[U-Boot] [Patch v2 1/1] driver/ddr: Fix DDR4 driver for ARM
Previously the driver was only tested on Power SoCs. Different barrier instructions are needed for ARM SoCs.
Signed-off-by: York Sun yorksun@freescale.com --- Change log v2: use mb() and isb() instead of #ifdef
arch/arm/include/asm/arch-fsl-lsch3/config.h | 4 ++++ arch/arm/include/asm/io.h | 1 + arch/powerpc/include/asm/io.h | 3 +++ drivers/ddr/fsl/fsl_ddr_gen4.c | 7 +++++-- 4 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-lsch3/config.h b/arch/arm/include/asm/arch-fsl-lsch3/config.h index c1c718e..b17410a 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/config.h +++ b/arch/arm/include/asm/arch-fsl-lsch3/config.h @@ -43,7 +43,11 @@ /* DDR */ #define CONFIG_SYS_FSL_DDR_LE #define CONFIG_VERY_BIG_RAM +#ifdef CONFIG_SYS_FSL_DDR4 +#define CONFIG_SYS_FSL_DDRC_GEN4 +#else #define CONFIG_SYS_FSL_DDRC_ARM_GEN3 /* Enable Freescale ARM DDR3 driver */ +#endif #define CONFIG_SYS_FSL_DDR /* Freescale DDR driver */ #define CONFIG_SYS_LS2_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_LS2_DDR_BLOCK1_SIZE diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index 95528dd..e5adaf7 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -136,6 +136,7 @@ extern inline void __raw_readsl(unsigned long addr, void *data, int longlen) * TODO: The kernel offers some more advanced versions of barriers, it might * have some advantages to use them instead of the simple one here. */ +#define mb() asm volatile("dsb sy" : : : "memory") #define dmb() __asm__ __volatile__ ("" : : : "memory") #define __iormb() dmb() #define __iowmb() dmb() diff --git a/arch/powerpc/include/asm/io.h b/arch/powerpc/include/asm/io.h index d8b7b97..a5257e9 100644 --- a/arch/powerpc/include/asm/io.h +++ b/arch/powerpc/include/asm/io.h @@ -123,6 +123,9 @@ static inline void isync(void) #define iobarrier_r() eieio() #define iobarrier_w() eieio()
+#define mb() sync() +#define isb() isync() + /* * Non ordered and non-swapping "raw" accessors */ diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index 7cd878a..bfc76b3 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -8,6 +8,7 @@ #include <asm/io.h> #include <fsl_ddr_sdram.h> #include <asm/processor.h> +#include <fsl_immap.h> #include <fsl_ddr.h>
#if (CONFIG_CHIP_SELECTS_PER_CTRL > 4) @@ -183,12 +184,14 @@ step2: * we choose the max, that is 500 us for all of case. */ udelay(500); - asm volatile("sync;isync"); + mb(); + isb();
/* Let the controller go */ temp_sdram_cfg = ddr_in32(&ddr->sdram_cfg) & ~SDRAM_CFG_BI; ddr_out32(&ddr->sdram_cfg, temp_sdram_cfg | SDRAM_CFG_MEM_EN); - asm volatile("sync;isync"); + mb(); + isb();
total_gb_size_per_controller = 0; for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) {
Excellent.
Thanks!
jdl
Jon Loeliger
York Sun
