[PATCH v2 0/7] toradex: fix reset and hardware detection regressions
From: Francesco Dolcini francesco.dolcini@toradex.com
This series fixes two regressions affecting multiple Toradex boards (i.MX, TI and TEGRA based) and targets the current master, e.g. v2024.04 release.
U-Boot `reset` command is broken on all Tordex i.MX6* based SoMs since v2023.07, this series fixes it enabling the `wdt-reboot` driver.
Since v2024.04-rc1 reading the Toradex configuration block is not working properly anymore, the serial number and the hardware version are not read correctly, preventing the board from functioning correctly (wrong mac address, wrong DT, ...). This is fixed by reading the config block in `EVT_SETTINGS_R` and adding a toradex sysinfo driver. In addition to that, we now use a random mac address in case the config block is invalid.
Reported-by: Sahaj Sarup sahaj.sarup@linaro.org Closes: https://lore.kernel.org/all/CAKZ1LvM45MB8N0CqgU+C7i9=Bjb6kqNTxWo2Tv407HKLWtC... Reported-by: Marcel Ziswiler marcel.ziswiler@toradex.com Closes: https://lore.kernel.org/all/e40ed93bd8f371ec56b8fc451dcb458f3ce6dcba.camel@t... Reported-by: Francesco Dolcini francesco@dolcini.it Closes: https://lore.kernel.org/all/ZY2ZDWAQuTlRjV9H@francesco-nb/
v2: - add Marcel acked and tested-by - remove CONFIG_NET_RANDOM_ETHADDR from verdin-am62_r5_defconfig
v1: https://lore.kernel.org/all/20240220182926.101161-1-francesco@dolcini.it/
Emanuele Ghidoli (6): toradex: Fix recursive call to checkboard toradex: Remove not necessary model prints from checkboard() toradex: common: Use SETTINGS_R event to read toradex config block arm: dts: Refactor device trees using "&{/aliases}" syntax toradex: common: Add sysinfo driver toradex: common: Use random mac address if toradex config block is missing
Parth Pancholi (1): toradex: imx6*: fix reset using wdt-reboot driver
arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi | 6 + arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi | 6 + .../dts/imx6dl-colibri-eval-v3-u-boot.dtsi | 28 +++- arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi | 36 +++-- .../dts/imx6ull-colibri-eval-v3-u-boot.dtsi | 14 ++ .../arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi | 14 +- .../dts/imx8mm-verdin-wifi-dev-u-boot.dtsi | 16 +- .../dts/imx8mp-verdin-wifi-dev-u-boot.dtsi | 16 +- .../dts/k3-am625-verdin-wifi-dev-u-boot.dtsi | 4 + arch/arm/dts/tegra124-apalis-u-boot.dtsi | 12 ++ arch/arm/dts/tegra20-colibri-u-boot.dtsi | 12 ++ arch/arm/dts/tegra30-apalis-u-boot.dtsi | 12 ++ arch/arm/dts/tegra30-colibri-u-boot.dtsi | 12 ++ .../arm/dts/vf610-colibri-eval-v3-u-boot.dtsi | 4 + board/toradex/apalis-imx8/apalis-imx8.c | 10 -- board/toradex/apalis-tk1/apalis-tk1.c | 7 - board/toradex/apalis_imx6/apalis_imx6.c | 21 --- board/toradex/apalis_t30/apalis_t30.c | 8 - .../toradex/colibri-imx6ull/colibri-imx6ull.c | 7 - board/toradex/colibri-imx8x/colibri-imx8x.c | 10 -- board/toradex/colibri_imx6/colibri_imx6.c | 20 --- board/toradex/colibri_imx7/colibri_imx7.c | 8 - board/toradex/colibri_t20/colibri_t20.c | 10 -- board/toradex/colibri_t30/colibri_t30.c | 7 - board/toradex/colibri_vf/colibri_vf.c | 10 -- board/toradex/common/Kconfig | 1 + board/toradex/common/tdx-common.c | 137 +++++++++++++----- board/toradex/common/tdx-common.h | 1 - configs/apalis-imx8_defconfig | 1 + configs/apalis-tk1_defconfig | 1 + configs/apalis_imx6_defconfig | 4 + configs/apalis_t30_defconfig | 1 + configs/colibri-imx6ull-emmc_defconfig | 4 + configs/colibri-imx6ull_defconfig | 4 + configs/colibri-imx8x_defconfig | 1 + configs/colibri_imx6_defconfig | 4 + configs/colibri_imx7_defconfig | 1 + configs/colibri_imx7_emmc_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/verdin-am62_a53_defconfig | 1 + configs/verdin-imx8mm_defconfig | 1 + configs/verdin-imx8mp_defconfig | 1 + 44 files changed, 283 insertions(+), 194 deletions(-) create mode 100644 arch/arm/dts/tegra124-apalis-u-boot.dtsi create mode 100644 arch/arm/dts/tegra20-colibri-u-boot.dtsi create mode 100644 arch/arm/dts/tegra30-apalis-u-boot.dtsi create mode 100644 arch/arm/dts/tegra30-colibri-u-boot.dtsi
From: Emanuele Ghidoli emanuele.ghidoli@toradex.com
Since checkboard() is used instead of show_board_info(), in case toradex config block is missing or malformed, checkboard is recursively called. It prints a long list of "MISSING TORADEX CONFIG BLOCK" till the stack is full.
