3) EXT_REFCLK1.I2C1_SDA */ >; };
- main_mmc1_pins_default: main-mmc1-pins-default { + main_mmc1_pins_default: main-mmc1-default-pins { pinctrl-single,pins = < J721E_IOPAD(0x104, PIN_INPUT, 0) /* (M20) MMC1_CMD */ J721E_IOPAD(0x100, PIN_INPUT, 0) /* (P21) MMC1_CLK */ @@ -131,15 +183,17 @@ >; };
- main_usbss0_pins_default: main-usbss0-pins-default { + vdd_sd_dv_pins_default: vdd-sd-dv-default-pins { pinctrl-single,pins = < - J721E_IOPAD(0x120, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ + J721E_IOPAD(0xd0, PIN_OUTPUT, 7) /* (T5) SPI0_D1.GPIO0_55 */ >; }; +};
- vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { +&main_pmx1 { + main_usbss0_pins_default: main-usbss0-default-pins { pinctrl-single,pins = < - J721E_IOPAD(0xd0, PIN_OUTPUT, 7) /* (T5) SPI0_D1.GPIO0_55 */ + J721E_IOPAD(0x04, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ >; }; }; @@ -147,11 +201,30 @@ &wkup_uart0 { /* Wakeup UART is used by System firmware */ status = "reserved"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; +}; + +&mcu_uart0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_uart0_pins_default>; + clock-frequency = <96000000>; };
&main_uart0 { + status = "okay"; /* Shared with ATF on this platform */ power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; +}; + +&main_uart1 { + status = "okay"; + /* Default pinmux */ + pinctrl-names = "default"; + pinctrl-0 = <&main_uart1_pins_default>; };
&main_uart2 { @@ -160,38 +233,10 @@ };
&main_uart3 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart4 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart5 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart6 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart7 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart8 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart9 { - /* UART not brought out */ - status = "disabled"; + /* Shared with MCAN Interface */ + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_uart3_pins_default>; };
&main_gpio2 { @@ -206,13 +251,18 @@ status = "disabled"; };
+&wkup_gpio0 { + pinctrl-names = "default"; + pinctrl-0 = <&wkup_gpio_pins_default>; +}; + &wkup_gpio1 { status = "disabled"; };
&mcu_cpsw { pinctrl-names = "default"; - pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; + pinctrl-0 = <&mcu_cpsw_pins_default>, <&mcu_mdio_pins_default>; };
&davinci_mdio { @@ -229,6 +279,7 @@ };
&main_i2c0 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>; @@ -256,6 +307,7 @@ * The i2c1 of the CPB (as it is labeled) is not connected to j7200. */ &main_i2c1 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; clock-frequency = <400000>; diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi index e8a41d09b4..ac62bbc166 100644 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ b/arch/arm/dts/k3-j7200-main.dtsi @@ -32,13 +32,20 @@ #size-cells = <1>; ranges = <0x00 0x00 0x00100000 0x1c000>;
- serdes_ln_ctrl: serdes-ln-ctrl@4080 { + serdes_ln_ctrl: mux-controller@4080 { compatible = "mmio-mux"; #mux-control-cells = <1>; mux-reg-masks = <0x4080 0x3>, <0x4084 0x3>, /* SERDES0 lane0/1 select */ <0x4088 0x3>, <0x408c 0x3>; /* SERDES0 lane2/3 select */ };
+ cpsw0_phy_gmii_sel: phy@4044 { + compatible = "ti,j7200-cpsw5g-phy-gmii-sel"; + ti,qsgmii-main-ports = <1>; + reg = <0x4044 0x10>; + #phy-cells = <1>; + }; + usb_serdes_mux: mux-controller@4000 { compatible = "mmio-mux"; #mux-control-cells = <1>; @@ -54,7 +61,10 @@ #interrupt-cells = <3>; interrupt-controller; reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */ - <0x00 0x01900000 0x00 0x100000>; /* GICR */ + <0x00 0x01900000 0x00 0x100000>, /* GICR */ + <0x00 0x6f000000 0x00 0x2000>, /* GICC */ + <0x00 0x6f010000 0x00 0x1000>, /* GICH */ + <0x00 0x6f020000 0x00 0x2000>; /* GICV */
/* vcpumntirq: virtual CPU interface maintenance interrupt */ interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; @@ -139,6 +149,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster1: mailbox@31f81000 { @@ -148,6 +159,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster2: mailbox@31f82000 { @@ -157,6 +169,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster3: mailbox@31f83000 { @@ -166,6 +179,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster4: mailbox@31f84000 { @@ -175,6 +189,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster5: mailbox@31f85000 { @@ -184,6 +199,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster6: mailbox@31f86000 { @@ -193,6 +209,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster7: mailbox@31f87000 { @@ -202,6 +219,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster8: mailbox@31f88000 { @@ -211,6 +229,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster9: mailbox@31f89000 { @@ -220,6 +239,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster10: mailbox@31f8a000 { @@ -229,6 +249,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster11: mailbox@31f8b000 { @@ -238,6 +259,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
main_ringacc: ringacc@3c000000 { @@ -289,10 +311,118 @@ }; };
+ cpsw0: ethernet@c000000 { + compatible = "ti,j7200-cpswxg-nuss"; + #address-cells = <2>; + #size-cells = <2>; + reg = <0x00 0xc000000 0x00 0x200000>; + reg-names = "cpsw_nuss"; + ranges = <0x00 0x00 0x00 0xc000000 0x00 0x200000>; + clocks = <&k3_clks 19 33>; + clock-names = "fck"; + power-domains = <&k3_pds 19 TI_SCI_PD_EXCLUSIVE>; + + dmas = <&main_udmap 0xca00>, + <&main_udmap 0xca01>, + <&main_udmap 0xca02>, + <&main_udmap 0xca03>, + <&main_udmap 0xca04>, + <&main_udmap 0xca05>, + <&main_udmap 0xca06>, + <&main_udmap 0xca07>, + <&main_udmap 0x4a00>; + dma-names = "tx0", "tx1", "tx2", "tx3", + "tx4", "tx5", "tx6", "tx7", + "rx"; + + status = "disabled"; + + ethernet-ports { + #address-cells = <1>; + #size-cells = <0>; + cpsw0_port1: port@1 { + reg = <1>; + ti,mac-only; + label = "port1"; + status = "disabled"; + }; + + cpsw0_port2: port@2 { + reg = <2>; + ti,mac-only; + label = "port2"; + status = "disabled"; + }; + + cpsw0_port3: port@3 { + reg = <3>; + ti,mac-only; + label = "port3"; + status = "disabled"; + }; + + cpsw0_port4: port@4 { + reg = <4>; + ti,mac-only; + label = "port4"; + status = "disabled"; + }; + }; + + cpsw5g_mdio: mdio@f00 { + compatible = "ti,cpsw-mdio","ti,davinci_mdio"; + reg = <0x00 0xf00 0x00 0x100>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&k3_clks 19 33>; + clock-names = "fck"; + bus_freq = <1000000>; + status = "disabled"; + }; + + cpts@3d000 { + compatible = "ti,j721e-cpts"; + reg = <0x00 0x3d000 0x00 0x400>; + clocks = <&k3_clks 19 16>; + clock-names = "cpts"; + interrupts-extended = <&gic500 GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "cpts"; + ti,cpts-ext-ts-inputs = <4>; + ti,cpts-periodic-outputs = <2>; + }; + }; + + /* TIMERIO pad input CTRLMMR_TIMER*_CTRL registers */ + main_timerio_input: pinctrl@104200 { + compatible = "pinctrl-single"; + reg = <0x0 0x104200 0x0 0x50>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x000001ff>; + }; + + /* TIMERIO pad output CTCTRLMMR_TIMERIO*_CTRL registers */ + main_timerio_output: pinctrl@104280 { + compatible = "pinctrl-single"; + reg = <0x0 0x104280 0x0 0x20>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000001f>; + }; + main_pmx0: pinctrl@11c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */ - reg = <0x00 0x11c000 0x00 0x2b4>; + reg = <0x00 0x11c000 0x00 0x10c>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + main_pmx1: pinctrl@11c11c { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x11c11c 0x00 0xc>; #pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>; @@ -307,6 +437,7 @@ power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 146 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart1: serial@2810000 { @@ -318,6 +449,7 @@ power-domains = <&k3_pds 278 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 278 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart2: serial@2820000 { @@ -329,6 +461,7 @@ power-domains = <&k3_pds 279 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 279 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart3: serial@2830000 { @@ -340,6 +473,7 @@ power-domains = <&k3_pds 280 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 280 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart4: serial@2840000 { @@ -351,6 +485,7 @@ power-domains = <&k3_pds 281 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 281 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart5: serial@2850000 { @@ -362,6 +497,7 @@ power-domains = <&k3_pds 282 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 282 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart6: serial@2860000 { @@ -373,6 +509,7 @@ power-domains = <&k3_pds 283 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 283 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart7: serial@2870000 { @@ -384,6 +521,7 @@ power-domains = <&k3_pds 284 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 284 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart8: serial@2880000 { @@ -395,6 +533,7 @@ power-domains = <&k3_pds 285 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 285 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart9: serial@2890000 { @@ -406,6 +545,7 @@ power-domains = <&k3_pds 286 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 286 2>; clock-names = "fclk"; + status = "disabled"; };
main_i2c0: i2c@2000000 { @@ -417,6 +557,7 @@ clock-names = "fck"; clocks = <&k3_clks 187 1>; power-domains = <&k3_pds 187 TI_SCI_PD_SHARED>; + status = "disabled"; };
main_i2c1: i2c@2010000 { @@ -428,6 +569,7 @@ clock-names = "fck"; clocks = <&k3_clks 188 1>; power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c2: i2c@2020000 { @@ -439,6 +581,7 @@ clock-names = "fck"; clocks = <&k3_clks 189 1>; power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c3: i2c@2030000 { @@ -450,6 +593,7 @@ clock-names = "fck"; clocks = <&k3_clks 190 1>; power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c4: i2c@2040000 { @@ -461,6 +605,7 @@ clock-names = "fck"; clocks = <&k3_clks 191 1>; power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c5: i2c@2050000 { @@ -472,6 +617,7 @@ clock-names = "fck"; clocks = <&k3_clks 192 1>; power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c6: i2c@2060000 { @@ -483,6 +629,7 @@ clock-names = "fck"; clocks = <&k3_clks 193 1>; power-domains = <&k3_pds 193 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_sdhci0: mmc@4f80000 { @@ -606,10 +753,10 @@ clock-names = "fck"; #address-cells = <3>; #size-cells = <2>; - bus-range = <0x0 0xf>; + bus-range = <0x0 0xff>; cdns,no-bar-match-nbits = <64>; - vendor-id = /bits/ 16 <0x104c>; - device-id = /bits/ 16 <0xb00f>; + vendor-id = <0x104c>; + device-id = <0xb00f>; msi-map = <0x0 &gic_its 0x0 0x10000>; dma-coherent; ranges = <0x01000000 0x0 0x18001000 0x00 0x18001000 0x0 0x0010000>, @@ -633,6 +780,7 @@ clocks = <&k3_clks 240 6>; clock-names = "fck"; max-functions = /bits/ 8 <6>; + max-virtual-functions = /bits/ 8 <4 4 4 4 0 0>; dma-coherent; };
@@ -735,6 +883,352 @@ clock-names = "gpio"; };
+ main_spi0: spi@2100000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02100000 0x00 0x400>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 266 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 266 1>; + status = "disabled"; + }; + + main_spi1: spi@2110000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02110000 0x00 0x400>; + interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 267 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 267 1>; + status = "disabled"; + }; + + main_spi2: spi@2120000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02120000 0x00 0x400>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 268 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 268 1>; + status = "disabled"; + }; + + main_spi3: spi@2130000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02130000 0x00 0x400>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 269 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 269 1>; + status = "disabled"; + }; + + main_spi4: spi@2140000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02140000 0x00 0x400>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 270 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 270 1>; + status = "disabled"; + }; + + main_spi5: spi@2150000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02150000 0x00 0x400>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 271 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 271 1>; + status = "disabled"; + }; + + main_spi6: spi@2160000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02160000 0x00 0x400>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 272 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 272 1>; + status = "disabled"; + }; + + main_spi7: spi@2170000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02170000 0x00 0x400>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 273 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 273 1>; + status = "disabled"; + }; + + watchdog0: watchdog@2200000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x0 0x2200000 0x0 0x100>; + clocks = <&k3_clks 252 1>; + power-domains = <&k3_pds 252 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 252 1>; + assigned-clock-parents = <&k3_clks 252 5>; + }; + + watchdog1: watchdog@2210000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x0 0x2210000 0x0 0x100>; + clocks = <&k3_clks 253 1>; + power-domains = <&k3_pds 253 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 253 1>; + assigned-clock-parents = <&k3_clks 253 5>; + }; + + main_timer0: timer@2400000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2400000 0x00 0x400>; + interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 49 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 49 1>; + assigned-clock-parents = <&k3_clks 49 2>; + power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer1: timer@2410000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2410000 0x00 0x400>; + interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 50 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 50 1>, <&k3_clks 313 0>; + assigned-clock-parents = <&k3_clks 50 2>, <&k3_clks 