[U-Boot] [PATCH 0/4] mmc: Fix recognition and selection of Dual Data Rate mode
This set of commits fixes some problems and drawbacks in current implementation of MMC Dual Data Rate mode support.
These changes were tested not with dw_mmc driver, but with DDR mode support implementation for fsl_esdhc driver, ported from Freescale's 2009.08 based version and not yet submitted to the community.
Andrew Gabbasov (4): mmc: Fix handling of bus widths and DDR card capabilities mmc: Fix Dual Data Rate capability recognition mmc: Fix block length for DDR mode mmc: dw_mmc: Use active DDR mode flag
common/cmd_mmc.c | 3 ++- drivers/mmc/dw_mmc.c | 2 +- drivers/mmc/mmc.c | 60 +++++++++++++++++++++++++++++++++------------------- include/mmc.h | 1 + 4 files changed, 42 insertions(+), 24 deletions(-)
If the MMC_MODE_DDR_52MHz flag is set in card capabilities bitmask, it is never cleared, even if switching to DDR mode fails, and if the controller driver uses this flag to check the DDR mode, it can take incorrect actions.
Also, DDR related checks in mmc_startup() incorrectly handle the case when the host controller does not support some bus widths (e.g. can't support 8 bits), since the host_caps is checked for DDR bit, but not bus width bits.
This fix clearly separates using of card_caps bitmask, having there the flags for the capabilities, that the card can support, and actual operation mode, described outside of card_caps (i.e. bus_width and ddr_mode fields in mmc structure). Separate host controller drivers may need to be updated to use the actual flags. Respectively, the capabilities checks in mmc_startup are made more correct and clear.
Also, some clean up is made with errors handling and code syntax layout.
Signed-off-by: Andrew Gabbasov andrew_gabbasov@mentor.com --- common/cmd_mmc.c | 3 ++- drivers/mmc/mmc.c | 52 +++++++++++++++++++++++++++++++--------------------- include/mmc.h | 1 + 3 files changed, 34 insertions(+), 22 deletions(-)
diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index 4286e26..96478e4 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -90,7 +90,8 @@ static void print_mmcinfo(struct mmc *mmc) puts("Capacity: "); print_size(mmc->capacity, "\n");
- printf("Bus Width: %d-bit\n", mmc->bus_width); + printf("Bus Width: %d-bit%s\n", mmc->bus_width, + mmc->ddr_mode ? " DDR" : ""); } static struct mmc *init_mmc_device(int dev, bool force_init) { diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 44a4feb..4603a81 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -159,7 +159,7 @@ int mmc_set_blocklen(struct mmc *mmc, int len) { struct mmc_cmd cmd;
- if (mmc->card_caps & MMC_MODE_DDR_52MHz) + if (mmc->ddr_mode) return 0;
cmd.cmdidx = MMC_CMD_SET_BLOCKLEN; @@ -486,7 +486,7 @@ static int mmc_change_freq(struct mmc *mmc) char cardtype; int err;
- mmc->card_caps = 0; + mmc->card_caps = MMC_MODE_4BIT | MMC_MODE_8BIT;