Fixes: edb0ecd18708 ("toradex: Use checkboard() instead of show_board_info()") Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com # Verdin iMX8M Plus Signed-off-by: Emanuele Ghidoli emanuele.ghidoli@toradex.com Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- board/toradex/common/tdx-common.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index ed8f0a6a4756..ddc4a175da68 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -103,7 +103,6 @@ int tdx_checkboard(void) if (read_tdx_cfg_block()) { printf("MISSING TORADEX CONFIG BLOCK\n"); get_mac_from_serial(tdx_serial, &tdx_eth_addr); - checkboard(); } else { snprintf(tdx_serial_str, sizeof(tdx_serial_str), "%08u", tdx_serial);
Sysinfo prints the model obtained from device tree, checkboard() take info from hardware and tdx_checkboard() use the model retrieved by toradex config block.
Remove the print from checkboard() function because the model obtained from toradex config block is the most complete. If toradex config block is missing the model info from device tree is enough.
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com # Verdin iMX8M Plus Signed-off-by: Emanuele Ghidoli emanuele.ghidoli@toradex.com Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- board/toradex/apalis-imx8/apalis-imx8.c | 10 --------- board/toradex/apalis-tk1/apalis-tk1.c | 7 ------- board/toradex/apalis_imx6/apalis_imx6.c | 21 ------------------- board/toradex/apalis_t30/apalis_t30.c | 8 ------- .../toradex/colibri-imx6ull/colibri-imx6ull.c | 7 ------- board/toradex/colibri-imx8x/colibri-imx8x.c | 10 --------- board/toradex/colibri_imx6/colibri_imx6.c | 20 ------------------ board/toradex/colibri_imx7/colibri_imx7.c | 8 ------- board/toradex/colibri_t20/colibri_t20.c | 10 --------- board/toradex/colibri_t30/colibri_t30.c | 7 ------- board/toradex/colibri_vf/colibri_vf.c | 10 --------- board/toradex/common/tdx-common.c | 9 +++++++- board/toradex/common/tdx-common.h | 1 - 13 files changed, 8 insertions(+), 120 deletions(-)
diff --git a/board/toradex/apalis-imx8/apalis-imx8.c b/board/toradex/apalis-imx8/apalis-imx8.c index b351ce64abfc..2483a63c6733 100644 --- a/board/toradex/apalis-imx8/apalis-imx8.c +++ b/board/toradex/apalis-imx8/apalis-imx8.c @@ -208,16 +208,6 @@ void board_preboot_os(void) gpio_direction_output(BKL1_GPIO, 0); }
-int checkboard(void) -{ - puts("Model: Toradex Apalis iMX8\n"); - - build_info(); - print_bootinfo(); - - return tdx_checkboard(); -} - static enum pcb_rev_t get_pcb_revision(void) { unsigned int pcb_vers = 0; diff --git a/board/toradex/apalis-tk1/apalis-tk1.c b/board/toradex/apalis-tk1/apalis-tk1.c index 79a1c92da0a0..ee87d9f4145f 100644 --- a/board/toradex/apalis-tk1/apalis-tk1.c +++ b/board/toradex/apalis-tk1/apalis-tk1.c @@ -91,13 +91,6 @@ int arch_misc_init(void) return 0; }
-int checkboard(void) -{ - puts("Model: Toradex Apalis TK1 2GB\n"); - - return tdx_checkboard(); -} - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 164fcc41f550..0da245374a0d 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -716,27 +716,6 @@ int board_late_init(void) } #endif /* CONFIG_BOARD_LATE_INIT */
-int checkboard(void) -{ - char it[] = " IT"; - int minc, maxc; - - switch (get_cpu_temp_grade(&minc, &maxc)) { - case TEMP_AUTOMOTIVE: - case TEMP_INDUSTRIAL: - break; - case TEMP_EXTCOMMERCIAL: - default: - it[0] = 0; - }; - printf("Model: Toradex Apalis iMX6 %s %s%s\n", - is_cpu_type(MXC_CPU_MX6D) ? "Dual" : "Quad", - (gd->ram_size == 0x80000000) ? "2GB" : - (gd->ram_size == 0x40000000) ? "1GB" : "512MB", it); - - return tdx_checkboard(); -} - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/toradex/apalis_t30/apalis_t30.c b/board/toradex/apalis_t30/apalis_t30.c index b9a2af33f19f..b10beb447965 100644 --- a/board/toradex/apalis_t30/apalis_t30.c +++ b/board/toradex/apalis_t30/apalis_t30.c @@ -45,14 +45,6 @@ int arch_misc_init(void) return 0; }
-int checkboard(void) -{ - printf("Model: Toradex Apalis T30 %dGB\n", - (gd->ram_size == 0x40000000) ? 1 : 2); - - return tdx_checkboard(); -} - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/toradex/colibri-imx6ull/colibri-imx6ull.c b/board/toradex/colibri-imx6ull/colibri-imx6ull.c index a775f54eb3f4..9b9fb342c9d9 100644 --- a/board/toradex/colibri-imx6ull/colibri-imx6ull.c +++ b/board/toradex/colibri-imx6ull/colibri-imx6ull.c @@ -205,13 +205,6 @@ int board_late_init(void) return 0; }
