[PATCH v2] cmd: mmc: allow use of hardware partition names for mmc partconf
eMMC devices have hardware partitions such as user, boot0, and boot1. Allow these names to be displayed when reading the mmc PARTITION_CONFIG field via 'mmc partconf'. Additionally allow a name to be specified when setting the PARTITION_CONFIG.
Before: u-boot=> mmc partconf 2 1 1 0 && mmc partconf 2 EXT_CSD[179], PARTITION_CONFIG: BOOT_ACK: 0x1 BOOT_PARTITION_ENABLE: 0x2 PARTITION_ACCESS: 0x0
After: u-boot=> mmc partconf 2 1 1 0 && mmc partconf 2 EXT_CSD[179], PARTITION_CONFIG: BOOT_ACK: 0x1 BOOT_PARTITION_ENABLE: 0x1 (boot0) PARTITION_ACCESS: 0x0 u-boot=> mmc partconf 2 1 boot1 0 && mmc partconf 2 EXT_CSD[179], PARTITION_CONFIG: BOOT_ACK: 0x1 BOOT_PARTITION_ENABLE: 0x2 (boot1) PARTITION_ACCESS: 0x0
Signed-off-by: Tim Harvey tharvey@gateworks.com --- v2: - fix typo in subject - add names for gp1..gp4 --- cmd/mmc.c | 25 ++++++++++++++++++++++--- 1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/cmd/mmc.c b/cmd/mmc.c index 2d5430a53079..af9a66cc6df4 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -14,6 +14,18 @@ #include <part.h> #include <sparse_format.h> #include <image-sparse.h> +#include <linux/ctype.h> + +static const char *mmc_partnames[] = { + "user", + "boot0", + "boot1", + "gp1", + "gp2", + "gp3", + "gp4", + "user", +};
static int curr_device = -1;
@@ -918,8 +930,8 @@ static int mmc_partconf_print(struct mmc *mmc, const char *varname)
printf("EXT_CSD[179], PARTITION_CONFIG:\n" "BOOT_ACK: 0x%x\n" - "BOOT_PARTITION_ENABLE: 0x%x\n" - "PARTITION_ACCESS: 0x%x\n", ack, part, access); + "BOOT_PARTITION_ENABLE: 0x%x (%s)\n" + "PARTITION_ACCESS: 0x%x\n", ack, part, mmc_partnames[part], access);
return CMD_RET_SUCCESS; } @@ -949,7 +961,14 @@ static int do_mmc_partconf(struct cmd_tbl *cmdtp, int flag, return mmc_partconf_print(mmc, cmd_arg2(argc, argv));
ack = dectoul(argv[2], NULL); - part_num = dectoul(argv[3], NULL); + if (!isdigit(*argv[3])) { + for (part_num = 0; part_num < ARRAY_SIZE(mmc_partnames); part_num++) { + if (!strcmp(argv[3], mmc_partnames[part_num])) + break; + } + } else { + part_num = dectoul(argv[3], NULL); + } access = dectoul(argv[4], NULL);
/* acknowledge to be sent during boot operation */
v2:
- "user",
- "boot0",
- "boot1",
- "gp1",
- "gp2",
- "gp3",
- "gp4",
Uh, maybe gp%d are indexed from zero too ?
(sorry for the confusion)
v2:
"user",
"boot0",
"boot1",
"gp1",
"gp2",
"gp3",
"gp4",
but 'mmc hwpartition' does not list them 0 based: u-boot=> mmc hwpartition switch to partitions #0, OK mmc2(part 0) is current device Partition configuration: No enhanced user data area No GP1 partition No GP2 partition No GP3 partition No GP4 partition
I'm ok with either, I'm just not sure what is more understandable and standard.
Tim
v2:
"user",
"boot0",
"boot1",
"gp1",
"gp2",
"gp3",
"gp4",
Then 1-based counting is OK, thanks for checking !
Hello Tim and Marek,
"user",
"boot0",
"boot1",
"gp1",
"gp2",
"gp3",
"gp4",
I can confirm that JEDEC also starts the numbering of the GP partitions from one in some of its documents.
Though, it's a bit intriguing why the numbering of the boot partitions starts from zero. Perhaps there's some good reason for that difference.
"user",
"boot0",
"boot1",
"gp1",
"gp2",
"gp3",
"gp4",
Hmm, it seems that JEDEC actually starts the numbering of the boot partitions from one in some of its documents, instead of starting from zero. I'll try to research that better.
Dragan Simic
Tim Harvey
