[PATCH v4] video: sunxi_display: Convert to DM_VIDEO
DM_VIDEO migration deadline is already expired, but around 80 Allwinner boards are still using video in a legacy way:
===================== WARNING ====================== This board does not use CONFIG_DM_VIDEO Please update the board to use CONFIG_DM_VIDEO before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ====================================================
Convert the legacy video driver over to the DM_VIDEO framework. This is a minimal conversion: it doesn't use the DT for finding its resources, nor does it use DM clocks or DM devices for the outputs (LCD, HDMI, CVBS).
Tested in Bananapi M1+ Plus 1920x1200 HDMI out. (Jagan)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com [Andre: rebase and smaller fixes] Signed-off-by: Andre Przywara andre.przywara@arm.com Acked-by: Maxime Ripard mripard@kernel.org Reviewed-by: Jernej Skrabec jernej.skrabec@siol.net Reviewed-by: Simon Glass sjg@chromium.org --- Hi,
some very small fixes, to address Jernej's and Simon's comments. As we figured, there is more improvement potential, but this should be a good first step.
Cheers, Andre
Changelog v3 .. v4: - remove no longer needed definitions in sunxi-common.h - rename struct sunxi_display to struct sunxi_display_priv - use VNBYTES to calculate bit depth - use ALIGN instead of open coding it
Changelog v2 .. v3: - rebase against master, fixing up renamed variables and structs - replace enum with #define - remove BMP from Kconfig - fix memory node size calculation in simplefb setup
arch/arm/mach-sunxi/Kconfig | 9 +- drivers/video/sunxi/sunxi_display.c | 268 ++++++++++++++++------------ include/configs/sunxi-common.h | 23 +-- scripts/config_whitelist.txt | 1 - 4 files changed, 159 insertions(+), 142 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 0135575ca1e..a29d11505aa 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -816,13 +816,14 @@ config VIDEO_SUNXI depends on !MACH_SUN9I depends on !MACH_SUN50I depends on !SUN50I_GEN_H6 - select VIDEO + select DM_VIDEO + select DISPLAY imply VIDEO_DT_SIMPLEFB default y ---help--- - Say Y here to add support for using a cfb console on the HDMI, LCD - or VGA output found on most sunxi devices. See doc/README.video for - info on how to select the video output and mode. + Say Y here to add support for using a graphical console on the HDMI, + LCD or VGA output found on older sunxi devices. This will also provide + a simple_framebuffer device for Linux.
config VIDEO_HDMI bool "HDMI output support" diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index f52aba4d21c..4361a58cd7e 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -7,6 +7,8 @@ */
#include <common.h> +#include <display.h> +#include <dm.h> #include <cpu_func.h> #include <efi_loader.h> #include <init.h> @@ -28,7 +30,9 @@ #include <fdt_support.h> #include <i2c.h> #include <malloc.h> +#include <video.h> #include <video_fb.h> +#include <dm/uclass-internal.h> #include "../videomodes.h" #include "../anx9804.h" #include "../hitachi_tx18d42vm_lcd.h" @@ -45,6 +49,11 @@
DECLARE_GLOBAL_DATA_PTR;
+/* Maximum LCD size we support */ +#define LCD_MAX_WIDTH 3840 +#define LCD_MAX_HEIGHT 2160 +#define LCD_MAX_LOG2_BPP VIDEO_BPP32 + enum sunxi_monitor { sunxi_monitor_none, sunxi_monitor_dvi, @@ -58,13 +67,12 @@ enum sunxi_monitor { }; #define SUNXI_MONITOR_LAST sunxi_monitor_composite_pal_nc
