[PATCH v3 0/2] use dt and UCLASS_IRQ/SYSCON to get gic details
Use device tree and driver class (UCLASS_IRQ and UCLASS_SYSCON) to get gic details like GICD, GICR base address, max number of redistributors and git lpi address.
Changes from v2: -Address review comments from Tom Rini, Fix build errors messages.
Changes from v1: -Address review comments from Tom Rini, Fix build warning messages.
Rayagonda Kokatanur (2): arch: arm: use dt and UCLASS_IRQ to get gic details arch: arm: use dt and UCLASS_SYSCON to get gic lpi details
arch/arm/Kconfig | 2 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 28 +---- arch/arm/include/asm/gic-v3.h | 4 +- arch/arm/lib/gic-v3-its.c | 136 +++++++++++++++++++++--- 4 files changed, 127 insertions(+), 43 deletions(-)
Use device tree and UCLASS_IRQ driver to get following Generic Interrupt Controller (GIC) details,
-GIC Distributor interface (GICD) base address and -GIC Redistributors (GICR) base address.
Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com --- Changes from v1: -Address review comments from Tom Rini, Fix build warning messages.
arch/arm/lib/gic-v3-its.c | 73 +++++++++++++++++++++++++++++++++++---- 1 file changed, 66 insertions(+), 7 deletions(-)
diff --git a/arch/arm/lib/gic-v3-its.c b/arch/arm/lib/gic-v3-its.c index 90f37a123c..5057cc5421 100644 --- a/arch/arm/lib/gic-v3-its.c +++ b/arch/arm/lib/gic-v3-its.c @@ -3,6 +3,7 @@ * Copyright 2019 Broadcom. */ #include <common.h> +#include <dm.h> #include <asm/gic.h> #include <asm/gic-v3.h> #include <asm/io.h> @@ -15,6 +16,48 @@ static u32 lpi_id_bits; #define LPI_PROPBASE_SZ ALIGN(BIT(LPI_NRBITS), SZ_64K) #define LPI_PENDBASE_SZ ALIGN(BIT(LPI_NRBITS) / 8, SZ_64K)
+/* + * gic_v3_its_priv - gic details + * + * @gicd_base: gicd base address + * @gicr_base: gicr base address + */ +struct gic_v3_its_priv { + u32 gicd_base; + u32 gicr_base; +}; + +static int gic_v3_its_get_gic_addr(struct gic_v3_its_priv *priv) +{ + struct udevice *dev; + fdt_addr_t addr; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_IRQ, + DM_GET_DRIVER(arm_gic_v3_its), &dev); + if (ret) { + pr_err("%s: failed to get %s irq device\n", __func__, + DM_GET_DRIVER(arm_gic_v3_its)->name); + return ret; + } + + addr = dev_read_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) { + pr_err("%s: failed to get GICD address\n", __func__); + return -EINVAL; + } + priv->gicd_base = addr; + + addr = dev_read_addr_index(dev, 1); + if (addr == FDT_ADDR_T_NONE) { + pr_err("%s: failed to get GICR address\n", __func__); + return -EINVAL; + } + priv->gicr_base = addr; + + return 0; +} + /* * Program the GIC LPI configuration tables for all * the re-distributors and enable the LPI table @@ -23,15 +66,18 @@ static u32 lpi_id_bits; */ int gic_lpi_tables_init(u64 base, u32 num_redist) { + struct gic_v3_its_priv priv; u32 gicd_typer; u64 val; u64 tmp; int i; u64 redist_lpi_base; - u64 pend_base = GICR_BASE + GICR_PENDBASER; + u64 pend_base;
