[U-Boot] [PATCH 0/3] RPi one binary for RPi3/4 and RPi1/2
In this series we prepare the RaspberryPi source code to be able to build one binary for RPi[3,4] and one for RPi[1,2]. To achieve this we need to set the IO base address on runtime. Apart from that, for arm64 we also need to set memory region correctly.
This patches fix this stuff. With this we could create one binary for each armv7 and armv8 based RPis. There is still some work to do to create a unified config, which will be done in a later patch series.
Matthias Brugger (3): ARM: bcm283x: Move BCM283x_BASE to a global variable ARM: bcm283x: Set rpi_bcm283x_base at run-time ARM: bcm283x: Set memory map at run-time
arch/arm/mach-bcm283x/Kconfig | 6 - arch/arm/mach-bcm283x/include/mach/base.h | 11 ++ arch/arm/mach-bcm283x/include/mach/mbox.h | 2 +- arch/arm/mach-bcm283x/include/mach/sdhci.h | 2 +- arch/arm/mach-bcm283x/include/mach/timer.h | 2 +- arch/arm/mach-bcm283x/include/mach/wdog.h | 2 +- arch/arm/mach-bcm283x/init.c | 123 +++++++++++++++++++++ arch/arm/mach-bcm283x/mbox.c | 8 +- arch/arm/mach-bcm283x/reset.c | 7 +- board/raspberrypi/rpi/lowlevel_init.S | 14 +++ board/raspberrypi/rpi/rpi.c | 45 -------- include/configs/rpi.h | 7 +- 12 files changed, 169 insertions(+), 60 deletions(-) create mode 100644 arch/arm/mach-bcm283x/include/mach/base.h
We move the per SOC define BCM283x_BASE to a global variable. This is a first step to provide a single binary for several bcm283x SoCs.
Signed-off-by: Matthias Brugger mbrugger@suse.com ---
arch/arm/mach-bcm283x/include/mach/base.h | 11 +++++++++++ arch/arm/mach-bcm283x/include/mach/mbox.h | 2 +- arch/arm/mach-bcm283x/include/mach/sdhci.h | 2 +- arch/arm/mach-bcm283x/include/mach/timer.h | 2 +- arch/arm/mach-bcm283x/include/mach/wdog.h | 2 +- arch/arm/mach-bcm283x/init.c | 8 ++++++++ arch/arm/mach-bcm283x/mbox.c | 8 ++++++-- arch/arm/mach-bcm283x/reset.c | 7 +++++-- board/raspberrypi/rpi/lowlevel_init.S | 8 ++++++++ include/configs/rpi.h | 7 ++++++- 10 files changed, 48 insertions(+), 9 deletions(-) create mode 100644 arch/arm/mach-bcm283x/include/mach/base.h
diff --git a/arch/arm/mach-bcm283x/include/mach/base.h b/arch/arm/mach-bcm283x/include/mach/base.h new file mode 100644 index 0000000000..c4ae39852f --- /dev/null +++ b/arch/arm/mach-bcm283x/include/mach/base.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * (C) Copyright 2019 Matthias Brugger + */ + +#ifndef _BCM283x_BASE_H_ +#define _BCM283x_BASE_H_ + +extern unsigned long rpi_bcm283x_base; + +#endif diff --git a/arch/arm/mach-bcm283x/include/mach/mbox.h b/arch/arm/mach-bcm283x/include/mach/mbox.h index 0b6c2543d5..39cf2cf9d5 100644 --- a/arch/arm/mach-bcm283x/include/mach/mbox.h +++ b/arch/arm/mach-bcm283x/include/mach/mbox.h @@ -37,7 +37,7 @@
/* Raw mailbox HW */