-struct sunxi_display { - GraphicDevice graphic_device; +struct sunxi_display_priv { enum sunxi_monitor monitor; unsigned int depth; unsigned int fb_addr; unsigned int fb_size; -} sunxi_display; +};
const struct ctfb_res_modes composite_video_modes[2] = { /* x y hz pixclk ps/kHz le ri up lo hs vs s vmode */ @@ -214,7 +222,8 @@ static int sunxi_hdmi_edid_get_block(int block, u8 *buf) return r; }
-static int sunxi_hdmi_edid_get_mode(struct ctfb_res_modes *mode, +static int sunxi_hdmi_edid_get_mode(struct sunxi_display_priv *sunxi_display, + struct ctfb_res_modes *mode, bool verbose_mode) { struct edid1_info edid1; @@ -291,14 +300,14 @@ static int sunxi_hdmi_edid_get_mode(struct ctfb_res_modes *mode, }
/* Check for basic audio support, if found enable hdmi output */ - sunxi_display.monitor = sunxi_monitor_dvi; + sunxi_display->monitor = sunxi_monitor_dvi; for (i = 0; i < ext_blocks; i++) { if (cea681[i].extension_tag != EDID_CEA861_EXTENSION_TAG || cea681[i].revision < 2) continue;
if (EDID_CEA861_SUPPORTS_BASIC_AUDIO(cea681[i])) - sunxi_display.monitor = sunxi_monitor_hdmi; + sunxi_display->monitor = sunxi_monitor_hdmi; }
return 0; @@ -414,9 +423,9 @@ static void sunxi_frontend_mode_set(const struct ctfb_res_modes *mode, static void sunxi_frontend_enable(void) {} #endif
-static bool sunxi_is_composite(void) +static bool sunxi_is_composite(enum sunxi_monitor monitor) { - switch (sunxi_display.monitor) { + switch (monitor) { case sunxi_monitor_none: case sunxi_monitor_dvi: case sunxi_monitor_hdmi: @@ -473,7 +482,8 @@ static const u32 sunxi_rgb2yuv_coef[12] = { };
static void sunxi_composer_mode_set(const struct ctfb_res_modes *mode, - unsigned int address) + unsigned int address, + enum sunxi_monitor monitor) { struct sunxi_de_be_reg * const de_be = (struct sunxi_de_be_reg *)SUNXI_DE_BE0_BASE; @@ -502,7 +512,7 @@ static void sunxi_composer_mode_set(const struct ctfb_res_modes *mode, #endif SUNXI_DE_BE_MODE_INTERLACE_ENABLE);
- if (sunxi_is_composite()) { + if (sunxi_is_composite(monitor)) { writel(SUNXI_DE_BE_OUTPUT_COLOR_CTRL_ENABLE, &de_be->output_color_ctrl); for (i = 0; i < 12; i++) @@ -616,7 +626,8 @@ static void sunxi_lcdc_backlight_enable(void) gpio_direction_output(pin, PWM_ON); }
-static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode, +static void sunxi_lcdc_tcon0_mode_set(struct sunxi_display_priv *sunxi_display, + const struct ctfb_res_modes *mode, bool for_ext_vga_dac) { struct sunxi_lcdc_reg * const lcdc = @@ -643,17 +654,18 @@ static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode, }
lcdc_pll_set(ccm, 0, mode->pixclock_khz, &clk_div, &clk_double, - sunxi_is_composite()); + sunxi_is_composite(sunxi_display->monitor));
video_ctfb_mode_to_display_timing(mode, &timing); lcdc_tcon0_mode_set(lcdc, &timing, clk_div, for_ext_vga_dac, - sunxi_display.depth, CONFIG_VIDEO_LCD_DCLK_PHASE); + sunxi_display->depth, CONFIG_VIDEO_LCD_DCLK_PHASE); }
#if defined CONFIG_VIDEO_HDMI || defined CONFIG_VIDEO_VGA || defined CONFIG_VIDEO_COMPOSITE static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, int *clk_div, int *clk_double, - bool use_portd_hvsync) + bool use_portd_hvsync, + enum sunxi_monitor monitor) { struct sunxi_lcdc_reg * const lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; @@ -663,7 +675,7 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode,