- gicd_typer = readl(GICD_BASE + GICD_TYPER); + if (gic_v3_its_get_gic_addr(&priv)) + return -EINVAL;
+ gicd_typer = readl((uintptr_t)(priv.gicd_base + GICD_TYPER)); /* GIC support for Locality specific peripheral interrupts (LPI's) */ if (!(gicd_typer & GICD_TYPER_LPIS)) { pr_err("GIC implementation does not support LPI's\n"); @@ -46,7 +92,7 @@ int gic_lpi_tables_init(u64 base, u32 num_redist) for (i = 0; i < num_redist; i++) { u32 offset = i * GIC_REDISTRIBUTOR_OFFSET;
- if ((readl((uintptr_t)(GICR_BASE + offset))) & + if ((readl((uintptr_t)(priv.gicr_base + offset))) & GICR_CTLR_ENABLE_LPIS) { pr_err("Re-Distributor %d LPI is already enabled\n", i); @@ -64,19 +110,21 @@ int gic_lpi_tables_init(u64 base, u32 num_redist) GICR_PROPBASER_RAWAWB | ((LPI_NRBITS - 1) & GICR_PROPBASER_IDBITS_MASK));
- writeq(val, (GICR_BASE + GICR_PROPBASER)); - tmp = readl(GICR_BASE + GICR_PROPBASER); + writeq(val, (uintptr_t)(priv.gicr_base + GICR_PROPBASER)); + tmp = readl((uintptr_t)(priv.gicr_base + GICR_PROPBASER)); if ((tmp ^ val) & GICR_PROPBASER_SHAREABILITY_MASK) { if (!(tmp & GICR_PROPBASER_SHAREABILITY_MASK)) { val &= ~(GICR_PROPBASER_SHAREABILITY_MASK | GICR_PROPBASER_CACHEABILITY_MASK); val |= GICR_PROPBASER_NC; - writeq(val, (GICR_BASE + GICR_PROPBASER)); + writeq(val, + (uintptr_t)(priv.gicr_base + GICR_PROPBASER)); } }
redist_lpi_base = base + LPI_PROPBASE_SZ;
+ pend_base = priv.gicr_base + GICR_PENDBASER; for (i = 0; i < num_redist; i++) { u32 offset = i * GIC_REDISTRIBUTOR_OFFSET;
@@ -94,9 +142,20 @@ int gic_lpi_tables_init(u64 base, u32 num_redist) }
/* Enable LPI for the redistributor */ - writel(GICR_CTLR_ENABLE_LPIS, (uintptr_t)(GICR_BASE + offset)); + writel(GICR_CTLR_ENABLE_LPIS, + (uintptr_t)(priv.gicr_base + offset)); }
return 0; }
+static const struct udevice_id gic_v3_its_ids[] = { + { .compatible = "arm,gic-v3" }, + {} +}; + +U_BOOT_DRIVER(arm_gic_v3_its) = { + .name = "gic-v3", + .id = UCLASS_IRQ, + .of_match = gic_v3_its_ids, +};
On Sun, 19 Jul 2020 at 03:35, Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com wrote:
- Copyright 2019 Broadcom.
- gic_v3_its_priv - gic details
- @gicd_base: gicd base address
- @gicr_base: gicr base address
u32 gicd_base;
u32 gicr_base;
ulong I think
fdt_addr_t addr;
int ret;
if (ret) {
return ret;
return -EINVAL;
return -EINVAL;
- Program the GIC LPI configuration tables for all
- the re-distributors and enable the LPI table
u64 pend_base;
return -EINVAL;
writeq(val,
(uintptr_t)(priv.gicr_base + GICR_PROPBASER)); } } redist_lpi_base = base + LPI_PROPBASE_SZ;
(uintptr_t)(priv.gicr_base + offset)); } return 0;
.name = "gic-v3",
.id = UCLASS_IRQ,
2.17.1
Use device tree and UCLASS_SYSCON driver to get Generic Interrupt Controller (GIC) lpi address and maximum GIC redistributors count.
Also update Kconfig to select REGMAP and SYSCON when GIC_V3_ITS is enabled.
Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com --- Changes from v2: -Address review comments from Tom Rini, Fix build errors messages.
arch/arm/Kconfig | 2 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 28 +---------- arch/arm/include/asm/gic-v3.h | 4 +- arch/arm/lib/gic-v3-its.c | 63 ++++++++++++++++++++++--- 4 files changed, 61 insertions(+), 36 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index e16fe03887..f88229d092 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -64,6 +64,8 @@ endif
config GIC_V3_ITS bool "ARM GICV3 ITS" + select REGMAP + select SYSCON help ARM GICV3 Interrupt translation service (ITS). Basic support for programming locality specific peripheral diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index ad7ea05935..135fe4a462 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -41,37 +41,11 @@ DECLARE_GLOBAL_DATA_PTR; #endif
#ifdef CONFIG_GIC_V3_ITS -#define PENDTABLE_MAX_SZ ALIGN(BIT(ITS_MAX_LPI_NRBITS), SZ_64K) -#define PROPTABLE_MAX_SZ ALIGN(BIT(ITS_MAX_LPI_NRBITS) / 8, SZ_64K) -#define GIC_LPI_SIZE ALIGN(cpu_numcores() * PENDTABLE_MAX_SZ + \ - PROPTABLE_MAX_SZ, SZ_1M) -static int fdt_add_resv_mem_gic_rd_tables(void *blob, u64 base, size_t size) -{ - u32 phandle; - int err; - struct fdt_memory gic_rd_tables; - - gic_rd_tables.start = base; - gic_rd_tables.end = base + size - 1; - err = fdtdec_add_reserved_memory(blob, "gic-rd-tables", &gic_rd_tables, - &phandle); - if (err < 0) - debug("%s: failed to add reserved memory: %d\n", __func__, err); - - return err; -} - int ls_gic_rd_tables_init(void *blob) { - u64 gic_lpi_base; int ret;
- gic_lpi_base = ALIGN(gd->arch.resv_ram - GIC_LPI_SIZE, SZ_64K); - ret = fdt_add_resv_mem_gic_rd_tables(blob, gic_lpi_base, GIC_LPI_SIZE); - if (ret) - return ret; - - ret = gic_lpi_tables_init(gic_lpi_base, cpu_numcores()); + ret = gic_lpi_tables_init(); if (ret) debug("%s: failed to init gic-lpi-tables\n", __func__);
diff --git a/arch/arm/include/asm/gic-v3.h b/arch/arm/include/asm/gic-v3.h index 5131fabec4..35efec78c3 100644 --- a/arch/arm/include/asm/gic-v3.h +++ b/arch/arm/include/asm/gic-v3.h @@ -127,9 +127,9 @@ #define GIC_REDISTRIBUTOR_OFFSET 0x20000
#ifdef CONFIG_GIC_V3_ITS -int gic_lpi_tables_init(u64 base, u32 max_redist); +int gic_lpi_tables_init(void); #else -int gic_lpi_tables_init(u64 base, u32 max_redist) +int gic_lpi_tables_init(void) { return 0; } diff --git a/arch/arm/lib/gic-v3-its.c b/arch/arm/lib/gic-v3-its.c index 5057cc5421..5e82bdf568 100644 --- a/arch/arm/lib/gic-v3-its.c +++ b/arch/arm/lib/gic-v3-its.c @@ -4,6 +4,8 @@ */ #include <common.h> #include <dm.h> +#include <regmap.h> +#include <syscon.h> #include <asm/gic.h> #include <asm/gic-v3.h> #include <asm/io.h> @@ -16,15 +18,22 @@ static u32 lpi_id_bits; #define LPI_PROPBASE_SZ ALIGN(BIT(LPI_NRBITS), SZ_64K) #define LPI_PENDBASE_SZ ALIGN(BIT(LPI_NRBITS) / 8, SZ_64K)
