Re: [U-Boot] [PATCH v1 4/4] ARM: DRA7: fastboot: Implement reboot-bootloader command
Hi Rob,
On 3 March 2015 at 19:45, Rob Herring robherring2@gmail.com wrote:
On Tue, Mar 3, 2015 at 5:10 AM, Dileep Katta dileep.katta@linaro.org wrote:
Signed-off-by: Angela Stegmaier angelabaker@ti.com Signed-off-by: Dileep Katta dileep.katta@linaro.org
board/ti/dra7xx/Makefile | 1 + board/ti/dra7xx/fastboot.c | 45
common/cmd_bootm.c | 5 ++++ drivers/usb/gadget/f_fastboot.c | 5 ++++ include/configs/dra7xx_evm_android.h | 14 +++++++++++ 5 files changed, 70 insertions(+) create mode 100644 board/ti/dra7xx/fastboot.c
diff --git a/board/ti/dra7xx/Makefile b/board/ti/dra7xx/Makefile index 434e8d1..ae730ae 100644 --- a/board/ti/dra7xx/Makefile +++ b/board/ti/dra7xx/Makefile @@ -6,3 +6,4 @@ #
obj-y := evm.o +obj-$(CONFIG_CMD_FASTBOOT) += fastboot.o diff --git a/board/ti/dra7xx/fastboot.c b/board/ti/dra7xx/fastboot.c new file mode 100644 index 0000000..e05010d --- /dev/null +++ b/board/ti/dra7xx/fastboot.c @@ -0,0 +1,45 @@ +/*
- (C) Copyright 2013
- Texas Instruments Incorporated, <www.ti.com>
- Lokesh Vutla lokeshvutla@ti.com
- Based on previous work by:
- Aneesh V aneesh@ti.com
- Steve Sakoman steve@sakoman.com
+#include <common.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <config.h>
+int fb_set_reboot_flag(void) +{
/* clear all reset events */
__raw_writel(DRA7XX_PRM_RSTST_CLR, PRM_RSTST);
strncpy((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE, "bootloader",
DRA7XX_REBOOT_REASON_SIZE - 1);
*(((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE) +
DRA7XX_REBOOT_REASON_SIZE - 1) = '\0';
/* trigger warm reset */
__raw_writel(DRA7XX_PRM_RSTCTRL_RESET_WARM_BIT,
DRA7XX_PRM_RSTCTRL);
Does this reset immediately? If so, then you will fail to send a response to the client.
+int fb_check_reboot_flag(void) +{
/* Check if we are coming from a warm reset */
if (__raw_readl(DRA7XX_PRM_RSTST) &
DRA7XX_PRM_RSTST_RESET_WARM_BIT)
if (!strncmp((const char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE,
"bootloader",
DRA7XX_REBOOT_REASON_SIZE)) {
strncpy((char *)DRA7XX_PUBLIC_SAR_RAM_1_FREE, "",
DRA7XX_REBOOT_REASON_SIZE);
return 1;
+} diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 48199bf..00791be 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -729,6 +729,11 @@ int do_booti(cmd_tbl_t *cmdtp, int flag, int argc,
char * const argv[])
{ int ret;
+#if defined(CONFIG_CMD_FASTBOOT)
if (!fb_check_reboot_flag())
do_fastboot(cmdtp, flag, argc, argv);
Part of the booti command? First, booti is for arm64 Image files. How does this work for you?
This was ported from an existing DRA7 implementation as per latest u-boot. Should have sent it as RFC patch, as this is not verified due to unavailability of board.
More importantly, this should not be tied into any bootX command. It should probably be done in a boot script. If the flag is set, the board code can set some environment variable. Then the boot script can run the fastboot command if the env var is set.
/* Consume 'booti' */ argc--; argv++;
diff --git a/drivers/usb/gadget/f_fastboot.c
b/drivers/usb/gadget/f_fastboot.c
index 206b6d1..a450357 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -332,6 +332,11 @@ int __weak fb_set_reboot_flag(void) return -ENOSYS; }
+int __weak fb_check_reboot_flag(void) +{
return -ENOSYS;
static void cb_reboot(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; diff --git a/include/configs/dra7xx_evm_android.h
b/include/configs/dra7xx_evm_android.h
index 68e7eec..2038e00 100644 --- a/include/configs/dra7xx_evm_android.h +++ b/include/configs/dra7xx_evm_android.h @@ -310,4 +310,18 @@ #endif #endif /* NOR support */
+#define DRA7XX_PUBLIC_SAR_RAM_1_FREE (0x4AE26000 + 0xFE0) +#define DRA7XX_PRM_RSTCTRL_RESET_WARM_BIT (1<<0) +#define DRA7XX_PRM_RSTST_RESET_WARM_BIT (1<<1) +#define DRA7XX_PRM_RSTST 0x4AE07D04 +#define DRA7XX_PRM_RSTCTRL 0x4AE07D00 +#define DRA7XX_PRM_RSTST_CLR 0xfff +#define DRA7XX_REBOOT_REASON_SIZE 0xf
+#define CONFIG_BOARD_MACH_TYPE 4070
You shouldn't need this anymore, right?
+#define MEMORY_BASE 0x80000000 +#define CONFIG_ADDR_ATAGS (MEMORY_BASE + 0x100)
Or this?
+#define CONFIG_ADDR_DOWNLOAD (MEMORY_BASE +
0x02000000)
+#define DEVICE_TREE 0x82f80000
Use fdt_addr_r env var instead?
Rob
Will change the implementation as per the comments. Thanks for the suggestions.
Regards, Dileep
{ int ret;
Ummm... I am curious and wonder why the authorship changed if it was just a "port"? Might be nice to point to original source where this was picked up from http://git.omapzoom.org/?p=repo/u-boot.git;a=shortlog;h=refs/heads/p-ti-u-bo...
For example patch #2 http://git.omapzoom.org/?p=repo/u-boot.git;a=commit;h=5df0356d4c34611d32f905... I cant see much of a change here to have an authorship change perhaps?
Do I understand that Angela is ok with the same? please confirm.
Hmm... interesting.... maybe Vish can help here?
Dileep Katta
Nishanth Menon
