[U-Boot] [PATCH] ppc4xx: Cleanup PMC405 board support
This patch fixes coding style for PMC405 board support. Also some unneeded features/code is removed.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- board/esd/pmc405/pmc405.c | 95 ++++----------- include/configs/PMC405.h | 285 ++++++++++++++++++++++----------------------- 2 files changed, 165 insertions(+), 215 deletions(-)
diff --git a/board/esd/pmc405/pmc405.c b/board/esd/pmc405/pmc405.c index 975b6d6..dd58d01 100644 --- a/board/esd/pmc405/pmc405.c +++ b/board/esd/pmc405/pmc405.c @@ -40,7 +40,6 @@ const unsigned char fpgadata[] = }; int filesize = sizeof(fpgadata);
- int board_early_init_f (void) { /* @@ -55,23 +54,23 @@ int board_early_init_f (void) * IRQ 30 (EXT IRQ 5) PCI INTA; active low; level sensitive * IRQ 31 (EXT IRQ 6) COMPACT FLASH; active high; level sensitive */ - mtdcr(uicsr, 0xFFFFFFFF); /* clear all ints */ - mtdcr(uicer, 0x00000000); /* disable all ints */ - mtdcr(uiccr, 0x00000000); /* set all to be non-critical*/ - mtdcr(uicpr, 0xFFFFFF81); /* set int polarities */ - mtdcr(uictr, 0x10000000); /* set int trigger levels */ - mtdcr(uicvcr, 0x00000001); /* set vect base=0,INT0 highest priority*/ - mtdcr(uicsr, 0xFFFFFFFF); /* clear all ints */ + mtdcr(uicsr, 0xFFFFFFFF); /* clear all ints */ + mtdcr(uicer, 0x00000000); /* disable all ints */ + mtdcr(uiccr, 0x00000000); /* set all to be non-critical*/ + mtdcr(uicpr, 0xFFFFFF81); /* set int polarities */ + mtdcr(uictr, 0x10000000); /* set int trigger levels */ + mtdcr(uicvcr, 0x00000001); /* set vect base=0, INT0 highest priority */ + mtdcr(uicsr, 0xFFFFFFFF); /* clear all ints */
/* - * EBC Configuration Register: set ready timeout to 512 ebc-clks -> ca. 15 us + * EBC Configuration Register: + * set ready timeout to 512 ebc-clks -> ca. 15 us */ mtebc (epcr, 0xa8400000);
/* * Setup GPIO pins */ - mtdcr(cntrl0, mfdcr(cntrl0) | ((CONFIG_SYS_FPGA_INIT | \ CONFIG_SYS_FPGA_DONE | \ CONFIG_SYS_XEREADY | \ @@ -85,26 +84,26 @@ int board_early_init_f (void) }
out32(GPIO0_OR, 0); - out32(GPIO0_TCR, CONFIG_SYS_FPGA_PRG | CONFIG_SYS_FPGA_CLK | CONFIG_SYS_FPGA_DATA | CONFIG_SYS_XEREADY); /* setup for output */ + /* setup for output */ + out32(GPIO0_TCR, CONFIG_SYS_FPGA_PRG | CONFIG_SYS_FPGA_CLK | \ + CONFIG_SYS_FPGA_DATA | CONFIG_SYS_XEREADY);
- /* - check if rev1_2 is low, then: - * - set/reset CONFIG_SYS_INTA_FAKE/CONFIG_SYS_SELF_RST in TCR to assert INTA# or SELFRST# + /* + * - check if rev1_2 is low, then: + * - set/reset CONFIG_SYS_INTA_FAKE/CONFIG_SYS_SELF_RST + * in TCR to assert INTA# or SELFRST# */ - return 0; }
- -/* ------------------------------------------------------------------------- */ - - int misc_init_r (void) { /* adjust flash start and offset */ gd->bd->bi_flashstart = 0 - gd->bd->bi_flashsize; gd->bd->bi_flashoffset = 0;
- out32(GPIO0_OR, in32(GPIO0_OR) | CONFIG_SYS_XEREADY); /* deassert EREADY# */ + /* deassert EREADY# */ + out32(GPIO0_OR, in32(GPIO0_OR) | CONFIG_SYS_XEREADY); return (0); }
@@ -113,16 +112,16 @@ ushort pmc405_pci_subsys_deviceid(void) ulong val; val = in32(GPIO0_IR); if (!(val & CONFIG_SYS_REV1_2)) { /* low=rev1.2 */ - if (val & CONFIG_SYS_NONMONARCH) { /* monarch# signal */ + /* check monarch# signal */ + if (val & CONFIG_SYS_NONMONARCH) return CONFIG_SYS_PCI_SUBSYS_DEVICEID_NONMONARCH; - } return CONFIG_SYS_PCI_SUBSYS_DEVICEID_MONARCH; } return CONFIG_SYS_PCI_SUBSYS_DEVICEID_NONMONARCH; }
/* - * Check Board Identity: + * Check Board Identity */ int checkboard (void) { @@ -133,29 +132,25 @@ int checkboard (void)
puts ("Board: ");