video_ctfb_mode_to_display_timing(mode, &timing); lcdc_tcon1_mode_set(lcdc, &timing, use_portd_hvsync, - sunxi_is_composite()); + sunxi_is_composite(monitor));
if (use_portd_hvsync) { sunxi_gpio_set_cfgpin(SUNXI_GPD(26), SUNXI_GPD_LCD0); @@ -671,7 +683,7 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, }
lcdc_pll_set(ccm, 1, mode->pixclock_khz, clk_div, clk_double, - sunxi_is_composite()); + sunxi_is_composite(monitor)); } #endif /* CONFIG_VIDEO_HDMI || defined CONFIG_VIDEO_VGA || CONFIG_VIDEO_COMPOSITE */
@@ -725,7 +737,8 @@ static void sunxi_hdmi_setup_info_frames(const struct ctfb_res_modes *mode) }
static void sunxi_hdmi_mode_set(const struct ctfb_res_modes *mode, - int clk_div, int clk_double) + int clk_div, int clk_double, + enum sunxi_monitor monitor) { struct sunxi_hdmi_reg * const hdmi = (struct sunxi_hdmi_reg *)SUNXI_HDMI_BASE; @@ -734,7 +747,7 @@ static void sunxi_hdmi_mode_set(const struct ctfb_res_modes *mode, /* Write clear interrupt status bits */ writel(SUNXI_HDMI_IRQ_STATUS_BITS, &hdmi->irq);
- if (sunxi_display.monitor == sunxi_monitor_hdmi) + if (monitor == sunxi_monitor_hdmi) sunxi_hdmi_setup_info_frames(mode);
/* Set input sync enable */ @@ -789,7 +802,7 @@ static void sunxi_hdmi_enable(void)
#if defined CONFIG_VIDEO_VGA || defined CONFIG_VIDEO_COMPOSITE
-static void sunxi_tvencoder_mode_set(void) +static void sunxi_tvencoder_mode_set(enum sunxi_monitor monitor) { struct sunxi_ccm_reg * const ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; @@ -801,7 +814,7 @@ static void sunxi_tvencoder_mode_set(void) /* Clock on */ setbits_le32(&ccm->ahb_gate1, 1 << AHB_GATE_OFFSET_TVE0);
- switch (sunxi_display.monitor) { + switch (monitor) { case sunxi_monitor_vga: tvencoder_mode_set(tve, tve_mode_vga); break; @@ -896,26 +909,28 @@ static void sunxi_engines_init(void) sunxi_drc_init(); }
-static void sunxi_mode_set(const struct ctfb_res_modes *mode, +static void sunxi_mode_set(struct sunxi_display_priv *sunxi_display, + const struct ctfb_res_modes *mode, unsigned int address) { + enum sunxi_monitor monitor = sunxi_display->monitor; int __maybe_unused clk_div, clk_double; struct sunxi_lcdc_reg * const lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; struct sunxi_tve_reg * __maybe_unused const tve = (struct sunxi_tve_reg *)SUNXI_TVE0_BASE;
- switch (sunxi_display.monitor) { + switch (sunxi_display->monitor) { case sunxi_monitor_none: break; case sunxi_monitor_dvi: case sunxi_monitor_hdmi: #ifdef CONFIG_VIDEO_HDMI - sunxi_composer_mode_set(mode, address); - sunxi_lcdc_tcon1_mode_set(mode, &clk_div, &clk_double, 0); - sunxi_hdmi_mode_set(mode, clk_div, clk_double); + sunxi_composer_mode_set(mode, address, monitor); + sunxi_lcdc_tcon1_mode_set(mode, &clk_div, &clk_double, 0, monitor); + sunxi_hdmi_mode_set(mode, clk_div, clk_double, monitor); sunxi_composer_enable(); - lcdc_enable(lcdc, sunxi_display.depth); + lcdc_enable(lcdc, sunxi_display->depth); sunxi_hdmi_enable(); #endif break; @@ -930,7 +945,7 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, axp_set_eldo(3, 1800); anx9804_init(CONFIG_VIDEO_LCD_I2C_BUS, 4, ANX9804_DATA_RATE_1620M, - sunxi_display.depth); + sunxi_display->depth); } if (IS_ENABLED(CONFIG_VIDEO_LCD_HITACHI_TX18D42VM)) { mdelay(50); /* Wait for lcd controller power on */ @@ -942,10 +957,10 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, i2c_reg_write(0x5c, 0x04, 0x42); /* Turn on the LCD */ i2c_set_bus_num(orig_i2c_bus); } - sunxi_composer_mode_set(mode, address); - sunxi_lcdc_tcon0_mode_set(mode, false); + sunxi_composer_mode_set(mode, address, monitor); + sunxi_lcdc_tcon0_mode_set(sunxi_display, mode, false); sunxi_composer_enable(); - lcdc_enable(lcdc, sunxi_display.depth); + lcdc_enable(lcdc, sunxi_display->depth); #ifdef CONFIG_VIDEO_LCD_SSD2828 sunxi_ssd2828_init(mode); #endif @@ -953,17 +968,17 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, break; case sunxi_monitor_vga: #ifdef CONFIG_VIDEO_VGA - sunxi_composer_mode_set(mode, address); - sunxi_lcdc_tcon1_mode_set(mode, &clk_div, &clk_double, 1); - sunxi_tvencoder_mode_set(); + sunxi_composer_mode_set(mode, address, monitor); + sunxi_lcdc_tcon1_mode_set(mode, &clk_div, &clk_double, 1, monitor); + sunxi_tvencoder_mode_set(monitor); sunxi_composer_enable(); - lcdc_enable(lcdc, sunxi_display.depth); + lcdc_enable(lcdc, sunxi_display->depth); tvencoder_enable(tve); #elif defined CONFIG_VIDEO_VGA_VIA_LCD - sunxi_composer_mode_set(mode, address); - sunxi_lcdc_tcon0_mode_set(mode, true); + sunxi_composer_mode_set(mode, address, monitor); + sunxi_lcdc_tcon0_mode_set(sunxi_display, mode, true); sunxi_composer_enable(); - lcdc_enable(lcdc, sunxi_display.depth); + lcdc_enable(lcdc, sunxi_display->depth); sunxi_vga_external_dac_enable(); #endif break; @@ -972,11 +987,11 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, case sunxi_monitor_composite_pal_m: case sunxi_monitor_composite_pal_nc: #ifdef CONFIG_VIDEO_COMPOSITE - sunxi_composer_mode_set(mode, address); - sunxi_lcdc_tcon1_mode_set(mode, &clk_div, &clk_double, 0); - sunxi_tvencoder_mode_set(); + sunxi_composer_mode_set(mode, address, monitor); + sunxi_lcdc_tcon1_mode_set(mode, &clk_div, &clk_double, 0, monitor); + sunxi_tvencoder_mode_set(monitor); sunxi_composer_enable(); - lcdc_enable(lcdc, sunxi_display.depth); + lcdc_enable(lcdc, sunxi_display->depth); tvencoder_enable(tve); #endif break; @@ -999,11 +1014,6 @@ static const char *sunxi_get_mon_desc(enum sunxi_monitor monitor) } }
-ulong board_get_usable_ram_top(ulong total_size) -{ - return gd->ram_top - CONFIG_SUNXI_MAX_FB_SIZE; -} - static bool sunxi_has_hdmi(void) { #ifdef CONFIG_VIDEO_HDMI @@ -1052,9 +1062,11 @@ static enum sunxi_monitor sunxi_get_default_mon(bool allow_hdmi) return sunxi_monitor_none; }
-void *video_hw_init(void) +static int sunxi_de_probe(struct udevice *dev) { - static GraphicDevice *graphic_device = &sunxi_display.graphic_device; + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + struct video_uc_plat *plat = dev_get_uclass_plat(dev); + struct sunxi_display_priv *sunxi_display = dev_get_priv(dev); const struct ctfb_res_modes *mode; struct ctfb_res_modes custom; const char *options; @@ -1067,10 +1079,8 @@ void *video_hw_init(void) char mon[16]; char *lcd_mode = CONFIG_VIDEO_LCD_MODE;
- memset(&sunxi_display, 0, sizeof(struct sunxi_display)); - video_get_ctfb_res_modes(RES_MODE_1024x768, 24, &mode, - &sunxi_display.depth, &options); + &sunxi_display->depth, &options); #ifdef CONFIG_VIDEO_HDMI hpd = video_get_option_int(options, "hpd", 1); hpd_delay = video_get_option_int(options, "hpd_delay", 500); @@ -1078,35 +1088,35 @@ void *video_hw_init(void) #endif overscan_x = video_get_option_int(options, "overscan_x", -1); overscan_y = video_get_option_int(options, "overscan_y", -1); - sunxi_display.monitor = sunxi_get_default_mon(true); + sunxi_display->monitor = sunxi_get_default_mon(true); video_get_option_string(options, "monitor", mon, sizeof(mon), - sunxi_get_mon_desc(sunxi_display.monitor)); + sunxi_get_mon_desc(sunxi_display->monitor)); for (i = 0; i <= SUNXI_MONITOR_LAST; i++) { if (strcmp(mon, sunxi_get_mon_desc(i)) == 0) { - sunxi_display.monitor = i; + sunxi_display->monitor = i; break; } } if (i > SUNXI_MONITOR_LAST) printf("Unknown monitor: '%s', falling back to '%s'\n", - mon, sunxi_get_mon_desc(sunxi_display.monitor)); + mon, sunxi_get_mon_desc(sunxi_display->monitor));
#ifdef CONFIG_VIDEO_HDMI /* If HDMI/DVI is selected do HPD & EDID, and handle fallback */ - if (sunxi_display.monitor == sunxi_monitor_dvi || - sunxi_display.monitor == sunxi_monitor_hdmi) { + if (sunxi_display->monitor == sunxi_monitor_dvi || + sunxi_display->monitor == sunxi_monitor_hdmi) { /* Always call hdp_detect, as it also enables clocks, etc. */ hdmi_present = (sunxi_hdmi_hpd_detect(hpd_delay) == 1); if (hdmi_present && edid) { printf("HDMI connected: "); - if (sunxi_hdmi_edid_get_mode(&custom, true) == 0) + if (sunxi_hdmi_edid_get_mode(sunxi_display, &custom, true) == 0) mode = &custom; else hdmi_present = false; } /* Fall back to EDID in case HPD failed */ if (edid && !hdmi_present) { - if (sunxi_hdmi_edid_get_mode(&custom, false) == 0) { + if (sunxi_hdmi_edid_get_mode(sunxi_display, &custom, false) == 0) { mode = &custom; hdmi_present = true; } @@ -1114,38 +1124,39 @@ void *video_hw_init(void) /* Shut down when display was not found */ if ((hpd || edid) && !hdmi_present) { sunxi_hdmi_shutdown(); - sunxi_display.monitor = sunxi_get_default_mon(false); + sunxi_display->monitor = sunxi_get_default_mon(false); } /* else continue with hdmi/dvi without a cable connected */ } #endif
- switch (sunxi_display.monitor) { + switch (sunxi_display->monitor) { case sunxi_monitor_none: - return NULL; + printf("Unknown monitor\n"); + return -EINVAL; case sunxi_monitor_dvi: case sunxi_monitor_hdmi: if (!sunxi_has_hdmi()) { printf("HDMI/DVI not supported on this board\n"); - sunxi_display.monitor = sunxi_monitor_none; - return NULL; + sunxi_display->monitor = sunxi_monitor_none; + return -EINVAL; } break; case sunxi_monitor_lcd: if (!sunxi_has_lcd()) { printf("LCD not supported on this board\n"); - sunxi_display.monitor = sunxi_monitor_none; - return NULL; + sunxi_display->monitor = sunxi_monitor_none; + return -EINVAL; } - sunxi_display.depth = video_get_params(&custom, lcd_mode); + sunxi_display->depth = video_get_params(&custom, lcd_mode); mode = &custom; break; case sunxi_monitor_vga: if (!sunxi_has_vga()) { printf("VGA not supported on this board\n"); - sunxi_display.monitor = sunxi_monitor_none; - return NULL; + sunxi_display->monitor = sunxi_monitor_none; + return -EINVAL; } - sunxi_display.depth = 18; + sunxi_display->depth = 18; break; case sunxi_monitor_composite_pal: case sunxi_monitor_composite_ntsc: @@ -1153,85 +1164,99 @@ void *video_hw_init(void) case sunxi_monitor_composite_pal_nc: if (!sunxi_has_composite()) { printf("Composite video not supported on this board\n"); - sunxi_display.monitor = sunxi_monitor_none; - return NULL; + sunxi_display->monitor = sunxi_monitor_none; + return -EINVAL; } - if (sunxi_display.monitor == sunxi_monitor_composite_pal || - sunxi_display.monitor == sunxi_monitor_composite_pal_nc) + if (sunxi_display->monitor == sunxi_monitor_composite_pal || + sunxi_display->monitor == sunxi_monitor_composite_pal_nc) mode = &composite_video_modes[0]; else mode = &composite_video_modes[1]; - sunxi_display.depth = 24; + sunxi_display->depth = 24; break; }