313 1>; + power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer2: timer@2420000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2420000 0x00 0x400>; + interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 51 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 51 1>; + assigned-clock-parents = <&k3_clks 51 2>; + power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer3: timer@2430000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2430000 0x00 0x400>; + interrupts = <GIC_SPI 227 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 52 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 52 1>, <&k3_clks 314 0>; + assigned-clock-parents = <&k3_clks 52 2>, <&k3_clks 314 1>; + power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer4: timer@2440000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2440000 0x00 0x400>; + interrupts = <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 53 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 53 1>; + assigned-clock-parents = <&k3_clks 53 2>; + power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer5: timer@2450000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2450000 0x00 0x400>; + interrupts = <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 54 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 54 1>, <&k3_clks 315 0>; + assigned-clock-parents = <&k3_clks 54 2>, <&k3_clks 315 1>; + power-domains = <&k3_pds 54 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer6: timer@2460000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2460000 0x00 0x400>; + interrupts = <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 55 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 55 1>; + assigned-clock-parents = <&k3_clks 55 2>; + power-domains = <&k3_pds 55 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer7: timer@2470000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2470000 0x00 0x400>; + interrupts = <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 57 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 57 1>, <&k3_clks 316 0>; + assigned-clock-parents = <&k3_clks 57 2>, <&k3_clks 316 1>; + power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer8: timer@2480000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2480000 0x00 0x400>; + interrupts = <GIC_SPI 232 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 58 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 58 1>; + assigned-clock-parents = <&k3_clks 58 2>; + power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer9: timer@2490000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2490000 0x00 0x400>; + interrupts = <GIC_SPI 233 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 59 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 59 1>, <&k3_clks 317 0>; + assigned-clock-parents = <&k3_clks 59 2>, <&k3_clks 317 1>; + power-domains = <&k3_pds 59 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer10: timer@24a0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24a0000 0x00 0x400>; + interrupts = <GIC_SPI 234 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 60 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 60 1>; + assigned-clock-parents = <&k3_clks 60 2>; + power-domains = <&k3_pds 60 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer11: timer@24b0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24b0000 0x00 0x400>; + interrupts = <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 62 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 62 1>, <&k3_clks 318 0>; + assigned-clock-parents = <&k3_clks 62 2>, <&k3_clks 318 1>; + power-domains = <&k3_pds 62 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer12: timer@24c0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24c0000 0x00 0x400>; + interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 63 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 63 1>; + assigned-clock-parents = <&k3_clks 63 2>; + power-domains = <&k3_pds 63 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer13: timer@24d0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24d0000 0x00 0x400>; + interrupts = <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 64 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 64 1>, <&k3_clks 319 0>; + assigned-clock-parents = <&k3_clks 64 2>, <&k3_clks 319 1>; + power-domains = <&k3_pds 64 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer14: timer@24e0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24e0000 0x00 0x400>; + interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 65 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 65 1>; + assigned-clock-parents = <&k3_clks 65 2>; + power-domains = <&k3_pds 65 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer15: timer@24f0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24f0000 0x00 0x400>; + interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 66 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 66 1>, <&k3_clks 320 0>; + assigned-clock-parents = <&k3_clks 66 2>, <&k3_clks 320 1>; + power-domains = <&k3_pds 66 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer16: timer@2500000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2500000 0x00 0x400>; + interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 67 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 67 1>; + assigned-clock-parents = <&k3_clks 67 2>; + power-domains = <&k3_pds 67 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer17: timer@2510000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2510000 0x00 0x400>; + interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 68 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 68 1>, <&k3_clks 321 0>; + assigned-clock-parents = <&k3_clks 68 2>, <&k3_clks 321 1>; + power-domains = <&k3_pds 68 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer18: timer@2520000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2520000 0x00 0x400>; + interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 69 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 69 1>; + assigned-clock-parents = <&k3_clks 69 2>; + power-domains = <&k3_pds 69 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer19: timer@2530000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2530000 0x00 0x400>; + interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 70 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 70 1>, <&k3_clks 322 0>; + assigned-clock-parents = <&k3_clks 70 2>, <&k3_clks 322 1>; + power-domains = <&k3_pds 70 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + main_r5fss0: r5fss@5c00000 { compatible = "ti,j7200-r5fss"; ti,cluster-mode = <1>; @@ -774,4 +1268,10 @@ ti,loczrama = <1>; }; }; + + main_esm: esm@700000 { + compatible = "ti,j721e-esm"; + reg = <0x0 0x700000 0x0 0x1000>; + ti,esm-pins = <656>, <657>; + }; }; diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi index 1044ec6c4b..c5e4c41eff 100644 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi @@ -12,8 +12,8 @@
mbox-names = "rx", "tx";
