[U-Boot] [PATCH v1] apalis/colibri_imx6: add device trees to makefile
Add device trees to Makefile to avoid newly introduced error:
Device Tree Source is not correctly specified. Please define 'CONFIG_DEFAULT_DEVICE_TREE' or build with 'DEVICE_TREE=<device_tree>' argument
make[1]: *** [dts/Makefile:28: arch/arm/dts/imx6-apalis.dtb] Error 1 make: *** [Makefile:1009: dts/dt.dtb] Error 2
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
arch/arm/dts/Makefile | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e261c5936b..7b7ccfd204 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -481,6 +481,10 @@ dtb-$(CONFIG_MX6UL) += \
dtb-$(CONFIG_MX6ULL) += imx6ull-14x14-evk.dtb
+dtb-$(CONFIG_ARCH_MX6) += \ + imx6-apalis.dtb \ + imx6-colibri.dtb + dtb-$(CONFIG_MX7) += imx7d-sdb.dtb \ imx7d-sdb-qspi.dtb
Hi Marcel,
Could you please provide steps to reproduce this issue? I've double checked on the latest master of u-boot-imx, and can sucessfully build U-boot for Colibri iMX6DL (as an example).
Thanks
imx6-apalis.dtb \
imx6-colibri.dtb
-- 2.20.1
Hi Igor
On Thu, 2019-03-28 at 16:49 +0000, Igor Opaniuk wrote:
Hi Marcel,
To be honest I don't remember exactly and can also no longer reproduce what happened. Just back when it happened this fixed it. However, at one point, I remember the discussion about having to add all device trees to the Makefile concluded in not requiring this. So we may also drop this patch then.
Thanks
Thank you.
Cheers
Marcel
imx6-apalis.dtb \
imx6-colibri.dtb
-- 2.20.1
Igor Opaniuk
Marcel Ziswiler
Marcel Ziswiler
