[U-Boot-Users] patch: Nios-II mini-app and I/O macros
Fix I/O Macros and mini-app stubs for Nios-II -Fix asm/io.h macros -Eliminate use of CACHE_BYPASS in cpu code -Eliminate assembler warnings -Fix mini-app stubs and force no small data
Regards, --Scott
diff -Naurb u-boot-current/CHANGELOG u-boot-new/CHANGELOG --- u-boot-current/CHANGELOG 2005-08-07 19:06:32.000000000 -0400 +++ u-boot-new/CHANGELOG 2005-08-11 10:30:51.000000000 -0400 @@ -26,6 +26,13 @@ Command line of course produces bigger images, and may be inappropriate for some targets, so by default it's off.
+* Fix I/O Macros and mini-app stubs for Nios-II + Patch by Scott McNutt + -Fix asm/io.h macros + -Eliminate use of CACHE_BYPASS in cpu code + -Eliminate assembler warnings + -Fix mini-app stubs and force no small data + * Fix build problems for PM856 Board
* Fix sign extension bug in 'fpga loadb' command; diff -Naurb u-boot-20050809/cpu/nios2/epcs.c u-boot-new/cpu/nios2/epcs.c --- u-boot-20050809/cpu/nios2/epcs.c 2005-03-30 18:28:19.000000000 -0500 +++ u-boot-new/cpu/nios2/epcs.c 2005-08-09 11:05:32.781250000 -0400 @@ -25,7 +25,7 @@
#if defined(CFG_NIOS_EPCSBASE) #include <command.h> -#include <nios2.h> +#include <asm/io.h> #include <nios2-io.h> #include <nios2-epcs.h>
@@ -72,8 +72,7 @@ */ #define EPCS_TIMEOUT 100 /* 100 msec timeout */
-static nios_spi_t *epcs = - (nios_spi_t *)CACHE_BYPASS(CFG_NIOS_EPCSBASE); +static nios_spi_t *epcs = (nios_spi_t *)CFG_NIOS_EPCSBASE;
/*********************************************************************** * Device access @@ -81,16 +80,20 @@ static int epcs_cs (int assert) { ulong start; + unsigned tmp; +
if (assert) { - epcs->control |= NIOS_SPI_SSO; + tmp = readl (&epcs->control); + writel (&epcs->control, tmp | NIOS_SPI_SSO); } else { /* Let all bits shift out */ start = get_timer (0); - while ((epcs->status & NIOS_SPI_TMT) == 0) + while ((readl (&epcs->status) & NIOS_SPI_TMT) == 0) if (get_timer (start) > EPCS_TIMEOUT) return (-1); - epcs->control &= ~NIOS_SPI_SSO; + tmp = readl (&epcs->control); + writel (&epcs->control, tmp & ~NIOS_SPI_SSO); } return (0); } @@ -100,10 +103,10 @@ ulong start;
start = get_timer (0); - while ((epcs->status & NIOS_SPI_TRDY) == 0) + while ((readl (&epcs->status) & NIOS_SPI_TRDY) == 0) if (get_timer (start) > EPCS_TIMEOUT) return (-1); - epcs->txdata = c; + writel (&epcs->txdata, c); return (0); }
@@ -112,10 +115,10 @@ ulong start;
start = get_timer (0); - while ((epcs->status & NIOS_SPI_RRDY) == 0) + while ((readl (&epcs->status) & NIOS_SPI_RRDY) == 0) if (get_timer (start) > EPCS_TIMEOUT) return (-1); - return (epcs->rxdata); + return (readl (&epcs->rxdata)); }
static unsigned char bitrev[] = { diff -Naurb u-boot-20050809/cpu/nios2/interrupts.c u-boot-new/cpu/nios2/interrupts.c --- u-boot-20050809/cpu/nios2/interrupts.c 2004-10-10 17:27:33.000000000 -0400 +++ u-boot-new/cpu/nios2/interrupts.c 2005-08-09 11:27:39.515625000 -0400 @@ -27,6 +27,7 @@
#include <nios2.h> #include <nios2-io.h> +#include <asm/io.h> #include <asm/ptrace.h> #include <common.h> #include <command.h> @@ -79,7 +80,7 @@ /* Interrupt is cleared by writing anything to the * status register. */ - tmr->status = 0; + writel (&tmr->status, 0); timestamp += CFG_NIOS_TMRMS; #ifdef CONFIG_STATUS_LED status_led_tick(timestamp); @@ -88,16 +89,17 @@
