[PATCH 1/1] efi_selftest: can't have measured device-tree with kaslr-seed
Test that we don't have a /chosen/kaslr-seed property if we measure the device-tree.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_selftest/efi_selftest_fdt.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/lib/efi_selftest/efi_selftest_fdt.c b/lib/efi_selftest/efi_selftest_fdt.c index aa3b13ae3ab..066d9581432 100644 --- a/lib/efi_selftest/efi_selftest_fdt.c +++ b/lib/efi_selftest/efi_selftest_fdt.c @@ -227,6 +227,13 @@ static int execute(void) return EFI_ST_FAILURE; } } + if (IS_ENABLED(CONFIG_EFI_TCG2_PROTOCOL_MEASURE_DTB)) { + str = get_property(u"kaslr-seed", u"chosen"); + if (str) { + efi_st_error("kaslr-seed with measured fdt\n"); + return EFI_ST_FAILURE; + } + } if (IS_ENABLED(CONFIG_RISCV)) { u32 fdt_hartid;
On Tue, 18 Jun 2024 at 15:24, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
if (str) {
When does this run? efi_try_purge_kaslr_seed() tries to remove the kaslr-seed before measuring a DT. Are we safe enavbling the check here?
Thanks /Ilias
-- 2.45.1
if (str) {
do_efi_selftest() is called after efi_install_fdt(). efi_install_fdt() invokes efi_try_purge_kaslr_seed().
We would get an error here if efi_try_purge_kaslr_seed() were removed and measuring the DTB enabled.
Best regards
Heinrich
Thanks /Ilias
-- 2.45.1
On Sat, 22 Jun 2024 at 17:58, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
if (str) {
Best regards
Thanks! That's what I was wondering
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Heinrich
Thanks /Ilias
-- 2.45.1
Ilias Apalodimas