-#define BCM2835_MBOX_PHYSADDR (CONFIG_BCM283x_BASE + 0x0000b880) +#define BCM2835_MBOX_OFFSET 0x0000b880
struct bcm2835_mbox_regs { u32 read; diff --git a/arch/arm/mach-bcm283x/include/mach/sdhci.h b/arch/arm/mach-bcm283x/include/mach/sdhci.h index b443c379d8..16af5787c2 100644 --- a/arch/arm/mach-bcm283x/include/mach/sdhci.h +++ b/arch/arm/mach-bcm283x/include/mach/sdhci.h @@ -6,7 +6,7 @@ #ifndef _BCM2835_SDHCI_H_ #define _BCM2835_SDHCI_H_
-#define BCM2835_SDHCI_BASE (CONFIG_BCM283x_BASE + 0x00300000) +#define BCM2835_SDHCI_OFFSET 0x00300000
int bcm2835_sdhci_init(u32 regbase, u32 emmc_freq);
diff --git a/arch/arm/mach-bcm283x/include/mach/timer.h b/arch/arm/mach-bcm283x/include/mach/timer.h index 014355e759..c789e188be 100644 --- a/arch/arm/mach-bcm283x/include/mach/timer.h +++ b/arch/arm/mach-bcm283x/include/mach/timer.h @@ -6,7 +6,7 @@ #ifndef _BCM2835_TIMER_H #define _BCM2835_TIMER_H
-#define BCM2835_TIMER_PHYSADDR (CONFIG_BCM283x_BASE + 0x00003000) +#define BCM2835_TIMER_OFFSET 0x00003000
#define BCM2835_TIMER_CS_M3 (1 << 3) #define BCM2835_TIMER_CS_M2 (1 << 2) diff --git a/arch/arm/mach-bcm283x/include/mach/wdog.h b/arch/arm/mach-bcm283x/include/mach/wdog.h index 8292b3cf1f..2ca0e8c035 100644 --- a/arch/arm/mach-bcm283x/include/mach/wdog.h +++ b/arch/arm/mach-bcm283x/include/mach/wdog.h @@ -6,7 +6,7 @@ #ifndef _BCM2835_WDOG_H #define _BCM2835_WDOG_H
-#define BCM2835_WDOG_PHYSADDR (CONFIG_BCM283x_BASE + 0x00100000) +#define BCM2835_WDOG_OFFSET 0x00100000
struct bcm2835_wdog_regs { u32 unknown0[7]; diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index 97414415a6..9dcc96ba2e 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -8,6 +8,8 @@
#include <common.h>
+extern unsigned long rpi_bcm283x_base; + int arch_cpu_init(void) { icache_enable(); @@ -15,6 +17,12 @@ int arch_cpu_init(void) return 0; }
+int mach_cpu_init(void) +{ + rpi_bcm283x_base = CONFIG_BCM283x_BASE; + + return 0; +} #ifdef CONFIG_ARMV7_LPAE void enable_caches(void) { diff --git a/arch/arm/mach-bcm283x/mbox.c b/arch/arm/mach-bcm283x/mbox.c index 3c67f68c17..21a7ce113d 100644 --- a/arch/arm/mach-bcm283x/mbox.c +++ b/arch/arm/mach-bcm283x/mbox.c @@ -10,13 +10,17 @@
#define TIMEOUT 1000 /* ms */
+extern unsigned long rpi_bcm283x_base; + int bcm2835_mbox_call_raw(u32 chan, u32 send, u32 *recv) { - struct bcm2835_mbox_regs *regs = - (struct bcm2835_mbox_regs *)BCM2835_MBOX_PHYSADDR; + struct bcm2835_mbox_regs *regs; ulong endtime = get_timer(0) + TIMEOUT; u32 val;
+ regs = (struct bcm2835_mbox_regs *)(rpi_bcm283x_base + + BCM2835_MBOX_OFFSET); + debug("time: %lu timeout: %lu\n", get_timer(0), endtime);
if (send & BCM2835_CHAN_MASK) { diff --git a/arch/arm/mach-bcm283x/reset.c b/arch/arm/mach-bcm283x/reset.c index b3da0c7cd6..aff894b3c6 100644 --- a/arch/arm/mach-bcm283x/reset.c +++ b/arch/arm/mach-bcm283x/reset.c @@ -11,6 +11,8 @@ #include <asm/arch/wdog.h> #include <efi_loader.h>