-int checkboard(void) -{ - printf("Model: Toradex Colibri iMX6ULL\n"); - - return tdx_checkboard(); -} - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/toradex/colibri-imx8x/colibri-imx8x.c b/board/toradex/colibri-imx8x/colibri-imx8x.c index d8cc72f323c5..2c673a4a6b06 100644 --- a/board/toradex/colibri-imx8x/colibri-imx8x.c +++ b/board/toradex/colibri-imx8x/colibri-imx8x.c @@ -114,16 +114,6 @@ int board_phy_config(struct phy_device *phydev) } #endif
-int checkboard(void) -{ - puts("Model: Toradex Colibri iMX8X\n"); - - build_info(); - print_bootinfo(); - - return tdx_checkboard(); -} - static void select_dt_from_module_version(void) { /* diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index 784ca7f65f7b..ce19a9c79752 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -636,26 +636,6 @@ int board_late_init(void) } #endif /* CONFIG_BOARD_LATE_INIT */
-int checkboard(void) -{ - char it[] = " IT"; - int minc, maxc; - - switch (get_cpu_temp_grade(&minc, &maxc)) { - case TEMP_AUTOMOTIVE: - case TEMP_INDUSTRIAL: - break; - case TEMP_EXTCOMMERCIAL: - default: - it[0] = 0; - }; - printf("Model: Toradex Colibri iMX6 %s %sMB%s\n", - is_cpu_type(MXC_CPU_MX6DL) ? "DualLite" : "Solo", - (gd->ram_size == 0x20000000) ? "512" : "256", it); - - return tdx_checkboard(); -} - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/toradex/colibri_imx7/colibri_imx7.c b/board/toradex/colibri_imx7/colibri_imx7.c index 2e5b02f72675..c37c5e0af6d9 100644 --- a/board/toradex/colibri_imx7/colibri_imx7.c +++ b/board/toradex/colibri_imx7/colibri_imx7.c @@ -273,14 +273,6 @@ void reset_cpu(void) } #endif
-int checkboard(void) -{ - printf("Model: Toradex Colibri iMX7%c\n", - is_cpu_type(MXC_CPU_MX7D) ? 'D' : 'S'); - - return tdx_checkboard(); -} - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/toradex/colibri_t20/colibri_t20.c b/board/toradex/colibri_t20/colibri_t20.c index 5861cf7dc93e..97e33d00f0d6 100644 --- a/board/toradex/colibri_t20/colibri_t20.c +++ b/board/toradex/colibri_t20/colibri_t20.c @@ -70,16 +70,6 @@ int arch_misc_init(void) return 0; }
-int checkboard(void) -{ - printf("Model: Toradex Colibri T20 %dMB V%s\n", - (gd->ram_size == 0x10000000) ? 256 : 512, - (get_nand_dev_by_index(0)->erasesize >> 10 == 512) ? - ((gd->ram_size == 0x10000000) ? "1.1B" : "1.1C") : "1.2A"); - - return tdx_checkboard(); -} - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/toradex/colibri_t30/colibri_t30.c b/board/toradex/colibri_t30/colibri_t30.c index 8cef098c8e59..0da247de98f9 100644 --- a/board/toradex/colibri_t30/colibri_t30.c +++ b/board/toradex/colibri_t30/colibri_t30.c @@ -28,13 +28,6 @@ int arch_misc_init(void) return 0; }
-int checkboard(void) -{ - puts("Model: Toradex Colibri T30 1GB\n"); - - return tdx_checkboard(); -} - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index af9f2d379cf4..35920008805f 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -366,16 +366,6 @@ int board_init(void) return 0; }
-int checkboard(void) -{ - if (is_colibri_vf61()) - puts("Model: Toradex Colibri VF61\n"); - else - puts("Model: Toradex Colibri VF50\n"); - - return tdx_checkboard(); -} - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index ddc4a175da68..cdf645b14177 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -96,7 +96,12 @@ static const char *get_board_assembly(u16 ver_assembly) return ver_name; }
-int tdx_checkboard(void) +__weak int print_bootinfo(void) +{ + return 0; +} + +int checkboard(void) { unsigned char ethaddr[6];
@@ -144,6 +149,8 @@ int tdx_checkboard(void) #endif }
+ print_bootinfo(); + /* * Check if environment contains a valid MAC address, * set the one from config block if not diff --git a/board/toradex/common/tdx-common.h b/board/toradex/common/tdx-common.h index 44234dc49cd7..d446e9f1d5ca 100644 --- a/board/toradex/common/tdx-common.h +++ b/board/toradex/common/tdx-common.h @@ -11,6 +11,5 @@
int ft_common_board_setup(void *blob, struct bd_info *bd); u32 get_board_revision(void); -int tdx_checkboard(void);
#endif /* _TDX_COMMON_H */
Use SETTINGS_R event to read toradex config block and checkboard() to print board info.