- mboxes= <&secure_proxy_main 11>, - <&secure_proxy_main 13>; + mboxes = <&secure_proxy_main 11>, + <&secure_proxy_main 13>;
reg-names = "debug_messages"; reg = <0x00 0x44083000 0x00 0x1000>; @@ -34,6 +34,136 @@ }; };
+ mcu_timer0: timer@40400000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40400000 0x00 0x400>; + interrupts = <GIC_SPI 816 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 35 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 35 1>; + assigned-clock-parents = <&k3_clks 35 2>; + power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer1: timer@40410000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40410000 0x00 0x400>; + interrupts = <GIC_SPI 817 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 71 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 71 1>, <&k3_clks 308 0>; + assigned-clock-parents = <&k3_clks 71 2>, <&k3_clks 308 1>; + power-domains = <&k3_pds 71 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer2: timer@40420000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40420000 0x00 0x400>; + interrupts = <GIC_SPI 818 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 72 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 72 1>; + assigned-clock-parents = <&k3_clks 72 2>; + power-domains = <&k3_pds 72 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer3: timer@40430000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40430000 0x00 0x400>; + interrupts = <GIC_SPI 819 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 73 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 73 1>, <&k3_clks 309 0>; + assigned-clock-parents = <&k3_clks 73 2>, <&k3_clks 309 1>; + power-domains = <&k3_pds 73 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer4: timer@40440000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40440000 0x00 0x400>; + interrupts = <GIC_SPI 820 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 74 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 74 1>; + assigned-clock-parents = <&k3_clks 74 2>; + power-domains = <&k3_pds 74 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer5: timer@40450000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40450000 0x00 0x400>; + interrupts = <GIC_SPI 821 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 75 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 75 1>, <&k3_clks 310 0>; + assigned-clock-parents = <&k3_clks 75 2>, <&k3_clks 310 1>; + power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer6: timer@40460000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40460000 0x00 0x400>; + interrupts = <GIC_SPI 822 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 76 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 76 1>; + assigned-clock-parents = <&k3_clks 76 2>; + power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer7: timer@40470000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40470000 0x00 0x400>; + interrupts = <GIC_SPI 823 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 77 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 77 1>, <&k3_clks 311 0>; + assigned-clock-parents = <&k3_clks 77 2>, <&k3_clks 311 1>; + power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer8: timer@40480000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40480000 0x00 0x400>; + interrupts = <GIC_SPI 824 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 78 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 78 1>; + assigned-clock-parents = <&k3_clks 78 2>; + power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer9: timer@40490000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40490000 0x00 0x400>; + interrupts = <GIC_SPI 825 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 79 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 79 1>, <&k3_clks 312 0>; + assigned-clock-parents = <&k3_clks 79 2>, <&k3_clks 312 1>; + power-domains = <&k3_pds 79 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + mcu_conf: syscon@40f00000 { compatible = "syscon", "simple-mfd"; reg = <0x00 0x40f00000 0x00 0x20000>; @@ -53,10 +183,57 @@ reg = <0x00 0x43000014 0x00 0x4>; };
+ /* MCU_TIMERIO pad input CTRLMMR_MCU_TIMER*_CTRL registers */ + mcu_timerio_input: pinctrl@40f04200 { + compatible = "pinctrl-single"; + reg = <0x0 0x40f04200 0x0 0x28>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000F>; + status = "reserved"; + }; + + /* MCU_TIMERIO pad output CTRLMMR_MCU_TIMERIO*_CTRL registers */ + mcu_timerio_output: pinctrl@40f04280 { + compatible = "pinctrl-single"; + reg = <0x0 0x40f04280 0x0 0x28>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000F>; + status = "reserved"; + }; + wkup_pmx0: pinctrl@4301c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */ - reg = <0x00 0x4301c000 0x00 0x178>; + reg = <0x00 0x4301c000 0x00 0x34>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx1: pinctrl@4301c038 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c038 0x00 0x8>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx2: pinctrl@4301c068 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c068 0x00 0xec>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx3: pinctrl@4301c174 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c174 0x00 0x20>; #pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>; @@ -79,6 +256,7 @@ power-domains = <&k3_pds 287 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 287 2>; clock-names = "fclk"; + status = "disabled"; };
mcu_uart0: serial@40a00000 { @@ -90,6 +268,7 @@ power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 149 2>; clock-names = "fclk"; + status = "disabled"; };
wkup_gpio_intr: interrupt-controller@42200000 { @@ -180,6 +359,21 @@ }; };
+ secure_proxy_mcu: mailbox@2a480000 { + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "target_data", "rt", "scfg"; + reg = <0x0 0x2a480000 0x0 0x80000>, + <0x0 0x2a380000 0x0 0x80000>, + <0x0 0x2a400000 0x0 0x80000>; + /* + * Marked Disabled: + * Node is incomplete as it is meant for bootloaders and + * firmware on non-MPU processors + */ + status = "disabled"; + }; + mcu_cpsw: ethernet@46000000 { compatible = "ti,j721e-cpsw-nuss"; #address-cells = <2>; @@ -249,6 +443,7 @@ clock-names = "fck"; clocks = <&k3_clks 194 1>; power-domains = <&k3_pds 194 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
mcu_i2c1: i2c@40b10000 { @@ -260,6 +455,7 @@ clock-names = "fck"; clocks = <&k3_clks 195 1>; power-domains = <&k3_pds 195 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
wkup_i2c0: i2c@42120000 { @@ -271,6 +467,40 @@ clock-names = "fck"; clocks = <&k3_clks 197 1>; power-domains = <&k3_pds 197 TI_SCI_PD_SHARED>; + status = "disabled"; + }; + + mcu_spi0: spi@40300000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040300000 0x00 0x400>; + interrupts = <GIC_SPI 848 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 274 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 274 0>; + status = "disabled"; + }; + + mcu_spi1: spi@40310000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040310000 0x00 0x400>; + interrupts = <GIC_SPI 849 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 275 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 275 0>; + status = "disabled"; + }; + + mcu_spi2: spi@40320000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040320000 0x00 0x400>; + interrupts = <GIC_SPI 850 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 276 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 276 0>; + status = "disabled"; };