- if (i == -1) { + if (i == -1) puts ("### No HW ID - assuming PMC405"); - } else { + else puts(str); - }
val = in32(GPIO0_IR); if (!(val & CONFIG_SYS_REV1_2)) { /* low=rev1.2 */ puts(" rev1.2 ("); - if (val & CONFIG_SYS_NONMONARCH) { /* monarch# signal */ + if (val & CONFIG_SYS_NONMONARCH) /* monarch# signal */ puts("non-"); - } puts("monarch)"); - } else { + } else puts(" <=rev1.1"); - }
putc ('\n');
return 0; }
-/* ------------------------------------------------------------------------- */ void reset_phy(void) { #ifdef CONFIG_LXT971_NO_SLEEP @@ -166,43 +161,3 @@ void reset_phy(void) lxt971_no_sleep(); #endif } - - -int do_cantest(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - ulong addr; - volatile uchar *ptr; - volatile uchar val; - int i; - - addr = simple_strtol (argv[1], NULL, 16) + 0x16; - - i = 0; - for (;;) { - ptr = (uchar *)addr; - for (i=0; i<8; i++) { - *ptr = i; - val = *ptr; - - if (val != i) { - printf("ERROR: addr=%p write=0x%02X, read=0x%02X\n", ptr, i, val); - return 0; - } - - /* Abort if ctrl-c was pressed */ - if (ctrlc()) { - puts("\nAbort\n"); - return 0; - } - - ptr++; - } - } - - return 0; -} -U_BOOT_CMD( - cantest, 3, 1, do_cantest, - "Test CAN controller", - NULL - ); diff --git a/include/configs/PMC405.h b/include/configs/PMC405.h index 43e9532..7fbdeb0 100644 --- a/include/configs/PMC405.h +++ b/include/configs/PMC405.h @@ -12,7 +12,7 @@ * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License @@ -21,16 +21,11 @@ * MA 02111-1307 USA */
-/* - * board/config.h - configuration options, board specific - */ - #ifndef __CONFIG_H #define __CONFIG_H
/* * High Level Configuration Options - * (easy to change) */
#define CONFIG_405GP 1 /* This is a PPC405 CPU */ @@ -45,13 +40,13 @@ #define CONFIG_BAUDRATE 9600 #define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */
-#undef CONFIG_BOOTARGS -#undef CONFIG_BOOTCOMMAND +#undef CONFIG_BOOTARGS +#undef CONFIG_BOOTCOMMAND
-#define CONFIG_PREBOOT /* enable preboot variable */ +#define CONFIG_PREBOOT /* enable preboot variable */
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
#define CONFIG_NET_MULTI 1 #undef CONFIG_HAS_ETH1 @@ -59,11 +54,8 @@ #define CONFIG_PPC4xx_EMAC #define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_PHY_ADDR 0 /* PHY address */ -#define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ -#define CONFIG_RESET_PHY_R 1 /* use reset_phy() to disable phy sleep mode */ - -#define CONFIG_NETCONSOLE /* include NetConsole support */ - +#define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ +#define CONFIG_RESET_PHY_R 1 /* use reset_phy() */
/* * BOOTP options @@ -73,7 +65,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -91,249 +82,253 @@ #define CONFIG_CMD_UNIVERSE #define CONFIG_CMD_EEPROM
- #define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION
-#undef CONFIG_WATCHDOG /* watchdog disabled */ +#undef CONFIG_WATCHDOG /* watchdog disabled */
-#define CONFIG_RTC_MC146818 /* DS1685 is MC146818 compatible*/ -#define CONFIG_SYS_RTC_REG_BASE_ADDR 0xF0000500 /* RTC Base Address */ +#define CONFIG_RTC_MC146818 /* DS1685 is MC146818 compatible */ +#define CONFIG_SYS_RTC_REG_BASE_ADDR 0xF0000500 /* RTC Base Address */
#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */
/* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */
-#undef CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#ifdef CONFIG_SYS_HUSH_PARSER +#undef CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #endif
#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Sz */
