[PATCH 1/1] efi_loader: Sphinx comments in efi_api.h
Fix incorrect Sphinx comments in efi_api.h:
* add missing 'struct' * correct indentation
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- include/efi_api.h | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index db35819473..41516cc7eb 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -902,8 +902,8 @@ struct efi_hii_package_list_header { * @fields: 'fields' replaces the bit-fields defined in the EFI * specification to to avoid possible compiler incompatibilities:: * - * u32 length:24; - * u32 type:8; + * u32 length:24; + * u32 type:8; */ struct efi_hii_package_header { u32 fields; @@ -1841,7 +1841,7 @@ struct efi_system_resource_table { 0x34, 0x7d, 0x37, 0x56, 0x65, 0xa7)
/** - * win_certificate_uefi_guid - A certificate that encapsulates + * struct win_certificate_uefi_guid - A certificate that encapsulates * a GUID-specific signature * * @hdr: Windows certificate header @@ -1855,7 +1855,7 @@ struct win_certificate_uefi_guid { } __attribute__((__packed__));
/** - * efi_variable_authentication_2 - A time-based authentication method + * struct efi_variable_authentication_2 - A time-based authentication method * descriptor * * This structure describes an authentication information for @@ -1872,7 +1872,7 @@ struct efi_variable_authentication_2 { } __attribute__((__packed__));
/** - * efi_firmware_image_authentication - Capsule authentication method + * struct efi_firmware_image_authentication - Capsule authentication method * descriptor * * This structure describes an authentication information for @@ -1890,7 +1890,7 @@ struct efi_firmware_image_authentication {
/** - * efi_signature_data - A format of signature + * struct efi_signature_data - A format of signature * * This structure describes a single signature in signature database. * @@ -1903,7 +1903,7 @@ struct efi_signature_data { } __attribute__((__packed__));
/** - * efi_signature_list - A format of signature database + * struct efi_signature_list - A format of signature database * * This structure describes a list of signatures with the same type. * An authenticated variable's value is a concatenation of one or more