+extern unsigned long rpi_bcm283x_base; + #define RESET_TIMEOUT 10
/* @@ -25,8 +27,7 @@
void hw_watchdog_disable(void) {}
-__efi_runtime_data struct bcm2835_wdog_regs *wdog_regs = - (struct bcm2835_wdog_regs *)BCM2835_WDOG_PHYSADDR; +__efi_runtime_data struct bcm2835_wdog_regs *wdog_regs;
void __efi_runtime reset_cpu(ulong ticks) { @@ -77,6 +78,8 @@ void __efi_runtime EFIAPI efi_reset_system(
efi_status_t efi_reset_system_init(void) { + wdog_regs = (struct bcm2835_wdog_regs *)(rpi_bcm283x_base + + BCM2835_WDOG_OFFSET); return efi_add_runtime_mmio(&wdog_regs, sizeof(*wdog_regs)); }
diff --git a/board/raspberrypi/rpi/lowlevel_init.S b/board/raspberrypi/rpi/lowlevel_init.S index 435eed521f..fcb99ebef7 100644 --- a/board/raspberrypi/rpi/lowlevel_init.S +++ b/board/raspberrypi/rpi/lowlevel_init.S @@ -7,6 +7,14 @@ #include <config.h>
.align 8 +.global rpi_bcm283x_base +rpi_bcm283x_base: +#ifdef CONFIG_ARM64 + .dword 0x0 +#else + .word 0x0 +#endif + .global fw_dtb_pointer fw_dtb_pointer: #ifdef CONFIG_ARM64 diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 77d2d5458a..88496ac44d 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -9,6 +9,10 @@ #include <linux/sizes.h> #include <asm/arch/timer.h>
+#ifndef __ASSEMBLY__ +#include <asm/arch/base.h> +#endif + #if defined(CONFIG_TARGET_RPI_2) || defined(CONFIG_TARGET_RPI_3_32B) #define CONFIG_SKIP_LOWLEVEL_INIT #endif @@ -19,7 +23,8 @@ #ifndef CONFIG_ARM64 #define CONFIG_SYS_TIMER_RATE 1000000 #define CONFIG_SYS_TIMER_COUNTER \ - (&((struct bcm2835_timer_regs *)BCM2835_TIMER_PHYSADDR)->clo) + (&((struct bcm2835_timer_regs *)(rpi_bcm283x_base \ + + BCM2835_TIMER_OFFSET))->clo) #endif
- (C) Copyright 2019 Matthias Brugger
Why rename and not just redefine as (rpi_bcm283x_base + 0x000...)? Also, you may want to add a BUG_ON(!rpi_bcm283x_base) in the query. There was some fancy way to do that in C. Something like
#define BCM2835_MBOX_PHYSADDR ({ BUG_ON(!rpi_bcm283x_base); rpi_bcm283x_base + 0x0000b880; })
may do the trick.
Also, shouldn't mbox.h just contain the definition for rpi_bcm283x_base?
#include <common.h>
Why doesn't this just include the header that you create above?
- int arch_cpu_init(void) { icache_enable();
- rpi_bcm283x_base = CONFIG_BCM283x_BASE;
Header?
Alex
- int bcm2835_mbox_call_raw(u32 chan, u32 send, u32 *recv) {
@@ -25,8 +27,7 @@
- wdog_regs = (struct bcm2835_wdog_regs *)(rpi_bcm283x_base +
return efi_add_runtime_mmio(&wdog_regs, sizeof(*wdog_regs)); }BCM2835_WDOG_OFFSET);
- .dword 0x0
+#else
- .word 0x0
- .global fw_dtb_pointer fw_dtb_pointer: #ifdef CONFIG_ARM64
- #if defined(CONFIG_TARGET_RPI_2) || defined(CONFIG_TARGET_RPI_3_32B) #define CONFIG_SKIP_LOWLEVEL_INIT #endif
#endif
How will this work, given that the memory layout is hard-coded into the the DTB?
