[U-Boot] [PATCH V0 1/1] Resolve i2c compilation error for non-FDT case
This patch resolves the below mentiond compilation error of i2c driver for non-FDT case.
Compilation error: s3c24x0_i2c.c: In function 'board_i2c_init': s3c24x0_i2c.c:544:18: error: 'CONFIG_MAX_I2C_NUM' undeclared (first use in this function) s3c24x0_i2c.c:544:18: note: each undeclared identifier is reported only once for each function it appears in s3c24x0_i2c.c:545:3: warning: implicit declaration of function 'exynos_pinmux_config' [-Wimplicit-function-declaration] s3c24x0_i2c.c:545:25: error: 'PERIPH_ID_I2C0' undeclared (first use in this function) s3c24x0_i2c.c:546:10: error: 'PINMUX_FLAG_NONE' undeclared (first use in this function) make[1]: *** [/home/albert/src/u-boot-arm/build/VCMA9/drivers/i2c/s3c24x0_i2c.o] Error 1 make: *** [/home/albert/src/u-boot-arm/build/VCMA9/drivers/i2c/libi2c.o] Error 2
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Signed-off-by: Amar amarendra.xt@samsung.com --- board/samsung/smdk5250/smdk5250.c | 9 +++++++++ drivers/i2c/s3c24x0_i2c.c | 9 +-------- 2 files changed, 10 insertions(+), 8 deletions(-)
diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index ae1f077..262398f 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -332,6 +332,15 @@ static int board_uart_init(void) return ret; }
+void board_i2c_init(const void *blob) +{ + int i; + for (i = 0; i < CONFIG_MAX_I2C_NUM; i++) { + exynos_pinmux_config((PERIPH_ID_I2C0 + i), + PINMUX_FLAG_NONE); + } +} + #ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index 3fc1c5b..382e4c2 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -515,10 +515,10 @@ int i2c_write(uchar chip, uint addr, int alen, uchar *buffer, int len) len) != 0); }
+#ifdef CONFIG_OF_CONTROL void board_i2c_init(const void *blob) { int i; -#ifdef CONFIG_OF_CONTROL int node_list[CONFIG_MAX_I2C_NUM]; int count;
@@ -540,15 +540,8 @@ void board_i2c_init(const void *blob) bus->bus_num = i2c_busses++; exynos_pinmux_config(bus->id, 0); } -#else - for (i = 0; i < CONFIG_MAX_I2C_NUM; i++) { - exynos_pinmux_config((PERIPH_ID_I2C0 + i), - PINMUX_FLAG_NONE); - } -#endif }
-#ifdef CONFIG_OF_CONTROL static struct s3c24x0_i2c_bus *get_bus(unsigned int bus_idx) { if (bus_idx < i2c_busses)
Dear amar_g
On 09/07/13 21:44, amar_g wrote:
Please add prefix at title.
typo. -> mentiond
for non-FDT case.
- int i;
please add blank line here.
PINMUX_FLAG_NONE);
This is for non-fdt case, right?
PINMUX_FLAG_NONE);
-#endif }
Thanks, Minkyu Kang.
Dear Minkyu,
Please find my responses below.
Thanks & Regards Amarendra Reddy
On 9 July 2013 18:50, Minkyu Kang mk7.kang@samsung.com wrote:
Dear amar_g
OK shall add aprefix 'EXYNOS' at title in the next patch.
typo. -> mentiond
OK shall remove the '.' form "for non-FDT case."
for non-FDT case.
int i;
Ok shall add a new line here.
PINMUX_FLAG_NONE);
Yes, it is for non-fdt case.
len) != 0);
PINMUX_FLAG_NONE);
-#endif }
Thanks, Minkyu Kang. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
amar_g
Amarendra Reddy
Minkyu Kang