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com # Verdin iMX8M Plus Signed-off-by: Emanuele Ghidoli emanuele.ghidoli@toradex.com Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- board/toradex/common/tdx-common.c | 92 ++++++++++++++++++------------- 1 file changed, 54 insertions(+), 38 deletions(-)
diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index cdf645b14177..6084436b48b4 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -103,54 +103,69 @@ __weak int print_bootinfo(void)
int checkboard(void) { - unsigned char ethaddr[6]; - - if (read_tdx_cfg_block()) { - printf("MISSING TORADEX CONFIG BLOCK\n"); - get_mac_from_serial(tdx_serial, &tdx_eth_addr); - } else { - snprintf(tdx_serial_str, sizeof(tdx_serial_str), - "%08u", tdx_serial); - snprintf(tdx_board_rev_str, sizeof(tdx_board_rev_str), - "V%1d.%1d%s", - tdx_hw_tag.ver_major, - tdx_hw_tag.ver_minor, - get_board_assembly(tdx_hw_tag.ver_assembly)); - - env_set("serial#", tdx_serial_str); - + if (valid_cfgblock) { printf("Model: Toradex %04d %s %s\n", tdx_hw_tag.prodid, toradex_modules[tdx_hw_tag.prodid].name, tdx_board_rev_str); printf("Serial#: %s\n", tdx_serial_str); + } + #ifdef CONFIG_TDX_CFG_BLOCK_EXTRA - if (read_tdx_cfg_block_carrier()) { - printf("MISSING TORADEX CARRIER CONFIG BLOCKS\n"); - try_migrate_tdx_cfg_block_carrier(); - } else { - tdx_carrier_board_name = - get_toradex_carrier_boards(tdx_car_hw_tag.prodid); - - snprintf(tdx_car_serial_str, sizeof(tdx_car_serial_str), - "%08u", tdx_car_serial); - snprintf(tdx_car_rev_str, sizeof(tdx_car_rev_str), - "V%1d.%1d%s", - tdx_car_hw_tag.ver_major, - tdx_car_hw_tag.ver_minor, - get_board_assembly(tdx_car_hw_tag.ver_assembly)); - - env_set("carrier_serial#", tdx_car_serial_str); - printf("Carrier: Toradex %s %s, Serial# %s\n", - tdx_carrier_board_name, - tdx_car_rev_str, - tdx_car_serial_str); - } + if (tdx_carrier_board_name) + printf("Carrier: Toradex %s %s, Serial# %s\n", + tdx_carrier_board_name, + tdx_car_rev_str, + tdx_car_serial_str); #endif - }
print_bootinfo();
+ return 0; +} + +static int settings_r(void) +{ + unsigned char ethaddr[6]; + + if (read_tdx_cfg_block()) { + printf("MISSING TORADEX CONFIG BLOCK\n"); + get_mac_from_serial(tdx_serial, &tdx_eth_addr); + + /* Board can run even if config block is not present */ + return 0; + } + + snprintf(tdx_serial_str, sizeof(tdx_serial_str), + "%08u", tdx_serial); + snprintf(tdx_board_rev_str, sizeof(tdx_board_rev_str), + "V%1d.%1d%s", + tdx_hw_tag.ver_major, + tdx_hw_tag.ver_minor, + get_board_assembly(tdx_hw_tag.ver_assembly)); + + env_set("serial#", tdx_serial_str); + +#ifdef CONFIG_TDX_CFG_BLOCK_EXTRA + if (read_tdx_cfg_block_carrier()) { + printf("MISSING TORADEX CARRIER CONFIG BLOCKS\n"); + try_migrate_tdx_cfg_block_carrier(); + } else { + tdx_carrier_board_name = + get_toradex_carrier_boards(tdx_car_hw_tag.prodid); + + snprintf(tdx_car_serial_str, sizeof(tdx_car_serial_str), + "%08u", tdx_car_serial); + snprintf(tdx_car_rev_str, sizeof(tdx_car_rev_str), + "V%1d.%1d%s", + tdx_car_hw_tag.ver_major, + tdx_car_hw_tag.ver_minor, + get_board_assembly(tdx_car_hw_tag.ver_assembly)); + + env_set("carrier_serial#", tdx_car_serial_str); + } +#endif + /* * Check if environment contains a valid MAC address, * set the one from config block if not @@ -171,6 +186,7 @@ int checkboard(void)
return 0; } +EVENT_SPY_SIMPLE(EVT_SETTINGS_R, settings_r);
#ifdef CONFIG_TDX_CFG_BLOCK_USB_GADGET_PID int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name)
Use the common syntax to define aliases.
