[PATCH] tools: mtk_image: add support for booting ARM64 images
mkimage is only able to package aarch32 binaries. Add support for AArch64 images.
One can create a ARM64 image using the following command line: mkimage -T mtk_image -a 0x201000 -e 0x201000 -n "media=emmc;arm64=1" -d bl2.bin bl2.img
Signed-off-by: Fabien Parent fparent@baylibre.com --- tools/mtk_image.c | 28 ++++++++++++++++++++++++---- tools/mtk_image.h | 6 +++++- 2 files changed, 29 insertions(+), 5 deletions(-)
diff --git a/tools/mtk_image.c b/tools/mtk_image.c index 2ca519483d33..bde1e5da4bec 100644 --- a/tools/mtk_image.c +++ b/tools/mtk_image.c @@ -246,6 +246,7 @@ static const struct brom_img_type { /* Image type selected by user */ static enum brlyt_img_type hdr_media; static int use_lk_hdr; +static bool is_arm64_image;
/* LK image name */ static char lk_name[32] = "U-Boot"; @@ -276,6 +277,7 @@ static int mtk_brom_parse_imagename(const char *imagename) static const char *media = ""; static const char *nandinfo = ""; static const char *lk = ""; + static const char *arm64_param = "";
key = buf; while (key) { @@ -323,6 +325,9 @@ static int mtk_brom_parse_imagename(const char *imagename)
if (!strcmp(key, "lkname")) snprintf(lk_name, sizeof(lk_name), "%s", val); + + if (!strcmp(key, "arm64")) + arm64_param = val; }
if (next) @@ -354,6 +359,9 @@ static int mtk_brom_parse_imagename(const char *imagename) } }
+ if (arm64_param && arm64_param[0] == '1') + is_arm64_image = true; + free(buf);
if (hdr_media == BRLYT_TYPE_INVALID) { @@ -458,6 +466,9 @@ static int mtk_image_verify_gen_header(const uint8_t *ptr, int print) le32_to_cpu(gfh->file_info.load_addr) + le32_to_cpu(gfh->file_info.jump_offset));
+ if (print) + printf("Architecture: %s\n", is_arm64_image ? "ARM64" : "ARM"); + return 0; }
@@ -523,6 +534,9 @@ static int mtk_image_verify_nand_header(const uint8_t *ptr, int print) le32_to_cpu(gfh->file_info.load_addr) + le32_to_cpu(gfh->file_info.jump_offset));
@@ -581,6 +595,8 @@ static void put_ghf_common_header(struct gfh_common_header *gfh, int size, static void put_ghf_header(struct gfh_header *gfh, int file_size, int dev_hdr_size, int load_addr, int flash_type) { + uint32_t cfg_bits; + memset(gfh, 0, sizeof(struct gfh_header));
/* GFH_FILE_INFO header */ @@ -608,11 +624,15 @@ static void put_ghf_header(struct gfh_header *gfh, int file_size, /* GFH_BROM_CFG header */ put_ghf_common_header(&gfh->brom_cfg.gfh, sizeof(gfh->brom_cfg), GFH_TYPE_BROM_CFG, 3); - gfh->brom_cfg.cfg_bits = cpu_to_le32( - GFH_BROM_CFG_USBDL_AUTO_DETECT_DIS | - GFH_BROM_CFG_USBDL_BY_KCOL0_TIMEOUT_EN | - GFH_BROM_CFG_USBDL_BY_FLAG_TIMEOUT_EN); + cfg_bits = GFH_BROM_CFG_USBDL_AUTO_DETECT_DIS | + GFH_BROM_CFG_USBDL_BY_KCOL0_TIMEOUT_EN | + GFH_BROM_CFG_USBDL_BY_FLAG_TIMEOUT_EN; gfh->brom_cfg.usbdl_by_kcol0_timeout_ms = cpu_to_le32(5000); + if (is_arm64_image) { + gfh->brom_cfg.jump_bl_arm64 = GFH_BROM_CFG_JUMP_BL_ARM64; + cfg_bits |= GFH_BROM_CFG_JUMP_BL_ARM64_EN; + } + gfh->brom_cfg.cfg_bits = cpu_to_le32(cfg_bits);
/* GFH_BL_SEC_KEY header */ put_ghf_common_header(&gfh->bl_sec_key.gfh, sizeof(gfh->bl_sec_key), diff --git a/tools/mtk_image.h b/tools/mtk_image.h index 4e78b3d0ff0b..7dda71ce88a5 100644 --- a/tools/mtk_image.h +++ b/tools/mtk_image.h @@ -136,7 +136,9 @@ struct gfh_brom_cfg { struct gfh_common_header gfh; uint32_t cfg_bits; uint32_t usbdl_by_auto_detect_timeout_ms; - uint8_t unused[0x48]; + uint8_t unused[0x45]; + uint8_t jump_bl_arm64; + uint8_t unused2[2]; uint32_t usbdl_by_kcol0_timeout_ms; uint32_t usbdl_by_flag_timeout_ms; uint32_t pad; @@ -146,6 +148,8 @@ struct gfh_brom_cfg { #define GFH_BROM_CFG_USBDL_AUTO_DETECT_DIS 0x10 #define GFH_BROM_CFG_USBDL_BY_KCOL0_TIMEOUT_EN 0x80 #define GFH_BROM_CFG_USBDL_BY_FLAG_TIMEOUT_EN 0x100 +#define GFH_BROM_CFG_JUMP_BL_ARM64_EN 0x1000 +#define GFH_BROM_CFG_JUMP_BL_ARM64 0x64
struct gfh_bl_sec_key { struct gfh_common_header gfh;
Fabien Parent