Hopefully we aren't going to do some kind of nasty bundle-all-the-dtbs-and-select-between-them approach, or edit-the-dtb-at-runtime.
With CONFIG_OF_BOARD the DT comes from the RPi firmware blob which already provides the correct DTB for the target system.
Alex
OK. Why does the U-Boot source code contain RPi DTBs then? Were they just not deleted when that CONFIG_ option was enabled, or is the transition to using FW-supplied DTBs still a work-in-progress?
The default option is to not use CONFIG_OF_BOARD. Making that the default is exactly what Matthias was referring to as a later step to enable a single binary.
Alex
As part of the effort to create one binary for several bcm83x SoCs we use the SoC compatible to decide which IO base address we use.
arch/arm/mach-bcm283x/Kconfig | 6 ---- arch/arm/mach-bcm283x/init.c | 60 ++++++++++++++++++++++++++++++++++- 2 files changed, 59 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-bcm283x/Kconfig b/arch/arm/mach-bcm283x/Kconfig index b08275f598..e8e0ff0eb4 100644 --- a/arch/arm/mach-bcm283x/Kconfig +++ b/arch/arm/mach-bcm283x/Kconfig @@ -202,10 +202,4 @@ config SYS_SOC config SYS_CONFIG_NAME default "rpi"
-config BCM283x_BASE - hex - default "0x20000000" if BCM2835 - default "0x3f000000" if BCM2836 || BCM2837 - default "0xfe000000" if BCM2711 - endmenu diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index 9dcc96ba2e..214e1078eb 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -7,9 +7,49 @@ */
#include <common.h> +#include <dm/device.h> + +#define PDATA_BCM2835 0 +#define PDATA_BCM2836 1 +#define PDATA_BCM2837 2 +#define PDATA_BCM2838 3
+struct bcm283x_pdata { + unsigned long io_base; +}; + +struct bcm283x_pdata pdata_bcm283x[] = { + [PDATA_BCM2835] = { + .io_base = 0x20000000, + }, + [PDATA_BCM2836] = { + .io_base = 0x3f000000, + }, +#ifdef CONFIG_ARM64 + [PDATA_BCM2837] = { + .io_base = 0x3f000000, + }, + [PDATA_BCM2838] = { + .io_base = 0xfe000000, + }, +#endif +}; + +/* + * I/O address space varies on different chip versions. + * We set the base address by inspecting the DTB. + */ +static const struct udevice_id board_ids[] = { + { .compatible = "brcm,bcm2835", .data = PDATA_BCM2835}, + { .compatible = "brcm,bcm2836", .data = PDATA_BCM2836}, + { .compatible = "brcm,bcm2837", .data = PDATA_BCM2837}, + { .compatible = "brcm,bcm2838", .data = PDATA_BCM2838}, + { .compatible = "brcm,bcm2711", .data = PDATA_BCM2838}, + { }, +}; + int arch_cpu_init(void) { icache_enable(); @@ -19,10 +59,28 @@ int arch_cpu_init(void)
int mach_cpu_init(void) { - rpi_bcm283x_base = CONFIG_BCM283x_BASE; + const struct udevice_id *of_match = board_ids; + int ret; + + rpi_bcm283x_base = 0; + + while (of_match->compatible) { + struct bcm283x_pdata pdat; + + ret = fdt_node_check_compatible(gd->fdt_blob, 0, + of_match->compatible); + if (!ret) { + pdat = pdata_bcm283x[of_match->data]; + rpi_bcm283x_base = pdat.io_base; + break; + } + + of_match++; + }
return 0; } + #ifdef CONFIG_ARMV7_LPAE void enable_caches(void) {
- hex
- endmenu
- unsigned long io_base;
- [PDATA_BCM2835] = {
- [PDATA_BCM2836] = {
- [PDATA_BCM2837] = {
- [PDATA_BCM2838] = {
+#endif +};
- I/O address space varies on different chip versions.
- We set the base address by inspecting the DTB.