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com # Verdin iMX8M Plus Signed-off-by: Emanuele Ghidoli emanuele.ghidoli@toradex.com Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- .../dts/imx6dl-colibri-eval-v3-u-boot.dtsi | 18 ++++++++----- arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi | 26 ++++++++++--------- .../arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi | 10 ++++--- .../dts/imx8mm-verdin-wifi-dev-u-boot.dtsi | 12 ++++----- .../dts/imx8mp-verdin-wifi-dev-u-boot.dtsi | 12 ++++----- 5 files changed, 43 insertions(+), 35 deletions(-)
diff --git a/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi b/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi index 31f3a48dd9f0..0eea4d1862ae 100644 --- a/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi +++ b/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi @@ -5,13 +5,17 @@
#include "imx6qdl-u-boot.dtsi"
-&{/aliases} { - /* U-Boot won't find PMIC otherwise */ - i2c0 = &i2c3; - i2c1 = &i2c2; - /* SDHCI instance order: eMMC, 4-bit SD/MMC (U-Boot won't find ConfigBlock otherwise) */ - mmc0 = &usdhc3; - mmc1 = &usdhc1; +/ { + aliases { + /* U-Boot won't find PMIC otherwise */ + i2c0 = &i2c3; + i2c1 = &i2c2; + /* SDHCI instance order: eMMC, 4-bit SD/MMC + * (U-Boot won't find ConfigBlock otherwise) + */ + mmc0 = &usdhc3; + mmc1 = &usdhc1; + }; };
&wdog1 { diff --git a/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi b/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi index 3d19796cb698..3c6e503d043b 100644 --- a/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi +++ b/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi @@ -5,18 +5,20 @@
-&{/aliases} { - /* U-Boot won't find PMIC otherwise */ - i2c0 = &i2c1; - i2c1 = &i2c2; - i2c2 = &i2c3; - /* - * SDHCI instance order: eMMC, 8-bit SD/MMC, 4-bit SD - * (U-Boot won't find ConfigBlock otherwise) - */ - mmc0 = &usdhc3; - mmc1 = &usdhc1; - mmc2 = &usdhc2; +/ { + aliases { + /* U-Boot won't find PMIC otherwise */ + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + /* + * SDHCI instance order: eMMC, 8-bit SD/MMC, 4-bit SD + * (U-Boot won't find ConfigBlock otherwise) + */ + mmc0 = &usdhc3; + mmc1 = &usdhc1; + mmc2 = &usdhc2; + }; };
&wdog1 { diff --git a/arch/arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi b/arch/arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi index 57ca28edb70d..b2c12a413daf 100644 --- a/arch/arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi +++ b/arch/arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi @@ -5,10 +5,12 @@
#include "imx7s-u-boot.dtsi"
-&{/aliases} { - /* SDHCI instance order: eMMC, SD/MMC */ - mmc0 = &usdhc3; - mmc1 = &usdhc1; +/ { + aliases { + /* SDHCI instance order: eMMC, SD/MMC */ + mmc0 = &usdhc3; + mmc1 = &usdhc1; + }; };
&lcdif { diff --git a/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi index 8efa4ddc734a..515f195ab759 100644 --- a/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi @@ -6,6 +6,12 @@ #include "imx8mm-u-boot.dtsi"
/ { + aliases { + eeprom0 = &eeprom_module; + eeprom1 = &eeprom_carrier_board; + eeprom2 = &eeprom_display_adapter; + }; + wdt-reboot { compatible = "wdt-reboot"; bootph-pre-ram; @@ -13,12 +19,6 @@ }; };
-&{/aliases} { - eeprom0 = &eeprom_module; - eeprom1 = &eeprom_carrier_board; - eeprom2 = &eeprom_display_adapter; -}; - &{/soc@0/bus@30800000/i2c@30a20000/pmic@25} { bootph-pre-ram; }; diff --git a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi index 2a1aa1935a76..67f1d45ce269 100644 --- a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi @@ -6,6 +6,12 @@ #include "imx8mp-u-boot.dtsi"
-&{/aliases} { - eeprom0 = &eeprom_module; - eeprom1 = &eeprom_carrier_board; - eeprom2 = &eeprom_display_adapter; -}; - &clk { bootph-all; bootph-pre-ram;
This commit introduces support for the Toradex sysinfo driver in U-Boot, which uses information from Toradex config block to print correct board model. In case the Toradex config block is not present sysinfo prints the model of the board provided by device tree removing per board specific prints.
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com # Verdin iMX8M Plus Signed-off-by: Emanuele Ghidoli emanuele.ghidoli@toradex.com Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi | 6 +++ arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi | 6 +++ .../dts/imx6dl-colibri-eval-v3-u-boot.dtsi | 4 ++ arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi | 4 ++ .../dts/imx6ull-colibri-eval-v3-u-boot.dtsi | 4 ++ .../arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi | 4 ++ .../dts/imx8mm-verdin-wifi-dev-u-boot.dtsi | 4 ++ .../dts/imx8mp-verdin-wifi-dev-u-boot.dtsi | 4 ++ .../dts/k3-am625-verdin-wifi-dev-u-boot.dtsi | 4 ++ arch/arm/dts/tegra124-apalis-u-boot.dtsi | 12 +++++ arch/arm/dts/tegra20-colibri-u-boot.dtsi | 12 +++++ arch/arm/dts/tegra30-apalis-u-boot.dtsi | 12 +++++ arch/arm/dts/tegra30-colibri-u-boot.dtsi | 12 +++++ .../arm/dts/vf610-colibri-eval-v3-u-boot.dtsi | 4 ++ board/toradex/common/Kconfig | 1 + board/toradex/common/tdx-common.c | 50 ++++++++++++++++--- 16 files changed, 136 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/tegra124-apalis-u-boot.dtsi create mode 100644 arch/arm/dts/tegra20-colibri-u-boot.dtsi create mode 100644 arch/arm/dts/tegra30-apalis-u-boot.dtsi create mode 100644 arch/arm/dts/tegra30-colibri-u-boot.dtsi
diff --git a/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi b/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi index c54a59e89c5d..d73be74d2112 100644 --- a/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi @@ -3,6 +3,12 @@ * Copyright 2019 Toradex AG */
+/ { + sysinfo { + compatible = "toradex,sysinfo"; + }; +}; + &mu { bootph-some-ram; }; diff --git a/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi index 6ab6b1f9ee69..60c4cd6fc01f 100644 --- a/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi @@ -3,6 +3,12 @@ * Copyright 2019 Toradex AG */
+/ { + sysinfo { + compatible = "toradex,sysinfo"; + }; +}; + &{/imx8qx-pm} {