static void tmr_init (void) { - nios_timer_t *tmr =(nios_timer_t *)CACHE_BYPASS(CFG_NIOS_TMRBASE); + nios_timer_t *tmr =(nios_timer_t *)CFG_NIOS_TMRBASE; + + writel (&tmr->status, 0); + writel (&tmr->control, 0); + writel (&tmr->control, NIOS_TIMER_STOP);
- tmr->control &= ~(NIOS_TIMER_START | NIOS_TIMER_ITO); - tmr->control |= NIOS_TIMER_STOP; #if defined(CFG_NIOS_TMRCNT) - tmr->periodl = CFG_NIOS_TMRCNT & 0xffff; - tmr->periodh = (CFG_NIOS_TMRCNT >> 16) & 0xffff; + writel (&tmr->periodl, CFG_NIOS_TMRCNT & 0xffff); + writel (&tmr->periodh, (CFG_NIOS_TMRCNT >> 16) & 0xffff); #endif - tmr->control |= ( NIOS_TIMER_ITO | - NIOS_TIMER_CONT | + writel (&tmr->control, NIOS_TIMER_ITO | NIOS_TIMER_CONT | NIOS_TIMER_START ); irq_install_handler (CFG_NIOS_TMRIRQ, tmr_isr, (void *)tmr); } diff -Naurb u-boot-20050809/cpu/nios2/serial.c u-boot-new/cpu/nios2/serial.c --- u-boot-20050809/cpu/nios2/serial.c 2004-10-10 17:27:33.000000000 -0400 +++ u-boot-new/cpu/nios2/serial.c 2005-08-09 10:49:40.203125000 -0400 @@ -24,7 +24,7 @@
#include <common.h> #include <watchdog.h> -#include <nios2.h> +#include <asm/io.h> #include <nios2-io.h>
/*------------------------------------------------------------------ @@ -32,8 +32,7 @@ *-----------------------------------------------------------------*/ #if defined(CONFIG_CONSOLE_JTAG)
-static nios_jtag_t *jtag = - (nios_jtag_t *)CACHE_BYPASS(CFG_NIOS_CONSOLE); +static nios_jtag_t *jtag = (nios_jtag_t *)CFG_NIOS_CONSOLE;
void serial_setbrg( void ){ return; } int serial_init( void ) { return(0);} @@ -42,9 +41,9 @@ { unsigned val;
- while (NIOS_JTAG_WSPACE (jtag->control) == 0) + while (NIOS_JTAG_WSPACE ( readl (&jtag->control)) == 0) WATCHDOG_RESET (); - jtag->data = (unsigned char)c; + writel (&jtag->data, (unsigned char)c); }
void serial_puts (const char *s) @@ -55,7 +54,7 @@
int serial_tstc (void) { - return (jtag->control & NIOS_JTAG_RRDY); + return ( readl (&jtag->control) & NIOS_JTAG_RRDY); }
int serial_getc (void) @@ -65,7 +64,7 @@
while (1) { WATCHDOG_RESET (); - val = jtag->data; + val = readl (&jtag->data); if (val & NIOS_JTAG_RVALID) break; } @@ -78,8 +77,7 @@ *-----------------------------------------------------------------*/ #else
-static nios_uart_t *uart = (nios_uart_t *) - CACHE_BYPASS(CFG_NIOS_CONSOLE); +static nios_uart_t *uart = (nios_uart_t *) CFG_NIOS_CONSOLE;
#if defined(CFG_NIOS_FIXEDBAUD)
@@ -97,7 +95,7 @@ unsigned div;
div = (CONFIG_SYS_CLK_FREQ/gd->baudrate)-1; - uart->divisor = div; + writel (&uart->divisor,div); return; }
@@ -117,9 +115,9 @@ { if (c == '\n') serial_putc ('\r'); - while ((uart->status & NIOS_UART_TRDY) == 0) + while ((readl (&uart->status) & NIOS_UART_TRDY) == 0) WATCHDOG_RESET (); - uart->txdata = (unsigned char)c; + writel (&uart->txdata,(unsigned char)c); }
void serial_puts (const char *s) @@ -131,14 +129,14 @@
int serial_tstc (void) { - return (uart->status & NIOS_UART_RRDY); + return (readl (&uart->status) & NIOS_UART_RRDY); }
int serial_getc (void) { while (serial_tstc () == 0) WATCHDOG_RESET (); - return( uart->rxdata & 0x00ff ); + return (readl (&uart->rxdata) & 0x00ff ); }
