[U-Boot] [PATCH 1/2] ARM: exynos: Fix build error if SERIAL is disabled in SPL
If CONFIG_SPL_SERIAL_SUPPORT is not defined in include/configs/exynos5-common.h the following error is produced during the build of the SPL:
arch/arm/mach-exynos/built-in.o: In function `do_lowlevel_init': ...u-boot/arch/arm/mach-exynos/lowlevel_init.c:221: undefined reference to `debug_uart_init'
Add additional condition to check if SPL build is in progress and in that case check if CONFIG_SPL_SERIAL_SUPPORT is also set before enabling the debug UART.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- arch/arm/mach-exynos/lowlevel_init.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-exynos/lowlevel_init.c b/arch/arm/mach-exynos/lowlevel_init.c index 6c39cb2..1e090fd 100644 --- a/arch/arm/mach-exynos/lowlevel_init.c +++ b/arch/arm/mach-exynos/lowlevel_init.c @@ -216,9 +216,12 @@ int do_lowlevel_init(void) if (actions & DO_CLOCKS) { system_clock_init(); #ifdef CONFIG_DEBUG_UART +#if (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL_SUPPORT)) || \ + !defined(CONFIG_SPL_BUILD) exynos_pinmux_config(PERIPH_ID_UART3, PINMUX_FLAG_NONE); debug_uart_init(); #endif +#endif mem_ctrl_init(actions & DO_MEM_RESET); tzpc_init(); }
The exynos5 platforms use DM in U-Boot and do not use DM in SPL. The serial driver, serial_s5p.c, is DM-only. This is OK for U-Boot, but in SPL, this will fail with the following compile error:
drivers/built-in.o: In function `get_current': ...u-boot/drivers/serial/serial.c:387: undefined reference to `default_serial_console'
This warning happens because common/console.c is compiled into U-Boot SPL if CONFIG_SPL_SERIAL_SUPPORT . The common/console.c invokes serial_*() functions and since exynos5 does not use DM in SPL, these functions come from drivers/serial/serial.c . The serial_*() locate default serial port by calling default_serial_console(), but because the serial_s5p.c is DM-only, it does no longer define default_serial_console(). Thus the error.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- include/configs/exynos5-common.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index b2ff4dd..6846ad6 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -60,7 +60,6 @@
#define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_GPIO_SUPPORT -#define CONFIG_SPL_SERIAL_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT
/* specific .lds file */
This is OK short term, can you see if turning on DM in SPL is easy for these platforms instead? Thanks!
Yes, indeed.
I hope Simon can take a look into that ;-)
Yes, indeed.
applied to u-boot-samsung.
Thanks, Minkyu Kang.
+Minkyu
On 02/05/16 03:55, Simon Glass wrote:
+Minkyu
Minkyu Kang