- { .compatible = "brcm,bcm2835", .data = PDATA_BCM2835},
- { .compatible = "brcm,bcm2836", .data = PDATA_BCM2836},
- { .compatible = "brcm,bcm2837", .data = PDATA_BCM2837},
- { .compatible = "brcm,bcm2838", .data = PDATA_BCM2838},
- { .compatible = "brcm,bcm2711", .data = PDATA_BCM2838},
Does this match all of the downstream dtbs as well as the upstream ones?
Alex
int ret;
if (!ret) {
break;
of_match++;
return 0; }
diff --git a/arch/arm/mach-bcm283x/Kconfig b/arch/arm/mach-bcm283x/Kconfig index b08275f598..e8e0ff0eb4 100644 --- a/arch/arm/mach-bcm283x/Kconfig +++ b/arch/arm/mach-bcm283x/Kconfig @@ -202,10 +202,4 @@ config SYS_SOC config SYS_CONFIG_NAME default "rpi" -config BCM283x_BASE - hex - default "0x20000000" if BCM2835 - default "0x3f000000" if BCM2836 || BCM2837 - default "0xfe000000" if BCM2711
endmenu diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index 9dcc96ba2e..214e1078eb 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -7,9 +7,49 @@ */ #include <common.h> +#include <dm/device.h>
+#define PDATA_BCM2835 0 +#define PDATA_BCM2836 1 +#define PDATA_BCM2837 2 +#define PDATA_BCM2838 3 extern unsigned long rpi_bcm283x_base; +struct bcm283x_pdata { + unsigned long io_base; +};
Yes, for RPi[1-3] upstream and downstream are the same for RPi4 the RaspberryPi FW is getting fixes by adding the upstream compatible, so I added both, the old downstream (bcm2838) and the upstream (bcm2711) one.
Regards, Matthias
Alex
int arch_cpu_init(void) { icache_enable(); @@ -19,10 +59,28 @@ int arch_cpu_init(void) int mach_cpu_init(void) { - rpi_bcm283x_base = CONFIG_BCM283x_BASE; + const struct udevice_id *of_match = board_ids; + int ret;
+ of_match++; + } return 0; }
For bcm283x based on arm64 we also have to change the mm_region. Add assign this in mach_cpu_init() so we can create now one binary for RPi3 and RPi4.
arch/arm/mach-bcm283x/init.c | 65 +++++++++++++++++++++++++-- board/raspberrypi/rpi/lowlevel_init.S | 6 +++ board/raspberrypi/rpi/rpi.c | 45 ------------------- 3 files changed, 67 insertions(+), 49 deletions(-)
diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index 214e1078eb..f6c2946922 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -8,16 +8,68 @@
#include <common.h> #include <dm/device.h> +#ifdef CONFIG_ARM64 +#include <asm/armv8/mmu.h> +#endif
#define PDATA_BCM2835 0 #define PDATA_BCM2836 1 #define PDATA_BCM2837 2 -#define PDATA_BCM2838 3 +#define PDATA_BCM2711 3
+#ifdef CONFIG_ARM64 +extern struct mm_region *mem_map; + +static struct mm_region bcm283x_mem_map[] = { + { + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0x3f000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0x3f000000UL, + .phys = 0x3f000000UL, + .size = 0x01000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + +static struct mm_region bcm2711_mem_map[] = { + { + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0xfe000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0xfe000000UL, + .phys = 0xfe000000UL, + .size = 0x01800000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; +#else +struct mm_region { + /* dummy struct */ +}; +#endif + struct bcm283x_pdata { unsigned long io_base; + struct mm_region *m_map; };