if (mmc_host_is_spi(mmc)) return 0; @@ -1103,8 +1103,10 @@ static int mmc_startup(struct mmc *mmc)
/* An array to map CSD bus widths to host cap bits */ static unsigned ext_to_hostcaps[] = { - [EXT_CSD_DDR_BUS_WIDTH_4] = MMC_MODE_DDR_52MHz, - [EXT_CSD_DDR_BUS_WIDTH_8] = MMC_MODE_DDR_52MHz, + [EXT_CSD_DDR_BUS_WIDTH_4] = + MMC_MODE_DDR_52MHz | MMC_MODE_4BIT, + [EXT_CSD_DDR_BUS_WIDTH_8] = + MMC_MODE_DDR_52MHz | MMC_MODE_8BIT, [EXT_CSD_BUS_WIDTH_4] = MMC_MODE_4BIT, [EXT_CSD_BUS_WIDTH_8] = MMC_MODE_8BIT, }; @@ -1116,13 +1118,13 @@ static int mmc_startup(struct mmc *mmc)
for (idx=0; idx < ARRAY_SIZE(ext_csd_bits); idx++) { unsigned int extw = ext_csd_bits[idx]; + unsigned int caps = ext_to_hostcaps[extw];
/* - * Check to make sure the controller supports - * this bus width, if it's more than 1 + * Check to make sure the card and controller support + * these capabilities */ - if (extw != EXT_CSD_BUS_WIDTH_1 && - !(mmc->cfg->host_caps & ext_to_hostcaps[extw])) + if ((mmc->card_caps & caps) != caps) continue;
err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, @@ -1131,26 +1133,33 @@ static int mmc_startup(struct mmc *mmc) if (err) continue;
+ mmc->ddr_mode = (caps & MMC_MODE_DDR_52MHz) ? 1 : 0; mmc_set_bus_width(mmc, widths[idx]);
err = mmc_send_ext_csd(mmc, test_csd); + + if (err) + continue; + /* Only compare read only fields */ - if (!err && ext_csd[EXT_CSD_PARTITIONING_SUPPORT] \ - == test_csd[EXT_CSD_PARTITIONING_SUPPORT] - && ext_csd[EXT_CSD_HC_WP_GRP_SIZE] \ - == test_csd[EXT_CSD_HC_WP_GRP_SIZE] \ - && ext_csd[EXT_CSD_REV] \ - == test_csd[EXT_CSD_REV] - && ext_csd[EXT_CSD_HC_ERASE_GRP_SIZE] \ - == test_csd[EXT_CSD_HC_ERASE_GRP_SIZE] - && memcmp(&ext_csd[EXT_CSD_SEC_CNT], \ - &test_csd[EXT_CSD_SEC_CNT], 4) == 0) { - - mmc->card_caps |= ext_to_hostcaps[extw]; + if (ext_csd[EXT_CSD_PARTITIONING_SUPPORT] + == test_csd[EXT_CSD_PARTITIONING_SUPPORT] && + ext_csd[EXT_CSD_HC_WP_GRP_SIZE] + == test_csd[EXT_CSD_HC_WP_GRP_SIZE] && + ext_csd[EXT_CSD_REV] + == test_csd[EXT_CSD_REV] && + ext_csd[EXT_CSD_HC_ERASE_GRP_SIZE] + == test_csd[EXT_CSD_HC_ERASE_GRP_SIZE] && + memcmp(&ext_csd[EXT_CSD_SEC_CNT], + &test_csd[EXT_CSD_SEC_CNT], 4) == 0) break; - } + else + err = SWITCH_ERR; }
+ if (err) + return err; + if (mmc->card_caps & MMC_MODE_HS) { if (mmc->card_caps & MMC_MODE_HS_52MHz) mmc->tran_speed = 52000000; @@ -1299,6 +1308,7 @@ int mmc_start_init(struct mmc *mmc) if (err) return err;
+ mmc->ddr_mode = 0; mmc_set_bus_width(mmc, 1); mmc_set_clock(mmc, 1);
diff --git a/include/mmc.h b/include/mmc.h index d74a190..9c6d792 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -314,6 +314,7 @@ struct mmc { char init_in_progress; /* 1 if we have done mmc_start_init() */ char preinit; /* start init as early as possible */ uint op_cond_response; /* the response byte from the last op_cond */ + int ddr_mode; };
int mmc_register(struct mmc *mmc);
Hi Andrew,
Looks good. I don’t have a DDR capable board to test, but at first glance it’s fine.