-#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ +#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ +#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console info */
-#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ +#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */
-#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ +#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */
-#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external serial clock used */ -#define CONFIG_SYS_BASE_BAUD 691200 +#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external serial clock */ +#define CONFIG_SYS_BASE_BAUD 691200
/* The following table includes the supported baudrates */ #define CONFIG_SYS_BAUDRATE_TABLE \ - { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ + { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ 57600, 115200, 230400, 460800, 921600 }
#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */ +#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */
-#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */
-#define CONFIG_LOOPW 1 /* enable loopw command */ +#define CONFIG_LOOPW 1 /* enable loopw command */
#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */
#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
-#define CONFIG_SYS_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */ +#define CONFIG_SYS_RX_ETH_BUFFER 16
-/*----------------------------------------------------------------------- +/* * PCI stuff - *----------------------------------------------------------------------- */ -#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ -#define PCI_HOST_FORCE 1 /* configure as pci host */ -#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ +#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ +#define PCI_HOST_FORCE 1 /* configure as pci host */ +#define PCI_HOST_AUTO 2 /* detected via arbiter enable */
-#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_HOST PCI_HOST_AUTO /* select pci host function */ -#define CONFIG_PCI_PNP /* do pci plug-and-play */ - /* resource configuration */ +#define CONFIG_PCI /* include pci support */ +#define CONFIG_PCI_HOST PCI_HOST_AUTO /* select pci host function */ +#define CONFIG_PCI_PNP /* do pci plug-and-play */ + /* resource configuration */
-#define CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ +#define CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */
-#define CONFIG_PCI_CONFIG_HOST_BRIDGE 1 /* don't skip host bridge config*/ +#define CONFIG_PCI_CONFIG_HOST_BRIDGE 1 /* don't skip host bridge config */
-#define CONFIG_PCI_BOOTDELAY 0 /* enable pci bootdelay variable*/ +#define CONFIG_PCI_BOOTDELAY 0 /* enable pci bootdelay variable */
-#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID_NONMONARCH 0x0408 /* PCI Device ID: Non-Monarch */ -#define CONFIG_SYS_PCI_SUBSYS_DEVICEID_MONARCH 0x0409 /* PCI Device ID: Monarch */ +#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ +#define CONFIG_SYS_PCI_SUBSYS_DEVICEID_NONMONARCH 0x0408 /* PCI Device ID */ +#define CONFIG_SYS_PCI_SUBSYS_DEVICEID_MONARCH 0x0409 /* PCI Device ID */ #define CONFIG_SYS_PCI_SUBSYS_DEVICEID pmc405_pci_subsys_deviceid()