bootph-some-ram; diff --git a/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi b/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi index 0eea4d1862ae..5a91d0aca204 100644 --- a/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi +++ b/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi @@ -16,6 +16,10 @@ mmc0 = &usdhc3; mmc1 = &usdhc1; }; + + sysinfo { + compatible = "toradex,sysinfo"; + }; };
&wdog1 { diff --git a/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi b/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi index 3c6e503d043b..59412635420a 100644 --- a/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi +++ b/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi @@ -19,6 +19,10 @@ mmc1 = &usdhc1; mmc2 = &usdhc2; }; + + sysinfo { + compatible = "toradex,sysinfo"; + }; };
&wdog1 { diff --git a/arch/arm/dts/imx6ull-colibri-eval-v3-u-boot.dtsi b/arch/arm/dts/imx6ull-colibri-eval-v3-u-boot.dtsi index 6823b42d4514..731814216e1f 100644 --- a/arch/arm/dts/imx6ull-colibri-eval-v3-u-boot.dtsi +++ b/arch/arm/dts/imx6ull-colibri-eval-v3-u-boot.dtsi @@ -9,6 +9,10 @@ usb0 = &usbotg1; /* required for ums */ display0 = &lcdif; }; + + sysinfo { + compatible = "toradex,sysinfo"; + }; };
&pinctrl_uart1 { diff --git a/arch/arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi b/arch/arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi index b2c12a413daf..68142769d360 100644 --- a/arch/arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi +++ b/arch/arm/dts/imx7d-colibri-eval-v3-u-boot.dtsi @@ -11,6 +11,10 @@ mmc0 = &usdhc3; mmc1 = &usdhc1; }; + + sysinfo { + compatible = "toradex,sysinfo"; + }; };
&lcdif { diff --git a/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi index 515f195ab759..38db56059d69 100644 --- a/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi @@ -12,6 +12,10 @@ eeprom2 = &eeprom_display_adapter; };
+ sysinfo { + compatible = "toradex,sysinfo"; + }; + wdt-reboot { compatible = "wdt-reboot"; bootph-pre-ram; diff --git a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi index 67f1d45ce269..03f211d5f7d3 100644 --- a/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi @@ -12,6 +12,10 @@ eeprom2 = &eeprom_display_adapter; };
+ sysinfo { + compatible = "toradex,sysinfo"; + }; + wdt-reboot { compatible = "wdt-reboot"; bootph-pre-ram; diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi index 02f34c90c6d7..28b697b67ae0 100644 --- a/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi @@ -19,6 +19,10 @@ memory@80000000 { bootph-all; }; + + sysinfo { + compatible = "toradex,sysinfo"; + }; };
&main_timer0 { diff --git a/arch/arm/dts/tegra124-apalis-u-boot.dtsi b/arch/arm/dts/tegra124-apalis-u-boot.dtsi new file mode 100644 index 000000000000..a3614d279439 --- /dev/null +++ b/arch/arm/dts/tegra124-apalis-u-boot.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + */ + +#include "tegra124-u-boot.dtsi" + +/ { + sysinfo { + compatible = "toradex,sysinfo"; + }; +}; diff --git a/arch/arm/dts/tegra20-colibri-u-boot.dtsi b/arch/arm/dts/tegra20-colibri-u-boot.dtsi new file mode 100644 index 000000000000..d4a669a288d8 --- /dev/null +++ b/arch/arm/dts/tegra20-colibri-u-boot.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + */ + +#include "tegra20-u-boot.dtsi" + +/ { + sysinfo { + compatible = "toradex,sysinfo"; + }; +}; diff --git a/arch/arm/dts/tegra30-apalis-u-boot.dtsi b/arch/arm/dts/tegra30-apalis-u-boot.dtsi new file mode 100644 index 000000000000..37cbfbcc3506 --- /dev/null +++ b/arch/arm/dts/tegra30-apalis-u-boot.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + */ + +#include "tegra30-u-boot.dtsi" + +/ { + sysinfo { + compatible = "toradex,sysinfo"; + }; +}; diff --git a/arch/arm/dts/tegra30-colibri-u-boot.dtsi b/arch/arm/dts/tegra30-colibri-u-boot.dtsi new file mode 100644 index 000000000000..37cbfbcc3506 --- /dev/null +++ b/arch/arm/dts/tegra30-colibri-u-boot.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2023 Toradex + */ + +#include "tegra30-u-boot.dtsi" + +/ { + sysinfo { + compatible = "toradex,sysinfo"; + }; +}; diff --git a/arch/arm/dts/vf610-colibri-eval-v3-u-boot.dtsi b/arch/arm/dts/vf610-colibri-eval-v3-u-boot.dtsi index 572d40877ef9..8c3b86c201fa 100644 --- a/arch/arm/dts/vf610-colibri-eval-v3-u-boot.dtsi +++ b/arch/arm/dts/vf610-colibri-eval-v3-u-boot.dtsi @@ -7,6 +7,10 @@ soc { bootph-all; }; + + sysinfo { + compatible = "toradex,sysinfo"; + }; };
&aips0 { diff --git a/board/toradex/common/Kconfig b/board/toradex/common/Kconfig index 1f6a5e4db561..b85893ab44e4 100644 --- a/board/toradex/common/Kconfig +++ b/board/toradex/common/Kconfig @@ -4,6 +4,7 @@ menuconfig TDX_CFG_BLOCK bool "Enable Toradex config block support" select OF_BOARD_SETUP + select SYSINFO help The Toradex config block stored production data on the on-module flash device (NAND, NOR or eMMC). The area is normally preserved by diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index 6084436b48b4..1f3253f4222e 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -3,15 +3,16 @@ * Copyright (c) 2016 Toradex, Inc. */
+#include <dm.h> #include <common.h> #include <env.h> #include <g_dnl.h> #include <init.h> #include <linux/libfdt.h> +#include <sysinfo.h>
#ifdef CONFIG_VIDEO #include <bmp_logo.h> -#include <dm.h> #include <splash.h> #include <video.h> #endif @@ -103,13 +104,8 @@ __weak int print_bootinfo(void)
int checkboard(void) { - if (valid_cfgblock) { - printf("Model: Toradex %04d %s %s\n", - tdx_hw_tag.prodid, - toradex_modules[tdx_hw_tag.prodid].name, - tdx_board_rev_str); + if (valid_cfgblock) printf("Serial#: %s\n", tdx_serial_str); - }
#ifdef CONFIG_TDX_CFG_BLOCK_EXTRA if (tdx_carrier_board_name) @@ -188,6 +184,46 @@ static int settings_r(void) } EVENT_SPY_SIMPLE(EVT_SETTINGS_R, settings_r);
+static int tdx_detect(struct udevice *dev) +{ + return valid_cfgblock ? 0 : -EINVAL; +} + +static int tdx_get_str(struct udevice *dev, int id, size_t size, char *val) +{ + int ret = -ENOTSUPP; + + switch (id) { + case SYSINFO_ID_BOARD_MODEL: + snprintf(val, size, + "Toradex %04d %s %s", + tdx_hw_tag.prodid, + toradex_modules[tdx_hw_tag.prodid].name, + tdx_board_rev_str); + + ret = 0; + } + + return ret; +} + +static const struct udevice_id sysinfo_tdx_ids[] = { + { .compatible = "toradex,sysinfo" }, + { /* sentinel */ } +}; + +static const struct sysinfo_ops sysinfo_tdx_ops = { + .detect = tdx_detect, + .get_str = tdx_get_str, +}; + +U_BOOT_DRIVER(sysinfo_toradex) = { + .name = "sysinfo_toradex", + .id = UCLASS_SYSINFO, + .of_match = sysinfo_tdx_ids, + .ops = &sysinfo_tdx_ops, +}; + #ifdef CONFIG_TDX_CFG_BLOCK_USB_GADGET_PID int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) {
