[U-Boot] [PATCH] common: image-fit: Cleanup spelling mistakes
The comments in the source file are riddled with spelling mistakes. Be a good citizen and take a stab at cleaning up some of the more obvious ones.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- common/image-fit.c | 30 +++++++++++++++--------------- 1 file changed, 15 insertions(+), 15 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 9873957..6f920da 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -147,7 +147,7 @@ int fit_get_subimage_count(const void *fit, int images_noffset) * @p: pointer to prefix string * * fit_print_contents() formats a multi line FIT image contents description. - * The routine prints out FIT image properties (root node level) follwed by + * The routine prints out FIT image properties (root node level) followed by * the details of each component image. * * returns: @@ -249,7 +249,7 @@ void fit_print_contents(const void *fit) * @p: pointer to prefix string * @type: Type of information to print ("hash" or "sign") * - * fit_image_print_data() lists properies for the processed hash node + * fit_image_print_data() lists properties for the processed hash node * * This function avoid using puts() since it prints a newline on the host * but does not in U-Boot. @@ -314,7 +314,7 @@ static void fit_image_print_data(const void *fit, int noffset, const char *p, * @noffset: offset of the hash or signature node * @p: pointer to prefix string * - * This lists properies for the processed hash node + * This lists properties for the processed hash node * * returns: * no returned results @@ -344,7 +344,7 @@ static void fit_image_print_verification_data(const void *fit, int noffset, * @image_noffset: offset of the component image node * @p: pointer to prefix string * - * fit_image_print() lists all mandatory properies for the processed component + * fit_image_print() lists all mandatory properties for the processed component * image. If present, hash nodes are printed out as well. Load * address for images of type firmware is also printed out. Since the load * address is not mandatory for firmware images, it will be output as @@ -459,10 +459,10 @@ void fit_image_print(const void *fit, int image_noffset, const char *p) * fit_get_desc - get node description property * @fit: pointer to the FIT format image header * @noffset: node offset - * @desc: double pointer to the char, will hold pointer to the descrption + * @desc: double pointer to the char, will hold pointer to the description * * fit_get_desc() reads description property from a given node, if - * description is found pointer to it is returened in third call argument. + * description is found pointer to it is returned in third call argument. * * returns: * 0, on success @@ -487,8 +487,8 @@ int fit_get_desc(const void *fit, int noffset, char **desc) * @noffset: node offset * @timestamp: pointer to the time_t, will hold read timestamp * - * fit_get_timestamp() reads timestamp poperty from given node, if timestamp - * is found and has a correct size its value is retured in third call + * fit_get_timestamp() reads timestamp property from given node, if timestamp + * is found and has a correct size its value is returned in third call * argument. * * returns: @@ -520,7 +520,7 @@ int fit_get_timestamp(const void *fit, int noffset, time_t *timestamp) * @fit: pointer to the FIT format image header * @image_uname: component image node unit name * - * fit_image_get_node() finds a component image (withing the '/images' + * fit_image_get_node() finds a component image (within the '/images' * node) of a provided unit name. If image is found its node offset is * returned to the caller. * @@ -989,7 +989,7 @@ static int fit_image_check_hash(const void *fit, int noffset, const void *data, }
/** - * fit_image_verify - verify data intergity + * fit_image_verify - verify data integrity * @fit: pointer to the FIT format image header * @image_noffset: component image node offset * @@ -1073,7 +1073,7 @@ error: }
/** - * fit_all_image_verify - verify data intergity for all images + * fit_all_image_verify - verify data integrity for all images * @fit: pointer to the FIT format image header * * fit_all_image_verify() goes over all images in the FIT and @@ -1380,8 +1380,8 @@ int fit_conf_find_compat(const void *fit, const void *fdt) * @fit: pointer to the FIT format image header * @conf_uname: configuration node unit name * - * fit_conf_get_node() finds a configuration (withing the '/configurations' - * parant node) of a provided unit name. If configuration is found its node + * fit_conf_get_node() finds a configuration (within the '/configurations' + * parent node) of a provided unit name. If configuration is found its node * offset is returned to the caller. * * When NULL is provided in second argument fit_conf_get_node() will search @@ -1447,7 +1447,7 @@ int fit_conf_get_prop_node(const void *fit, int noffset, * @noffset: offset of the configuration node * @p: pointer to prefix string * - * fit_conf_print() lists all mandatory properies for the processed + * fit_conf_print() lists all mandatory properties for the processed * configuration node. * * returns: @@ -1558,7 +1558,7 @@ static const char *fit_get_image_type_property(int type) { /* * This is sort-of available in the uimage_type[] table in image.c - * but we don't have access to the sohrt name, and "fdt" is different + * but we don't have access to the short name, and "fdt" is different * anyway. So let's just keep it here. */ switch (type) {
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Reviewed-by: Simon Glass sjg@chromium.org
Andreas Dannenberg