fss: syscon@47000000 { @@ -325,7 +555,7 @@ clocks = <&k3_clks 0 1>; assigned-clocks = <&k3_clks 0 3>; assigned-clock-rates = <60000000>; - clock-names = "adc_tsc_fck"; + clock-names = "fck"; dmas = <&main_udmap 0x7400>, <&main_udmap 0x7401>; dma-names = "fifo0", "fifo1"; @@ -375,4 +605,31 @@ ti,loczrama = <1>; }; }; + + mcu_crypto: crypto@40900000 { + compatible = "ti,j721e-sa2ul"; + reg = <0x00 0x40900000 0x00 0x1200>; + power-domains = <&k3_pds 265 TI_SCI_PD_SHARED>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x00 0x40900000 0x00 0x40900000 0x00 0x30000>; + dmas = <&mcu_udmap 0xf501>, <&mcu_udmap 0x7502>, + <&mcu_udmap 0x7503>; + dma-names = "tx", "rx1", "rx2"; + + rng: rng@40910000 { + compatible = "inside-secure,safexcel-eip76"; + reg = <0x00 0x40910000 0x00 0x7d>; + interrupts = <GIC_SPI 945 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; /* Used by OP-TEE */ + }; + }; + + wkup_vtm0: temperature-sensor@42040000 { + compatible = "ti,j7200-vtm"; + reg = <0x00 0x42040000 0x00 0x350>, + <0x00 0x42050000 0x00 0x350>; + power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; + #thermal-sensor-cells = <1>; + }; }; diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index e62f9218e8..bd4be7215f 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -1,13 +1,14 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2020-2023 Texas Instruments Incorporated - https://www.ti.com/ */
/dts-v1/;
-#include "k3-j7200-som-p0.dtsi" +#include "k3-j7200-common-proc-board.dts" #include "k3-j7200-ddr-evm-lp4-2666.dtsi" #include "k3-j721e-ddr.dtsi" +#include "k3-j7200-common-proc-board-u-boot.dtsi"
/ { aliases { @@ -15,17 +16,6 @@ remoteproc1 = &a72_0; };
- chosen { - stdout-path = &main_uart0; - tick-timer = &timer1; - firmware-loader = &fs_loader0; - }; - - fs_loader0: fs_loader@0 { - bootph-all; - compatible = "u-boot,fs-loader"; - }; - a72_0: a72@0 { compatible = "ti,am654-rproc"; reg = <0x0 0x00a90000 0x0 0x10>; @@ -41,44 +31,34 @@ ti,sci-host-id = <10>; bootph-pre-ram; }; - - clk_200mhz: dummy_clock_200mhz { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - bootph-pre-ram; - }; - - clk_19_2mhz: dummy_clock_19_2mhz { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <19200000>; - bootph-pre-ram; - }; };
&memorycontroller { power-domains = <&k3_pds 8 TI_SCI_PD_SHARED>, <&k3_pds 90 TI_SCI_PD_SHARED>; clocks = <&k3_clks 8 5>, <&k3_clks 30 9>; + bootph-pre-ram; +}; + +&mcu_timer0 { + /delete-property/ power-domains; + ti,timer-alwon; + clock-frequency = <25000000>; + bootph-pre-ram; };
&cbass_mcu_wakeup { - mcu_secproxy: secproxy@2a380000 { + secure_proxy_mcu: mailbox@2a480000 { bootph-pre-ram; - compatible = "ti,am654-secure-proxy"; - reg = <0x0 0x2a380000 0x0 0x80000>, - <0x0 0x2a400000 0x0 0x80000>, - <0x0 0x2a480000 0x0 0x80000>; - reg-names = "rt", "scfg", "target_data"; - #mbox-cells = <1>; + status = "okay"; };
sysctrler: sysctrler { - bootph-pre-ram; compatible = "ti,am654-system-controller"; - mboxes= <&mcu_secproxy 4>, <&mcu_secproxy 5>; + mboxes= <&secure_proxy_mcu 4>, + <&secure_proxy_mcu 5>; mbox-names = "tx", "rx"; + bootph-pre-ram; };
dm_tifs: dm-tifs { @@ -86,250 +66,23 @@ ti,host-id = <3>; ti,secure-host; mbox-names = "rx", "tx"; - mboxes= <&mcu_secproxy 21>, - <&mcu_secproxy 23>; + mboxes= <&secure_proxy_mcu 21>, + <&secure_proxy_mcu 23>; bootph-pre-ram; }; - - wkup_vtm0: vtm@42040000 { - compatible = "ti,am654-vtm", "ti,j721e-avs"; - reg = <0x0 0x42040000 0x0 0x330>; - power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; - #thermal-sensor-cells = <1>; - }; };
&dmsc { - mboxes= <&mcu_secproxy 8>, <&mcu_secproxy 6>, <&mcu_secproxy 5>; + mboxes= <&secure_proxy_mcu 8>, + <&secure_proxy_mcu 6>, <&secure_proxy_mcu 5>; mbox-names = "tx", "rx", "notify"; ti,host-id = <4>; ti,secure-host; -}; - -&wkup_pmx0 { - bootph-pre-ram; - wkup_uart0_pins_default: wkup_uart0_pins_default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 0) /* (B14) WKUP_UART0_RXD */ - J721E_WKUP_IOPAD(0xb4, PIN_OUTPUT, 0) /* (A14) WKUP_UART0_TXD */ - >; - }; - - mcu_uart0_pins_default: mcu_uart0_pins_default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xf4, PIN_INPUT, 0) /* (D20) WKUP_GPIO0_13.MCU_UART0_RXD */ - J721E_WKUP_IOPAD(0xf0, PIN_OUTPUT, 0) /* (D19) WKUP_GPIO0_12.MCU_UART0_TXD */ - J721E_WKUP_IOPAD(0xf8, PIN_INPUT, 0) /* (E20) WKUP_GPIO0_14.MCU_UART0_CTSn */ - J721E_WKUP_IOPAD(0xfc, PIN_OUTPUT, 0) /* (E21) WKUP_GPIO0_15.MCU_UART0_RTSn */ - >; - }; - - wkup_i2c0_pins_default: wkup-i2c0-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x100, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */ - J721E_WKUP_IOPAD(0x104, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */ - >; - }; - - mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (E20) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */ - J721E_WKUP_IOPAD(0x4, PIN_OUTPUT, 1) /* (C21) MCU_OSPI0_LBCLKO.MCU_HYPERBUS0_CKn */ - J721E_WKUP_IOPAD(0x2c, PIN_OUTPUT, 1) /* (F19) MCU_OSPI0_CSn0.MCU_HYPERBUS0_CSn0 */ - J721E_WKUP_IOPAD(0x54, PIN_OUTPUT, 3) /* (E22) MCU_OSPI1_CSn1.MCU_HYPERBUS0_CSn1 */ - J721E_WKUP_IOPAD(0x30, PIN_OUTPUT, 1) /* (E19) MCU_OSPI0_CSn1.MCU_HYPERBUS0_RESETn */ - J721E_WKUP_IOPAD(0x8, PIN_INPUT, 1) /* (D21) MCU_OSPI0_DQS.MCU_HYPERBUS0_RWDS */ - J721E_WKUP_IOPAD(0xc, PIN_INPUT, 1) /* (D20) MCU_OSPI0_D0.MCU_HYPERBUS0_DQ0 */ - J721E_WKUP_IOPAD(0x10, PIN_INPUT, 1) /* (G19) MCU_OSPI0_D1.MCU_HYPERBUS0_DQ1 */ - J721E_WKUP_IOPAD(0x14, PIN_INPUT, 1) /* (G20) MCU_OSPI0_D2.MCU_HYPERBUS0_DQ2 */ - J721E_WKUP_IOPAD(0x18, PIN_INPUT, 1) /* (F20) MCU_OSPI0_D3.MCU_HYPERBUS0_DQ3 */ - J721E_WKUP_IOPAD(0x1c, PIN_INPUT, 1) /* (F21) MCU_OSPI0_D4.MCU_HYPERBUS0_DQ4 */ - J721E_WKUP_IOPAD(0x20, PIN_INPUT, 1) /* (E21) MCU_OSPI0_D5.MCU_HYPERBUS0_DQ5 */ - J721E_WKUP_IOPAD(0x24, PIN_INPUT, 1) /* (B22) MCU_OSPI0_D6.MCU_HYPERBUS0_DQ6 */ - J721E_WKUP_IOPAD(0x28, PIN_INPUT, 1) /* (G21) MCU_OSPI0_D7.MCU_HYPERBUS0_DQ7 */ - >; - }; - - wkup_gpio_pins_default: wkup-gpio-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xd8, PIN_INPUT, 7) /* (C14) WKUP_GPIO0_6 */ - >; - }; -}; - -&main_pmx0 { - bootph-pre-ram; - - main_uart0_pins_default: main_uart0_pins_default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_IOPAD(0xb0, PIN_INPUT, 0) /* (T16) UART0_RXD */ - J721E_IOPAD(0xb4, PIN_OUTPUT, 0) /* (T17) UART0_TXD */ - J721E_IOPAD(0xc0, PIN_INPUT, 2) /* (W3) SPI0_CS0.UART0_CTSn */ - J721E_IOPAD(0xc4, PIN_OUTPUT, 2) /* (U5) SPI0_CS1.UART0_RTSn */ - >; - }; - - main_i2c0_pins_default: main-i2c0-pins-default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ - J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ - >; - }; - - main_mmc1_pins_default: main_mmc1_pins_default { - pinctrl-single,pins = < - J721E_IOPAD(0x104, PIN_INPUT, 0) /* (M20) MMC1_CMD */ - J721E_IOPAD(0x100, PIN_INPUT, 0) /* (P21) MMC1_CLK */ - J721E_IOPAD(0xfc, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */ - J721E_IOPAD(0xf8, PIN_INPUT, 0) /* (M19) MMC1_DAT0 */ - J721E_IOPAD(0xf4, PIN_INPUT, 0) /* (N21) MMC1_DAT1 */ - J721E_IOPAD(0xf0, PIN_INPUT, 0) /* (N20) MMC1_DAT2 */ - J721E_IOPAD(0xec, PIN_INPUT, 0) /* (N19) MMC1_DAT3 */ - J721E_IOPAD(0xe4, PIN_INPUT, 8) /* (V1) TIMER_IO0.MMC1_SDCD */ - >; - }; - - main_usbss0_pins_default: main_usbss0_pins_default { - pinctrl-single,pins = < - J721E_IOPAD(0x120, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ - >; - }; -}; - -&wkup_uart0 { bootph-pre-ram; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_uart0_pins_default>; - status = "okay"; -}; - -&mcu_uart0 { - /delete-property/ power-domains; - /delete-property/ clocks; - /delete-property/ clock-names; - pinctrl-names = "default"; - pinctrl-0 = <&mcu_uart0_pins_default>; - status = "okay"; - clock-frequency = <96000000>; -}; - -&main_uart0 { - status = "okay"; - power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart0_pins_default>; - status = "okay"; -}; - -&main_sdhci0 { - /delete-property/ power-domains; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - pinctrl-0 = <&main_mmc1_pins_default>; - pinctrl-names = "default"; - clock-names = "clk_xin"; - clocks = <&clk_200mhz>; - ti,driver-strength-ohm = <50>; - non-removable; - bus-width = <8>; -}; - -&main_sdhci1 { - /delete-property/ power-domains; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - clock-names = "clk_xin"; - clocks = <&clk_200mhz>; - ti,driver-strength-ohm = <50>; -}; - -&wkup_i2c0 { - bootph-pre-ram; - lp876441: lp876441@4c { - compatible = "ti,lp876441"; - reg = <0x4c>; - bootph-pre-ram; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_i2c0_pins_default>; - clock-frequency = <400000>; - - regulators: regulators { - bootph-pre-ram; - buck1_reg: buck1 { - /*VDD_CPU_AVS_REG*/ - regulator-name = "buck1"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1250000>; - regulator-always-on; - regulator-boot-on; - bootph-pre-ram; - }; - }; - }; - };
&wkup_vtm0 { + compatible = "ti,am654-vtm", "ti,j721e-avs"; vdd-supply-2 = <&buck1_reg>; bootph-pre-ram; }; - -&main_i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c0_pins_default>; - clock-frequency = <400000>; - - exp1: gpio@20 { - compatible = "ti,tca6416"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - }; - - exp2: gpio@22 { - compatible = "ti,tca6424"; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&usbss0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_usbss0_pins_default>; - ti,vbus-divider; - ti,usb2-only; -}; - -&usb0 { - dr_mode = "otg"; - maximum-speed = "high-speed"; -}; - -&hbmc { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mcu_fss0_hpb0_pins_default>; - reg = <0x0 0x47040000 0x0 0x100>, - <0x0 0x50000000 0x0 0x8000000>; - ranges = <0x0 0x0 0x0 0x50000000 0x4000000>, /* 64MB Flash on CS0 */ - <0x1 0x0 0x0 0x54000000 0x800000>; /* 8MB flash on CS1 */ - - flash@0,0 { - compatible = "cypress,hyperflash", "cfi-flash"; - reg = <0x0 0x0 0x4000000>; - }; -}; - -&mcu_ringacc { - ti,sci = <&dm_tifs>; -}; - -&mcu_udmap { - ti,sci = <&dm_tifs>; -}; -#include "k3-j7200-common-proc-board-u-boot.dtsi" diff --git a/arch/arm/dts/k3-j7200-som-p0.dtsi b/arch/arm/dts/k3-j7200-som-p0.dtsi index 3472444017..b37f4f88ec 100644 --- a/arch/arm/dts/k3-j7200-som-p0.dtsi +++ b/arch/arm/dts/k3-j7200-som-p0.dtsi @@ -83,7 +83,7 @@ };
&wkup_pmx0 { - mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-pins-default { + mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-default-pins { pinctrl-single,pins = < J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (B6) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */ J721E_WKUP_IOPAD(0x4, PIN_OUTPUT, 1) /* (C8) MCU_OSPI0_LBCLKO.MCU_HYPERBUS0_CKn */ @@ -101,7 +101,7 @@ >; };
- mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-pins-default { + mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-default-pins { pinctrl-single,pins = < J721E_WKUP_IOPAD(0x0000, PIN_OUTPUT, 0) /* MCU_OSPI0_CLK */ J721E_WKUP_IOPAD(0x002c, PIN_OUTPUT, 0) /* MCU_OSPI0_CSn0 */ @@ -118,8 +118,17 @@ }; };
+&wkup_pmx2 { + wkup_i2c0_pins_default: wkup-i2c0-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x98, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */ + J721E_WKUP_IOPAD(0x9c, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */ + >; + }; +}; + &main_pmx0 { - main_i2c0_pins_default: main-i2c0-pins-default { + main_i2c0_pins_default: main-i2c0-default-pins { pinctrl-single,pins = < J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ @@ -140,10 +149,42 @@ flash@0,0 { compatible = "cypress,hyperflash", "cfi-flash"; reg = <0x00 0x00 0x4000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "hbmc.tiboot3"; + reg = <0x0 0x100000>; + }; + + partition@100000 { + label = "hbmc.tispl"; + reg = <0x100000 0x200000>; + }; + + partition@300000 { + label = "hbmc.u-boot"; + reg = <0x300000 0x400000>; + }; + + partition@700000 { + label = "hbmc.env"; + reg = <0x700000 0x40000>; + }; + + partition@800000 { + label = "hbmc.rootfs"; + reg = <0x800000 0x3800000>; + }; + }; }; };
&mailbox0_cluster0 { + status = "okay"; interrupts = <436>;
mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 { @@ -158,6 +199,7 @@ };
&mailbox0_cluster1 { + status = "okay"; interrupts = <432>;
mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 { @@ -171,66 +213,26 @@ }; };
-&mailbox0_cluster2 { - status = "disabled"; -}; - -&mailbox0_cluster3 { - status = "disabled"; -}; - -&mailbox0_cluster4 { - status = "disabled"; -}; - -&mailbox0_cluster5 { - status = "disabled"; -}; - -&mailbox0_cluster6 { - status = "disabled"; -}; - -&mailbox0_cluster7 { - status = "disabled"; -}; - -&mailbox0_cluster8 { - status = "disabled"; -}; - -&mailbox0_cluster9 { - status = "disabled"; -}; - -&mailbox0_cluster10 { - status = "disabled"; -}; - -&mailbox0_cluster11 { - status = "disabled"; -}; - &mcu_r5fss0_core0 { - mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>; + mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core0>; memory-region = <&mcu_r5fss0_core0_dma_memory_region>, <&mcu_r5fss0_core0_memory_region>; };
&mcu_r5fss0_core1 { - mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>; + mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core1>; memory-region = <&mcu_r5fss0_core1_dma_memory_region>, <&mcu_r5fss0_core1_memory_region>; };
&main_r5fss0_core0 { - mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>; + mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core0>; memory-region = <&main_r5fss0_core0_dma_memory_region>, <&main_r5fss0_core0_memory_region>; };
&main_r5fss0_core1 { - mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>; + mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core1>; memory-region = <&main_r5fss0_core1_dma_memory_region>, <&main_r5fss0_core1_memory_region>; }; @@ -252,11 +254,23 @@ }; };
+&wkup_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>; + + eeprom@50 { + compatible = "atmel,24c256"; + reg = <0x50>; + }; +}; + &ospi0 { pinctrl-names = "default"; pinctrl-0 = <&mcu_fss0_ospi0_pins_default>;