/* Yes these defaults are quite high, overscan on composite sucks... */ if (overscan_x == -1) - overscan_x = sunxi_is_composite() ? 32 : 0; + overscan_x = sunxi_is_composite(sunxi_display->monitor) ? 32 : 0; if (overscan_y == -1) - overscan_y = sunxi_is_composite() ? 20 : 0; + overscan_y = sunxi_is_composite(sunxi_display->monitor) ? 20 : 0;
- sunxi_display.fb_size = - (mode->xres * mode->yres * 4 + 0xfff) & ~0xfff; + sunxi_display->fb_size = plat->size; overscan_offset = (overscan_y * mode->xres + overscan_x) * 4; /* We want to keep the fb_base for simplefb page aligned, where as * the sunxi dma engines will happily accept an unaligned address. */ if (overscan_offset) - sunxi_display.fb_size += 0x1000; - - if (sunxi_display.fb_size > CONFIG_SUNXI_MAX_FB_SIZE) { - printf("Error need %dkB for fb, but only %dkB is reserved\n", - sunxi_display.fb_size >> 10, - CONFIG_SUNXI_MAX_FB_SIZE >> 10); - return NULL; - } + sunxi_display->fb_size += 0x1000;
printf("Setting up a %dx%d%s %s console (overscan %dx%d)\n", mode->xres, mode->yres, (mode->vmode == FB_VMODE_INTERLACED) ? "i" : "", - sunxi_get_mon_desc(sunxi_display.monitor), + sunxi_get_mon_desc(sunxi_display->monitor), overscan_x, overscan_y);
- gd->fb_base = gd->bd->bi_dram[0].start + - gd->bd->bi_dram[0].size - sunxi_display.fb_size; + sunxi_display->fb_addr = plat->base; sunxi_engines_init();
#ifdef CONFIG_EFI_LOADER - efi_add_memory_map(gd->fb_base, sunxi_display.fb_size, + efi_add_memory_map(sunxi_display->fb_addr, sunxi_display->fb_size, EFI_RESERVED_MEMORY_TYPE); #endif
- fb_dma_addr = gd->fb_base - CONFIG_SYS_SDRAM_BASE; - sunxi_display.fb_addr = gd->fb_base; + fb_dma_addr = sunxi_display->fb_addr - CONFIG_SYS_SDRAM_BASE; if (overscan_offset) { fb_dma_addr += 0x1000 - (overscan_offset & 0xfff); - sunxi_display.fb_addr += (overscan_offset + 0xfff) & ~0xfff; - memset((void *)gd->fb_base, 0, sunxi_display.fb_size); - flush_cache(gd->fb_base, sunxi_display.fb_size); + sunxi_display->fb_addr += ALIGN(overscan_offset, 0x1000); + memset((void *)sunxi_display->fb_addr, 0, sunxi_display->fb_size); + flush_cache(sunxi_display->fb_addr, sunxi_display->fb_size); } - sunxi_mode_set(mode, fb_dma_addr); + sunxi_mode_set(sunxi_display, mode, fb_dma_addr);
- /* - * These are the only members of this structure that are used. All the - * others are driver specific. The pitch is stored in plnSizeX. - */ - graphic_device->frameAdrs = sunxi_display.fb_addr; - graphic_device->gdfIndex = GDF_32BIT_X888RGB; - graphic_device->gdfBytesPP = 4; - graphic_device->winSizeX = mode->xres - 2 * overscan_x; - graphic_device->winSizeY = mode->yres - 2 * overscan_y; - graphic_device->plnSizeX = mode->xres * graphic_device->gdfBytesPP; - - return graphic_device; + /* The members of struct video_priv to be set by the driver. */ + uc_priv->bpix = VIDEO_BPP32; + uc_priv->xsize = mode->xres; + uc_priv->ysize = mode->yres; + + video_set_flush_dcache(dev, true); + + return 0; }