+/* Number of GIC re-distributors */ +#define MAX_GIC_REDISTRIBUTORS 8 + /* * gic_v3_its_priv - gic details * * @gicd_base: gicd base address * @gicr_base: gicr base address + * @lpi_base: gic lpi base address + * @num_redist: number of gic re-distributors */ struct gic_v3_its_priv { u32 gicd_base; u32 gicr_base; + u32 lpi_base; + u32 num_redist; };
static int gic_v3_its_get_gic_addr(struct gic_v3_its_priv *priv) @@ -58,13 +67,39 @@ static int gic_v3_its_get_gic_addr(struct gic_v3_its_priv *priv) return 0; }
+static int gic_v3_its_get_gic_lpi_addr(struct gic_v3_its_priv *priv) +{ + struct regmap *regmap; + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_SYSCON, + DM_GET_DRIVER(gic_lpi_syscon), &dev); + if (ret) { + pr_err("%s: failed to get %s syscon device\n", __func__, + DM_GET_DRIVER(gic_lpi_syscon)->name); + return ret; + } + + regmap = syscon_get_regmap(dev); + if (!regmap) { + pr_err("%s: failed to regmap for %s syscon device\n", __func__, + DM_GET_DRIVER(gic_lpi_syscon)->name); + return -ENODEV; + } + priv->lpi_base = regmap->ranges[0].start; + + priv->num_redist = dev_read_u32_default(dev, "max-gic-redistributors", + MAX_GIC_REDISTRIBUTORS); + + return 0; +} + /* * Program the GIC LPI configuration tables for all * the re-distributors and enable the LPI table - * base: Configuration table address - * num_redist: number of redistributors */ -int gic_lpi_tables_init(u64 base, u32 num_redist) +int gic_lpi_tables_init(void) { struct gic_v3_its_priv priv; u32 gicd_typer; @@ -77,6 +112,9 @@ int gic_lpi_tables_init(u64 base, u32 num_redist) if (gic_v3_its_get_gic_addr(&priv)) return -EINVAL;
+ if (gic_v3_its_get_gic_lpi_addr(&priv)) + return -EINVAL; + gicd_typer = readl((uintptr_t)(priv.gicd_base + GICD_TYPER)); /* GIC support for Locality specific peripheral interrupts (LPI's) */ if (!(gicd_typer & GICD_TYPER_LPIS)) { @@ -89,7 +127,7 @@ int gic_lpi_tables_init(u64 base, u32 num_redist) * Once the LPI table is enabled, can not program the * LPI configuration tables again, unless the GIC is reset. */ - for (i = 0; i < num_redist; i++) { + for (i = 0; i < priv.num_redist; i++) { u32 offset = i * GIC_REDISTRIBUTOR_OFFSET;
if ((readl((uintptr_t)(priv.gicr_base + offset))) & @@ -105,7 +143,7 @@ int gic_lpi_tables_init(u64 base, u32 num_redist) ITS_MAX_LPI_NRBITS);
/* Set PropBase */ - val = (base | + val = (priv.lpi_base | GICR_PROPBASER_INNERSHAREABLE | GICR_PROPBASER_RAWAWB | ((LPI_NRBITS - 1) & GICR_PROPBASER_IDBITS_MASK)); @@ -122,10 +160,10 @@ int gic_lpi_tables_init(u64 base, u32 num_redist) } }
- redist_lpi_base = base + LPI_PROPBASE_SZ; + redist_lpi_base = priv.lpi_base + LPI_PROPBASE_SZ;
pend_base = priv.gicr_base + GICR_PENDBASER; - for (i = 0; i < num_redist; i++) { + for (i = 0; i < priv.num_redist; i++) { u32 offset = i * GIC_REDISTRIBUTOR_OFFSET;
val = ((redist_lpi_base + (i * LPI_PENDBASE_SZ)) | @@ -159,3 +197,14 @@ U_BOOT_DRIVER(arm_gic_v3_its) = { .id = UCLASS_IRQ, .of_match = gic_v3_its_ids, }; + +static const struct udevice_id gic_lpi_syscon_ids[] = { + { .compatible = "gic-lpi-base" }, + {} +}; + +U_BOOT_DRIVER(gic_lpi_syscon) = { + .name = "gic-lpi-base", + .id = UCLASS_SYSCON, + .of_match = gic_lpi_syscon_ids, +};
Rayagonda Kokatanur
