[U-Boot] [PATCH 0/3] Support driving rv1108 evb board to bootrom download mode by adc key
RV1108 evb also has a adc based recovery key, but connect to adc channel 0, this is differnt from most other rockchip based boards. To cover adc based key from differnt adc channel, this patch will parse the adc channel from dts.
Andy Yan (3): rockchip: boot mode: parse adc channel from dts rockchip: rv1108: add adc key dt node for evb_rv1108 rockchip: rv1108: call setup_boot_mode
arch/arm/dts/rv1108-evb.dts | 21 +++++++++++++++++++++ arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-rockchip/boot_mode.c | 15 ++++++++++++++- arch/arm/mach-rockchip/rv1108/rv1108.c | 6 ++++++ 4 files changed, 42 insertions(+), 1 deletion(-)
Most the current rockchip based boards use adc channel 1 detect the download key, but there are also some boards like rv1108 based plaform use adc channel 0. So we parse the adc channel from dts if we can get it, otherwise we use the channel 1 as default.
Signed-off-by: Andy Yan andy.yan@rock-chips.com
arch/arm/mach-rockchip/boot_mode.c | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/boot_mode.c b/arch/arm/mach-rockchip/boot_mode.c index 942849f..49dfd39 100644 --- a/arch/arm/mach-rockchip/boot_mode.c +++ b/arch/arm/mach-rockchip/boot_mode.c @@ -8,6 +8,9 @@ #include <adc.h> #include <asm/io.h> #include <asm/arch/boot_mode.h> +#include <fdtdec.h> + +DECLARE_GLOBAL_DATA_PTR;
void set_back_to_bootrom_dnl_flag(void) { @@ -26,9 +29,19 @@ void set_back_to_bootrom_dnl_flag(void)
__weak int rockchip_dnl_key_pressed(void) { + const void *blob = gd->fdt_blob; unsigned int val; + int channel = 1; + int node; + u32 chns[2]; + + node = fdt_node_offset_by_compatible(blob, 0, "adc-keys"); + if (node >= 0) { + if (!fdtdec_get_int_array(blob, node, "io-channels", chns, 2)) + channel = chns[1]; + }
- if (adc_channel_single_shot("saradc", 1, &val)) { + if (adc_channel_single_shot("saradc", channel, &val)) { pr_err("%s: adc_channel_single_shot fail!\n", __func__); return false; }
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
+sjg
Signed-off-by: Andy Yan andy.yan@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
- const void *blob = gd->fdt_blob; unsigned int val;
- int channel = 1;
- int node;
- u32 chns[2];
- node = fdt_node_offset_by_compatible(blob, 0, "adc-keys");
- if (node >= 0) {
channel = chns[1];
The driver for 'adc-keys' should be a driver in drivers/input that can then be retrieved via DM and queried using keyboard_getc().
- if (adc_channel_single_shot("saradc", channel, &val)) { pr_err("%s: adc_channel_single_shot fail!\n", __func__); return false; }
Hi Philipp:
On 2017年11月28日 21:59, Philipp Tomsich wrote:
+sjg
Yes, if there is an exiting adc-keys driver, we will use it here with no doubts, but there is not now. I just need to check the button down event once, no up or other things needed, so I call the adc api directly. I grep all the u-boot project, and found all other boards handle this kind of button status check by call device specific api directly, rather than use the api from input subsystem. So I think this is a acceptable way. Would you please consider taking this patch if there is no other problems. And when there is a adc-keys driver in the future, I can move it to input based api, or I will write a adc-keys driver when my workloads is not so heavy as now.
On 29 Nov 2017, at 07:34, Andy Yan andy.yan@rock-chips.com wrote:
Hi Philipp:
+sjg
- int channel = 1;
- int node;
- u32 chns[2];
- if (node >= 0) {
channel = chns[1];
Which other boards did you find that used the “adc-keys” node this way? My grep shows only a few sunxi DTS referring to it: ptomsich@android:~/u-boot-rockchip$ git status On branch master Your branch is up-to-date with 'origin/master'. ptomsich@android:~/u-boot-rockchip$ git grep adc-keys arch/arm/dts/sun4i-a10.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun5i-gr8.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun5i.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun6i-a31.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun7i-a20.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun8i-a23-a33.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys";
The problem is that if we go ahead with this as-is, there never be a driver for the "adc-keys” created ... Let’s see what for Simon’s input is, before we make a final decision.
Simon,
could you comment on this one from a general U-Boot architecture and DM-maintainer perspective?
Thanks, Philipp.
On 29 Nov 2017, at 10:50, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
On 29 Nov 2017, at 07:34, Andy Yan <andy.yan@rock-chips.com mailto:andy.yan@rock-chips.com> wrote:
Hi Philipp:
+sjg
Signed-off-by: Andy Yan <andy.yan@rock-chips.com mailto:andy.yan@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com>
- int channel = 1;
- int node;
- u32 chns[2];
- if (node >= 0) {
channel = chns[1];
[Getting Simon's email-address right, helps…]
Simon,
Thanks, Philipp.
