[PATCH] qemu: common: Fix build with update capsule
The common emulation Makefile has a dependency on a non-existent qemu_capsule.o when building with support for capsule update enabled (CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y). The code which was in qemu_capsule.c has been completely moved to lib/efi_loader/efi_capsule.c by commit 7a6fb28c8e4b ("efi_loader: capsule: add back efi_get_public_key_data()"). Remove the false dependency.
This fixes the following build error:
make[1]: *** No rule to make target 'board/emulation/common/qemu_capsule.o', needed by 'board/emulation/common/built-in.o'. Stop.
Fixes: commit 47a25e81d35c ("Revert "efi_capsule: Move signature from DTB to .rodata"") Signed-off-by: Vincent Stehlé vincent.stehle@arm.com Cc: Simon Glass sjg@chromium.org --- board/emulation/common/Makefile | 1 - 1 file changed, 1 deletion(-)
diff --git a/board/emulation/common/Makefile b/board/emulation/common/Makefile index 7ed447a69dc..c5b452e7e34 100644 --- a/board/emulation/common/Makefile +++ b/board/emulation/common/Makefile @@ -2,4 +2,3 @@
obj-$(CONFIG_SYS_MTDPARTS_RUNTIME) += qemu_mtdparts.o obj-$(CONFIG_SET_DFU_ALT_INFO) += qemu_dfu.o -obj-$(CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT) += qemu_capsule.o
Vincent Stehlé