struct bcm283x_pdata pdata_bcm283x[] = { @@ -30,9 +82,11 @@ struct bcm283x_pdata pdata_bcm283x[] = { #ifdef CONFIG_ARM64 [PDATA_BCM2837] = { .io_base = 0x3f000000, + .m_map = bcm283x_mem_map, }, - [PDATA_BCM2838] = { + [PDATA_BCM2711] = { .io_base = 0xfe000000, + .m_map = bcm2711_mem_map }, #endif }; @@ -45,8 +99,8 @@ static const struct udevice_id board_ids[] = { { .compatible = "brcm,bcm2835", .data = PDATA_BCM2835}, { .compatible = "brcm,bcm2836", .data = PDATA_BCM2836}, { .compatible = "brcm,bcm2837", .data = PDATA_BCM2837}, - { .compatible = "brcm,bcm2838", .data = PDATA_BCM2838}, - { .compatible = "brcm,bcm2711", .data = PDATA_BCM2838}, + { .compatible = "brcm,bcm2838", .data = PDATA_BCM2711}, + { .compatible = "brcm,bcm2711", .data = PDATA_BCM2711}, { }, };
@@ -72,6 +126,9 @@ int mach_cpu_init(void) if (!ret) { pdat = pdata_bcm283x[of_match->data]; rpi_bcm283x_base = pdat.io_base; +#ifdef CONFIG_ARM64 + mem_map = pdat.m_map; +#endif break; }
diff --git a/board/raspberrypi/rpi/lowlevel_init.S b/board/raspberrypi/rpi/lowlevel_init.S index fcb99ebef7..9786a5a4b3 100644 --- a/board/raspberrypi/rpi/lowlevel_init.S +++ b/board/raspberrypi/rpi/lowlevel_init.S @@ -23,6 +23,12 @@ fw_dtb_pointer: .word 0x0 #endif
+#ifdef CONFIG_ARM64 +.global mem_map +mem_map: + .dword 0x0 +#endif + /* * Routine: save_boot_params (called after reset from start.S) * Description: save ATAG/FDT address provided by the firmware at boot time diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 9e0abdda31..cf1666ce5f 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -248,51 +248,6 @@ static uint32_t rev_scheme; static uint32_t rev_type; static const struct rpi_model *model;
-#ifdef CONFIG_ARM64 -#ifndef CONFIG_BCM2711 -static struct mm_region bcm283x_mem_map[] = { - { - .virt = 0x00000000UL, - .phys = 0x00000000UL, - .size = 0x3f000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x3f000000UL, - .phys = 0x3f000000UL, - .size = 0x01000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; -#else -static struct mm_region bcm283x_mem_map[] = { - { - .virt = 0x00000000UL, - .phys = 0x00000000UL, - .size = 0xfe000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xfe000000UL, - .phys = 0xfe000000UL, - .size = 0x01800000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; -#endif -struct mm_region *mem_map = bcm283x_mem_map; -#endif - int dram_init(void) { ALLOC_CACHE_ALIGN_BUFFER(struct msg_get_arm_mem, msg, 1);
What is this change?
0,
0,
- /* dummy struct */
+}; +#endif
},.m_map = bcm283x_mem_map,
- [PDATA_BCM2711] = { .io_base = 0xfe000000,
}, #endif };.m_map = bcm2711_mem_map
- { .compatible = "brcm,bcm2838", .data = PDATA_BCM2711},
- { .compatible = "brcm,bcm2711", .data = PDATA_BCM2711}, { }, };
+#endif break; }
- .dword 0x0
Why does this live in .S?
Alex
- Routine: save_boot_params (called after reset from start.S)
- Description: save ATAG/FDT address provided by the firmware at boot time
0,
0,
diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index 214e1078eb..f6c2946922 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -8,16 +8,68 @@ #include <common.h> #include <dm/device.h> +#ifdef CONFIG_ARM64 +#include <asm/armv8/mmu.h> +#endif #define PDATA_BCM2835 0 #define PDATA_BCM2836 1 #define PDATA_BCM2837 2 -#define PDATA_BCM2838 3 +#define PDATA_BCM2711 3
Wrong patch, I will fix this in v2.