- flash@0{ + flash@0 { compatible = "jedec,spi-nor"; reg = <0x0>; spi-tx-bus-width = <8>; @@ -267,7 +281,46 @@ cdns,tchsh-ns = <60>; cdns,tslch-ns = <60>; cdns,read-delay = <4>; - #address-cells = <1>; - #size-cells = <1>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "ospi.tiboot3"; + reg = <0x0 0x100000>; + }; + + partition@100000 { + label = "ospi.tispl"; + reg = <0x100000 0x200000>; + }; + + partition@300000 { + label = "ospi.u-boot"; + reg = <0x300000 0x400000>; + }; + + partition@700000 { + label = "ospi.env"; + reg = <0x700000 0x40000>; + }; + + partition@740000 { + label = "ospi.env.backup"; + reg = <0x740000 0x40000>; + }; + + partition@800000 { + label = "ospi.rootfs"; + reg = <0x800000 0x37c0000>; + }; + + partition@3fc0000 { + label = "ospi.phypattern"; + reg = <0x3fc0000 0x40000>; + }; + }; }; }; diff --git a/arch/arm/dts/k3-j7200-thermal.dtsi b/arch/arm/dts/k3-j7200-thermal.dtsi new file mode 100644 index 0000000000..e7e3a643a6 --- /dev/null +++ b/arch/arm/dts/k3-j7200-thermal.dtsi @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include <dt-bindings/thermal/thermal.h> + +thermal_zones: thermal-zones { + mcu_thermal: mcu-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 0>; + + trips { + wkup_crit: wkup-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; + }; + + mpu_thermal: mpu-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 1>; + + trips { + mpu_crit: mpu-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; + }; + + main_thermal: main-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 2>; + + trips { + c7x_crit: c7x-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; + }; +}; diff --git a/arch/arm/dts/k3-j7200.dtsi b/arch/arm/dts/k3-j7200.dtsi index b7005b8031..ef73e6d7e8 100644 --- a/arch/arm/dts/k3-j7200.dtsi +++ b/arch/arm/dts/k3-j7200.dtsi @@ -7,9 +7,10 @@
#include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/pinctrl/k3.h> #include <dt-bindings/soc/ti,sci_pm_domain.h>
+#include "k3-pinctrl.h" + / { model = "Texas Instruments K3 J7200 SoC"; compatible = "ti,j7200"; @@ -17,21 +18,6 @@ #address-cells = <2>; #size-cells = <2>;
- aliases { - serial0 = &wkup_uart0; - serial1 = &mcu_uart0; - serial2 = &main_uart0; - serial3 = &main_uart1; - serial4 = &main_uart2; - serial5 = &main_uart3; - serial6 = &main_uart4; - serial7 = &main_uart5; - serial8 = &main_uart6; - serial9 = &main_uart7; - serial10 = &main_uart8; - serial11 = &main_uart9; - }; - chosen { };
cpus { @@ -60,7 +46,7 @@ i-cache-sets = <256>; d-cache-size = <0x8000>; d-cache-line-size = <64>; - d-cache-sets = <128>; + d-cache-sets = <256>; next-level-cache = <&L2_0>; };
@@ -74,7 +60,7 @@ i-cache-sets = <256>; d-cache-size = <0x8000>; d-cache-line-size = <64>; - d-cache-sets = <128>; + d-cache-sets = <256>; next-level-cache = <&L2_0>; }; }; @@ -82,15 +68,17 @@ L2_0: l2-cache0 { compatible = "cache"; cache-level = <2>; + cache-unified; cache-size = <0x100000>; cache-line-size = <64>; - cache-sets = <2048>; + cache-sets = <1024>; next-level-cache = <&msmc_l3>; };
msmc_l3: l3-cache0 { compatible = "cache"; cache-level = <3>; + cache-unified; };
firmware { @@ -124,9 +112,11 @@ #size-cells = <2>; ranges = <0x00 0x00100000 0x00 0x00100000 0x00 0x00020000>, /* ctrl mmr */ <0x00 0x00600000 0x00 0x00600000 0x00 0x00031100>, /* GPIO */ + <0x00 0x00700000 0x00 0x00700000 0x00 0x00001000>, /* ESM */ <0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* timesync router */ <0x00 0x01000000 0x00 0x01000000 0x00 0x0d000000>, /* Most peripherals */ <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>, /* MAIN NAVSS */ + <0x00 0x6f000000 0x00 0x6f000000 0x00 0x00310000>, /* A72 PERIPHBASE */ <0x00 0x70000000 0x00 0x70000000 0x00 0x00800000>, /* MSMC RAM */ <0x00 0x18000000 0x00 0x18000000 0x00 0x08000000>, /* PCIe1 DAT0 */ <0x41 0x00000000 0x41 0x00000000 0x01 0x00000000>, /* PCIe1 DAT1 */ @@ -165,6 +155,8 @@ <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; /* FSS OSPI1 data region 3 */ }; }; + + #include "k3-j7200-thermal.dtsi" };
/* Now include the peripherals for each bus segments */ diff --git a/arch/arm/mach-k3/j7200/dev-data.c b/arch/arm/mach-k3/j7200/dev-data.c index 4ddc34210e..8ce6796fd0 100644 --- a/arch/arm/mach-k3/j7200/dev-data.c +++ b/arch/arm/mach-k3/j7200/dev-data.c @@ -46,6 +46,7 @@ static struct ti_lpsc soc_lpsc_list[] = {
static struct ti_dev soc_dev_list[] = { PSC_DEV(30, &soc_lpsc_list[0]), + PSC_DEV(35, &soc_lpsc_list[0]), PSC_DEV(61, &soc_lpsc_list[1]), PSC_DEV(90, &soc_lpsc_list[2]), PSC_DEV(8, &soc_lpsc_list[3]),
On 13:57-20230822, Reid Tonking wrote:
diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index e62f9218e8..bd4be7215f 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -41,44 +31,34 @@ ti,sci-host-id = <10>; bootph-pre-ram; };
#clock-cells = <0>;
bootph-pre-ram;
#clock-cells = <0>;
bootph-pre-ram;
- bootph-pre-ram;
+&mcu_timer0 {
- ti,timer-alwon;
- clock-frequency = <25000000>;
- bootph-pre-ram;
This needs to be.. $mcu_timer0 { clock-frequency = <25000000>; bootph-pre-ram; };
This fix was accidently left out of the commit, so it'll be changed for v2. The change to dev-data.c allows this.
-Reid
Sync j7200 device tree files with Linux 6.5-rc1
I understand this is a major step forward, but a still:
There is more work to do: a) split the dev-data.c fixup as the first patch b) See comments in https://lore.kernel.org/u-boot/20230816114445.c4c7rgdp5arhmiaq@polyester/
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index f25c7136c9..a00e85e366 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /*
- Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/
- Copyright (C) 2020-2023 Texas Instruments Incorporated - https://www.ti.com/
#include "k3-j7200-binman.dtsi" @@ -8,7 +8,7 @@ / { chosen { stdout-path = "serial2:115200n8";
Drop this
tick-timer = &mcu_timer0;
aliases {
You dont need the aliases - these come in from board.dts
@@ -28,16 +28,12 @@ bootph-pre-ram; };
-&cbass_mcu_wakeup { +&main_esm{
space before the {
bootph-pre-ram; +};
- timer1: timer@40400000 {
compatible = "ti,omap5430-timer";
reg = <0x0 0x40400000 0x0 0x80>;
ti,timer-alwon;
clock-frequency = <250000000>;
bootph-pre-ram;
+&cbass_mcu_wakeup {
bootph-pre-ram;
chipid@43000014 { bootph-pre-ram;
}; End it here.
@@ -45,8 +41,6 @@
mcu_navss: bus@28380000 {
Dont duplicate the entire node. &mcu_navss { bootph-pre-ram; };
&mcu_ringacc { bootph-pre-ram; }; NOTE: you only need to override reg-names and reg in R5.dtsi not u-boot.dtsi.
&mcu_udmap { bootph-pre-ram; };
bootph-pre-ram;
#size-cells = <2>;
ringacc@2b800000 { reg = <0x0 0x2b800000 0x0 0x400000>,
And clean this up.
&wkup_i2c0 { bootph-pre-ram;
NAK. Why is this new stuff coming in -> should'nt be here.
bootph-pre-ram;
bootph-pre-ram;
buck1_reg: buck1 {
bootph-pre-ram;
&main_i2c0 { bootph-pre-ram;
- exp1: gpio@20 {
Again - just do it using the reference &exp1 { bootph-pre-ram; };
And this pattern repeats itself..
bootph-pre-ram;
- exp2: gpio@22 {
This as well.
hbmc -> arch/arm64/boot/dts/ti/k3-j7200-som-p0.dtsi: flash@0,0 weird that does'nt throw a dtbs_check warning
WARNING: u-boot,mux-autoprobe -> this is'nt supported.