Set CONFIG_NET_RANDOM_ETHADDR=y, which sets random eth address in case there is no toradex config block programmed. In case of missing toradex config block the generated mac address was always the same, linked to serial number 0. Use random generated mac address instead.
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com # Verdin iMX8M Plus Signed-off-by: Emanuele Ghidoli emanuele.ghidoli@toradex.com Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- v2: remove CONFIG_NET_RANDOM_ETHADDR from verdin am62 r5 --- board/toradex/common/tdx-common.c | 1 - configs/apalis-imx8_defconfig | 1 + configs/apalis-tk1_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/colibri-imx6ull-emmc_defconfig | 1 + configs/colibri-imx6ull_defconfig | 1 + configs/colibri-imx8x_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colibri_imx7_emmc_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/verdin-am62_a53_defconfig | 1 + configs/verdin-imx8mm_defconfig | 1 + configs/verdin-imx8mp_defconfig | 1 + 17 files changed, 16 insertions(+), 1 deletion(-)
diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index 1f3253f4222e..9f09788137d5 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -126,7 +126,6 @@ static int settings_r(void)
if (read_tdx_cfg_block()) { printf("MISSING TORADEX CONFIG BLOCK\n"); - get_mac_from_serial(tdx_serial, &tdx_eth_addr);
/* Board can run even if config block is not present */ return 0; diff --git a/configs/apalis-imx8_defconfig b/configs/apalis-imx8_defconfig index 982098d81420..da3b0e254899 100644 --- a/configs/apalis-imx8_defconfig +++ b/configs/apalis-imx8_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_TFTP_TSIZE=y diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 6ed3898b60c3..20c9c06cdeac 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -52,6 +52,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_TFTP_TSIZE=y diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 05ff6fa115ce..492550607035 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -75,6 +75,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_USE_IPADDR=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 0a27509a97e6..03a1f2c23906 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -45,6 +45,7 @@ CONFIG_OF_LIVE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_TFTP_TSIZE=y diff --git a/configs/colibri-imx6ull-emmc_defconfig b/configs/colibri-imx6ull-emmc_defconfig index 285fed9e4faf..2b04855770ab 100644 --- a/configs/colibri-imx6ull-emmc_defconfig +++ b/configs/colibri-imx6ull-emmc_defconfig @@ -51,6 +51,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_TFTP_TSIZE=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index a8a633063d00..959930cf2e31 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -60,6 +60,7 @@ CONFIG_ENV_RANGE=0x80000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_TFTP_TSIZE=y diff --git a/configs/colibri-imx8x_defconfig b/configs/colibri-imx8x_defconfig index aa18d28d3e6d..88928b0e4bc5 100644 --- a/configs/colibri-imx8x_defconfig +++ b/configs/colibri-imx8x_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_TFTP_TSIZE=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 70cb79531e92..55c71a000d00 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -74,6 +74,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_USE_IPADDR=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index d5c8604f7097..58eb4317857b 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -60,6 +60,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_RANGE=0x80000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_USE_IPADDR=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index ae8406f70de5..3382371d40de 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -51,6 +51,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_USE_IPADDR=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 3c506ffb6877..3405e02ad347 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -50,6 +50,7 @@ CONFIG_OF_LIVE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=1536 CONFIG_TFTP_TSIZE=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index c7012031c0a8..394d656a1260 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -43,6 +43,7 @@ CONFIG_OF_LIVE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=16352 CONFIG_TFTP_TSIZE=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 3d1319cf812e..891637dee741 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -66,6 +66,7 @@ CONFIG_ENV_RANGE=0x80000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_USE_IPADDR=y CONFIG_IPADDR="192.168.10.2" CONFIG_USE_NETMASK=y diff --git a/configs/verdin-am62_a53_defconfig b/configs/verdin-am62_a53_defconfig index 956e3a1ad75e..63e75474ca71 100644 --- a/configs/verdin-am62_a53_defconfig +++ b/configs/verdin-am62_a53_defconfig @@ -104,6 +104,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eth0" CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_SPL_DM=y diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index 0c88982f75c8..4e00fb4008dc 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -90,6 +90,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eth0" CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_SPL_DM=y diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index 22b8a334dfaf..a95edff961b2 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -99,6 +99,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eth0" CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_SPL_DM=y
commit 68dcbdd594d4 ("ARM: imx: Add weak default reset_cpu()") introduced a regression that 'reset' command unable to reset imx6 and imx6ull based Toradex's modules in the u-boot.
