[U-Boot] Converting serial_s3c24x0.c to driver model
Hi David,
I'm sorry if you have not heard about this before. I sent out an email to all maintainers some months ago.
You are listed as the maintainer of a few boards which use the serial_s3c24x0.c serial driver. We are trying to convert all of these drivers to driver model. Please see doc/driver-model/serial-howto.txt.
Do you have an update please?
Hello
Simon Glass wrote:
I'm sorry if you have not heard about this before. I sent out an email to all maintainers some months ago. You are listed as the maintainer of a few boards which use the serial_s3c24x0.c serial driver. We are trying to convert all of these drivers to driver model. Please see doc/driver-model/serial-howto.txt.
Sorry, seems that I missed your previous message somehow.
Dave
Hi David,
On 2 February 2016 at 08:59, David Müller (ELSOFT AG) d.mueller@elsoft.ch wrote:
Hello
I'm sorry about that. - it was a cc to you in November. Are you planning to take a look at this?
Hello
While trying to convert the serial_s3c24x0.c driver to DM, I noticed that no offical U-Boot configuration seems to be using the CONFIG_MODEM_SUPPORT or CONFIG_HWFLOW option.
Do you know if these two options are still in use somewhere else? Or can all the references to these options be removed irrevocably?
git grep CONFIG_MODEM_SUPPORT | uniq
README: CONFIG_MODEM_SUPPORT arch/powerpc/cpu/mpc8xx/serial.c:#ifdef CONFIG_MODEM_SUPPORT common/Makefile:obj-$(CONFIG_MODEM_SUPPORT) += modem.o common/board_f.c:#ifdef CONFIG_MODEM_SUPPORT common/main.c:#ifdef CONFIG_MODEM_SUPPORT drivers/serial/serial_s3c24x0.c:#ifdef CONFIG_MODEM_SUPPORT include/asm-generic/global_data.h:#ifdef CONFIG_MODEM_SUPPORT
git grep CONFIG_HWFLOW | uniq
README: CONFIG_HWFLOW common/modem.c:#ifdef CONFIG_HWFLOW doc/README.Modem:UART driver supports it (see CONFIG_HWFLOW compile-time flag in drivers/serial/serial_imx.c:#ifdef CONFIG_HWFLOW drivers/serial/serial_s3c24x0.c:#ifdef CONFIG_HWFLOW
Dave
On Fri, Feb 05, 2016 at 11:59:17AM +0100, David Müller (ELSOFT AG) wrote:
Hello
I think all boards have been removed so yes, go ahead and drop the code as a pre-req patch to the DM work you're doing, thanks!
Dear David,
IIRC the modem support was added more than a decade ago for a specific board which has been removed from the tree long ago. I cannot remember that any other user has questions or problems with that code, so probably nobody else ever used it.
I think chances are good that you can remove this stuff and nobody would ever notice ;-)