- printf("Bus Width: %d-bit%s\n", mmc->bus_width,
};MMC_MODE_DDR_52MHz | MMC_MODE_8BIT, [EXT_CSD_BUS_WIDTH_4] = MMC_MODE_4BIT, [EXT_CSD_BUS_WIDTH_8] = MMC_MODE_8BIT,
unsigned int caps = ext_to_hostcaps[extw]; /*
if ((mmc->card_caps & caps) != caps) continue; err = mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL,
mmc->ddr_mode = (caps & MMC_MODE_DDR_52MHz) ? 1 : 0; mmc_set_bus_width(mmc, widths[idx]); err = mmc_send_ext_csd(mmc, test_csd);
if (err)
continue;
else
err = SWITCH_ERR;
if (err)
return err;
- mmc->ddr_mode = 0; mmc_set_bus_width(mmc, 1); mmc_set_clock(mmc, 1);
- int ddr_mode;
2.1.0
Applied, thanks.
— Pantelis
Since the driver doesn't work in 1.2V or 1.8V signaling level modes, Dual Data Rate mode can be supported by the driver only if it is supported by the card in regular 3.3V mode. So, check for a particular single bit in card type field.
Signed-off-by: Andrew Gabbasov andrew_gabbasov@mentor.com --- drivers/mmc/mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 4603a81..d878c1e 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -519,7 +519,7 @@ static int mmc_change_freq(struct mmc *mmc)
/* High Speed is set, there are two types: 52MHz and 26MHz */ if (cardtype & EXT_CSD_CARD_TYPE_52) { - if (cardtype & EXT_CSD_CARD_TYPE_DDR_52) + if (cardtype & EXT_CSD_CARD_TYPE_DDR_1_8V) mmc->card_caps |= MMC_MODE_DDR_52MHz; mmc->card_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS; } else {
Hi Andrew,
mmc->card_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS; } else {if (cardtype & EXT_CSD_CARD_TYPE_DDR_1_8V) mmc->card_caps |= MMC_MODE_DDR_52MHz;
-- 2.1.0
Applied, thanks.
— Pantelis
Block length for write and read commands is fixed to 512 bytes when the card is in Dual Data Rate mode. If block length read from CSD is different, make sure the driver will use correct length in all further calculations and settings.
Signed-off-by: Andrew Gabbasov andrew_gabbasov@mentor.com --- drivers/mmc/mmc.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index d878c1e..9918597 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -1170,6 +1170,12 @@ static int mmc_startup(struct mmc *mmc)
mmc_set_clock(mmc, mmc->tran_speed);
+ /* Fix the block length for DDR mode */ + if (mmc->ddr_mode) { + mmc->read_bl_len = MMC_MAX_BLOCK_LEN; + mmc->write_bl_len = MMC_MAX_BLOCK_LEN; + } + /* fill in device description */ mmc->block_dev.lun = 0; mmc->block_dev.type = 0;
Hi Andrew,
- /* Fix the block length for DDR mode */
- if (mmc->ddr_mode) {
- /* fill in device description */ mmc->block_dev.lun = 0; mmc->block_dev.type = 0;
-- 2.1.0
Applied, thanks.
— Pantelis
The card_caps bit should denote the card capability to use DDR mode, but we need the flag indicating that the DDR mode is active.
Signed-off-by: Andrew Gabbasov andrew_gabbasov@mentor.com --- drivers/mmc/dw_mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 785eed5..b18c75d 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -318,7 +318,7 @@ static void dwmci_set_ios(struct mmc *mmc) dwmci_writel(host, DWMCI_CTYPE, ctype);
regs = dwmci_readl(host, DWMCI_UHS_REG); - if (mmc->card_caps & MMC_MODE_DDR_52MHz) + if (mmc->ddr_mode) regs |= DWMCI_DDR_MODE; else regs &= DWMCI_DDR_MODE;
Hi Andrew,
- if (mmc->ddr_mode) regs |= DWMCI_DDR_MODE; else regs &= DWMCI_DDR_MODE;
-- 2.1.0
Applied, thanks
— Pantelis
Andrew Gabbasov
Pantelis Antoniou