extern unsigned long rpi_bcm283x_base; +#ifdef CONFIG_ARM64 +extern struct mm_region *mem_map;
struct bcm283x_pdata { unsigned long io_base; + struct mm_region *m_map; }; struct bcm283x_pdata pdata_bcm283x[] = { @@ -30,9 +82,11 @@ struct bcm283x_pdata pdata_bcm283x[] = { #ifdef CONFIG_ARM64 [PDATA_BCM2837] = { .io_base = 0x3f000000, + .m_map = bcm283x_mem_map, }, - [PDATA_BCM2838] = { + [PDATA_BCM2711] = { .io_base = 0xfe000000, + .m_map = bcm2711_mem_map }, #endif }; @@ -45,8 +99,8 @@ static const struct udevice_id board_ids[] = { { .compatible = "brcm,bcm2835", .data = PDATA_BCM2835}, { .compatible = "brcm,bcm2836", .data = PDATA_BCM2836}, { .compatible = "brcm,bcm2837", .data = PDATA_BCM2837}, - { .compatible = "brcm,bcm2838", .data = PDATA_BCM2838}, - { .compatible = "brcm,bcm2711", .data = PDATA_BCM2838}, + { .compatible = "brcm,bcm2838", .data = PDATA_BCM2711}, + { .compatible = "brcm,bcm2711", .data = PDATA_BCM2711}, { }, }; @@ -72,6 +126,9 @@ int mach_cpu_init(void) if (!ret) { pdat = pdata_bcm283x[of_match->data]; rpi_bcm283x_base = pdat.io_base; +#ifdef CONFIG_ARM64 + mem_map = pdat.m_map; +#endif break; } diff --git a/board/raspberrypi/rpi/lowlevel_init.S b/board/raspberrypi/rpi/lowlevel_init.S index fcb99ebef7..9786a5a4b3 100644 --- a/board/raspberrypi/rpi/lowlevel_init.S +++ b/board/raspberrypi/rpi/lowlevel_init.S @@ -23,6 +23,12 @@ fw_dtb_pointer: .word 0x0 #endif +#ifdef CONFIG_ARM64 +.global mem_map +mem_map: + .dword 0x0 +#endif
It took me some time but now I think I understand what happens. rpi_bcm283x_base and mem_map are assigned in mach_cpu_init. My understanding is that for this function holds the same as for board_init_f (from Readme): - BSS is not available, so you cannot use global/static variables, only stack variables and global_data
If we put the declaration of both variables in a source file, it will be put into .bss and we won't be able to boot.
The whole low_level.S lives in text_rest, so if I add __attribute__ ((section (".text"))) to the declaration of the variables in, let's say, init.c I get a compiler warning but U-Boot works as expected.
So my question is now, how to proceed. I could add them in the global_data arch struct. That would work for fine for rpi_bcm283x_base but would need to some bigger changes for mem_map as this is used by armv8 code for all SoCs.
Any idea?
Regards, Matthias
Alex
/* * Routine: save_boot_params (called after reset from start.S) * Description: save ATAG/FDT address provided by the firmware at boot time diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 9e0abdda31..cf1666ce5f 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -248,51 +248,6 @@ static uint32_t rev_scheme; static uint32_t rev_type; static const struct rpi_model *model; -#ifdef CONFIG_ARM64 -#ifndef CONFIG_BCM2711 -static struct mm_region bcm283x_mem_map[] = { - { - .virt = 0x00000000UL, - .phys = 0x00000000UL, - .size = 0x3f000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x3f000000UL, - .phys = 0x3f000000UL, - .size = 0x01000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; -#else -static struct mm_region bcm283x_mem_map[] = { - { - .virt = 0x00000000UL, - .phys = 0x00000000UL, - .size = 0xfe000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xfe000000UL, - .phys = 0xfe000000UL, - .size = 0x01800000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - /* List terminator */ - 0, - } -}; -#endif -struct mm_region *mem_map = bcm283x_mem_map; -#endif
Why not just force put it in ".data"? In fact, it might be as simple as
extern struct mm_region *mem_map = bcm283x_mem_map;
which should already move it right into .data. Then you only need to special the RPi4 (and above).
Alex
Any idea?
Regards, Matthias
Alex
Alexander Graf
Matthias Brugger
Stephen Warren
