[U-Boot] [PATCH] ARM: meson-gx: Reset GXL/GXM to external PHY when not using internal PHY
When using External PHY, reset the mux to use the external PHY in case U-Boot was chainloaded from a misconfigured bootloader.
Fixes: 33e3378091 ("ARM: meson: rework soc arch file to prepare for new SoC") Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/mach-meson/board-gx.c | 17 ++++++++++++----- 1 file changed, 12 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-meson/board-gx.c b/arch/arm/mach-meson/board-gx.c index e41552db52..2b0614b79b 100644 --- a/arch/arm/mach-meson/board-gx.c +++ b/arch/arm/mach-meson/board-gx.c @@ -112,6 +112,11 @@ void meson_eth_init(phy_interface_t mode, unsigned int flags) GX_ETH_REG_0_TX_RATIO(4) | GX_ETH_REG_0_PHY_CLK_EN | GX_ETH_REG_0_CLK_EN); + + /* Reset to external PHY */ + if(!IS_ENABLED(CONFIG_MESON_GXBB)) + writel(0x2009087f, GX_ETH_REG_3); + break;
case PHY_INTERFACE_MODE_RMII: @@ -119,11 +124,13 @@ void meson_eth_init(phy_interface_t mode, unsigned int flags) out_le32(GX_ETH_REG_0, GX_ETH_REG_0_INVERT_RMII_CLK | GX_ETH_REG_0_CLK_EN);
- /* Use GXL RMII Internal PHY */ - if (IS_ENABLED(CONFIG_MESON_GXL) && - (flags & MESON_USE_INTERNAL_RMII_PHY)) { - writel(0x10110181, GX_ETH_REG_2); - writel(0xe40908ff, GX_ETH_REG_3); + /* Use GXL RMII Internal PHY (also on GXM) */ + if (!IS_ENABLED(CONFIG_MESON_GXBB)) { + if ((flags & MESON_USE_INTERNAL_RMII_PHY)) { + writel(0x10110181, GX_ETH_REG_2); + writel(0xe40908ff, GX_ETH_REG_3); + } else + writel(0x2009087f, GX_ETH_REG_3); }
break;
break;
} else
break;
Applied to u-boot-amlogic
Neil Armstrong