+static int sunxi_de_bind(struct udevice *dev) +{ + struct video_uc_plat *plat = dev_get_uclass_plat(dev); + + plat->size = LCD_MAX_WIDTH * LCD_MAX_HEIGHT * VNBYTES(LCD_MAX_LOG2_BPP); + + return 0; +} + +static const struct video_ops sunxi_de_ops = { +}; + +U_BOOT_DRIVER(sunxi_de) = { + .name = "sunxi_de", + .id = UCLASS_VIDEO, + .ops = &sunxi_de_ops, + .bind = sunxi_de_bind, + .probe = sunxi_de_probe, + .priv_auto = sizeof(struct sunxi_display_priv), + .flags = DM_FLAG_PRE_RELOC, +}; + +U_BOOT_DRVINFO(sunxi_de) = { + .name = "sunxi_de" +}; + /* * Simplefb support. */ #if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_VIDEO_DT_SIMPLEFB) int sunxi_simplefb_setup(void *blob) { - static GraphicDevice *graphic_device = &sunxi_display.graphic_device; + struct sunxi_display_priv *sunxi_display; + struct video_priv *uc_priv; + struct udevice *de; int offset, ret; u64 start, size; const char *pipeline = NULL; @@ -1242,7 +1267,19 @@ int sunxi_simplefb_setup(void *blob) #define PIPELINE_PREFIX #endif
- switch (sunxi_display.monitor) { + ret = uclass_find_device_by_name(UCLASS_VIDEO, "sunxi_de", &de); + if (ret) { + printf("DE not present\n"); + return 0; + } else if (!device_active(de)) { + printf("DE is present but not probed\n"); + return 0; + } + + uc_priv = dev_get_uclass_priv(de); + sunxi_display = dev_get_priv(de); + + switch (sunxi_display->monitor) { case sunxi_monitor_none: return 0; case sunxi_monitor_dvi: @@ -1280,16 +1317,17 @@ int sunxi_simplefb_setup(void *blob) * linux/arch/arm/mm/ioremap.c around line 301. */ start = gd->bd->bi_dram[0].start; - size = gd->bd->bi_dram[0].size - sunxi_display.fb_size; + size = sunxi_display->fb_addr - start; ret = fdt_fixup_memory_banks(blob, &start, &size, 1); if (ret) { eprintf("Cannot setup simplefb: Error reserving memory\n"); return ret; }
- ret = fdt_setup_simplefb_node(blob, offset, sunxi_display.fb_addr, - graphic_device->winSizeX, graphic_device->winSizeY, - graphic_device->plnSizeX, "x8r8g8b8"); + ret = fdt_setup_simplefb_node(blob, offset, sunxi_display->fb_addr, + uc_priv->xsize, uc_priv->ysize, + VNBYTES(uc_priv->bpix) * uc_priv->xsize, + "x8r8g8b8"); if (ret) eprintf("Cannot setup simplefb: Error setting properties\n");
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index ded5aea551d..e08cc2080ba 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -223,23 +223,6 @@ extern int soft_i2c_gpio_scl; #define CONFIG_VIDEO_LCD_I2C_BUS -1 /* NA, but necessary to compile */ #endif
-#ifdef CONFIG_VIDEO_SUNXI -/* - * The amount of RAM to keep free at the top of RAM when relocating u-boot, - * to use as framebuffer. This must be a multiple of 4096. - */ -#define CONFIG_SUNXI_MAX_FB_SIZE (16 << 20) - -#define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_STD_TIMINGS -#define CONFIG_I2C_EDID -#define VIDEO_LINE_LEN (pGD->plnSizeX) - -/* allow both serial and cfb console. */ -/* stop x86 thinking in cfbconsole from trying to init a pc keyboard */ - -#endif /* CONFIG_VIDEO_SUNXI */ - /* Ethernet support */
#ifdef CONFIG_USB_EHCI_HCD @@ -401,11 +384,7 @@ extern int soft_i2c_gpio_scl; "stdin=serial\0" #endif
-#ifdef CONFIG_VIDEO -#define CONSOLE_STDOUT_SETTINGS \ - "stdout=serial,vga\0" \ - "stderr=serial,vga\0" -#elif CONFIG_DM_VIDEO +#ifdef CONFIG_DM_VIDEO #define CONSOLE_STDOUT_SETTINGS \ "stdout=serial,vidconsole\0" \ "stderr=serial,vidconsole\0" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index cd59acdab86..471fbb732a3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1636,7 +1636,6 @@ CONFIG_STV0991 CONFIG_STV0991_HZ CONFIG_STV0991_HZ_CLOCK CONFIG_ST_SMI -CONFIG_SUNXI_MAX_FB_SIZE CONFIG_SXNI855T CONFIG_SYSFLAGS_ADDR CONFIG_SYSFS
Andre Przywara