On 29 Nov 2017, at 10:50, Dr. Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com> wrote:
On 29 Nov 2017, at 07:34, Andy Yan <andy.yan@rock-chips.com mailto:andy.yan@rock-chips.com <mailto:andy.yan@rock-chips.com mailto:andy.yan@rock-chips.com>> wrote:
Hi Philipp:
+sjg
Signed-off-by: Andy Yan <andy.yan@rock-chips.com mailto:andy.yan@rock-chips.com <mailto:andy.yan@rock-chips.com mailto:andy.yan@rock-chips.com>> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com <mailto:philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com>>
- int channel = 1;
- int node;
- u32 chns[2];
- if (node >= 0) {
channel = chns[1];
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de mailto:U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot https://lists.denx.de/listinfo/u-boot
Hi PHilipp:
Simon,
Thanks, Philipp.
On 29 Nov 2017, at 07:34, Andy Yan <andy.yan@rock-chips.com mailto:andy.yan@rock-chips.commailto:andy.yan@rock-chips.com> wrote:
Hi Philipp:
+sjg
Signed-off-by: Andy Yan <andy.yan@rock-chips.com mailto:andy.yan@rock-chips.commailto:andy.yan@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com
mailto:philipp.tomsich@theobroma-systems.commailto:philipp.tomsich@theobroma-systems.com>
unsigned int val;
- int channel = 1;
- int node;
- u32 chns[2];
- if (node >= 0) {
- if (!fdtdec_get_int_array(blob, node, "io-channels",
chns, 2))
- channel = chns[1];
I not only mean adc-keys, actually many boards want to detect key status: board/samsung/common/misc.c, detected by pmic board/qualcomm/dragonboard410c/dragonboard410c.c, detected by gpio board/boundary/nitrogen6x/nitrogen6x.c, detected by gpio board/nokia/rx51/rx51.c, detected by a chip named twl4030 board/timll/devkit8000/devkit8000.c, detected by gpio
board/timll/devkit8000/devkit8000.c ptomsich@android:~/u-boot-rockchip$ git status On branch master Your branch is up-to-date with 'origin/master'. ptomsich@android:~/u-boot-rockchip$ git grep adc-keys arch/arm/dts/sun4i-a10.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun5i-gr8.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun5i.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun6i-a31.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun7i-a20.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys"; arch/arm/dts/sun8i-a23-a33.dtsi: compatible = "allwinner,sun4i-a10-lradc-keys";
Hi Philipp,
On 29 November 2017 at 02:53, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Simon,
Thanks, Philipp.
Hi Philipp:
+sjg
- int channel = 1;
- int node;
- u32 chns[2];
- if (node >= 0) {
channel = chns[1];
I agree that we should do this with a generic driver if that is what Linux does. We should try to avoid creating migration work for the next person.
It does not seem that hard to do?
RV1108 EVB uses a adc-based recovery(VOL+) key, which connected to saradc channel 0. This patch add dt node for it.
Signed-off-by: Andy Yan andy.yan@rock-chips.com ---
arch/arm/dts/rv1108-evb.dts | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/dts/rv1108-evb.dts b/arch/arm/dts/rv1108-evb.dts index 8e857b2..66da40c 100644 --- a/arch/arm/dts/rv1108-evb.dts +++ b/arch/arm/dts/rv1108-evb.dts @@ -7,11 +7,32 @@ /dts-v1/;
#include "rv1108.dtsi" +#include <dt-bindings/input/input.h>
/ { model = "Rockchip RV1108 Evaluation board"; compatible = "rockchip,rv1108-evb", "rockchip,rv1108";
+ adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 0>; + io-channel-names = "buttons"; + poll-interval = <100>; + keyup-threshold-microvolt = <3300000>; + + button-up { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + press-threshold-microvolt = <0>; + }; + + button-down { + label = "Volume Down"; + linux,code = <KEY_VOLUMEDOWN>; + press-threshold-microvolt = <1650000>; + }; + }; + memory@60000000 { device_type = "memory"; reg = <0x60000000 0x08000000>;
+sjg
See below for comments.
- adc-keys {
The DTS-binding should be documented in the documentation directory.
"adc-keys" seems to be a standard binding in Linux and used by the input subsystem: so this sounds like it should be a driver in drivers/input for U-Boot that uses an ADC driver.
button-up {
button-down {
- memory@60000000 { device_type = "memory"; reg = <0x60000000 0x08000000>;
Call setup_boot_mode to check current boot mode.
arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-rockchip/rv1108/rv1108.c | 6 ++++++ 2 files changed, 7 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index a26736a..b555d60 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -130,6 +130,7 @@ config ROCKCHIP_RK3399 config ROCKCHIP_RV1108 bool "Support Rockchip RV1108" select CPU_V7 + select BOARD_LATE_INIT help The Rockchip RV1108 is a ARM-based SoC with a single-core Cortex-A7 and a DSP. diff --git a/arch/arm/mach-rockchip/rv1108/rv1108.c b/arch/arm/mach-rockchip/rv1108/rv1108.c index 868cdd5..e21e505 100644 --- a/arch/arm/mach-rockchip/rv1108/rv1108.c +++ b/arch/arm/mach-rockchip/rv1108/rv1108.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/arch/boot_mode.h>
#ifndef CONFIG_SYS_DCACHE_OFF void enable_caches(void) @@ -13,3 +14,8 @@ void enable_caches(void) dcache_enable(); } #endif + +int board_late_init(void) +{ + return setup_boot_mode(); +}
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Andy Yan
Dr. Philipp Tomsich
Philipp Tomsich