#endif /* CONFIG_JTAG_CONSOLE */ diff -Naurb u-boot-20050809/cpu/nios2/sysid.c u-boot-new/cpu/nios2/sysid.c --- u-boot-20050809/cpu/nios2/sysid.c 2005-03-30 18:28:19.000000000 -0500 +++ u-boot-new/cpu/nios2/sysid.c 2005-08-09 10:55:19.234375000 -0400 @@ -26,20 +26,21 @@ #if defined (CFG_NIOS_SYSID_BASE)
#include <command.h> -#include <nios2.h> +#include <asm/io.h> #include <nios2-io.h> #include <linux/time.h>
void display_sysid (void) { - struct nios_sysid_t *sysid = - (struct nios_sysid_t *)CACHE_BYPASS(CFG_NIOS_SYSID_BASE); + struct nios_sysid_t *sysid = (struct nios_sysid_t *)CFG_NIOS_SYSID_BASE; struct tm t; char asc[32]; + time_t stamp;
- localtime_r ((time_t *)&sysid->timestamp, &t); + stamp = readl (&sysid->timestamp); + localtime_r (&stamp, &t); asctime_r (&t, asc); - printf ("SYSID : %08x, %s", sysid->id, asc); + printf ("SYSID : %08x, %s", readl (&sysid->id), asc);
diff -Naurb u-boot-20050809/include/asm-nios2/io.h u-boot-new/include/asm-nios2/io.h --- u-boot-20050809/include/asm-nios2/io.h 2005-03-30 18:28:19.000000000 -0500 +++ u-boot-new/include/asm-nios2/io.h 2005-05-26 14:50:50.421875000 -0400 @@ -39,12 +39,13 @@ #define readl(addr)\ ({unsigned long val;\ asm volatile( "ldwio %0, 0(%1)" :"=r"(val) : "r" (addr)); val;}) + #define writeb(addr,val)\ - asm volatile ("stbio %0, 0(%1)" : : "r" (addr), "r" (val)) + asm volatile ("stbio %1, 0(%0)" : : "r" (addr), "r" (val)) #define writew(addr,val)\ - asm volatile ("sthio %0, 0(%1)" : : "r" (addr), "r" (val)) + asm volatile ("sthio %1, 0(%0)" : : "r" (addr), "r" (val)) #define writel(addr,val)\ - asm volatile ("stwio %0, 0(%1)" : : "r" (addr), "r" (val)) + asm volatile ("stwio %1, 0(%0)" : : "r" (addr), "r" (val))
#define inb(addr) readb(addr) #define inw(addr) readw(addr) diff -Naurb u-boot-current/cpu/nios2/exceptions.S u-boot-new/cpu/nios2/exceptions.S --- u-boot-current/cpu/nios2/exceptions.S 2004-10-10 17:27:33.000000000 -0400 +++ u-boot-new/cpu/nios2/exceptions.S 2005-08-09 14:04:34.000000000 -0400 @@ -30,6 +30,9 @@
.global _exception
+ .set noat + .set nobreak + _exception: /* SAVE ALL REGS -- this allows trap and unimplemented * instruction handlers to be coded conveniently in C diff -Naurb u-boot-current/examples/Makefile u-boot-new/examples/Makefile --- u-boot-current/examples/Makefile 2005-05-16 10:19:50.000000000 -0400 +++ u-boot-new/examples/Makefile 2005-08-09 17:43:17.000000000 -0400 @@ -42,7 +42,7 @@ endif
ifeq ($(ARCH),nios2) -LOAD_ADDR = 0x00800000 -L $(gcclibdir) -T nios2.lds +LOAD_ADDR = 0x02000000 -L $(gcclibdir) -T nios2.lds endif
ifeq ($(ARCH),m68k) diff -Naurb u-boot-current/examples/stubs.c u-boot-new/examples/stubs.c --- u-boot-current/examples/stubs.c 2004-10-10 17:27:33.000000000 -0400 +++ u-boot-new/examples/stubs.c 2005-08-09 16:59:16.000000000 -0400 @@ -92,7 +92,7 @@ #x ":\n" \ " movhi r8, %%hi(%0)\n" \ " ori r8, r0, %%lo(%0)\n" \ -" add r8, r0, r15\n" \ +" add r8, r8, r15\n" \ " ldw r8, 0(r8)\n" \ " ldw r8, %1(r8)\n" \ " jmp r8\n" \ diff -Naurb u-boot-current/nios2_config.mk u-boot-new/nios2_config.mk --- u-boot-current/nios2_config.mk 2004-10-10 17:27:30.000000000 -0400 +++ u-boot-new/nios2_config.mk 2005-08-09 16:02:12.000000000 -0400 @@ -23,4 +23,4 @@ #
PLATFORM_CPPFLAGS += -DCONFIG_NIOS2 -D__NIOS2__ -PLATFORM_CPPFLAGS += -ffixed-r15 +PLATFORM_CPPFLAGS += -ffixed-r15 -G0
Merged. Thanks.
Scott McNutt