Also &main_r5fss0 -> ti,cluster-mode=<0> -> Drop that.
There is a bit debate about dr_mode = "peripheral"; https://lore.kernel.org/u-boot/fc205109-fd3d-ea79-abcc-f1638115d0d3@kernel.o...
Depending on where it ends up...
+&mcu_timer0 {
- ti,timer-alwon;
- bootph-pre-ram;
you already caught this - just pre-ram and clock-frequency.
&cbass_mcu_wakeup {
- secure_proxy_mcu: mailbox@2a480000 {
Move this out.
bootph-pre-ram;
#mbox-cells = <1>;
status = "okay";
compatible = "ti,am654-system-controller";bootph-pre-ram;
bootph-pre-ram;
dm_tifs: dm-tifs {
Move this to root similar to am625. it is more or less a hanky stuff we do with this.
<&mcu_secproxy 23>;
bootph-pre-ram; };<&secure_proxy_mcu 23>;
&dmsc {
- mboxes= <&secure_proxy_mcu 8>,
mbox-names = "tx", "rx", "notify"; ti,host-id = <4>; ti,secure-host;<&secure_proxy_mcu 6>, <&secure_proxy_mcu 5>;
-&wkup_pmx0 {
- bootph-pre-ram;
bootph-pre-ram;
bootph-pre-ram;
-&main_pmx0 {
- bootph-pre-ram;
bootph-pre-ram;
bootph-pre-ram;
- status = "okay";
-&mcu_uart0 {
- status = "okay";
-&main_uart0 {
- status = "okay";
- status = "okay";
-&main_sdhci0 {
- non-removable;
- bus-width = <8>;
-&main_sdhci1 {
-&wkup_i2c0 {
- bootph-pre-ram;
There is no such driver in linux kernel compatible space. might need a ticket to implement the driver.
reg = <0x4c>;
bootph-pre-ram;
bootph-pre-ram;
buck1_reg: buck1 {
/*VDD_CPU_AVS_REG*/
regulator-boot-on;
bootph-pre-ram;
&wkup_vtm0 {
&wkup_vtm0 -> there is already stuff coming in from kernel. why do we need to define our own compatible "ti,am654-vtm", "ti,j721e-avs"? there is already compatible = "ti,j7200-vtm"; if we need to fix the driver as part of the series, please do as a path in the series.
Should have been handled in kernel please. Please file an internal tracking ticket for this to be handled.
bootph-pre-ram; };
-&main_i2c0 {
- exp1: gpio@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
- exp2: gpio@22 {
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
-&usbss0 {
- ti,vbus-divider;
- ti,usb2-only;
-&usb0 {
- dr_mode = "otg";
-&hbmc {
- status = "okay";
- flash@0,0 {
-&mcu_ringacc {
-&mcu_udmap {
https://gist.github.com/nmenon/662262b0256eab004485035a02ede963 is probably the set of changes I commented about above.
Split this out as a separate patch.
- PSC_DEV(35, &soc_lpsc_list[0]), PSC_DEV(61, &soc_lpsc_list[1]), PSC_DEV(90, &soc_lpsc_list[2]), PSC_DEV(8, &soc_lpsc_list[3]),
-- 2.34.1
Drop this
aliases {
space before the {
bootph-pre-ram; +};
ti,timer-alwon;
bootph-pre-ram;
bootph-pre-ram;
}; End it here.
all the above, done
@@ -45,8 +41,6 @@
I saw you mentioned at [0] that mcu_ringacc (and I assume mcu_udmap) need to be retained for now. If moved to r5.dts, something breaks, as dhcp fails then [1]. Should the full nodes remain for now until 6.6-rc1 sync? I'll still take them outside of mcu_navss.
[0] https://lore.kernel.org/all/20230816114445.c4c7rgdp5arhmiaq@polyester/ [1] https://gist.github.com/Glockn/f0cf1ae8f8fd92e70f4e798c6221e81a
bootph-pre-ram;
#size-cells = <2>;
And clean this up.
This was left because &wkup_vtm0 uses &buck1_reg below which isn't apart of the kernel dt files.
bootph-pre-ram;
bootph-pre-ram;
buck1_reg: buck1 {
bootph-pre-ram;
- exp1: gpio@20 {
bootph-pre-ram;
- exp2: gpio@22 {
This as well.
will do
change these to bootph-pre-ram?
I'll keep an eye on this
+&mcu_timer0 {
- ti,timer-alwon;
- bootph-pre-ram;
&cbass_mcu_wakeup {
Move this out.
done
bootph-pre-ram;
#mbox-cells = <1>;
status = "okay";
bootph-pre-ram;
dm_tifs: dm-tifs {
done
<&mcu_secproxy 23>;
&dmsc {
-&wkup_pmx0 {
- bootph-pre-ram;
bootph-pre-ram;
bootph-pre-ram;
-&main_pmx0 {
- bootph-pre-ram;
bootph-pre-ram;
bootph-pre-ram;
- status = "okay";
-&mcu_uart0 {
- status = "okay";
-&main_uart0 {
- status = "okay";
- status = "okay";
-&main_sdhci0 {
- non-removable;
- bus-width = <8>;
-&main_sdhci1 {
-&wkup_i2c0 {
- bootph-pre-ram;
Interesting - I'll look into it. Makes me wonder about the buck1_reg for wkup_vtm0 and what's going on there.
reg = <0x4c>;
bootph-pre-ram;
bootph-pre-ram;
buck1_reg: buck1 {
/*VDD_CPU_AVS_REG*/
regulator-boot-on;
bootph-pre-ram;
&wkup_vtm0 {
ti,j7200-vtm doesn't work and throws a "AVS init failed: -19", so i'll work on that. The compatible I used was taken from our TI u-boot
will do
bootph-pre-ram; };
-&main_i2c0 {
- exp1: gpio@20 {
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
- exp2: gpio@22 {
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
-&usbss0 {
- ti,vbus-divider;
- ti,usb2-only;
-&usb0 {
- dr_mode = "otg";
-&hbmc {
- status = "okay";
- flash@0,0 {
-&mcu_ringacc {
-&mcu_udmap {
Thanks for the feedback!
will do
-- 2.34.1
-- Regards, Nishanth Menon Key (0xDDB5849D1736249D) / Fingerprint: F8A2 8693 54EB 8232 17A3 1A34 DDB5 849D 1736 249D
On 15:01-20230823, reidt wrote: [...]
True.. But, I understand the overrides are only for the R5 usage when DM is'nt around to support us. So, yes override it in R5 dts - Now why without a A72 override it breaks is beyond me and I'd suggest poking Vignesh or someone more knowledgable about DMA/CPSW for help there.
Please send it upstream kernel. What breaks if we keep that out of tree?
My vague recollection is avs0 is mandatory for j7200?
No, I was just surprised to see a new u-boot property.. dont really know what it does. I doubt switching it to bootph-pre-ram will work there.
-&wkup_i2c0 {
- bootph-pre-ram;
Alright - checkout AVS0 - maybe Keerthy or someone can help guide.
&wkup_vtm0 {
Sounds like a driver fixup needed in u-boot to match up with the compatible that was accepted in upstream kernel. Also the classic reason why we are now insisting that the device tree come in from kernel pristine.
Nishanth Menon
Reid Tonking
reidt
