Re: [U-Boot] Kernel to U-boot messaging and vice versa.
Thank You Hannes and Andy for replying back.
I agree that the kernel and U-boot are very old. There are many units deployed out in the field which are running these versions. Hence, we are stuck on these old versions.
There are some kernel modules which are running above linux kernel. When we try to field upgrade these deployed units, due to external failures for example power surge, these kernel modules hang in a bad state, which causes the unit unusable. In those conditions we want the unit to go through reset sequence.
Regards, -Dev
From: andy.pont@sdcsystems.com To: dsupehia@hotmail.com CC: u-boot@lists.denx.de Subject: RE: [U-Boot] Kernel to U-boot messaging and vice versa. Date: Tue, 17 Mar 2015 19:15:24 +0000
Dev wrote...
I am new to U-boot development. We are using U-Boot 1.1.4 on a MIPS 74Kc QCA 9557 processor, which is running Linux Kernel 2.6.32.27.
Is there a reason why you have to be running a kernel from 2010 and a version of bootloader that is even older? It makes life much easier to provide support if you can update to more recent versions and you never know they may already have fixed your problems!
We have a situation were our firmware keeps hanging due to some issues.
What is your "firmware" in this context? As you rightly said, once the Linux kernel is running U-Boot is no more and if U-Boot is hanging then you aren't going to get to the kernel anyway!
We are looking into a solution where U-boot and Kernel keep communicating with each other every some minutes. If U-boot finds that there is no communication, it will reset the board.
This sounds like it is the territory of watchdog timers. I don't know that CPU to know whether it has one built in though, nor if the kernel supports it.
Andy.
Hi Dev,
Altough your problem is off-topic from u-boot, we want to help you :-)
the only solution what i see, is some watchdog. Maybe your CPU has such feature or your hardware around does offer some watchdog.
best regards, Hannes
Regards, -Dev
Dev wrote...
Andy.
Thanks Hannes, Let me look around for watchdog functionality.
Regards, -Dev
Date: Tue, 17 Mar 2015 22:39:41 +0100 From: hannes@petermaier.org To: u-boot@lists.denx.de Subject: Re: [U-Boot] Kernel to U-boot messaging and vice versa.
Hi Dev,
Regards, -Dev
Dev wrote...
Andy.
Dev
Hannes Petermaier