This change enables a watchdog-based sysreset driver for Toradex's colibri-imx6, colibri-imx6ull (with nand and emmc) and apalis-imx6 which solves the reset command regression on these modules.
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com Fixes: 68dcbdd594d4 ("ARM: imx: Add weak default reset_cpu()") Signed-off-by: Parth Pancholi parth.pancholi@toradex.com Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi | 6 ++++++ arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi | 6 ++++++ arch/arm/dts/imx6ull-colibri-eval-v3-u-boot.dtsi | 10 ++++++++++ configs/apalis_imx6_defconfig | 3 +++ configs/colibri-imx6ull-emmc_defconfig | 3 +++ configs/colibri-imx6ull_defconfig | 3 +++ configs/colibri_imx6_defconfig | 3 +++ 7 files changed, 34 insertions(+)
diff --git a/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi b/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi index 5a91d0aca204..44baaa803243 100644 --- a/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi +++ b/arch/arm/dts/imx6dl-colibri-eval-v3-u-boot.dtsi @@ -20,6 +20,12 @@ sysinfo { compatible = "toradex,sysinfo"; }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + bootph-pre-ram; + }; };
&wdog1 { diff --git a/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi b/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi index 59412635420a..103605ac930d 100644 --- a/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi +++ b/arch/arm/dts/imx6q-apalis-eval-u-boot.dtsi @@ -23,6 +23,12 @@ sysinfo { compatible = "toradex,sysinfo"; }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + bootph-pre-ram; + }; };
&wdog1 { diff --git a/arch/arm/dts/imx6ull-colibri-eval-v3-u-boot.dtsi b/arch/arm/dts/imx6ull-colibri-eval-v3-u-boot.dtsi index 731814216e1f..8494b1a2c603 100644 --- a/arch/arm/dts/imx6ull-colibri-eval-v3-u-boot.dtsi +++ b/arch/arm/dts/imx6ull-colibri-eval-v3-u-boot.dtsi @@ -13,6 +13,12 @@ sysinfo { compatible = "toradex,sysinfo"; }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + bootph-pre-ram; + }; };
&pinctrl_uart1 { @@ -58,3 +64,7 @@ }; }; }; + +&wdog1 { + bootph-pre-ram; +}; diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 492550607035..fae3dc322471 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -96,6 +96,8 @@ CONFIG_DM_I2C=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y CONFIG_SYS_MXC_I2C3_SPEED=400000 +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y @@ -113,6 +115,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_SCSI=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y CONFIG_USB=y CONFIG_SPL_USB_HOST=y CONFIG_USB_MAX_CONTROLLER_COUNT=2 diff --git a/configs/colibri-imx6ull-emmc_defconfig b/configs/colibri-imx6ull-emmc_defconfig index 2b04855770ab..c4ecdc03e2a8 100644 --- a/configs/colibri-imx6ull-emmc_defconfig +++ b/configs/colibri-imx6ull-emmc_defconfig @@ -69,6 +69,8 @@ CONFIG_FASTBOOT_BUF_ADDR=0x81100000 CONFIG_FASTBOOT_UUU_SUPPORT=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y @@ -83,6 +85,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 959930cf2e31..9c68d96b2fd7 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -80,6 +80,8 @@ CONFIG_FASTBOOT_BUF_ADDR=0x81100000 CONFIG_FASTBOOT_UUU_SUPPORT=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_DM_MTD=y @@ -100,6 +102,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 55c71a000d00..74c54011989c 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -22,6 +22,8 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_CMD_HDMIDETECT=y CONFIG_SYS_LOAD_ADDR=0x14200000 CONFIG_SYS_MEMTEST_START=0x10000000 @@ -109,6 +111,7 @@ CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y CONFIG_USB=y CONFIG_SPL_USB_HOST=y CONFIG_USB_MAX_CONTROLLER_COUNT=2
On Fri, Feb 23, 2024 at 6:11 AM Francesco Dolcini francesco@dolcini.it wrote:
For the series:
Reviewed-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
Francesco Dolcini