-#define CONFIG_SYS_PCI_CLASSCODE 0x0b20 /* PCI Class Code: Processor/PPC*/ - -#define CONFIG_SYS_PCI_PTM1LA (bd->bi_memstart) /* point to sdram */ -#define CONFIG_SYS_PCI_PTM1MS (~(bd->bi_memsize - 1) | 1) /* memsize, enable hard-wired to 1 */ -#define CONFIG_SYS_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ -#if 1 -#define CONFIG_SYS_PCI_PTM2LA 0xef000000 /* point to internal regs */ -#define CONFIG_SYS_PCI_PTM2MS 0xff000001 /* 16MB, enable */ -#define CONFIG_SYS_PCI_PTM2PCI 0x00000000 /* Host: use this pci address */ -#else /* old mapping */ -#define CONFIG_SYS_PCI_PTM2LA 0xffc00000 /* point to flash */ -#define CONFIG_SYS_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ -#define CONFIG_SYS_PCI_PTM2PCI 0x04000000 /* Host: use this pci address */ -#endif -/*----------------------------------------------------------------------- +#define CONFIG_SYS_PCI_CLASSCODE 0x0b20 /* Processor/PPC */ + +#define CONFIG_SYS_PCI_PTM1LA (bd->bi_memstart) /* point to sdram */ +#define CONFIG_SYS_PCI_PTM1MS (~(bd->bi_memsize - 1) | 1) /* memsize, enable */ +#define CONFIG_SYS_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ +#define CONFIG_SYS_PCI_PTM2LA 0xef000000 /* point to internal regs */ +#define CONFIG_SYS_PCI_PTM2MS 0xff000001 /* 16MB, enable */ +#define CONFIG_SYS_PCI_PTM2PCI 0x00000000 /* Host: use this pci address */ + +/* * Start addresses for the final memory configuration * (Set up by the startup code) * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_BASE 0xFFFC0000 -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserve 128 kB for malloc() */ +#define CONFIG_SYS_MONITOR_BASE 0xFFFC0000 +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* 256 kB for Monitor */ +#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* 128 kB for malloc() */
/* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
-/*----------------------------------------------------------------------- +/* * FLASH organization */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 #define CONFIG_SYS_FLASH_INCREMENT 0x01000000
-#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* don't use hardware protection */ -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of flash banks */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE + CONFIG_SYS_FLASH_INCREMENT } -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max num of sects on one chip */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ +#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* don't use hardware protection */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (faster) */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max num of flash banks */ +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE, \ + CONFIG_SYS_FLASH_BASE + CONFIG_SYS_FLASH_INCREMENT} +#define CONFIG_SYS_MAX_FLASH_SECT 128 /* max num of sects on one chip */ +#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on fli */
/* * JFFS2 partitions - second bank contains u-boot - * + * No command line, one static partition, whole device */ -/* No command line, one static partition, whole device */ #undef CONFIG_JFFS2_CMDLINE #define CONFIG_JFFS2_DEV "nor0" #define CONFIG_JFFS2_PART_SIZE 0x01b00000 #define CONFIG_JFFS2_PART_OFFSET 0x00400000
-/* mtdparts command line support */ -/* Note: fake mtd_id used, no linux mtd map file */ /* + * mtdparts command line support + * Note: fake mtd_id used, no linux mtd map file + */ #define CONFIG_JFFS2_CMDLINE #define MTDIDS_DEFAULT "nor0=pmc405-0" #define MTDPARTS_DEFAULT "mtdparts=pmc405-0:-(jffs2)" -*/
-/*----------------------------------------------------------------------- +/* * Environment Variable setup */ #define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CONFIG_ENV_OFFSET 0x000 /* environment starts at the beginning of the EEPROM */ -#define CONFIG_ENV_SIZE 0x800 /* 2048 bytes may be used for env vars*/ - /* total size of a CAT24WC16 is 2048 bytes */
