[U-Boot] [PATCH] env_ext4: fix build error.
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- common/env_ext4.c | 20 +++++++++++--------- 1 file changed, 11 insertions(+), 9 deletions(-)
diff --git a/common/env_ext4.c b/common/env_ext4.c index ce748ed..5683890 100644 --- a/common/env_ext4.c +++ b/common/env_ext4.c @@ -25,6 +25,7 @@ #include <environment.h> #include <linux/stddef.h> #include <malloc.h> +#include <memalign.h> #include <search.h> #include <errno.h> #include <ext4fs.h> @@ -49,7 +50,7 @@ int env_init(void) int saveenv(void) { env_t env_new; - block_dev_desc_t *dev_desc = NULL; + struct blk_desc *dev_desc = NULL; disk_partition_t info; int dev, part; int err; @@ -58,13 +59,13 @@ int saveenv(void) if (err) return err;
- part = get_device_and_partition(EXT4_ENV_INTERFACE, + part = blk_get_device_part_str(EXT4_ENV_INTERFACE, EXT4_ENV_DEVICE_AND_PART, &dev_desc, &info, 1); if (part < 0) return 1;
- dev = dev_desc->dev; + dev = dev_desc->devnum; ext4fs_set_blk_dev(dev_desc, &info);
if (!ext4fs_mount(info.size)) { @@ -90,18 +91,19 @@ int saveenv(void) void env_relocate_spec(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); - block_dev_desc_t *dev_desc = NULL; + struct blk_desc *dev_desc = NULL; disk_partition_t info; int dev, part; int err; + long long int actread;
- part = get_device_and_partition(EXT4_ENV_INTERFACE, - EXT4_ENV_DEVICE_AND_PART, - &dev_desc, &info, 1); + part = blk_get_device_part_str(EXT4_ENV_INTERFACE, + EXT4_ENV_DEVICE_AND_PART, + &dev_desc, &info, 1); if (part < 0) goto err_env_relocate;
if (!ext4fs_mount(info.size)) { @@ -110,7 +112,7 @@ void env_relocate_spec(void) goto err_env_relocate; }
- err = ext4_read_file(EXT4_ENV_FILE, buf, 0, CONFIG_ENV_SIZE); + err = ext4_read_file(EXT4_ENV_FILE, buf, 0, CONFIG_ENV_SIZE, &actread); ext4fs_close();
if (err == -1) {
Am 18.04.2016 um 09:55 schrieb Yoshinori Sato:
- struct blk_desc *dev_desc = NULL; disk_partition_t info; int dev, part; int err;
- part = blk_get_device_part_str(EXT4_ENV_INTERFACE, EXT4_ENV_DEVICE_AND_PART, &dev_desc, &info, 1);
Below you adjusted the indentation, here you didn't?
While at it, you could drop the trailing full stop from the subject.
Regards, Andreas
- long long int actread;
if (part < 0) goto err_env_relocate;&dev_desc, &info, 1);
if (err == -1) {
Andreas Färber
Yoshinori Sato
