[PATCH 1/1] efi_loader: function description cmp_pe_section()
Rework the description of function cmp_pe_section().
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_image_loader.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index 9078d61980..d03bff8dcd 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -212,14 +212,16 @@ static void efi_set_code_and_data_type(
#ifdef CONFIG_EFI_SECURE_BOOT /** - * cmp_pe_section() - compare two sections - * @arg1: Pointer to pointer to first section - * @arg2: Pointer to pointer to second section + * cmp_pe_section() - compare virtual addresses of two PE image sections + * @arg1: pointer to pointer to first section header + * @arg2: pointer to pointer to second section header * - * Compare two sections in PE image. + * Compare the virtual addresses of two sections of an portable executable. + * The arguments are defined as const void * to allow usage with qsort(). * - * Return: -1, 0, 1 respectively if arg1 < arg2, arg1 == arg2 or - * arg1 > arg2 + * Return: -1 if the virtual address of arg1 is less than that of arg2, + * 0 if the virtual addresses are equal, 1 if the virtual address + * of arg1 is greater than that of arg2. */ static int cmp_pe_section(const void *arg1, const void *arg2) { -- 2.26.2