-#define CONFIG_SYS_NVRAM_BASE_ADDR 0xF0000500 /* NVRAM base address */ -#define CONFIG_SYS_NVRAM_SIZE 242 /* NVRAM size */ +/* environment starts at the beginning of the EEPROM */ +#define CONFIG_ENV_OFFSET 0x000 +#define CONFIG_ENV_SIZE 0x800 /* 2048 bytes may be used for env vars */ + +#define CONFIG_SYS_NVRAM_BASE_ADDR 0xF0000500 /* NVRAM base address */ +#define CONFIG_SYS_NVRAM_SIZE 242 /* NVRAM size */
-/*----------------------------------------------------------------------- +/* * I2C EEPROM (CAT24WC16) for environment */ #define CONFIG_HARD_I2C /* I2c with hardware support */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ #define CONFIG_SYS_I2C_SLAVE 0x7F
-#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ +/* mask of address bits that overflow into the "EEPROM chip address" */ #define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ - /* 16 byte page write mode using*/ - /* last 4 bits of the address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */
-/*----------------------------------------------------------------------- +/* * External Bus Controller (EBC) Setup */ -#define FLASH0_BA 0xFF000000 /* FLASH 0 Base Address */ -#define FLASH1_BA 0xFE000000 /* FLASH 1 Base Address */ -#define CAN_BA 0xF0000000 /* CAN Base Address */ -#define RTC_BA 0xF0000500 /* RTC Base Address */ -#define NVRAM_BA 0xF0200000 /* NVRAM Base Address */ +#define FLASH0_BA 0xFF000000 /* FLASH 0 Base Address */ +#define FLASH1_BA 0xFE000000 /* FLASH 1 Base Address */ +#define CAN_BA 0xF0000000 /* CAN Base Addres */ +#define RTC_BA 0xF0000500 /* RTC Base Address */ +#define NVRAM_BA 0xF0200000 /* NVRAM Base Address */
-/* Memory Bank 0 (Flash Bank 0) initialization */ +/* Memory Bank 0 (Flash Bank 0) initialization */ #define CONFIG_SYS_EBC_PB0AP 0x92015480 -#define CONFIG_SYS_EBC_PB0CR FLASH0_BA | 0x9A000 /* BAS=0xFF0,BS=16MB,BU=R/W,BW=16bit*/ +/* BAS=0xFF0,BS=16MB,BU=R/W,BW=16bit */ +#define CONFIG_SYS_EBC_PB0CR (FLASH0_BA | 0x9A000)
-/* Memory Bank 1 (Flash Bank 1) initialization */ +/* Memory Bank 1 (Flash Bank 1) initialization */ #define CONFIG_SYS_EBC_PB1AP 0x92015480 -#define CONFIG_SYS_EBC_PB1CR FLASH1_BA | 0x9A000 /* BAS=0xFE0,BS=16MB,BU=R/W,BW=16bit*/ +/* BAS=0xFE0,BS=16MB,BU=R/W,BW=16bit*/ +#define CONFIG_SYS_EBC_PB1CR (FLASH1_BA | 0x9A000)
-/* Memory Bank 2 (CAN0, 1, RTC) initialization */ -#define CONFIG_SYS_EBC_PB2AP 0x03000440 /* TWT=5,TH=2,CSN=0,OEN=0,WBN=0,WBF=0 */ -#define CONFIG_SYS_EBC_PB2CR CAN_BA | 0x18000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ +/* Memory Bank 2 (CAN0, 1, RTC) initialization */ +/* TWT=5,TH=2,CSN=0,OEN=0,WBN=0,WBF=0 */ +#define CONFIG_SYS_EBC_PB2AP 0x03000440 +/* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ +#define CONFIG_SYS_EBC_PB2CR (CAN_BA | 0x18000)
/* Memory Bank 3 -> unused */
-/* Memory Bank 4 (NVRAM) initialization */ -#define CONFIG_SYS_EBC_PB4AP 0x03000440 /* TWT=5,TH=2,CSN=0,OEN=0,WBN=0,WBF=0 */ -#define CONFIG_SYS_EBC_PB4CR NVRAM_BA | 0x18000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ +/* Memory Bank 4 (NVRAM) initialization */ +/* TWT=5,TH=2,CSN=0,OEN=0,WBN=0,WBF=0 */ +#define CONFIG_SYS_EBC_PB4AP 0x03000440 +/* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ +#define CONFIG_SYS_EBC_PB4CR (NVRAM_BA | 0x18000)
-/*----------------------------------------------------------------------- +/* * FPGA stuff */ -#define CONFIG_SYS_FPGA_XC95XL 1 /* using Xilinx XC95XL CPLD */ -#define CONFIG_SYS_FPGA_MAX_SIZE 32*1024 /* 32kByte is enough for CPLD */ +#define CONFIG_SYS_FPGA_XC95XL 1 /* using Xilinx XC95XL CPLD */ +#define CONFIG_SYS_FPGA_MAX_SIZE 32*1024 /* 32kByte is enough for CPLD */
/* FPGA program pin configuration */ -#define CONFIG_SYS_FPGA_PRG 0x04000000 /* JTAG TMS pin (ppc output) */ -#define CONFIG_SYS_FPGA_CLK 0x02000000 /* JTAG TCK pin (ppc output) */ -#define CONFIG_SYS_FPGA_DATA 0x01000000 /* JTAG TDO->TDI data pin (ppc output) */ -#define CONFIG_SYS_FPGA_INIT 0x00010000 /* unused (ppc input) */ -#define CONFIG_SYS_FPGA_DONE 0x00008000 /* JTAG TDI->TDO pin (ppc input) */ +#define CONFIG_SYS_FPGA_PRG 0x04000000 /* JTAG TMS pin (output) */ +#define CONFIG_SYS_FPGA_CLK 0x02000000 /* JTAG TCK pin (output) */ +#define CONFIG_SYS_FPGA_DATA 0x01000000 /* JTAG TDO pin (output) */ +#define CONFIG_SYS_FPGA_INIT 0x00010000 /* unused (ppc input) */ +#define CONFIG_SYS_FPGA_DONE 0x00008000 /* JTAG TDI pin (input) */
-#define CONFIG_SYS_VXWORKS_MAC_PTR 0x00000000 /* Pass Ethernet MAC to VxWorks */ +/* pass Ethernet MAC to VxWorks */ +#define CONFIG_SYS_VXWORKS_MAC_PTR 0x00000000
-/*----------------------------------------------------------------------- +/* * GPIOs */ -#define CONFIG_SYS_NONMONARCH (0x80000000 >> 14) /* GPIO24 */ -#define CONFIG_SYS_XEREADY (0x80000000 >> 15) /* GPIO15 */ -#define CONFIG_SYS_INTA_FAKE (0x80000000 >> 19) /* GPIO19 */ -#define CONFIG_SYS_SELF_RST (0x80000000 >> 21) /* GPIO21 */ -#define CONFIG_SYS_REV1_2 (0x80000000 >> 23) /* GPIO23 */ +#define CONFIG_SYS_NONMONARCH (0x80000000 >> 14) /* GPIO14 */ +#define CONFIG_SYS_XEREADY (0x80000000 >> 15) /* GPIO15 */ +#define CONFIG_SYS_INTA_FAKE (0x80000000 >> 19) /* GPIO19 */ +#define CONFIG_SYS_SELF_RST (0x80000000 >> 21) /* GPIO21 */ +#define CONFIG_SYS_REV1_2 (0x80000000 >> 23) /* GPIO23 */
-/*----------------------------------------------------------------------- +/* * Definitions for initial stack pointer and data area (in data cache) */
-/* use on chip memory ( OCM ) for temperary stack until sdram is tested */ +/* use on chip memory (OCM) for temperary stack until sdram is tested */ #define CONFIG_SYS_TEMP_STACK_OCM 1
/* On Chip Memory location */ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000
-#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +/* inside of SDRAM */ +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR + +/* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE + +/* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ + CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* @@ -341,7 +336,7 @@ * * Boot Flags */ -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */
-#endif /* __CONFIG_H */ +#endif /* __CONFIG_H */
Please find some comments below.
- Setup GPIO pins
out32(GPIO0_OR, 0);
- out32(GPIO0_TCR, CONFIG_SYS_FPGA_PRG | CONFIG_SYS_FPGA_CLK | \
I suggest to switch to using the out_be32()/in_be32() accessor functions instead. I am aware that many other 4xx boards still use the "wrong" accessor functions for initial GPIO configuration. I'll try to change this soon.
Thanks.
Best regards, Stefan
- Setup GPIO pins
out32(GPIO0_OR, 0);
You are right I missed these. I will update the patch and resend. I will also fix the other esd boards in the next days.
Matthias
Great, thanks.
Hi Stefan,
please take a look at my 2nd patch ("Update PMC405 ...."). It does the requested accessor fixes. So my first patch does nothing by style cleanup while the 2nd one brings some updates. I tried not to mix up beautyfication with functional code changes :-) So please keep these patches as they are :-)
Matthias
OK, I'll apply your patches as they are.
Applied to ppc4xx/master. Thanks.
Hi Matthias,
After applying I noticed still some minor coding style issues in pmc405.c. I just generated a patch fixing those problems.
Matthias Fuchs
Matthias Fuchs
Stefan Roese
